Cancer Posted 23 hours ago Posted 23 hours ago Hi All I've made for my sbc image, however found during this process messages including 1 marked as error : ``` Error response from registry: failed to fetch the content of "ghcr.io/armbian/os/armbian-bsp-cli-bananapipro-current:1-PCc91e-V4b00-H9299-B1e5d-Rf36a": ghcr.io/armbian/os/armbian-bsp-cli-bananapipro-current:1-PCc91e-V4b00-H9299-B1e5d-Rf36a: not found ``` some repeatible during the process: ``` gpg: WARNING: unsafe ownership on homedir '/home/bask/.gnupg' /usr/bin/deb-systemd-helper was not called from dpkg. Exiting. /usr/bin/deb-systemd-helper was not called from dpkg. Exiting. invoke-rc.d: unknown initscript, /etc/init.d/iperf3 not found. ``` and finally filtered from log: ``` filtered from log @output/logs/log-build-322ed1c8-a4db-4873-85ac-be8e6a87fbd6.log.ans Error 3 occurred in main shell /home/bask/Dokumenty/build/lib/functions/configuration/menu.sh:38 dialog_if_terminal_set_vars() --> lib/functions/configuration/menu.sh:38 interactive_config_ask_board_list() --> lib/functions/configuration/interactive.sh:149 config_possibly_interactive_kernel_board() --> lib/functions/main/config-interactive.sh:16 prep_conf_main_build_single() --> lib/functions/main/config-prepare.sh:21 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:22 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ``` Not sure if I should worry or it is handled somehow? I'll try an expert mode as there was not too much to configure and verify Second thing: 90 mins for this process is normal? I was doing it on newly installed Ubuntu (directly on the disk in dual mode so whole HW available for it) 0 Quote
Werner Posted 23 hours ago Posted 23 hours ago Excerpts are often useless. Provide full logs using the curl command from the end of each run. 5 minutes ago, Cancer said: g: 90 mins for this process is normal? If the used hardware isn't very powerful, yes, can be. 0 Quote
Cancer Posted 22 hours ago Author Posted 22 hours ago HP Pavilion8 core processor, 32Gig RAM laptop. I wanted to limit information to limit time for digging into it, but here they are: log-build-322ed1c8-a4db-4873-85ac-be8e6a87fbd6.log.ans summary-build-322ed1c8-a4db-4873-85ac-be8e6a87fbd6.md 0 Quote
Werner Posted 10 hours ago Posted 10 hours ago What's wrong with just using the curl command? It will upload the logs to one of our paste servers and it will be nicely formatted and colorful. Way easier to read. 0 Quote
Cancer Posted 2 hours ago Author Posted 2 hours ago Here it is: https://paste.armbian.com/ququgojasu 0 Quote
