When the ODROID-M1 is setup to boot from SPI with the system installed on a M2 ssd, power loss seems to lead to an unbootable system.
Once an SD card with armbian is inserted and the system is booted through the recovery button once, logged in* and then shutdown normally, the system boots again from SPI.
* Without login and regular shutdown of the system booted from sd card, the issue remains
I have observed and reproduced this issue several times in the last year.
In my case the M1 is connected to a power strip that turns on and off the multiple devices.
When I forget to unplug the M1 and it gets turned on and off several times over a day or more, the issue appears.
When I turn it of manually I could not yet observe the issue, so it may be related to being booted and turned off multiple times in short order.
When I investigate the journal of the last boot circles, there is nothing there, as if the boot process never started, leaving me to suspect an issue with the bootloader in combination with SPI and power loss.
8 hours ago, ceri said:
unbootable
This error description leads nowhere. Hook up a debug serial console to get an idea what happens inside while the system does not boot. Share the logs here. Also verify powering and wiring.
https://debug.armbian.de
Posted (edited)
I was hoping that the description would make it easy to reproduce to find the issue.
If that's not the case I can try to find the required cable somewhere nearby to give it a try myself.
Update: Any recommendations where to get a UART adapter in germany when amazon is to be avoided? :)
Even conrad does not have any listed that I can find
Edited by ceri
Posted (edited)
Finally got around to debug this:
Previously I had the system on an nvme drive and the bootloader on spi
After reinstalling the system and bootloader both on mmc flash, I eventually ran into the very same issue.
According to the logs, the boot bails with the following error:
Log1:
Quote
Scanning for bootflows in all bootdevs
Seq  Method       State   Uclass    Part  Name                      Filename
Scanning global bootmeth 'efi_mgr':
7[r[999;999H[6n8Card did not respond to voltage select! : -110
Cannot persist EFI variables without system partition
  0  efi_mgr      ready   (none)       0  <NULL>
** Booting bootflow '<NULL>' with efi_mgr
Loading Boot0000 'mmc 0' failed
EFI boot manager: Cannot load any image
Boot failed (err=-14)
Scanning bootdev 'mmc@fe2b0000.bootdev':
 ** fs_devread read error - block
Scanning bootdev 'nvme#0.blk#1.bootdev':
\00\00
When I remove the nvme drive, the boot process works just fine for some reason:
(boot log after nvme removal)
Log2:
Quote
pcie_dw_rockchip pcie@fe280000: PCIe-0 Link Fail
scanning bus for devices...
SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
flags: ncq stag pm led clo only pmp fbss pio slum part ccc apst
Bus usb@fd000000: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus usb@fd800000: USB EHCI 1.00
Bus usb@fd840000: USB OHCI 1.0
Bus usb@fd880000: USB EHCI 1.00
Bus usb@fd8c0000: USB OHCI 1.0
scanning bus usb@fd000000 for devices... 1 USB Device(s) found
scanning bus usb@fd800000 for devices... 1 USB Device(s) found
scanning bus usb@fd840000 for devices... 2 USB Device(s) found
scanning bus usb@fd880000 for devices... 1 USB Device(s) found
scanning bus usb@fd8c0000 for devices... 2 USB Device(s) found
Scanning bootdev 'mmc@fe310000.bootdev':
  1  script       ready   mmc          1  mmc@fe310000.bootdev.part /boot/boot.scr
** Booting bootflow 'mmc@fe310000.bootdev.part_1' with script
Boot script loaded from mmc 0:1
246 bytes read in 11 ms (21.5 KiB/s)
16644645 bytes read in 110 ms (144.3 MiB/s)
37874176 bytes read in 230 ms (157 MiB/s)
121646 bytes read in 35 ms (3.3 MiB/s)
Working FDT set to 12000000
Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards.
Unknown command 'kaslrseed' - try 'help'
## Loading init Ramdisk from Legacy Image at 12180000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    16644581 Bytes = 15.9 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 12000000
   Booting using the fdt blob at 0x12000000
   Loading Ramdisk to ebe9a000, end ece799e5 ... OK
   Loading Device Tree to 00000000ebe13000, end 00000000ebe99fff ... OK
Working FDT set to ebe13000
Starting kernel ...
When I reinstall the nvme, the boot fails again. However, booting from sd-card (using recovery button) and reflashing the bootloader to the mmc fixes the issue as well with the same result as removing the nvme drive had, resulting in the same log2 as above.
I had fixed the issue before by reflashing the bootloader to spi but just like yesterday, it eventually stopped booting again until I reflashed the boot loader.
There isn't anything particular happening before this occurs, though the last few times it was always after the system had run for some time. After cutting power (without shutdown) and booting it again, the issue would appear. (The device is always cut from power instead of shutting it down, but there was never an error on any drive due to that).
The issue also did not show when the device  was just turned of (without power) for a day or two. It seems to trigger quite randomly.
I already tried to erase the spi flash to avoid any old entries messing up the boot order but without effect.
Any clue what I could try next?
Edited by ceri
Ok this happened again and I'm out of ideas.
@Werner Could you tell me the dependencies for the boot process on this board and how I could read out the values like the boot loader to verify they are still the same?
There should be nothing wrong with cutting power right? I have had raspberry pi's be cut from power daily for years without issues and I assume it would work the same for the odroid boards?!
I don't know particular about this board so I can only give generic clues and hints how to help us helping you.
What kind of dependencies you mean? There is uboot only. For variables and boot script check the contents of /boot
Power loss is not an issue. Most that can happen is corrupted rootfs.
The issue happened again, and each time it occurred so far, it was after some heavy write activity over several hours which resulted in the cooler becoming noticeably warm (but could still be touched without burning the hand). Could heat be related to this? Its strange that it would only affect the bootloader though. Any ideas what heavy load could have to to with this otherwise?
And again, this time after writing 600 GB over 12 hours, then waiting a full hour before cutting power. Bootloader gone
Only even happened after writing on the nvme disk for at least 30 minutes
And for some reason the issue disappears when you boot from sd card one and shutdown cleanly. The system starts booting again afterwards even though nothing was manually changed.
What does the shutdown process to that could fix this?
It leaves the device with an intact file system.
The corrupted file system structure has likely been restored by rolling back the journal during the automatic file system check of the unmounted file system at system startup. But the data loss is permanent.
There is a reason why UPS systems exist.
@usual user But the filesystem was never currupt and the issue was only with the boot partition which is not a journaling filesystem.
The Odruids is also known to work reliably without UPS.
I confirm this issue.
For the purposes of this experiment, I replaced the power supply with a similar one equipped with an LED. The power supply is connected to an electrostatic precipitator equipped with a power button.
We turn on the electrostatic precipitator using the button. The power supply LED lights up. The Odroid M1 turns on and boots normally.
We shut down the Odroid M1. We turn off the electrostatic precipitator using the button. After 2 seconds, we turn it back on.
The Odroid M1 does NOT turn on again. Therefore, replacing the power supply did NOT solve the problem.
Experimentally, we have determined that the Odroid M1 does NOT turn on again as long as the power supply LED remains lit, even when the electrostatic precipitator is turned off. Therefore, the issue lies with the residual charge in the power supply capacitors.
If, with the electrostatic precipitator turned off, we wait until the power supply capacitors are depleted and the power supply LED goes out, then when we turn on the electrostatic precipitator again, the Odroid M1 turns on normally and boots normally.
Meanwhile, the Raspberry Pi doesn't have this power supply issue.
Therefore, this is a design flaw in the Odroid M1.
