Hello everyone, I own this android box
and I followed this tutorial https://ragone.dev/post/install-linux-on-android-tv-box which is based on tutorials on armbian website, I tried to install Armbian 25.8 server with Debian.
Everything went fine until the step "5. Flash Armbian to the internal eMMC", despite me running the install-aml.sh script and getting a complete message in the end (see following images for script execution output),
when I reboot it just always starts from the sd (see the following screenshot showing that the mounted storage is 16 GB, but my box internal storage is 8 GB).
fdisk -l output to also show the internal mmc (in the screen /dev/mmcblk1)
If I remove the sd and then turn it on, it is just stuck in a loop, having the following errors:
Can you please help me in solving this problem?
I already tried looking on the web and found these two topics:
https://github.com/ophub/amlogic-s9xxx-armbian/issues/3032
But they didn't help me.
Kind regards
The issue is that your u-boot can't read the emmc.  The linux kernel can since when it was run from your sd card you can access the emmc.  But after you have copied the install to emmc and then boot, the uboot is reporting it can't read the emmc.
There are instruction in /boot/build-u-boot for building the various uboots.  I would suggest you try building with a newer version of uboot.  What is currently shipped (the u-boot-s905x-s912 was built from uboot 2020-07 sources) so trying with newer uboot 2025-xx might provide better support for your specific emmc.
Hi @SteeMan thanks for your reply. I'm not sure I understand your suggestion, however, I tried going in /boot/build-u-boot and the instructions (file readme.txt in the very same folder) suggest that the latest available u-boot for my device (s905x) is indeed the one that I already have (2020.07 from march 2023).
The newer u-boot are for s905x2 or s905x3
@pochopsp You would need to use the information in that readme and patch and apply it to a newer u-boot (i.e port the patch to a newer u-boot) and build then a newer u-boot than the 2020.07 currently shipped.
Could you please be more explicit or point me to some tutorial? In the readme the only info I can see are how to build U-Boot for s905x in the version I already have, or newer but for different chips s905x2 and s905x3.
Thanks again for your help
@pochopsp - as you contacted me via message directly, let me respond here: i can only repeat what @SteeMan already said - you can either do your own research and experiments if you get some newer u-boot built and working (which will be a lot of learning and effort and can also fail in the end) or you accept that running from emmc will not work on your box and continue to use an sd card (which should work nearly as good as running from internal storage) - there is no easy tutorial to get it working, either it works out of the box (as the box is closer to one of the supported and tested ones) or you have to find your own way to get it working with those tv boxes ...
Thanks for the reply @hexdump , the thing I don't understand is that in the thread I mentioned in my first message to this thread :
the person claims to have successfully installed the OS on the internal eMMC on my very same box. Why running from eMMC wouldn't be possible on mine?
What I am afraid of is that maybe there is some information / log which might be important in the outputs I provided in my pictures in the first message which I fail to recognize.
About the message from @SteeMan I don't understand what he means by "and patch and apply it to a newer u-boot and build a newer u-boot"... In the /boot/build-u-boot/readme.txt file the instructions only have 3 different u-boots possible (s905x, s905x2 and s905x3) and all of them are like "git clone, run make" and that's it. Could you please be more explicit in what I should do or point me to some useful documentation?
Thanks a lot for your help.
@pochopsp - you can buy two tv-boxes of the same type at once from the same seller and they might have different hardware internally still - that is the reason why it is not prossible to provide really good images for tv boxes: the hardware is simply too random and often also low quality
Hi pochopsp - I have the same issue on my Vontar X3. The frustrating thing is that it used in the past and now for some reason it doesn't detect the eMMC installation anymore.
I haven't done a deep dive but probably (as the other participants in this thread suggest) it's only solvable with a new u-boot. Have you tried something out there?
I guess if we get a new build running that new u-boot could be bundled with the releases to solve this issue for other users as well
