MB2 Posted October 15, 2017 Posted October 15, 2017 Hello, i will move my project from RPI2 to tinkerboard. I have 2 Serial Converter, USB to RS422 and USB to RS485, both working on the PI. On the Tinkerboard with "ARMBIAN 5.33 stable Ubuntu 16.04.3 LTS 4.13.3-rockchip" runs only the RS422, the RS485 (Vendor 1a86) is not available as /dev/ttyUSB. What can i do? Regards Marco Tinkerboard Log: Spoiler Oct 14 17:52:45 localhost kernel: [ 1.942542] usb 1-1.1: new full-speed USB device number 3 using dwc2 Oct 14 17:52:45 localhost kernel: [ 2.020053] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=7523 Oct 14 17:52:45 localhost kernel: [ 2.020066] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0 Oct 14 17:52:45 localhost kernel: [ 2.020076] usb 1-1.1: Product: USB2.0-Serial Oct 14 17:52:45 localhost kernel: [ 2.175542] usb 1-1.2: new full-speed USB device number 4 using dwc2 Oct 14 17:52:45 localhost kernel: [ 2.258393] usb 1-1.2: New USB device found, idVendor=0403, idProduct=6001 Oct 14 17:52:45 localhost kernel: [ 2.258407] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Oct 14 17:52:45 localhost kernel: [ 2.258416] usb 1-1.2: Product: FT232R USB UART Oct 14 17:52:45 localhost kernel: [ 2.258425] usb 1-1.2: Manufacturer: FTDI Oct 14 17:52:45 localhost kernel: [ 2.258433] usb 1-1.2: SerialNumber: 00000000 Oct 14 17:52:45 localhost kernel: [ 2.261754] ftdi_sio 1-1.2:1.0: FTDI USB Serial Device converter detected Oct 14 17:52:45 localhost kernel: [ 2.261918] usb 1-1.2: Detected FT232RL Oct 14 17:52:45 localhost kernel: [ 2.262583] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0 Raspberry Log: Spoiler Oct 8 18:40:45 raspberrypi2 kernel: [ 2.180505] usb 1-1.2: new full-speed USB device number 4 using dwc_otg Oct 8 18:40:45 raspberrypi2 kernel: [ 2.338225] usb 1-1.2: New USB device found, idVendor=0403, idProduct=6001 Oct 8 18:40:45 raspberrypi2 kernel: [ 2.342105] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Oct 8 18:40:45 raspberrypi2 kernel: [ 2.346076] usb 1-1.2: Product: FT232R USB UART Oct 8 18:40:45 raspberrypi2 kernel: [ 2.348063] usb 1-1.2: Manufacturer: FTDI Oct 8 18:40:45 raspberrypi2 kernel: [ 2.349980] usb 1-1.2: SerialNumber: 00000000 Oct 8 18:40:45 raspberrypi2 kernel: [ 2.460527] usb 1-1.3: new full-speed USB device number 5 using dwc_otg Oct 8 18:40:45 raspberrypi2 kernel: [ 2.594261] usb 1-1.3: New USB device found, idVendor=1a86, idProduct=7523 Oct 8 18:40:45 raspberrypi2 kernel: [ 2.597560] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0 Oct 8 18:40:45 raspberrypi2 kernel: [ 2.601164] usb 1-1.3: Product: USB2.0-Serial Oct 8 18:40:45 raspberrypi2 kernel: [ 3.444436] usbcore: registered new interface driver usbserial Oct 8 18:40:45 raspberrypi2 kernel: [ 3.444562] usbcore: registered new interface driver usbserial_generic Oct 8 18:40:45 raspberrypi2 kernel: [ 3.444690] usbserial: USB Serial support registered for generic Oct 8 18:40:45 raspberrypi2 kernel: [ 3.462009] usbcore: registered new interface driver ch341 Oct 8 18:40:45 raspberrypi2 kernel: [ 3.462155] usbserial: USB Serial support registered for ch341-uart Oct 8 18:40:45 raspberrypi2 kernel: [ 3.462280] ch341 1-1.3:1.0: ch341-uart converter detected Oct 8 18:40:45 raspberrypi2 kernel: [ 3.467197] usb 1-1.3: ch341-uart converter now attached to ttyUSB0 Oct 8 18:40:45 raspberrypi2 kernel: [ 3.566268] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000 Oct 8 18:40:45 raspberrypi2 kernel: [ 3.710760] usbcore: registered new interface driver ftdi_sio Oct 8 18:40:45 raspberrypi2 kernel: [ 3.710934] usbserial: USB Serial support registered for FTDI USB Serial Device Oct 8 18:40:45 raspberrypi2 kernel: [ 3.711359] ftdi_sio 1-1.2:1.0: FTDI USB Serial Device converter detected Oct 8 18:40:45 raspberrypi2 kernel: [ 3.711676] usb 1-1.2: Detected FT232RL Oct 8 18:40:45 raspberrypi2 kernel: [ 3.732489] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB1
Igor Posted October 15, 2017 Posted October 15, 2017 1 hour ago, MB2 said: What can i do? https://docs.armbian.com/Developer-Guide_Build-Preparation/ Enable, build (with parameter KERNEL_CONFIGURE="yes") and(or) send a patch upstream or wait few days that its added ... under the condition that only enabling is needed. We rebuild all kernels daily and you can find them in beta.armbian.com repository.
MB2 Posted October 15, 2017 Author Posted October 15, 2017 Hi Igor, thanks for the reply, but I do not quite understand. I am not a specialist in the ux world, but only compile the kernel is not enough? As I see it is missing the driver for the CH340 / CH341 or even only the assignment of the Vendor / Device ID to this driver. I do not know how I can check whether the driver is available or how I can include. There is a driver for the converter, but only for kernels 2.x and 3.x http://www.wch.cn/download/CH341SER_LINUX_ZIP.html regards Marco
martinayotte Posted October 15, 2017 Posted October 15, 2017 This is a bit strange that CH34x driver is missing, it has been added months, maybe year ago. Here is the results of "grep CH34" in Armbian defconfig : config/kernel/linux-sun4i-default.config:CONFIG_USB_SERIAL_CH341=m config/kernel/linux-sun7i-default.config:CONFIG_USB_SERIAL_CH341=m config/kernel/linux-sun8i-default.config:CONFIG_USB_SERIAL_CH341=m config/kernel/linux-sun8i-dev.config:CONFIG_USB_SERIAL_CH341=m config/kernel/linux-sunxi64-dev.config:CONFIG_USB_SERIAL_CH341=m config/kernel/linux-sunxi64-next.config:CONFIG_USB_SERIAL_CH341=m config/kernel/linux-sunxi-dev.config:CONFIG_USB_SERIAL_CH341=m config/kernel/linux-sunxi-next.config:CONFIG_USB_SERIAL_CH341=m Verify that is really missing by doing : find /lib/modules/ -name "ch34*ko" Check also "dmesg" while plugging the USB-RS485 device, you should see something like : [2830916.592706] usb 1-1: new full-speed USB device number 3 using dwc2 [2830916.776738] usb 1-1: New USB device found, idVendor=1a86, idProduct=7523 [2830916.776768] usb 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0 [2830916.776788] usb 1-1: Product: USB2.0-Serial [2830918.390022] usbcore: registered new interface driver usbserial [2830918.390154] usbcore: registered new interface driver usbserial_generic [2830918.390266] usbserial: USB Serial support registered for generic [2830918.393881] usbcore: registered new interface driver ch341 [2830918.394055] usbserial: USB Serial support registered for ch341-uart [2830918.394199] ch341 1-1:1.0: ch341-uart converter detected [2830918.397152] usb 1-1: ch341-uart converter now attached to ttyUSB0
zador.blood.stained Posted October 15, 2017 Posted October 15, 2017 22 minutes ago, martinayotte said: it has been added months, maybe year ago but not to Rockchip configs, so somebody has to add it and push the changes to our repository.
martinayotte Posted October 15, 2017 Posted October 15, 2017 1 hour ago, zador.blood.stained said: but not to Rockchip configs I'm still thinking AllWinner all the time ... EDIT : Another reason for by "bad", I'm still using Ayufan build ... So, it is a good oppotunity to add those drivers and test new Armbian ... I will probably commit that this afternoon.
MB2 Posted October 15, 2017 Author Posted October 15, 2017 no ch3xx.ko with "find /lib/modules/ -name "ch34*ko""
martinayotte Posted October 15, 2017 Posted October 15, 2017 In the mean time that I'm doing the required commit, you can use temporarily an Ayufan image, it has this driver.
zador.blood.stained Posted October 15, 2017 Posted October 15, 2017 @martinayotte Tinkerboard images are not compatible with Rock64 ones, so there are no Ayufan's images for it
martinayotte Posted October 15, 2017 Posted October 15, 2017 ... But, I will do the task for Rock64 ...
TonyMac32 Posted October 15, 2017 Posted October 15, 2017 Thanks @martinayotte, I'm operating from cell phone right now, a storm took out my power... I'll check these when it comes back if it hasn't been done, it will need added to the Meson64 as well, I would expect.
martinayotte Posted October 15, 2017 Posted October 15, 2017 Oh, to my surprise since I was still using Ayufan image on my Rock64, it seems that current Dev build, although building properly, isn't booting and get stuck at "starting kernel" ... Anyone got the Dev working ? Then, I've built Default version, and this one is working ... It is maybe question of DT itself or U-Boot, I will need to investigate more.
MB2 Posted October 20, 2017 Author Posted October 20, 2017 any news from the driver? So my project ist migrated to the tinkerboard with an ttl to rs485 adapter, but I would be happy if the usb adapter would work
martinayotte Posted October 20, 2017 Posted October 20, 2017 The commit has been done 4 days ago : https://github.com/armbian/build/commit/d70ce66742a55579c49e712ce6a867c7ac68df83 So, if you build your own image, you will getting those USB-TTL dongles working.
MB2 Posted October 20, 2017 Author Posted October 20, 2017 oh, I did not see that. I will try that, thanks
