Posted (edited)
For those with a Radxa Cubie A7A/A7Z, I made a custom Armbian Build using the BSP kernel.
https://github.com/NickAlilovic/build/tree/Radxa-A7A
Now supports automatic first boot configuration by default. No need for a usb serial device to boot into a desktop image. First boot takes awhile to load. If you are using a server image you need a usb serial device/ssh to interact with the console. There is no Framebuffer console support in the BSP kernel.
If you want to edit the automatic first boot configuration read the documentation.
https://docs.armbian.com/User-Guide_Autoconfig/
Username: radxa
password: radxa
Edited by Nick A
Add a7z support
  • Nick A changed the title to Radxa Cubie A7A - Allwinner a733
Posted (edited)
Fixed the automatic first boot configuration on Bookwarm. Now you can boot the desktop image without a usb serial device.
Edited by Nick A
Hey @Nick A, first of all, thanks for providing us with the build, I flashed and tried the image, But I could not see kvm enabled in the system. Is this expected?
some example outputs:
~$ ls -l /dev/kvm
ls: cannot access '/dev/kvm': No such file or directory
~$ sudo dmesg | grep -i kvm
[    0.184039] kvm [1]: HYP mode not available
also no output on
lscpu | grep Virtualization
Posted (edited)
@zmxyz I added support for A7Z. But I haven't tested it yet. I don't own a A7Z. Compile an image and let me know if it works.
Edited by Nick A
  • Nick A changed the title to Radxa Cubie A7A/A7Z - Allwinner a733
Posted (edited)
@Gavin Munday Did you compile a desktop or server image? Did you write the image onto a reliable sdcard? Remember there’s no framebuffer support. Server images need a usb to serial device attached to the UART. Having a usb serial device attached to the UART helps with these types of problems.
https://docs.radxa.com/en/cubie/a7a/system-config/uart_debug
Also, first boot might take awhile to boot. For desktop images wait at least 5 minutes for a display manager login screen.
Edited by Nick A
