xalu Posted September 21, 2017 Posted September 21, 2017 (edited) Hello, Just received this board and I can't get it to turn on if the SD card is present. I've tried several cards and I know them to be good (Samsung Evo 32GB). Any ideas? Edited September 21, 2017 by chwe Moved to h5
chwe Posted September 21, 2017 Posted September 21, 2017 13 minutes ago, xalu said: I know them to be good (Samsung Evo 32GB). Know means you've tested it wit F3 or H2testw and they didn't show any errors. I throw my ring in the hat and say: Powersource.
xalu Posted September 21, 2017 Author Posted September 21, 2017 6 hours ago, chwe said: Know means you've tested it wit F3 or H2testw and they didn't show any errors. I throw my ring in the hat and say: Powersource. Hi, thanks for the reply. After your post I downloaded H2testw and there were no issues. It's from amazon so it is a legitimate card. Cards good for sure thanks to the test. For power Ive tried my PSU from my Pi3, its rated at 2 amps. I've also tried my powered 3.0 usb hub rated at 2.4amps.
chwe Posted September 21, 2017 Posted September 21, 2017 33 minutes ago, xalu said: It's from amazon so it is a legitimate card. Just wait until @tkaiser sees this conclusion. Nothing against amazon, I also buy stuff from there (also SD-Cards), but they could also get counterfeit/fake sd-cards in their supply chain. But, you checked it and we assume it should be ok. 33 minutes ago, xalu said: For power Ive tried my PSU from my Pi3, its rated at 2 amps The one from the RPi store? Which image do you use? Can we assume you followed the getting started guide (e.g. burning Image with etcher)? Do you have an USB-ttl?
xalu Posted September 21, 2017 Author Posted September 21, 2017 56 minutes ago, chwe said: The one from the RPi store? My power supply is also from amazon But again it works fine under load from the Pi and the opi zero plus 2 h3 (these names are annoying to type out). But I may be able to source a different psu if you really think that's it. No power with SD but power without : Is that a common issue for weak/bad PSU? 56 minutes ago, chwe said: Which image do you use? Can we assume you followed the getting started guide (e.g. burning Image with etcher)? Yes, followed the guide up to burning with etcher and putting it in the opi. But no power so not much I can do. 57 minutes ago, chwe said: Do you have an USB-ttl? Well I just went rummaging around for one I had but I can't find it. I do have ample supply of arduino boards so I can use one of them. I think I have a OTG splitter cable that might work for powering and data. I thought my hub would be ok for OTG power & data..at least to set up. But that doesn't look likely now/
xalu Posted September 21, 2017 Author Posted September 21, 2017 Oh and the image I used was the one on the page for this board:https://www.armbian.com/orange-pi-zero-2-h5/
chwe Posted September 22, 2017 Posted September 22, 2017 3 hours ago, xalu said: My power supply is also from amazon But again it works fine under load from the Pi and the opi zero plus 2 h3 (these names are annoying to type out). But I may be able to source a different psu if you really think that's it. I'm not an expert, but I think, when it runs stable with your OPi0+h3 (yeah, it is an annoying naming from xunlong ), it should also run with the h5. The RPi has some 'protection' against low voltage whereas the opi doesn't have such a protection. So, at the moment I don't think that it is a powersource or SD-card issue (a personal opinion). 3 hours ago, xalu said: Well I just went rummaging around for one I had but I can't find it. I do have ample supply of arduino boards so I can use one of them A usb-ttl would make debug easier. It should be possible to use a 3.3V arduino as serial debugger. I'm not sure if RX/TX is capable for 5V logic level (maybe not the best idea to figure it out yet.. ). You'll see if something boots and where it hangs. H5 images are experimental, but to my knowledge it should boot up (to be honest, I don't have a opi0+2 to test it). Edit: an other bonus for usb-ttl: you don't' need any peripherals connected to your pi during boot (so, if psu is an issue with all your peripherals connected to the board, this should help decreasing power consumption of the board).
xalu Posted September 22, 2017 Author Posted September 22, 2017 1 hour ago, chwe said: A usb-ttl would make debug easier. It should be possible to use a 3.3V arduino as serial debugger. I'm not sure if RX/TX is capable for 5V logic level (maybe not the best idea to figure it out yet.. ). You'll see if something boots and where it hangs. The arduino wouldn't handle 5v from the Pi you mean? If that's the case I have a 5v clone I might be able to use. Save me 10 bucks. EDIT: I'll use my multimeter to be safe and find out voltage for both. I'll give it a try. Thanks for the help.
chwe Posted September 22, 2017 Posted September 22, 2017 NO! OPi is @3.3V, most arduinos (or clones) are at 5V logic level.
xalu Posted September 22, 2017 Author Posted September 22, 2017 5 minutes ago, chwe said: NO! OPi is @3.3V, most arduinos (or clones) are at 5V logic level. Haha Okay.. No blue smoke didnt get that far. I guess I'll have to figure it out, or buy one. Thanks again!
chwe Posted September 22, 2017 Posted September 22, 2017 You got them for 1-2$ from your *random chinese supplier*. Keep in mind, most FDTI driven ones are fake (just google fake fdti). I have one, running without issues (but known, it is fake), one makes me crazy everytime. I prefer the CH340G ones, this chip is too cheap to fake it. Easiest is a usb-ttl whereas you can decide between 5V and 3.3V, so you can use it for programming your arduinos too.
xalu Posted September 22, 2017 Author Posted September 22, 2017 I spent a good 45 minutes looking everywhere for what I thought might be a USB to TTL. Finally gave up and came back to do some work. I looked in the drawer at my desk and I found what I was looking for and I saw my arduino pro-mini with its programmer attached. That's when it clicked.. THIS was a usb to serial. (DOH) 5V's though... Flipped it over and its both! I found what I was looking for but its PIC programmer. Not sure if it would work for this. I'll report back if I get some answers when I get the board connected to serial This is something I've never heard before but it's probably just me...I've been talking to support at aliexpress they said: Quote Zero Plus2 H5 have EMMC, we pre-installed the Android image on EMMC, so you can boot the board without the SD card. I had no idea. Not sure how to connect the wifi I dont have a usb
xalu Posted September 22, 2017 Author Posted September 22, 2017 Alright, So UART got me to the terminal (Thanks for pushing me to it!)and I got some really good help from the aliexpress team by being on the nightshift for work. With TTL: First I tried no SD card which just gave me a bunch of unusable stuff. Next I tried with a burnt SD card (this was a flavor from there site since the armbian didnt work before). Nothing, no output on terminal. No power LED After that I figured why not try an SD card thats just been formatted (Empyt). That way I could see if it would at least turn on if an SD card was in there, and also narrow it down. Sure enough it loaded and I got U-Boot: Quote 127|root@cheetah-p1:/ # U-Boot SPL 2017.01-rc1-g5df570f-dirty (May 14 2017 - 17:34:08) DRAM: 512 MiB Failed to set core voltage! Can't set CPU frequency Trying to boot from MMC1NOTICE: BL3-1: Running on H5 (1718) in SRAM A2 (@0x44000) NOTICE: Configuring SPC Controller NOTICE: BL3-1: v1.0(debug):aa75c8d NOTICE: BL3-1: Built : 17:34:02, May 14 2017 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9 U-Boot 2017.01-rc1-g5df570f-dirty (May 14 2017 - 17:34:15 +0200) Allwinner Technology CPU: Allwinner H5 (SUN50I) Model: OrangePiZeroPlus DRAM: 512 MiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 *** Warning - bad CRC, using default environment Setting up a 720x576i composite-pal console (overscan 32x20) Error: no valid bmp image at 66000000 In: serial Out: vga Err: vga Net: No ethernet found. Hit any key to stop autoboot: 0 reading /boot/boot.bmp ** Unable to read file /boot/boot.bmp ** reading boot.bmp ** Unable to read file boot.bmp ** switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found USB device 0: unknown device No ethernet found. missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-sunxi No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default No ethernet found. Config file not found No ethernet found. No ethernet found. => > version U-Boot 2017.01-rc1-g5df570f-dirty (May 14 2017 - 17:34:15 +0200) Allwinner Technology aarch64-linux-gnu-gcc (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609 GNU ld (GNU Binutils for Ubuntu) 2.26.1 After playing around I tried boot: => boot reading /boot/boot.bmp ** Unable to read file /boot/boot.bmp ** reading boot.bmp ** Unable to read file boot.bmp ** switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot.scr reading /boot.scr 538 bytes read in 52 ms (9.8 KiB/s) ## Executing script at 4fc00000 gpio: pin PA17 (gpio 17) value is 1 reading script.bin 35260 bytes read in 54 ms (636.7 KiB/s) reading uImage 4680288 bytes read in 331 ms (13.5 MiB/s) ## Booting kernel from Legacy Image at 48000000 ... Image Name: Linux-3.4.39 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 4680224 Bytes = 4.5 MiB Load Address: 40008000 Entry Point: 40008000 Verifying Checksum ... OK Unsupported Architecture 0x2 ERROR: can't get kernel image! SCRIPT FAILED: continuing... switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... Progress at last. I don't know whats going with the errors it threw up there, but armbian is next and I will try to burn SD on my macbook if it doesnt work
xalu Posted September 22, 2017 Author Posted September 22, 2017 Worked first try with armbian from the u-boot window I'll play around but that covers the issue that started the post.
rusatch Posted September 22, 2017 Posted September 22, 2017 You have to try use this build . There is wifi working, but without 802.11n support, and without usb. 1
chwe Posted September 22, 2017 Posted September 22, 2017 Completely forgot this stock androids on eMMC... It's not that uncommon.. 9 hours ago, xalu said: Thanks for pushing me to it! There's a reason why we push people to the usb-ttl. Even if it's not solved everything yet, you see now what's going on during boot. 1
