konsD Posted Tuesday at 05:39 PM Posted Tuesday at 05:39 PM (edited) Hello. I am a new user of the armbian. I installed nextcloud from armbian-config. Need docker to have access to the file system. I want to place the nextcloud files in the home directory, which is mounted on another partition. I don't understand how to give docker access to my file system. I didn't find the necessary setting in armbian-config. I'm stuck on initial setup Edited Tuesday at 05:41 PM by konsD 0 Quote
Igor Posted 14 hours ago Posted 14 hours ago 21 hours ago, konsD said: I want to place the nextcloud files in the home directory, which is mounted on another partition By default we mount all containers (data and config) folders under /armbian which has rights of 1st normal user of the OS - most expected use case scenario. If you want more complex deployment, you need to create your own Docker run / compose and mount containers folder elsewhere or try to bind mount what you need - on the OS level. Armbian-config is designed for inexperienced Linux users that would likely use default setup scenario. We purpusefully don't allow too many config options which would be confusing or / and would require additional learning in the process of installation. If you want to do it more on your own, please check this article https://docs.linuxserver.io/images/docker-nextcloud/ This is the fundation behind armbian-config way. 0 Quote
konsD Posted 14 hours ago Author Posted 14 hours ago It may be possible to change the mount parameters of an already installed docker container. Is it possible to add mount options? 0 Quote
Werner Posted 13 hours ago Posted 13 hours ago Not via armbian-config. This is just a very simply way to do an initial setup. Here is the code that basically happens behind the scenes: https://github.com/armbian/configng/blob/main/tools/modules/software/module_nextcloud.sh So nothing fancy. just a docker run command. I personally prefer using docker-compose.yml instead of endless docker commands. Stuff is well-arranged and after adjusting like mounts down, up and ready to go. As mentioned above for customized installation please refer to the origin of the nextcloud container linuxserver.io. I am pretty sure they have examples for docker compose as well. 0 Quote
konsD Posted 9 hours ago Author Posted 9 hours ago 3 часа назад, Werner сказал: Not via armbian-config I understand that. It can probably be done with /lib/systemd/system/docker.service? I used to install the nextcloud manually, but it was very tedious. I don't know docker at all, so I have difficulties with it Where can I see the error logs? 0 Quote
Michael Robinson Posted 4 hours ago Posted 4 hours ago You could load up portainer and edit the container config. https://docs.portainer.io/start/install-ce/server/docker/linux This will give you a web based gui to deploy or configure your docker containers. 0 Quote
