teknoid Posted March 6 Posted March 6 my C2 did not boot after upgrading from 6.6.63-current-meson64 to 6.12.17. I also tested kernel 6.12.13 from debian minimal image, same problem: Applying kernel provided DT fixup script (meson-fixup.scr) ## Executing script at 32000000 ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 17076402 Bytes = 16.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 04080000 Booting using the fdt blob at 0x4080000 Loading Ramdisk to 7af01000, end 7bf4a0b2 ... OK Loading Device Tree to 000000007ae8e000, end 000000007af00fff ... OK "Synchronous Abort" handler, esr 0x96000004 elr: 000000000105d0b8 lr : 000000000104cdd0 (reloc) elr: 000000007dfb90b8 lr : 000000007dfa8dd0 x0 : fbbfe1e3d45df41f x1 : 000000007dfc0438 x2 : 0000000000000010 x3 : 000000007bfa3830 x4 : 0000000000000000 x5 : fbbfe1e3d45df41f x6 : 0000000001000000 x7 : 0000000000000000 x8 : 0000000000000007 x9 : 0000000000000000 x10: 00000000000001dc x11: 000000007bf4e34c x12: 00000000000000b0 x13: 000000007bf4e308 x14: 000000007ae8e000 x15: 0000000000000020 x16: 000000007df8f8a8 x17: 0000000000000000 x18: 000000007bf59dd0 x19: 000000007af4f040 x20: 000000007df5cb18 x21: 000000007dfc0438 x22: 0000000000001000 x23: 000000007bf613d0 x24: 000000007dfdd638 x25: 0000000001000000 x26: 0000000000000000 x27: 0000000001000000 x28: 0000000000001000 x29: 000000007bf4e300 Code: eb04005f 54000061 52800000 14000006 (386468a3) Resetting CPU ... I have no idea. Can someone verify? So for the moment I do not recommend updating to latest 6.12 kernel on Odroid C2. 0 Quote
Igor Posted March 6 Posted March 6 18 minutes ago, teknoid said: I have no idea. Can someone verify? C2 was tested booting from a fresh image. Probably u-boot updating is mandatory prior to upgrade. 0 Quote
teknoid Posted March 6 Author Posted March 6 I upgraded all in one step, uboot, dtb, ... Then switched back the kernel to 24.11.1 and it was working again root@odroid25:~# dpkg -l |grep 25.2.2 ii armbian-bsp-cli-odroidc2-current 25.2.2 arm64 Armbian CLI BSP for board 'odroidc2' branch 'current' ii base-files 25.2.2-12.4+deb12u9-bookworm arm64 Armbian base system miscellaneous files ii linux-dtb-current-meson64 25.2.2 arm64 Armbian Linux current DTBs in /boot/dtb-6.12.17-current-meson64 ii linux-u-boot-odroidc2-current 25.2.2 arm64 Das U-Boot for odroidc2 root@odroid25:~# dpkg -l |grep 24.11.1 ii linux-image-current-meson64 24.11.1 arm64 Armbian Linux current kernel image 6.6.63-current-meson64 I'll do further investigations... 0 Quote
teknoid Posted March 6 Author Posted March 6 hmm, strange. After manually recreating the boot script it worked: mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr I did not take care of the output during upgrade, probably I missed a "No space left on device" or similar... Anayway, solved... 0 Quote
teknoid Posted March 6 Author Posted March 6 Now I've got it: It does not boot from emmc module if a sdcard is present! 0 Quote
Pavel Löbl Posted 18 hours ago Posted 18 hours ago (edited) I have exactly the same issue. Cannot boot after upgrade, also newly flashed image won't boot with exactly the same trace. I compiled latest upstream U-Boot v2025.04 as described here (Pre-Built FIP variant). https://docs.u-boot.org/en/latest/board/amlogic/odroid-c2.html Then I patched Armbian image with latest U-Boot. dd if=u-boot.bin.sd.bin of=Armbian_25.2.1_Odroidc2_bookworm_current_6.12.13_minimal.img conv=notrunc bs=512 skip=1 seek=1 And that works for me, system boots just fine Edited 18 hours ago by Pavel Löbl 0 Quote
