Cancer Posted 7 hours ago Posted 7 hours ago Hi All I've made for my sbc image, however found during this process messages including 1 marked as error : ``` Error response from registry: failed to fetch the content of "ghcr.io/armbian/os/armbian-bsp-cli-bananapipro-current:1-PCc91e-V4b00-H9299-B1e5d-Rf36a": ghcr.io/armbian/os/armbian-bsp-cli-bananapipro-current:1-PCc91e-V4b00-H9299-B1e5d-Rf36a: not found ``` some repeatible during the process: ``` gpg: WARNING: unsafe ownership on homedir '/home/bask/.gnupg' /usr/bin/deb-systemd-helper was not called from dpkg. Exiting. /usr/bin/deb-systemd-helper was not called from dpkg. Exiting. invoke-rc.d: unknown initscript, /etc/init.d/iperf3 not found. ``` and finally filtered from log: ``` filtered from log @output/logs/log-build-322ed1c8-a4db-4873-85ac-be8e6a87fbd6.log.ans Error 3 occurred in main shell /home/bask/Dokumenty/build/lib/functions/configuration/menu.sh:38 dialog_if_terminal_set_vars() --> lib/functions/configuration/menu.sh:38 interactive_config_ask_board_list() --> lib/functions/configuration/interactive.sh:149 config_possibly_interactive_kernel_board() --> lib/functions/main/config-interactive.sh:16 prep_conf_main_build_single() --> lib/functions/main/config-prepare.sh:21 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:22 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ``` Not sure if I should worry or it is handled somehow? I'll try an expert mode as there was not too much to configure and verify Second thing: 90 mins for this process is normal? I was doing it on newly installed Ubuntu (directly on the disk in dual mode so whole HW available for it) 0 Quote
Werner Posted 7 hours ago Posted 7 hours ago Excerpts are often useless. Provide full logs using the curl command from the end of each run. 5 minutes ago, Cancer said: g: 90 mins for this process is normal? If the used hardware isn't very powerful, yes, can be. 0 Quote
Cancer Posted 5 hours ago Author Posted 5 hours ago HP Pavilion8 core processor, 32Gig RAM laptop. I wanted to limit information to limit time for digging into it, but here they are: log-build-322ed1c8-a4db-4873-85ac-be8e6a87fbd6.log.ans summary-build-322ed1c8-a4db-4873-85ac-be8e6a87fbd6.md 0 Quote
