Blind55 Posted August 8 Posted August 8 I have been pulling my hair out trying to get the acceleration performance (smooth 4K video playback in mpv / chromium) in Armbian (any of the MESA/VPU marked releases) that I am getting from the FriendlyElec distributions. In my naive mind, I thought the MESA/VPU version would get me there, but mpv stutters on 4K videos. I suspect this is because Armbian avoids the proprietary drives. A long time ago, Armbian Ubuntu versions were able to be 'amended' with the Amazingfate/liujianfeng1994 repository, but I have not been able to make that work in a while. Could someone point me to a guide that allows me to get similar performance with Armbian as I am getting with FriendlyElec? Thanks bunch in advance! 0 Quote
Werner Posted August 9 Posted August 9 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Solution Dantes Posted September 7 Solution Posted September 7 (edited) Or wait until the end of the year when 6.18 will be the new Linux version, that enables pretty much everything. RK3588 Mainline Linux Status: https://gitlab.collabora.com/hardware-enablement/rockchip-3588/notes-for-rockchip-3588/-/blob/main/mainline-status.md If you really need a bleeding edge working mediaplayer, LibreElec has experimental support for R6S/R6C: Thread: https://forum.libreelec.tv/thread/29953-le13-testing-for-rk3288-rk3328-rk3399-rk3566-rk3568-rk3576-rk3588/ Downloads: https://chewitt.libreelec.tv/testing/ Edited September 7 by Dantes 0 Quote
Blind55 Posted 1 hour ago Author Posted 1 hour ago Thank you, everyone, for the suggestions. After having been absent here for a while, I am going to try Dante's suggestion first. Thanks again! 0 Quote
