(BananaPi) OTG not working in latest published testing image (Armbian_5.00_Bananapi_Debian_jessie_4.4.0-rc5.zip)
--- a/arch/arm/boot/dts/sun7i-a20-bananapi.dts
+++ b/arch/arm/boot/dts/sun7i-a20-bananapi.dts
@@ -269,7 +269,7 @@
 &usb_otg {
-	dr_mode = "otg";
+	dr_mode = "host";
 	status = "okay";
That image was deliberately compiled with OTG in host mode  :D
You need to alter Bananapi DTB ... Simply use the one from BananaPRO and it should work since OTG mode is default.
My luck is bad here Igor. :( port still dead.
To be sure I have compiled whole own kernel too. First time with "host", second time with "otg" option in sun7i-a20-bananapi.dts (I have deleted source dir before second attempt). Nothing changes.  (I have installed both new kernel and dtb .deb files)
I do not know where I could make a mistake. Chrrrm. Maybe port is broken physically.
I will just wait to next release and will see what is up.
Loaded sunxi module (modprobe sunxi), lsmod shows it, but OTG is still not powered.
EDIT: Just installed 3.4 kernel and after script.bin modification OTG works OK. So it is not HW problem.
Try to use bin files from Bananian images https://www.bananian.org/download.
Download image of Jessie for example, unpack zip folder and you can mount image with gnome-disk-utility (gnome-disks command if you are running Ubuntu based system).
When is first partition mounted go to fex/BananaPi-OTG/. I think you just need to replace script.bin in your armbian image or just part of it.
The problem is in kernel 4.x ...
I have armbian with kernel 4.4 and it works out of the box... 50%. If I use a Y connector (power from another USB and data from otg port) it works correctly. It is not a problem because I have USB power nearby and a stock Y cable, but it is not they way it is expected to work (In fact I was going crazy until I read in another post from Igor that port is not powered)
Powering USB OTG port on Banana Pi is not implemented in mainline kernel - it is wired in non-standart (compared i.e. to cubietruck) way. In theory it's possible to do it manually, but using Y-cable should be more safe anyway.
Hi to All,
I also try to use USB OTG on Lime 2 board without success.
I use Armbian (from SVN) customized and build by me with U-Boot 2016.05-rc1 and kernel 4.5.2.
After checking sun7i-a20-olinuxino-lime2.dts (generated by dtc) I apply proposed by Igor patch:
 &usb_otg {
-	dr_mode = "otg";
+	dr_mode = "host";
 	status = "okay";
compile dts file to dtb and copy it back to /boot/dtb.
Unfortunately, USB OTG did not work but I see following inside boot messages:
[    3.369524] sun4i-usb-phy 1c13400.phy: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb0_id_detect_pin@0, deferring probe
I do not change anything else and verify that there is dts node for usb0_id_detect_pin.
It is strange to see sun4i-usb-phy ... and why usb0_id_detect_pin is used in case of selecting HOST only mode?
Where could be the problem?
EDIT: I go back to dr_mode = "otg" and find that probably USB is recognized in both cases but usb0-vbus is disabled for some reason:
[ 3.254763] reg-fixed-voltage usb0-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb0_vbus_pin@0, deferring probe
[ 3.254800] reg-fixed-voltage usb1-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb1_vbus_pin@0, deferring probe
[ 3.254834] reg-fixed-voltage usb2-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb2_vbus_pin@0, deferring probe
[ 3.257728] usbcore: registered new interface driver usbfs
[ 3.257804] usbcore: registered new interface driver hub
[ 3.257907] usbcore: registered new device driver usb
[ 3.369483] sun4i-usb-phy 1c13400.phy: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb0_id_detect_pin@0, deferring probe
[ 3.493156] usbcore: registered new interface driver usb-storage
[ 3.601446] usbcore: registered new interface driver usbhid
[ 3.601453] usbhid: USB HID core driver
[ 3.682401] ehci-platform 1c14000.usb: EHCI Host Controller
[ 3.682452] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
[ 3.682710] ehci-platform 1c14000.usb: irq 29, io mem 0x01c14000
[ 3.700016] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
[ 3.700386] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.700400] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.700410] usb usb1: Product: EHCI Host Controller
[ 3.700419] usb usb1: Manufacturer: Linux 4.5.2-sunxi ehci_hcd
[ 3.700428] usb usb1: SerialNumber: 1c14000.usb
[ 3.702306] ehci-platform 1c1c000.usb: EHCI Host Controller
[ 3.702362] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2
[ 3.702617] ehci-platform 1c1c000.usb: irq 33, io mem 0x01c1c000
[ 3.720002] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[ 3.720332] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.720346] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.720356] usb usb2: Product: EHCI Host Controller
[ 3.720365] usb usb2: Manufacturer: Linux 4.5.2-sunxi ehci_hcd
[ 3.720374] usb usb2: SerialNumber: 1c1c000.usb
[ 3.722163] ohci-platform 1c14400.usb: Generic Platform OHCI controller
[ 3.722206] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 3
[ 3.722440] ohci-platform 1c14400.usb: irq 30, io mem 0x01c14400
[ 3.784331] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.784346] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.784356] usb usb3: Product: Generic Platform OHCI controller
[ 3.784366] usb usb3: Manufacturer: Linux 4.5.2-sunxi ohci_hcd
[ 3.784375] usb usb3: SerialNumber: 1c14400.usb
[ 3.786187] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[ 3.786248] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 4
[ 3.786499] ohci-platform 1c1c400.usb: irq 34, io mem 0x01c1c400
[ 3.844318] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.844336] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.844347] usb usb4: Product: Generic Platform OHCI controller
[ 3.844356] usb usb4: Manufacturer: Linux 4.5.2-sunxi ohci_hcd
[ 3.844366] usb usb4: SerialNumber: 1c1c400.usb
[ 3.846329] usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 3.846918] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 3.846939] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5
[ 3.847378] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.847394] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.847404] usb usb5: Product: MUSB HDRC host driver
[ 3.847413] usb usb5: Manufacturer: Linux 4.5.2-sunxi musb-hcd
[ 3.847422] usb usb5: SerialNumber: musb-hdrc.1.auto
[ 3.876821] usb0-vbus: disabling
[ 4.040024] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 4.208615] usb 2-1: New USB device found, idVendor=148f, idProduct=5370
[ 4.208645] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.208656] usb 2-1: Product: 802.11 n WLAN
[ 4.208666] usb 2-1: Manufacturer: Ralink
[ 4.208850] usb 2-1: SerialNumber: 1.0
[ 7.080184] usb 2-1: reset high-speed USB device number 2 using ehci-platform
[ 7.296089] usbcore: registered new interface driver rt2800usb
To verify if the problem is in USB OTG powering I have connected to it a self powered device.
Unfortunately, it does not work while connecting it to one of the USB Host ports it works.
Best regards
Chris
