AaronNGray Posted September 26, 2025 Posted September 26, 2025 (edited) I am using :- [ Ubuntu 24.04 (Noble)](https://dl.armbian.com/rock-5b-plus/Noble_vendor_server) from :- [Radxa Rock 5B Plus - Armbian](https://www.armbian.com/rock-5b-plus/) Trying to turn fan on on Radxa Rock 5B+ selecting the device using armbian-config actually makes it disappear Quote > cat usr/local/bin/test_fan_run.sh #!/bin/bash echo "Trun on Fan" echo 0 > /sys/devices/platform/fd8b0010.pwm/pwm/pwmchip0/export echo 10000 > /sys/devices/platform/fd8b0010.pwm/pwm/pwmchip0/pwm0/period echo 5000 > /sys/devices/platform/fd8b0010.pwm/pwm/pwmchip0/pwm0/duty_cycle echo normal > /sys/devices/platform/fd8b0010.pwm/pwm/pwmchip0/pwm0/polarity echo 1 > /sys/devices/platform/fd8b0010.pwm/pwm/pwmchip0/pwm0/enable I am getting `line 3: echo: write error:Device or resource busy` Edited September 26, 2025 by AaronNGray 0 Quote
e.j. Frölich Posted October 2, 2025 Posted October 2, 2025 I use the desktop version and have the same issue. 0 Quote
Igor Posted October 2, 2025 Posted October 2, 2025 2 hours ago, e.j. Frölich said: I use the desktop version HW (features are determined by kernel used in the image) related issues are shared among all variants, desktop, cli, minimal, Debian or Ubuntu. 0 Quote
AaronNGray Posted October 7, 2025 Author Posted October 7, 2025 (edited) I have the default radxa image rock-5b-plus_bookworm_kde_b2 image with the fan working :- https://github.com/radxa-build/rock-5b-plus/releases/download/rsdk-b2/rock-5b-plus_bookworm_kde_b2.output.img.xz I/We need to try and find how this was built and the Linux DTD file the `uname -a` kernel reports as "Linux rock-5b-plus 6.1.84-1-rk2410" kernel. rsetup :- https://docs.radxa.com/en/rock5/rock5b/getting-started/interface-usage/fan https://github.com/radxa-pkg/rsetup Edited October 7, 2025 by AaronNGray 0 Quote
AaronNGray Posted October 7, 2025 Author Posted October 7, 2025 From the Circuit Schematic it looks like the Radxa Rock 5B+ RK3588 GPIO0-C0 is the fan I/O, GPIO pin 24, if thats correct. I will verify I can access this on the Armbian distro. 0 Quote
AaronNGray Posted October 19, 2025 Author Posted October 19, 2025 Yeah fan working on :- https://github.com/radxa-build/rock-5b-plus/releases/download/rsdk-b2/rock-5b-plus_bookworm_kde_b2.output.img.xz 0 Quote
AaronNGray Posted October 24, 2025 Author Posted October 24, 2025 (edited) @Igor - Can you have a look at this please. I have retrieved the devicetree's for the radxa Debian release on which the fan works and my Armbian Ubuntu build using dtc -I fs /sys/firmware/devicetree/base uname -a lsb_release -a https://github.com/AaronNGray/radxa-rock-5b-plus The 'pwm-fan' nodes are the same. Edited October 24, 2025 by AaronNGray 0 Quote
Werner Posted October 25, 2025 Posted October 25, 2025 There is a minor difference in another node: "phandle = <0x2c2>;" in radxa.dts and phandle = <0x2c3>; No clue if that's the culprit or if there is something on software-side to make fan work. 0 Quote
usual user Posted October 25, 2025 Posted October 25, 2025 51 minutes ago, Werner said: No clue if that's the culprit A phandle is a magical number assigned during DTB assembly, whose value is irrelevant as long as it references the same node with the phandle property. The magic value can change when the structure changes because it is assigned arbitrarily; for example, by inserting an additional node. 0 Quote
