JohnQPublic Posted October 26, 2017 Posted October 26, 2017 (edited) I've installed Armbian again. Initially I logged in as root and 1234 password which worked. Then it asked to change the password. Something wen't wrong with it. My OrangePi PC boots fine and ok. When I open a terminal and try to do a "sudo this that" it asks my password and won't accept the one I gave, nor 1234. I've done the full installation a couple of times and same problem persists. How do I rest root password? The problem is that everytime I re-install everything and I'me at the very firts log (where I enter root and 1234) the screen scrolls so that I cannot see what it is asking since my monitor is 1600x1024. That I why I need to reset password afterwards. I' the only user. Edited October 27, 2017 by JohnQPublic solved
guidol Posted October 26, 2017 Posted October 26, 2017 Hmmm. something that I did on some distributions: Normally after the root password you would been forwarded to create a normal user (mine is guido ) and this should get sudo rights. So try to login as your user (not root) and do a sudo passwd then armbian should ask for the user password and not the root-password....after the user-password you have to enter 2 times the new root-password. And for the first time try to enter a password which hasnt chars like y or z (different keyboard-layout before dpkg-reconfigure keyboard-configuration) A easy one is 'Joshua' If that works you could try to use a password which is more secure
arox Posted October 26, 2017 Posted October 26, 2017 Well, last time I installed ubuntu, something also went wrong : bad keyboard configuration. So, how stupid to ask a password when you are nor sure of the keyboard configured and when some obscure mechanisms can change it any time ? I found myself in the same situation as you. Another trick is that the installation procedure ask to enter old password, which is unusual for root password and a source of errors. So if you are not using a qwerty keyboard, you could try to enter what would be your password if your keyboard were qwerty. If you want to reset (suppress) root password (and really understand what I describe here), you can mount the sdcard first partition on another system on /mnt, then edit /mnt/etc/passwd file and remove second field of first line (that is to say leave "root::0:0:root:/root:/bin/bash").
tkaiser Posted October 26, 2017 Posted October 26, 2017 4 hours ago, JohnQPublic said: I've done the full installation a couple of times and same problem persists Check your SD card and dmesg for 'read-only' messages. Man, this gets so booooooooring. 1
JohnQPublic Posted October 27, 2017 Author Posted October 27, 2017 Ah, I found a solution. I reformatted the sd card again and instead of using the display I used putty to first enter everything including h3disp settings that enable me to see what is going on and what it is asking. Thinking back I now recall that that was what I did a year ago when facing the same problem .
