October 27, 20251 yr Hi Guys, I just did a new custom Armbian build ./compile.sh BOARD=orangepi5-plus BRANCH=vendor RELEASE=noble KERNEL_ONLY=yes KERNEL_CONFIGURE=no. The image is Armbian-unofficial_25.11.0-trunk_Orangepi5-plus_noble_vendor_6.1.115_cinnamon_desktop and when I installed it on orangepi I see it is not supporting Panfrost/Mail: glxinfo | grep -E "OpenGL renderer|OpenGL version" OpenGL renderer string: llvmpipe (LLVM 20.1.2, 128 bits) OpenGL version string: 4.5 (Compatibility Profile) Mesa 25.0.7-0ubuntu0.24.04.2 but for older image Old_Armbian-unofficial_25.08.0-trunk_Orangepi5-plus_noble_vendor_6.1.115_cinnamon_desktop All was well glxinfo | grep -E "OpenGL renderer|OpenGL version" OpenGL renderer string: Mali-G610 (Panfrost) OpenGL version string: 3.1 Mesa 25.0.7-0ubuntu0.24.04.2 I did need to enable "ARM Mail Display Processor" under Device Drivers -> Graphics support -> ARM devices before I perform custom build. And I did this for both OS version 25.11.0 and 25.08.0. But newer version is not able to use it. Thanks Manish
October 27, 20251 yr I suggest to build desktop images with ENABLE_EXTENSIONS=mesa-vpu to have necessary stuff built-in automatically.
October 29, 20251 yr @Werner, This is an Orange PI 5 Plus post. Wouldn't it belong in the Orange PI 5 Plus forum under Standard Support? https://forum.armbian.com/forum/250-orange-pi-5-plus/
October 29, 20251 yr 1 hour ago, The Tall Man said: t. Wouldn't it belong in the Orange PI 5 Plus forum under Standard Support? Yes, that's correct. Didn't pay attention. Thanks.
November 23, 2025Nov 23 I'm having the same problem with an official 25.8.2 / 6.1.115. It's a new build, jumping to today's 25.11.1 / 6.12.58 to see if it changes.
November 23, 2025Nov 23 I tested v25.11.1 https://www.armbian.com/orangepi-5/ released yesterday - vendor kernel, Gnome desktop, acceleration works, 4k video playing with Chromium, audio works ... Since I don't have model + right on hand, i didn't test it. But its very similar board and I assume it works. It should even boot with image for normal Opi 5 but all peripherals won't be working correctly.
November 23, 2025Nov 23 Bad News: same issue with 25.11.1 / 6.12.58, and a few others... Worse News: The issue affects all rk3588's (Orange Pi 5/5B/5+, Rock 5A/5B/5C, etc.). Good News: PR is a permanent fix for all images, and also identifies an immediate workaround that only requires a reboot (add "overlays=panthor-gpu" to /boot/armbianEnv.txt). https://github.com/armbian/build/pull/8979
November 24, 2025Nov 24 Digging deeper @Igor... I tried 25.11.1 Noble Gnome Vendor 6.1.115 from today, and am also seeing Mali-G610. However it's [disabled for xfce](https://github.com/armbian/build/blob/d2e208ace18b8003f926057ddfc038f8cce0bce0/extensions/mesa-vpu.sh#L19). I'm also reading some conflicting info so guessing there have been other conversations I'm not aware of. I started another post to try and better understand expectations.
November 24, 2025Nov 24 1 hour ago, gpupoor said: better understand expectations. afaik wayland is not supported in this version of xfce. You have to use Gnome or KDE.
