Hi All
 I've made for my sbc image, however found during this process  messages including 1 marked as error :
Error response from registry: failed to fetch the content of "ghcr.io/armbian/os/armbian-bsp-cli-bananapipro-current:1-PCc91e-V4b00-H9299-B1e5d-Rf36a": ghcr.io/armbian/os/armbian-bsp-cli-bananapipro-current:1-PCc91e-V4b00-H9299-B1e5d-Rf36a: not found
some repeatible during the process:
gpg: WARNING: unsafe ownership on homedir '/home/bask/.gnupg'
/usr/bin/deb-systemd-helper was not called from dpkg. Exiting.
invoke-rc.d: unknown initscript, /etc/init.d/iperf3 not found.
and finally filtered from log:
filtered from log  @output/logs/log-build-322ed1c8-a4db-4873-85ac-be8e6a87fbd6.log.ans
Error 3 occurred in main shell /home/bask/Dokumenty/build/lib/functions/configuration/menu.sh:38
  dialog_if_terminal_set_vars() --> lib/functions/configuration/menu.sh:38
  interactive_config_ask_board_list() --> lib/functions/configuration/interactive.sh:149
  config_possibly_interactive_kernel_board() --> lib/functions/main/config-interactive.sh:16
  prep_conf_main_build_single() --> lib/functions/main/config-prepare.sh:21
  cli_standard_build_run() --> lib/functions/cli/cli-build.sh:22
  armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136
  cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176
  main() --> compile.sh:50
Not sure if I should worry or it is handled somehow?
I'll try an expert mode as there was not too much to configure and verify
Second thing: 90 mins for this process is normal? I was doing it on newly installed Ubuntu (directly on the disk in dual mode so whole HW available for it)
Excerpts are often useless. Provide full logs using the curl command from the end of each run.
If the used hardware isn't very powerful, yes, can be.
What's wrong with just using the curl command? It will upload the logs to one of our paste servers and it will be nicely formatted and colorful. Way easier to read.
