Posted (edited)
Hi
I'm trying to use Armbian with Orange pi 5 Ultra.
So far so good :) The hdmirx is working great!
I'm not able to control my gpio pins with PWM in equivalent to orange pi 5 ultra image. I guess that i need to load additional overlays, Am I correct?
Please review the armbian logs here:
https://paste.next.armbian.com/nekodihico
I also noticed that pin numbers were changed if I compare it to the Orange pi OS.
Thanks in advance!
Edited by Erez Alster
So you are using a device tree for a different device and complain that things don't work as expected?
Well on the bright sight both max and ultra are very similar.
Though overlays might differ but that would need investigation. Easiest route is the one you actually already got on by checking the vendor source. Maybe they also provide a handful of matching overlays for this board. Maybe they can be ported.
Hello Erez Alster, im on the same page, but the issue is that im trying to get PWM to work using ubuntu that is from the orangepi wbesite, did you get it working? if yes, can you share with me how you got the pwm to work? for me, it blinks and its very choppy! thanks in advance.
  • Solution
I was able to make things work. i had bad configuration :)
So everything is working correctly.
I've another issue. I've the following errors in dmesg
Quote
[ 2920.617507] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 2920.650043] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 2920.736016] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:24!
[ 2921.332591] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1920x1080p30.00 (2200x1125)
[ 2924.616773] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 2924.670940] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 2924.701372] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:23!
[ 2925.298296] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1920x1080p29.99 (2200x1125)
[ 2927.883494] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 2927.955102] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:23!
[ 2928.566048] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1920x1080p25.05 (2200x1125)
[ 2928.727603] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 2929.716865] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 2929.737624] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 2929.795089] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:23!
[ 2930.399397] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1920x1080p29.99 (2200x1125)
[ 2932.150233] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 2932.224940] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:23!
[ 2932.777658] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 2932.876647] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1920x1080p30.00 (2200x1125)
[ 2935.350287] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2
[ 2935.421794] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:23!
[ 2935.817696] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio
[ 2936.032717] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1920x1080p29.99 (2200x1125)
Something I'm able to use the HDMI input and sometimes i'm not. Any idea what can be the issue?
Posted (edited)
On 3/4/2025 at 11:05 AM, Erez Alster said:
I copied the dtb from orange pi 5 ultra official image and copied it.
Hey, how did you do this? I would like to do the same.
Did you replace the 'Max' dtb file content or placed the new file and referenced it from elsewhere (like /boot/armbianEnv.txt)?
Edited by Sirmalinton
typo
