WaveShare 5inch HDMI LCD (B), OPi PC 2
Hello, guys. I have a trouble with touch screen on OPi PC 2 (Connected via USB). Touch detected like
Bus 006 Device 002: ID 0eef:0005 D-WAV Scientific Co., Ltd
Tried to add `modprobe ads7846` and `modprobe hid-multitouch`. Without results. But on last command returned an error
modprobe: FATAL: Module hid-multitouch not found in directory /lib/modules/4.11.1-sun50iw2
Can u help me? Thanks.
We don't deal with 3rd party hardware support. Board troubles are already over the top.
Edit: Moved to Peer to Peer technical support
  On 9/25/2017 at 6:16 PM, o_flyer said:
Very little information on this matter ;(
Expand
You need to get a driver to run and that driver is usually supplied by hardware maker. It's also possible that support exists in a kernel, but it's not enabled. It's on you to find out ...
  On 9/25/2017 at 5:57 PM, o_flyer said:
Touch detected like
Expand
ADS7846 is an SPI driver, but you list a USB based device.
Expand
It's not enabled in the kernel config, and even if we enable it you will need to compile a new kernel or install new packages manually.
Does it still appear as "eth0" in "ifconfig" ?
What "dmesg" is showing ?
Did you update DT from the same kernel build, ie .: installed the "linux-dtb-<version>.deb" ?
When installing new kernel, you should always install the DTB that comes from the same build, because there can be discrepancies across 2 builds.
EDIT : I've just realized that maybe you are using Legacy build instead of Mainline, in such case DTB doesn't exist.
BTW, did you carefully looked at the "dmesg" logs ?
