After updating the edge kernel to 6.17, and then to 6.18-rc, the performance of my ODroid-N2 dropped drastically.
Here are the performance test results of 7zip with different kernel versions for comparison
I compile the kernel myself using the armbian build system and install the resulting .deb.
'7z b'
7-Zip 23.01 (arm64) : Copyright (c) 1999-2023 Igor Pavlov : 2023-06-20
 64-bit arm_v:8 locale=en_GB.UTF-8 Threads:6 OPEN_MAX:1024
Compiler: 13.2.0 GCC 13.2.0
Linux : 6.16.6-edge-meson64 : #1 SMP PREEMPT Tue Sep  9 17:02:41 UTC 2025 : aarch64
PageSize:4KB THP:always hwcap:8FF:CRC32:SHA1:SHA2:AES:ASIMD
LE
1T CPU Freq (MHz):  1901  1897  1904  1904  1904  1904  1903
3T CPU Freq (MHz): 298% 1894   298% 1892
RAM size:    3769 MB,  # CPU hardware threads:   6
RAM usage:   1334 MB,  # Benchmark threads:      6
                       Compressing  |                  Decompressing
Dict     Speed Usage    R/U Rating  |      Speed Usage    R/U Rating
         KiB/s     %   MIPS   MIPS  |      KiB/s     %   MIPS   MIPS
22:       7244   525   1343   7048  |     136762   553   2109  11660
23:       6896   533   1317   7026  |     128222   535   2071  11092
24:       6626   539   1323   7124  |     114197   478   2096  10021
25:       6170   542   1301   7045  |     121553   536   2020  10818
Avr:      6734   535   1321   7061  |     125184   526   2074  10898
Tot:             530   1698   8979
Linux : 6.18.0-rc7-edge-meson64 : #1 SMP PREEMPT Sun Nov 23 22:53:16 UTC 2025 : aarch64
LE
1T CPU Freq (MHz):  1966  1985  1732  1940  1979  1946  1486
3T CPU Freq (MHz):  64% 424    97% 641
RAM size:    3773 MB,  # CPU hardware threads:   6
22:       1045    85   1191   1018  |      20252    91   1903   1727
23:       1078    90   1218   1099  |      18815    86   1889   1628
24:       1100    93   1274   1183  |      19644    92   1880   1724
25:        914    78   1332   1044  |      19697    94   1873   1753
Avr:      1034    87   1253   1086  |      19602    91   1886   1708
Tot:              89   1570   1397
I have done similar tests on ODroid-M1 (rockchip), but nothing similar happens there.
What could be the reason?
Is see no significant differences:
ssd-006
Hardkernel ODROID-N2Plus
CPU 0-1: performance 1000 MHz - 2016 MHz
CPU 2-5: performance 1000 MHz - 2400 MHz
GPU: performance 124 MHz - 799 MHz
6.16.0-0.rc1.17.fc43.aarch64 #1 SMP PREEMPT_DYNAMIC Sat Jun 14 11:19:02 CEST 2025
7z b
7-Zip 24.09 (arm64) : Copyright (c) 1999-2024 Igor Pavlov : 2024-11-29
 64-bit arm_v:8-A locale=en_US.UTF-8 Threads:6 OPEN_MAX:1024
Compiler:  ver:15.2.1 20250924 (Red Hat 15.2.1-2) GCC 15.2.1 : UNALIGNED
Linux : 6.16.0-0.rc1.17.fc43.aarch64 : #1 SMP PREEMPT_DYNAMIC Sat Jun 14 11:19:02 CEST 2025 : aarch64
PageSize:4KB THP:madvise hwcap:8FF:CRC32:SHA1:SHA2:AES:ASIMD
arm64
1T CPU Freq (MHz):  2092  2387  2384  2390  2361  2389  2388
3T CPU Freq (MHz): 282% 2239   296% 2352..
6T CPU Freq (MHz): 538% 2040   497% 1893..
RAM size:    3740 MB,  # CPU hardware threads:   6
22:       7107   508   1362   6914  |     141426   488   2473  12058
23:       6459   494   1332   6581  |     136949   489   2421  11847
24:       6268   508   1327   6740  |     132118   485   2390  11593
25:       5695   515   1264   6503  |     127085   483   2343  11310
Avr:      6382   506   1321   6684  |     134394   486   2407  11702
Tot:             496   1864   9193
ssd-006
6.18.0-0.rc3.30.fc44.aarch64 #1 SMP PREEMPT_DYNAMIC Mon Oct 27 21:17:35 CET 2025
7z b
Linux : 6.18.0-0.rc3.30.fc44.aarch64 : #1 SMP PREEMPT_DYNAMIC Mon Oct 27 21:17:35 CET 2025 : aarch64
arm64
1T CPU Freq (MHz):  2365  2380  2383  2390  2389  2391  2388
3T CPU Freq (MHz): 277% 2162   274% 2095..
6T CPU Freq (MHz): 533% 2021   508% 1926..
RAM size:    3737 MB,  # CPU hardware threads:   6
22:       6924   491   1373   6737  |     136783   473   2465  11662
23:       6586   495   1356   6711  |     141391   506   2418  12232
24:       6240   494   1359   6709  |     138310   510   2382  12137
25:       5912   507   1330   6750  |     127792   487   2337  11373
Avr:      6415   497   1355   6727  |     136069   494   2401  11851
Tot:             495   1878   9289
