Cancer Posted Tuesday at 02:40 PM Posted Tuesday at 02:40 PM Hi All I've made for my sbc image, however found during this process messages including 1 marked as error : ``` Error response from registry: failed to fetch the content of "ghcr.io/armbian/os/armbian-bsp-cli-bananapipro-current:1-PCc91e-V4b00-H9299-B1e5d-Rf36a": ghcr.io/armbian/os/armbian-bsp-cli-bananapipro-current:1-PCc91e-V4b00-H9299-B1e5d-Rf36a: not found ``` some repeatible during the process: ``` gpg: WARNING: unsafe ownership on homedir '/home/bask/.gnupg' /usr/bin/deb-systemd-helper was not called from dpkg. Exiting. /usr/bin/deb-systemd-helper was not called from dpkg. Exiting. invoke-rc.d: unknown initscript, /etc/init.d/iperf3 not found. ``` and finally filtered from log: ``` filtered from log @output/logs/log-build-322ed1c8-a4db-4873-85ac-be8e6a87fbd6.log.ans Error 3 occurred in main shell /home/bask/Dokumenty/build/lib/functions/configuration/menu.sh:38 dialog_if_terminal_set_vars() --> lib/functions/configuration/menu.sh:38 interactive_config_ask_board_list() --> lib/functions/configuration/interactive.sh:149 config_possibly_interactive_kernel_board() --> lib/functions/main/config-interactive.sh:16 prep_conf_main_build_single() --> lib/functions/main/config-prepare.sh:21 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:22 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ``` Not sure if I should worry or it is handled somehow? I'll try an expert mode as there was not too much to configure and verify Second thing: 90 mins for this process is normal? I was doing it on newly installed Ubuntu (directly on the disk in dual mode so whole HW available for it) 0 Quote
Werner Posted Tuesday at 02:46 PM Posted Tuesday at 02:46 PM Excerpts are often useless. Provide full logs using the curl command from the end of each run. 5 minutes ago, Cancer said: g: 90 mins for this process is normal? If the used hardware isn't very powerful, yes, can be. 0 Quote
Cancer Posted Tuesday at 04:16 PM Author Posted Tuesday at 04:16 PM HP Pavilion8 core processor, 32Gig RAM laptop. I wanted to limit information to limit time for digging into it, but here they are: log-build-322ed1c8-a4db-4873-85ac-be8e6a87fbd6.log.ans summary-build-322ed1c8-a4db-4873-85ac-be8e6a87fbd6.md 0 Quote
Werner Posted yesterday at 04:23 AM Posted yesterday at 04:23 AM What's wrong with just using the curl command? It will upload the logs to one of our paste servers and it will be nicely formatted and colorful. Way easier to read. 0 Quote
Cancer Posted yesterday at 12:23 PM Author Posted yesterday at 12:23 PM Here it is: https://paste.armbian.com/ququgojasu 0 Quote
Igor Posted yesterday at 04:20 PM Posted yesterday at 04:20 PM Works well on my side - could not reproduce (with Docker based compilation), but however there is a (common to a20 boards) problem with HDMI output while boards otherwise works. 0 Quote
Cancer Posted yesterday at 04:32 PM Author Posted yesterday at 04:32 PM My setting was without docker and I was not using it. I was observing shell output, and because I selected version without desktop (on which HDMI could affect) while there were some desktop components additions during script processing. Small remark: I use sbc as server with good quality server 1TB 2,5"drive. 0 Quote
Igor Posted yesterday at 06:27 PM Posted yesterday at 06:27 PM 1 hour ago, Cancer said: without docker This is not recommended as its not controlled environment. It might work, but no warranties. 1 hour ago, Cancer said: I selected version without desktop HDMI output is broken in general (on this particular SoC) regardless of variant, desktop, cli, minimal. Its known bug, but we currently don't have anyone maintaining Allwinner A20 series so its up to random person to fix this. Code is open, so anyone can. 1 hour ago, Cancer said: I use sbc as server Then it should be o.k. since HDMI output is not needed. 0 Quote
Cancer Posted yesterday at 07:24 PM Author Posted yesterday at 07:24 PM Thanks, all's clear Just now, Igor said: anyone maintaining Allwinner A20 series so its up to random person to fix this I might be such random person lol. However it would need either a lot of time or information delivered when it has been broken; open code is nice but there are too many kernel versions and distributions. That matter would need some deeper conversation. I think you was the person managing this area so maybe you know where to search the issue to correct it or you know the person who might know. I'm affraid I found the reason of long image generation time: my laptop fans are to silent today and it might be the reason... 0 Quote
Werner Posted 17 hours ago Posted 17 hours ago Alright, let's give a real quick overview where the code for A20 comes from. Let's focus on current. First stop. Board config: https://github.com/armbian/build/blob/main/config/boards/bananapipro.csc -> BOARDFAMILY="sun7i" Next stop. Family config: https://github.com/armbian/build/blob/main/config/sources/families/sun7i.conf -> No sources defined. However there are includes. Next stop. Includes: https://github.com/armbian/build/blob/main/config/sources/families/include/sunxi_common.inc -> No kernel source URL defined. Therefore kernel comes from mainline (kernel.org to say). However a version is tagged: v6.12.43 So we know: Linux source comes from unmodified mainline and the version is 6.12.43 Next stop. Patches: https://github.com/armbian/build/tree/main/patch/kernel/archive/sunxi-6.12 -> vendor family = sunxi, kernel major.minor is 6.12 All these patches are applied on top of the kernel source from kernel.org. And yes, that's a lot. I think sunxi is the worst family regarding number of additional patches to make stuff work. Next component is u-boot. https://github.com/armbian/build/blob/main/config/sources/families/include/sunxi_common.inc -> BOOTBRANCH:-"tag:v2024.01" so uboot is tagged to this version. So we know: U-Boot source comes from unmodified mainline and the version is v2024.01. And BOOTPATCHDIR="${BOOTPATCHDIR:-"u-boot-sunxi"}" which means here we find the patchset put on top of that version. Let's check. https://github.com/armbian/build/tree/main/patch/u-boot/u-boot-sunxi -> folders starting with board_ are applied only if the target board is being built. All remaining paches are always applied. There are more definitions of stuff appling for multiple families, whole architectures or even all boards regardless of architecture but in this case they are not important. Just including for the sake of completion/information: https://github.com/armbian/build/blob/main/config/sources/armhf.conf https://github.com/armbian/build/blob/main/config/sources/common.conf Good luck. 1 Quote
Igor Posted 14 hours ago Posted 14 hours ago 11 hours ago, Cancer said: However it would need either a lot of time or information delivered when it has been broken When things are not actively monitored, features stopped working without knowing. This has to be find out. 11 hours ago, Cancer said: too many kernel versions and distributions At least all Armbian distributions have the same kernel, regardless of its upstream origin - Debian X,Y,Z and Ubuntu A,B,C ... have same kernel. But of course kernels versions go up all the time. 11 hours ago, Cancer said: I think you was the person managing this area so maybe you know where to search the issue to correct it or you know the person who might know. I am not managing this that deep / specific. Where to search? On this forum. I am sure that this was already brought up. 0 Quote
Cancer Posted 7 hours ago Author Posted 7 hours ago 6 hours ago, Igor said: When things are not actively monitored, features stopped working without knowing. This has to be find out. As I understood they are not tested, am I right? 0 Quote
Werner Posted 7 hours ago Posted 7 hours ago Yes, csc boards are not actively monitored. Build test only. 0 Quote
Werner Posted 6 hours ago Posted 6 hours ago Our CI produces automated builds which are published here: https://github.com/armbian/community/releases If a build fails we will notice and fix if it doesn't much effort. Otherwise it's demoted to EOS and autobuilds disabled. 0 Quote
Cancer Posted 5 hours ago Author Posted 5 hours ago ok , so no special procedure exists. There is only minimal image is accessible for download for bpi pro. Does It mean all other failed or nobody tried to build them? Random images are accessible from archive too. What does "CI" stand for? 0 Quote
Werner Posted 4 hours ago Posted 4 hours ago There is usually only one or two images built per board. That's enough to make sure it compiles properly. All other combinations can be made DIY with the framework, check documentation. Continous Integration https://en.wikipedia.org/wiki/Continuous_integration 0 Quote
laibsch Posted 1 hour ago Posted 1 hour ago 3 hours ago, Werner said: All other combinations can be made DIY with the framework, check documentation. Or simply add whatever packages you desire with apt. 0 Quote
