Eddy_T Posted March 1, 2018 Posted March 1, 2018 I followed balbes instructions and successfully copied the system from my USB drive to the eMMC. Removed the drive and rebooted and all started well and the system was up. I then edited fstab to add a line for automounting a usb HD (which worked well when running on the flash drive). I also did modeprobe wifi_dummy and found the names of the modules which I added to the modules file. Now when I rebooted the system, it went into emergency mode. Here are some questions for those who have tried this: Here are some important questions: 1- is it not possible to edit fstab once the system is running from FLASH? 2- How to automatically run the modprobe wifi_dummy command so that the wifi works on bootup? 3- is it possible to run apt-get update && apt-get upgrade && apt-get dist-upgrade while running from NAND? 4- can the swap partition be moved to the external USB disk drive? 5- is there an easy way to let the system install all new software (like lamp) on the USB drive Thanks again! At least i am still alive.. hardly breathing though
balbes150 Posted March 2, 2018 Posted March 2, 2018 16 hours ago, Eddy_T said: I followed balbes instructions and successfully copied the system from my USB drive to the eMMC. Removed the drive and rebooted and all started well and the system was up. I then edited fstab to add a line for automounting a usb HD (which worked well when running on the flash drive). I also did modeprobe wifi_dummy and found the names of the modules which I added to the modules file. Now when I rebooted the system, it went into emergency mode. Here are some questions for those who have tried this: Here are some important questions: 1- is it not possible to edit fstab once the system is running from FLASH? 2- How to automatically run the modprobe wifi_dummy command so that the wifi works on bootup? 3- is it possible to run apt-get update && apt-get upgrade && apt-get dist-upgrade while running from NAND? 4- can the swap partition be moved to the external USB disk drive? 5- is there an easy way to let the system install all new software (like lamp) on the USB drive Thanks again! At least i am still alive.. hardly breathing though Don't create doubles in different themes.
Tido Posted April 14, 2018 Author Posted April 14, 2018 Hi @balbes150, I have installed some Add-ons to Kodi and I wanted to make use of the remote-control RC6 (Gateway). Reading in the main thread I found that due to dtb the remote will not work on my image. I have this running on eMMC: Armbian_5.41_S9xxx_Ubuntu_xenial_3.14.29_mate_20180216.img I have questions: If I do apt-get update && apt-get upgrade, will it also update the dtb & Kodi ? If above update does not work, is there a trick to copy all Add-ons to the fresh install ? Thank you
balbes150 Posted April 16, 2018 Posted April 16, 2018 On 14.04.2018 at 12:25 PM, Tido said: I have installed some Add-ons to Kodi and I wanted to make use of the remote-control RC6 (Gateway). Reading in the main thread I found that due to dtb the remote will not work on my image. I have this running on eMMC: Armbian_5.41_S9xxx_Ubuntu_xenial_3.14.29_mate_20180216.img I have questions: If I do apt-get update && apt-get upgrade, will it also update the dtb & Kodi ? If above update does not work, is there a trick to copy all Add-ons to the fresh install ? Thank you The remote control requires a configuration file (which must be located in /boot/remote.conf). Commands do not update the kernel, dtb, and KODI.
Tido Posted May 10, 2018 Author Posted May 10, 2018 On 4/16/2018 at 10:47 AM, balbes150 said: The remote control requires a configuration file (which must be located in /boot/remote.conf) I know, I read that. As I wrote I have a Microsoft MCE-RC6 remote which is very common. However, I read this: For KODI & LibreELEC I read that the keymaps for this remote-control are already integrated, but my remote does not work. What do you use in your image: LIRC where a separate program, lircd, decodes the IR signals ? Modern Linux kernels, like the ones used in LibreELEC, have built-in support for IR remotes ? I found this for MCE-RC6 torvalds keymaps/rc-rc6-mce.c In which direction shall I search: KODI-Wiki or LibreELEC ??
balbes150 Posted May 11, 2018 Posted May 11, 2018 There is a great variety of different builds of KODI and Libreelec for different platforms (x86 , ARM, etc) and different models. This is a different system, description, for some not suitable to others. To operate your remote control, you need a settings file. See the example files (remote.conf) on a recorded medium. For KODI-17 from the composition of Armbian, the file must match the format of the driver amremote. For KODI-18, this is a different format (lirc). 1
Tido Posted May 11, 2018 Author Posted May 11, 2018 The service is running Spoiler root@amlogic:~# service amlogic-remotecfg status ● amlogic-remotecfg.service - Amlogic IR remote support Loaded: loaded (/usr/lib/systemd/system/amlogic-remotecfg.service; enabled; vendor preset: enabled) Active: active (exited) since Fri 2018-05-11 07:08:48 UTC; 4h 23min ago Process: 3218 ExecStart=/usr/lib/libreelec/remote-config (code=exited, status=0/SUCCESS) Main PID: 3218 (code=exited, status=0/SUCCESS) CGroup: /system.slice/amlogic-remotecfg.service May 11 07:08:47 amlogic remote-config[3218]: debug_enable = 0x0 May 11 07:08:47 amlogic remote-config[3218]: fn_key_scancode = 27 May 11 07:08:47 amlogic remote-config[3218]: left_key_scancode = 28 May 11 07:08:47 amlogic remote-config[3218]: right_key_scancode = 72 May 11 07:08:47 amlogic remote-config[3218]: up_key_scancode = 68 May 11 07:08:47 amlogic remote-config[3218]: down_key_scancode = 29 May 11 07:08:47 amlogic remote-config[3218]: ok_key_scancode = 92 May 11 07:08:47 amlogic remote-config[3218]: pageup_key_scancode = 5 May 11 07:08:47 amlogic remote-config[3218]: pagedown_key_scancode = 89 May 11 07:08:48 amlogic systemd[1]: Started Amlogic IR remote support. cat /proc/bus/input/devices root@amlogic:~# cat /proc/bus/input/devices I: Bus=0010 Vendor=0001 Product=0001 Version=0100 N: Name="aml_keypad" P: Phys=keypad/input0 S: Sysfs=/devices/meson-remote.11/input/input0 U: Uniq= H: Handlers=sysrq kbd mouse0 event0 B: PROP=0 B: EV=f B: KEY=7fffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff fffffffffffffffe B: REL=103 B: ABS=0 How do I find out if the software can talk to the IR-receiver ? In the configuration file I saw these lines and I guess I have to adjust it to LePotato... # factory_code each device has it's unique factory code. # pattern:custom_code(16bit)+index_code(16bit) # example: 0xff000001 = 0xff00(custom cod) 0001 (index) but how do I find this ?
Tido Posted May 11, 2018 Author Posted May 11, 2018 (edited) I have tried all (3) available in /boot/, I have renamed each to /boot/remote.conf one after the other, did a: service amlogic-remotecfg stop service amlogic-remotecfg start klicked with the remote, nothing happend on the Monitor. Looked at dmesg -c nothing. How can I test if the IR-Receiver works (devicetree activated?) ? Edit: I read in a WETEK forum about LG remote-control, so I grab my LG remote and try: root@amlogic:~# dmesg [ 8082.947291] remote: Wrong custom code is 0xbf40fb04 but I wanted to use the mce.. mission impossible ? Edited May 11, 2018 by Tido LG remote works
Tido Posted May 11, 2018 Author Posted May 11, 2018 (edited) Hi @balbes150, I am running Armbian_5.41_S9xxx_Ubuntu_xenial_3.14.29_mate_20180307.img with this device tree: gxl_p212_2g_lepotato.dtb Why is the System Load so high ? Welcome to ARMBIAN 5.41 user-built Ubuntu 16.04.4 LTS 3.14.29 System load: 1.26 1.18 1.10 Up time: 2:41 hours Memory usage: 10 % of 1784MB IP: 192.168.11.10 CPU temp: 49°C Usage of /: 10% of 29G With my the remote of my LG TV ( of 2011) I can use the navigation buttons (most japanese companies support NEC protocol, whereas RC-5 and RC-6 is from Philips): Spoiler factory_code = 0xfb040001 work_mode = 0 repeat_enable = 1 release_delay = 150 debug_enable = 1 reg_control = 0xfbe40 key_begin 0xca 116 ;POWER 0x07 105 ;KEY_LEFT 0x06 106 ;KEY_RIGHT 0x40 103 ;KEY_UP 0x41 108 ;KEY_DOWN 0x44 28 ;KEY_ENTER 0x5b 102 ;KEY_HOME 0x09 113 ;KEY_MUTE 0x03 114 ;KEY_VOLUMEDOWN 0x02 115 ;KEY_VOLUMEUP 0x28 14 ;KEY_BACKSPACE 0x72 59 ;KEY_F1 0x71 60 ;KEY_F2 0x63 61 ;KEY_F3 0x61 62 ;KEY_F4 0x10 11 ;KEY_0 0x11 2 ;KEY_1 0x12 3 ;KEY_2 0x13 4 ;KEY_3 0x14 5 ;KEY_4 0x15 6 ;KEY_5 0x16 7 ;KEY_6 0x17 8 ;KEY_7 0x18 9 ;KEY_8 0x19 10 ;KEY_9 0xb0 164 ;KEY_PLAYPAUSE 0xb1 128 ;KEY_STOP 0x1e 0x16c ;KEY_FAV key_end Edited May 12, 2018 by Tido NEC, RC-6
balbes150 Posted May 12, 2018 Posted May 12, 2018 13 hours ago, Tido said: I have renamed each to /boot/remote.conf one after the other, did a: To operate the remote control, you need your own settings file. The image contains files for TV boxes remote control models with the specified names. They're not right for you. You need to create or find a settings file for your remote control model. 12 hours ago, Tido said: Why is the System Load so high ? This is a special feature of this variant of the kernel (change in the driver settings for LE). Have you tried the latest version (from the "no-mali" directory) with kernel 4.16 ? Does sound work on your model ?
Tido Posted May 12, 2018 Author Posted May 12, 2018 (edited) 13 hours ago, balbes150 said: Have you tried the latest version (from the "no-mali" directory) with kernel 4.16 ? I have not, I am still on Armbian_5.41_S9xxx_Ubuntu_xenial_3.14.29_mate_20180307.img. no-mali is this good, video needs VPU or am I wrong ? 13 hours ago, balbes150 said: Does sound work on your model ? I tried Audio-Jack, doesn't work. I want to try HDMI audio later. I have now tested HDMI - when I navigate it makes the clicking sound = it works How can I return from KODI to standard Mate desktop ? Edited May 12, 2018 by Tido sound via HDMI works
balbes150 Posted May 14, 2018 Posted May 14, 2018 On 5/12/2018 at 11:23 AM, Tido said: How can I return from KODI to standard Mate desktop ? The choice of shell to start (Mate\XFCE or KODI). On the screen enter username and password (in lightdm) in the upper right corner of the screen there is a menu where you choose which GUI to run. The list will be three items (two rows with kodi) and the last line mate. Select mate (something opposite mate was the point), then enter the username and password. The system remembers the last selected mode. If at the next login or what not to choose in this menu, system at the entrance will trigger the option that was turning off in the previous session.
Tido Posted May 14, 2018 Author Posted May 14, 2018 after you didn't answer me for a bit of time I came up with the idea to search in this Thread, however I was looking for something like: Ctrl + Alt + Backspace to restart X. When I jump around too fast the audio hangs and won't stop to repeat the clicking-sound. Playing a movie or YouTube doesn't work then neither. What is the difference between Mali-5, Mali-6, Mali-7 did you already explain that?
balbes150 Posted May 15, 2018 Posted May 15, 2018 19 hours ago, Tido said: after you didn't answer me for a bit of time I came up with the idea to search in this Thread, however I was looking for something like: Ctrl + Alt + Backspace to restart X. When I jump around too fast the audio hangs and won't stop to repeat the clicking-sound. Playing a movie or YouTube doesn't work then neither. What is the difference between Mali-5, Mali-6, Mali-7 did you already explain that? These are different versions of KODI and different versions of libMali (5, 6, 7) or build without libMali .
PhracturedBlue Posted September 5, 2018 Posted September 5, 2018 Sorry to revive this topic after many months, but are there recent instructions to copy Armbian to the eMMC? When I boot with the eMMC installed, it boots into Android. If I look at the SD card, I have ls -ld /boot lrwxrwxrwx 1 root root 18 Aug 25 13:17 dtb -> dtb-4.18.5-meson64 drwxr-xr-x 3 root root 4096 Jul 24 12:06 dtb-4.14.57-meson64 drwxr-xr-x 3 root root 4096 Aug 25 13:17 dtb-4.18.5-meson64 lrwxrwxrwx 1 root root 19 Jul 24 12:06 dtb.old -> dtb-4.14.57-meson64 I don't see a dtb.img to remove. How can I boot into armbian with the eMMC module installed?
Tido Posted September 5, 2018 Author Posted September 5, 2018 @PhracturedBlue , start reading on page 2 my first post until you come back here. Balbes150 images offers dual boot and once this works you can flash it on the eMMC. I have never used the armbian How to install to eMMC, NAND, SATA & USB? https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb
PhracturedBlue Posted September 5, 2018 Posted September 5, 2018 @Tido, thanks. I was hoping there were instructions that would let me work directly with Armbian. I need to run a nightly kernel. I am unsure whether I can intsall @Balbes150's image and then install a kernel on top of it (from eMMC) since it won't have the right dtb. I don't suppose Balbes150 has instructions on builiding his kernel? or is it all in the dtb and if I copy that from one of his images, it will be enough? I'll give it a shot.
PhracturedBlue Posted September 7, 2018 Posted September 7, 2018 Here is my current progress... Note: I have not yet been able to boot directly from the emmc into Armbian. I was not able to get balbes150's images to boot with emmc installed. Not sure why, but it wasn't too interesting to me since I want to run a 4.17 kernel. I was able to boot into a current armbian (via SSD) with the emmc module enabled via: 1) install armbian to an sd-card, boot and configure without emmc installed 2) connect a serial UART connecton to the UART pins on the le potato (baud 115200) 3) boot or reboot le-potato (still without emmc) 4) press enter several times in serial-console to enter u-boot prompt 5) install emmc module (while in u-boot prompt) 6) type 'run distro_bootcmd' in serial console to load armbian from sd-card This at least gets me a current armbian env with the emmc available: Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 0 8191 8192 4M 83 Linux /dev/mmcblk0p2 73728 204799 131072 64M 83 Linux /dev/mmcblk0p3 221184 1269759 1048576 512M 83 Linux /dev/mmcblk0p4 1269760 25800703 24530944 11.7G 5 Extended /dev/mmcblk0p5 1286144 1302527 16384 8M 83 Linux /dev/mmcblk0p6 1318912 1384447 65536 32M 83 Linux /dev/mmcblk0p7 1400832 1466367 65536 32M 83 Linux /dev/mmcblk0p8 1482752 1499135 16384 8M 83 Linux /dev/mmcblk0p9 1515520 1531903 16384 8M 83 Linux /dev/mmcblk0p10 1548288 1613823 65536 32M 83 Linux /dev/mmcblk0p11 1630208 1695743 65536 32M 83 Linux /dev/mmcblk0p12 1712128 1777663 65536 32M 83 Linux /dev/mmcblk0p13 1794048 5988351 4194304 2G 83 Linux /dev/mmcblk0p14 6004736 30535679 24530944 11.7G 83 Linux Looking at the u-boot code from armbian, I am not sure it will be able to boot emmc without modification. It seems to only load from mmc or usb...I think we need to boot from emmc? I have to play with it some more. Alternatives are to try to use use the existing u-boot on the emmc, or to use balbes150's u-boot with a FAT fs... I am currently going through the nand-sata-install script to make sure it isn't likley to break anything before I try it. One thing I am happy to see...The EMMC is much faster than the fastest sd card I have. Comparison: EMMC: | | Read(MB/s)|Write(MB/s)| |------|-----------|-----------| |Seq1M | 75.438| 41.317| |Seq32M| 80.075| 43.023| | 512K | 72.856| 39.066| | 4K | 14.463| 15.634| SD (Samsung Extreme 16GB) | | Read(MB/s)|Write(MB/s)| |------|-----------|-----------| |Seq1M | 21.873| 14.821| |Seq32M| 21.917| 15.424| | 512K | 21.121| 12.297| | 4K | 7.578| 0.926| Same SD card (Sandisk Extreme 16GB) in PC on USB3 port: | | Read(MB/s)|Write(MB/s)| |------|-----------|-----------| |Seq1M | 72.737| 48.762| |Seq32M| 72.847| 49.757| | 512K | 67.712| 32.398| | 4K | 6.694| 0.750| So we can see that the emmc provides massively improved sequential and random-access performance on the le potato.
Tido Posted September 7, 2018 Author Posted September 7, 2018 On 9/5/2018 at 8:40 AM, Tido said: Balbes150 images offers dual boot I guess you came across his first post: https://forum.armbian.com/topic/2419-armbian-for-amlogic-s905-and-s905x/ Once you have multiboot, you can backup the eMMC (especially the dtb), then copy Balbes armbian on eMMC and now you can tweak it how you like it. eMMC needs many partitions, I don't know why. 1
PhracturedBlue Posted September 8, 2018 Posted September 8, 2018 9 hours ago, Tido said: I guess you came across his first post: https://forum.armbian.com/topic/2419-armbian-for-amlogic-s905-and-s905x/ Once you have multiboot, you can backup the eMMC (especially the dtb), then copy Balbes armbian on eMMC and now you can tweak it how you like it. eMMC needs many partitions, I don't know why. Thanks @Tido I did indeed miss that. Thta would probably be the easiest way to get this working. I, however, tend to prefer the hard way. Balbes appears to be working with the legacy uboot shipped by Amlogic. Armbian is using 2018.05 (probably soon to be 2018.07) which actually has mainline support for the le potato. I'd much prefer to use the more modern version (that also doesn't require all those partitions). I'm going to continue trying to figure out what that will take
Tido Posted September 8, 2018 Author Posted September 8, 2018 I don't know and don't care so much about the u-Boot as long as it works as expected. Balbes images are based on armbian 5.59 and Kernel 4.18 https://yadi.sk/d/pHxaRAs-tZiei/5.59/20180829 And as I wrote before, with Multiboot you can boot from every source obviously which might be useful doing it the hardway ;-) 1
PhracturedBlue Posted September 8, 2018 Posted September 8, 2018 Thanks again @Tido. I ended up using that image to install multiboot, which was indeed very helpful. While the install.sh script included won't work as is (need to change some paths since it is setup to install on mmc1), and the install.sh from 3.14 won't work with this image because the /dev paths are completely different, this was really helpful to understand how the boot process and upgrade works. In the end, I didn't use Balbes's boot at all. His multboot isn't compatible with stock Armbian, and whle it is probably possible to write an aml_autoscript which would work, I didn't bother. Here is my process of installing a stock Armbian system on a Le Potato's EMMC. The nand-sata-install almost works properly, I'm not sure if the issue is in u-boot or armbian, but I'll try to file a bug when I figure out where. This process gives full access to the full EMMC (The legacy u-boot wastes ~3GB in random partitions). Note that because these steps erase all of the partitions, it would be challenging to go back to Android in the future. 1) put Armbian official 'le potato' image on sd card 2) install sd card into le-potato and remove emmc 3) install UART onto 'le potato' and connect to PC @ 115200 baud 4) power up le potato 5) press enter several times in serial terminal to enter u-boot 6) install emmc 7) type 'run distro_bootcmd' in serial terminal 8) boot into Armbian...setup root and user, etc 9) sudo cfdisk /dev/mmcblk0 9a) remove all partitions. 9b) create a single linux partition (type 83) that fills the whole disk 9c) write changes 10) ls -l /dev/mmcblk0* and ensure you do not see mmcblk0p2-p14 10a) if you see any partitions (/dev/mmcblk0p2-p14) you need to reboot and go through steps 4-8 again 11) sudo nand-sata-install 11a) select emmc 11b) select ext4 11c) let the installation complete 11d) complete but DO NOT REBOOT 12) sudo mount /dev/mmcblk0p1 /mnt 13) sudo sh -c 'echo "bloader=ext4load mmc 1:1" >> /boot/armbianEnv.txt' 14) shutdown, remove sd card and reboot steps 11d-13 are needed because u-boot 2018.05 sets 'bloader=ext4load mmc 0:1' which forces booting the sdcard. This should ideally be calculated in either armbian's boot.scr or in u-boot itself
PhracturedBlue Posted September 8, 2018 Posted September 8, 2018 Here is an alternative solution that doesn't require a UART...i didn't test these exact steps, but I believe they should work. Again, note that step (5) will make it impossible to boot back to Android OR to mount Balbes's images onto EMMC 1) install Balbes's 5.59 debian-stretch-default onto USB/SD( it is important to use a 4.xx kernel for this method!): https://yadi.sk/d/pHxaRAs-tZiei/5.59/20180829 2) Follow his instructions to setup multiboot: https://forum.armbian.com/topic/2419-armbian-for-amlogic-s905-and-s905x/ 3) Reboot into armbian 4) From armbian, download the official 'Le Potato image' ( You could also put this on a second USB drive and mount it in Armbian) 5) Copy the image onto EMMC: sudo dd if=<path to armbian.img> of=/dev/mmcblk0 bs=4096 status=progress 6) Fixup armbianEnv.txt: 6a) sudo mount /dev/mmcblk0p1 /mnt 6b) sudo sh -c 'echo "bloader=ext4load mmc 1:1" >> /boot/armbianEnv.txt' 7) remove USB/SD and reboot
MartijnB Posted October 23, 2018 Posted October 23, 2018 I recently purchased a Libre Compter AML-S905 SBC and installed Armbian- 5.60 stable (stretch) with 4.18.8-meson64 kernel on both the SD card and a eMMC disk. I used armbian-config to copy the OS to the eMMC. After modification of armbianEnv.txt on the SD card, I can boot into the eMMC, but only with the SDcard installed. After reading several threads on u-boot and eMMC I am still somewhat confused. To investigate whether I have a bootloader on the eMMC disk, I dd-ed the first sectors of the eMMC to a file an compared it to /usr/lib/linux-u-boot-next-lepotato_5.6_arm64/u-boot.bin, and they look similar. Then I tried to copy /usr/lib/linux-u-boot-next-lepotato_5.6_arm64/u-boot.bin to the eMMC disk, as shown in https://github.com/BayLibre/u-boot/tree/readme dd if=u-boot.bin of=/dev/mmcblk0 bs=512 seek=1 But then the system did not boot either and my eMMC partition table was gone. Using testdisk, I could restore my partition table. Now I am wondering how to get u-boot on my eMMC, and I have number of questions. Can the u-boot provided with the last armbian images boot from a eMMC? (no) Do I need the latest u-boot from github (https://github.com/BayLibre/u-boot/tree/readme) to get eMMC booting? I am not looking forward to setup cross compilation on my desktop... Do I need multiboot or Balbes Debian image to proceed from where I am? I assume that I only need step 6 from the guide above, since I copied the official image using armbian-config. Does step 5 also include the bootloader? If so, why doesn't armbian-config not does something similar to get a proper bootloader on the eMMC disk? I don't understand 6 above. While running from SD card, the eMMC is mounted but armbinaEnv.txt from the SD card is modified. Is there a working u-boot.bin that can be dd-ed to my eMMC? Are there more steps required, e.g. compiling zimages or something to make sure u-boot can find the kernel? Help is appreciated. I have been running linux for years at home and have done quite some playing with partitions and bootloaders, but this u-boot thing confuses me.
sbc_chrisb Posted November 15, 2018 Posted November 15, 2018 So, I've been fighting with getting a working Armbian install on my eMMC for almost a week now. I should also mention I have a serial console hooked up, so I am working strictly over the serial debug console. I've ruled out power issues, and here's the problem I'm at now. I used balbes' latest image to create a bootable SD card. I can boot with that card. I ended up only having success by using the nand-sata-install command once I had gotten booted into that version of armbian. I mounted the eMMC and verified the boot files, and then reboot without the SD card present in order to boot straight from eMMC. The kernel gets to remounting the root filesystem and just hangs. The last message is: [ 4.062163] [drm] Cannot find any crtc or sizes It just sits there. If, at this point, I insert the SD card, the system sees it, and mounts that card as root and boot. So, my system is then running only on the SD card, again. I've tried a few things with changing the fstab on the emmc to use the /dev/mmcblk1p2 for root instead of LABEL= as well as for /boot, figuring it was that old bug that prevented mounting with labels. It's not that. I also tried changing the boot/uEnv.ini file to use the /dev/ device rather than the label, still no luck. It just will not mount the mmc as the root file system. Not sure what info is needed to proceed. I also gave the above bloader line a spin in armbianEnv.txt but it didn't help anything. Any one have any ideas here? Is there another file I need to modify to boot solely from the eMMC?
TonyMac32 Posted November 15, 2018 Posted November 15, 2018 This should just need a bootscript update to work properly under standard Armbian. I ran nand-sata-install and the board boots, but the script isn't ready for it and tries to load everything from SD even though it doesn't exist. [update] https://github.com/armbian/build/commit/cfd8a8956814a2f9da465769c1f9f5ad49e369cc This boot script takes care of eMMC and has overlays baked in, that I need to experiment with/test. File size set to 102400 kB Record Size 4 kB Record Size 16 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 102400 4 14931 15285 18479 21632 17644 13118 102400 16 20817 25509 43118 43201 39345 23868 102400 512 26357 26404 76260 76124 76281 26328 102400 1024 27718 27917 77808 77832 77815 27793 102400 16384 27825 28640 81196 81216 81233 28761
sbc_chrisb Posted November 15, 2018 Posted November 15, 2018 Thanks for the update. I copied the file linked and pasted it into my emmc boot as boot.cmd, then ran mkimage to generate the scr. Unfortunately, I'm still getting the previous results. I then re-ran the nand-sata-install command to clear the emmc back to a default state before any of my tinkering, and tried again. Still stops at remounting root fs. Is there a direct link to an image for the version of armbian you are using here that I can plop onto my SD card to try booting from? I am currently using the images from balbes, and I don't know if that's configured differently. I'd like to just use whatever image you're reporting success with here.
TonyMac32 Posted November 15, 2018 Posted November 15, 2018 2 hours ago, sbc_chrisb said: I am currently using the images from balbes, and I don't know if that's configured differently. I'd like to just use whatever image you're reporting success with here. I am using the image family you would find on the Armbian download page, you are correct that the configuration of Balbes' images are different. Whenever the next round of images are made this update will be included.
TonyMac32 Posted November 15, 2018 Posted November 15, 2018 Also forgot, you need to run the command that is commented in the bottom of the cmd file to create a script file out of it Sent from my Pixel using Tapatalk
