nachoparker 10 Posted November 22, 2017 Share Posted November 22, 2017 Hello everyone First congratulations for this project. I just started playing with it recently and I am very impressed. Good job! I am the developer of NextCloudPi, which basically consists on providing Nextcloud images for the Raspberry Pi, but has evolved to other flavours such as docker x86 and docker ARM. It also features many scripts for managing the instance that can be run from a classic whiptail like TUI or a simple web interface. The initial goal of the project is to drive as many people away from dropbox into selfhosting, so there's also a Wizard and I try to ease the process of DDNS, certificates and so on. I am after porting it to more powerful boards, so I adapted my build scripts for Armbian and I would like to share them here. I generated a first version of the SD armbian based image for the odroid HC1/X4, that you can find here. If anyone would be interested on trying this and even better help me adapt it further for performance and polish that would be fantastic The build code that I use to produce it is git clone https://github.com/armbian/build ncpbian cd ncpbian wget https://raw.githubusercontent.com/nextcloud/nextcloudpi/master/armbian.sh -O userpatches/customize-image.sh ./compile.sh docker BOARD=odroidxu4 BRANCH=next KERNEL_ONLY=no KERNEL_CONFIGURE=no RELEASE=stretch BUILD_DESKTOP=no NextCloudPi can be installer on any Debian Stretch system with curl -sSL https://raw.githubusercontent.com/nextcloud/nextcloudpi/master/install.sh | bash That script has been tested on Debian x86 servers and also a rock64 (@inos tested it) and an odroid HC1 (and rpi too). Now what I do for the SD images is basically that with a couple adjustments inside customize-image.sh Some issues that I found, maybe you have suggestions the most annoying one: there's about four places where the build process clones from git. There is around a 50% chance that the process will get just stuck there and I have to start over. This means that I sometimes have to try up to five times for the build to finish. Running top inside the container gives 1 root 20 0 21620 5104 2920 S 0.0 0.1 0:00.45 /bin/bash /root/armbian/compile.sh docker-guest BOARD=odroidxu4 BRANCH=next KERNEL_ONLY=no KERNEL_CONFIGURE=no RELEASE=stretch BUILD_DESKTOP=no CLEAN_LEVEL= NO_APT_CACHE+ 9945 root 20 0 4116468 9368 4364 S 0.0 0.1 0:00.16 /usr/bin/qemu-arm-static /bin/bash /tmp/customize-image.sh stretch odroidxu4 odroidxu4 no 9958 root 20 0 4116468 9500 4356 S 0.0 0.1 0:00.28 /usr/bin/qemu-arm-static /bin/bash 10356 109 20 0 4659004 106464 14556 S 0.0 1.3 0:01.66 /usr/bin/qemu-arm-static /usr/sbin/mysqld 13408 root 20 0 4116468 8408 3096 S 0.0 0.1 0:00.10 /usr/bin/qemu-arm-static /bin/bash 14636 root 20 0 4116468 11312 4452 S 0.0 0.1 0:00.12 /usr/bin/qemu-arm-static /bin/bash /usr/local/bin/ncp-update 14668 root 20 0 4116468 9488 4368 S 0.0 0.1 0:00.25 /usr/bin/qemu-arm-static /bin/bash ./update.sh 18087 root 20 0 4116468 8004 2788 S 0.0 0.1 0:00.03 /usr/bin/qemu-arm-static /bin/bash ./update.sh 18929 root 20 0 4116468 9928 4776 S 0.0 0.1 0:00.17 /usr/bin/qemu-arm-static /usr/bin/git clone https://github.com/letsencrypt/letsencrypt 18932 root 20 0 4182572 35188 8016 S 0.0 0.4 0:02.04 /usr/bin/qemu-arm-static /usr/lib/git-core/git-remote-https origin https://github.com/letsencrypt/letsencrypt 18936 root 20 0 4182544 12032 4596 S 0.0 0.2 0:00.24 /usr/bin/qemu-arm-static /usr/lib/git-core/git fetch-pack --stateless-rpc --stdin --lock-pack --thin --check-self-contained-and-connected --cloning https://github.com/le+ 18940 root 20 0 4182544 8980 1416 S 0.0 0.1 0:00.00 /usr/bin/qemu-arm-static /usr/lib/git-core/git fetch-pack --stateless-rpc --stdin --lock-pack --thin --check-self-contained-and-connected --cloning https://github.com/le+ 18942 root 20 0 19948 3652 3128 S 0.0 0.0 0:00.04 bash 18957 root 20 0 38328 3344 2904 R 0.0 0.0 0:00.01 top Also, I had to re-set the root password for installing some packages that use `sudo -u`, such as mariadb, or I get Setting up mariadb-common (10.1.26-0+deb9u1) ... update-alternatives: using /etc/mysql/mariadb.cnf to provide /etc/mysql/my.cnf (my.cnf) in auto mode Selecting previously unselected package mariadb-server-10.1. (Reading database ... 33975 files and directories currently installed.) Preparing to unpack .../mariadb-server-10.1_10.1.26-0+deb9u1_armhf.deb ... You are required to change your password immediately (root enforced) chfn: PAM: Authentication token is no longer valid; new one required adduser: `/usr/bin/chfn -f MySQL Server mysql' returned error code 1. Exiting. dpkg: error processing archive /var/cache/apt/archives/mariadb-server-10.1_10.1.26-0+deb9u1_armhf.deb (--unpack): subprocess new pre-installation script returned error exit status 1 Finally, postfix postinstallation script fails here /usr/sbin/postconf: fatal: inet_addr_local[getifaddrs]: getifaddrs: Address family not supported by protocol So it gets marked as not successfully installed until we run some apt action on the board. Not a big deal really but it would be nice to fix it without ugly hacks. It seems like a qemu-user-static issue https://lists.gnu.org/archive/html/qemu-devel/2016-05/msg02382.html I tested this with my odroid HC1 and I also own a rock64 like this one. Next, I want to try it on the rock64, so what target should I use to build for this board? Thanks, and I hope this is helpful! Feedback is welcome! Link to post Share on other sites More sharing options...
nachoparker 10 Posted November 22, 2017 Author Share Posted November 22, 2017 I noticed the first one on this build. Let's encrypt failed to install because of the git issue mentioned above. We can force reinstall for now with sudo rm /usr/local/etc/nextcloudpi-config.d/letsencrypt.sh sudo ncp-update Link to post Share on other sites More sharing options...
tkaiser 1646 Posted November 22, 2017 Share Posted November 22, 2017 In case you haven't already you might look through https://github.com/armbian/build/blob/master/config/templates/customize-image.sh.template#L35 to get an idea how to workaround or solve some of the issues when installing not in an already running system but from customize-image.sh. BUT... the above OMV installation routine can be considered a proof of concept and also part of a journey (that ended in the meantime -- see last 2 posts here please). Stuff like this should become part of armbian-config/softy. Link to post Share on other sites More sharing options...
nachoparker 10 Posted November 28, 2017 Author Share Posted November 28, 2017 Hi, thanks for the info Well, I tried to build an OMV image using the customize-image.sh template and there were many errors during the build process, and the web interface for OMV didn't show up. Didn't look into that any more. I did notice that the proposed workaround for postfix didn't work, and the package was in an unconfigured state during installation. The most annoying problem is the github one, because the build randomly fails. Maybe I should start a new post on this to give it some more visibility? On 11/22/2017 at 8:32 PM, tkaiser said: Stuff like this should become part of armbian-config/softy. I guess the 'curl installer' could be launched from the armbian menu easily enough. How do you suggest we proceed? it should really be just a matter of adding the 'curl command' in a new menu entry. I have received good feedback from this first test image. Link to post Share on other sites More sharing options...
nachoparker 10 Posted May 3, 2018 Author Share Posted May 3, 2018 On 11/22/2017 at 8:32 PM, tkaiser said: Stuff like this should become part of armbian-config/softy. The NCP Nextcloud ready armbian images are now considered stable. What do you think about me sending a PR to include it in armbian-config/softy? Link to post Share on other sites More sharing options...
Igor 2458 Posted May 3, 2018 Share Posted May 3, 2018 5 minutes ago, nachoparker said: What do you think about me sending a PR to include it in armbian-config/softy? Absolutely! Use branch development - I am doing lot's of changes those days https://github.com/armbian/config/commits/development and I'll test and adjust if needed. Link to post Share on other sites More sharing options...
nachoparker 10 Posted May 3, 2018 Author Share Posted May 3, 2018 @Igor great! I'll create my commit locally in that branch, then generate a plain image for the Odroid HC1, then test it directly in the board, when everything is ok will PR to development branch. Sounds good? 2 Link to post Share on other sites More sharing options...
nachoparker 10 Posted May 4, 2018 Author Share Posted May 4, 2018 PR tested and ready to use https://github.com/armbian/config/pull/19 1 Link to post Share on other sites More sharing options...
JMCC 356 Posted October 12, 2018 Share Posted October 12, 2018 In case someone is looking to add an Emby media server to their Nextcloudpi with hardware accelerated transcoding, I made a step-by-step guide here: 1 Link to post Share on other sites More sharing options...
t3l3m4k0 3 Posted October 23, 2018 Share Posted October 23, 2018 thx nachoparker, tested and running on an old orange pi mini (A20) Link to post Share on other sites More sharing options...
esbeeb 18 Posted October 25, 2018 Share Posted October 25, 2018 I just tried to install Nextcloud from Softy. It downloaded Nextcloud 14. But the installer showed errors: Installing nc-update-nextcloud Installing nc-update Installing nc-webui Installing nc-wifi Hit:1 http://security.debian.org stretch/updates InRelease Hit:3 http://deb.debian.org/debian buster InRelease Ign:2 http://cdn-fastly.deb.debian.org/debian stretch InRelease Hit:5 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease Hit:6 http://cdn-fastly.deb.debian.org/debian stretch-backports InRelease Hit:7 http://cdn-fastly.deb.debian.org/debian stretch Release Hit:4 https://apt.armbian.com stretch InRelease Reading package lists... Done Reading package lists... Done Building dependency tree Reading state information... Done The following additional packages will be installed: python-dbus python-gi python-gobject python-gobject-2 python-urwid python-wicd wicd-daemon Suggested packages: python-dbus-dbg python-dbus-doc python-gi-cairo python-gobject-2-dbg pm-utils The following NEW packages will be installed: python-dbus python-gi python-gobject python-gobject-2 python-urwid python-wicd wicd-curses wicd-daemon 0 upgraded, 8 newly installed, 0 to remove and 1 not upgraded. Need to get 2,242 kB of archives. After this operation, 6,965 kB of additional disk space will be used. 0% [Connecting to httpredir.debian.org] 0% [Connecting to httpredir.debian.org] Err:1 http://httpredir.debian.org/debian stretch/main arm64 python-dbus arm64 1.2.4-1+b1 Could not resolve 'httpredir.debian.org' Err:2 http://httpredir.debian.org/debian stretch/main arm64 python-gi arm64 3.22.0-2 Could not resolve 'httpredir.debian.org' Err:3 http://httpredir.debian.org/debian stretch/main arm64 python-gobject-2 arm64 2.28.6-13 Could not resolve 'httpredir.debian.org' Ign:4 http://httpredir.debian.org/debian stretch/main arm64 python-gobject all 3.22.0-2 Ign:5 http://httpredir.debian.org/debian stretch/main arm64 python-wicd all 1.7.4+tb2-4 Ign:6 http://httpredir.debian.org/debian stretch/main arm64 wicd-daemon all 1.7.4+tb2-4 Err:7 http://httpredir.debian.org/debian stretch/main arm64 python-urwid arm64 1.3.1-2+b1 Could not resolve 'httpredir.debian.org' Ign:8 http://httpredir.debian.org/debian stretch/main arm64 wicd-curses all 1.7.4+tb2-4 Err:4 http://httpredir.debian.org/debian stretch/main armhf python-gobject all 3.22.0-2 Could not resolve 'httpredir.debian.org' Err:5 http://httpredir.debian.org/debian stretch/main armhf python-wicd all 1.7.4+tb2-4 Could not resolve 'httpredir.debian.org' Err:6 http://httpredir.debian.org/debian stretch/main armhf wicd-daemon all 1.7.4+tb2-4 Could not resolve 'httpredir.debian.org' Err:8 http://httpredir.debian.org/debian stretch/main armhf wicd-curses all 1.7.4+tb2-4 Could not resolve 'httpredir.debian.org' E: Failed to fetch http://httpredir.debian.org/debian/pool/main/d/dbus-python/python-dbus_1.2.4-1+b1_arm64.deb Could not resolve 'httpredir.debian.org' E: Failed to fetch http://httpredir.debian.org/debian/pool/main/p/pygobject/python-gi_3.22.0-2_arm64.deb Could not resolve 'httpredir.debian.org' E: Failed to fetch http://httpredir.debian.org/debian/pool/main/p/pygobject-2/python-gobject-2_2.28.6-13_arm64.deb Could not resolve 'httpredir.debian.org' E: Failed to fetch http://httpredir.debian.org/debian/pool/main/p/pygobject/python-gobject_3.22.0-2_all.deb Could not resolve 'httpredir.debian.org' E: Failed to fetch http://httpredir.debian.org/debian/pool/main/w/wicd/python-wicd_1.7.4+tb2-4_all.deb Could not resolve 'httpredir.debian.org' E: Failed to fetch http://httpredir.debian.org/debian/pool/main/w/wicd/wicd-daemon_1.7.4+tb2-4_all.deb Could not resolve 'httpredir.debian.org' E: Failed to fetch http://httpredir.debian.org/debian/pool/main/u/urwid/python-urwid_1.3.1-2+b1_arm64.deb Could not resolve 'httpredir.debian.org' E: Failed to fetch http://httpredir.debian.org/debian/pool/main/w/wicd/wicd-curses_1.7.4+tb2-4_all.deb Could not resolve 'httpredir.debian.org' E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? Failed to disable unit: No such file or directory Plenty of other packages successfully installed. It's just that whenever "httpredir.debian.org" was called upon, it wouldn't resolve! So my Nextcloud install is only partially there. I'm not sure what to run to re-initiate another attempt to install those missing Nextcloud parts. Link to post Share on other sites More sharing options...
Igor 2458 Posted October 25, 2018 Share Posted October 25, 2018 49 minutes ago, esbeeb said: Could not resolve 'httpredir.debian.org' Is a network / Debian problem. Nothing to do with our installer. Link to post Share on other sites More sharing options...
esbeeb 18 Posted November 1, 2018 Share Posted November 1, 2018 On 10/25/2018 at 5:20 PM, Igor said: Is a network / Debian problem. Nothing to do with our installer. That's true. But I was stuck, not knowing how to re-initiate the Nextcloud install (like an hour later). I can't just unselect (then quit Softy, hoping the Nextcloud install would return to a clean state), then re-select Nextcloud within Softy (to try a Nextcloud over again). My sense is that this Nextcloud Installer could use some improvement in the way of recovering/resuming from partial installs. Link to post Share on other sites More sharing options...
Igor 2458 Posted November 1, 2018 Share Posted November 1, 2018 43 minutes ago, esbeeb said: My sense is that this Nextcloud Installer could use some improvement in the way of recovering/resuming from partial installs. There is always room for improvement -> https://www.armbian.com/get-involved I will certainly not touch this anytime soon. Link to post Share on other sites More sharing options...
esbeeb 18 Posted November 1, 2018 Share Posted November 1, 2018 On 11/23/2017 at 3:21 AM, nachoparker said: Feedback is welcome! @nachoparkerNachoparker, my feedback is that NextcloudPi rocks. Thanks so much for doing it. I was able to use one of your pre-built images on one ARM board and it worked really, really well. Your text-based config menu for Nextcloud was extremely helpful, especially the backup/restore features. I also loved how I could migrate the data and database folders to an external hard drive (and not have them on a slow MicroSD card). I look forward to more Armbian boards appearing with pre-built images on your Nextcloud Pi downloads page. Link to post Share on other sites More sharing options...
yogui 1 Posted November 1, 2018 Share Posted November 1, 2018 Hello, I try to install NextCloudPi over the softy menu on a OrangePi PC+ with arbian inst Link to post Share on other sites More sharing options...
yogui 1 Posted November 1, 2018 Share Posted November 1, 2018 Hello, I try to install NextCloudPi over the softy menu on a OrangePi PC+ with armbian is installed on the eMMC.. instalation finished without error. after I connect to the webserver I have folowing image and message : if try to start with cli I have following errors. Did I forget to install something?? If you need some other information please let me know thank you for your help Link to post Share on other sites More sharing options...
martinayotte 678 Posted November 1, 2018 Share Posted November 1, 2018 15 minutes ago, yogui said: Did I forget to install something?? As the screenshot shows, several php modules are missing ... Install them with the following and try again, maybe more needed ... apt-get install php-zip phpmd php-gd php-curl php-xml Link to post Share on other sites More sharing options...
martinayotte 678 Posted November 1, 2018 Share Posted November 1, 2018 16 minutes ago, yogui said: I try to install NextCloudPi Some software installers don't carefully doing dependencies checking, so you have sometime to fix things by hand ... Did you ran the apt-get I've mentioned above ? Link to post Share on other sites More sharing options...
yogui 1 Posted November 1, 2018 Share Posted November 1, 2018 hello sorry my previous message it was a mistake thank you for you fast answer 2 other pakage was needed : libculr3 and php7.0-curl i have installed them an those you suggest instalation was sucessful I have the same error after, I also reboot my opi Link to post Share on other sites More sharing options...
martinayotte 678 Posted November 1, 2018 Share Posted November 1, 2018 4 minutes ago, yogui said: I have the same error after If you mean the last error "Environment not properly prepared", maybe that was caused by the fact earlier missing packages, some data scripts didn't run properly to prepare environment. Maybe try to uninstall and re-install NextCloudPi, maybe this will fix things ... Link to post Share on other sites More sharing options...
yogui 1 Posted November 1, 2018 Share Posted November 1, 2018 no I mean missing package (the same package are missing ) I have tryed to remove nexclode with apt-get remove NextCloudPi and apt-get remove NextCloud but package ar neo avalable any idea how the package is named Link to post Share on other sites More sharing options...
martinayotte 678 Posted November 1, 2018 Share Posted November 1, 2018 4 minutes ago, yogui said: no I mean missing package (the same package are missing ) The PHP packages from the above list ? Even if installed manually with apt-get ? Link to post Share on other sites More sharing options...
Igor 2458 Posted November 1, 2018 Share Posted November 1, 2018 2 hours ago, yogui said: if try to start with cli I have following errors. In this case we only call @nachoparker install script from Softy menu: https://github.com/armbian/config/blob/master/debian-software#L523-L525 1 Link to post Share on other sites More sharing options...
yogui 1 Posted November 1, 2018 Share Posted November 1, 2018 39 minutes ago, martinayotte said: The PHP packages from the above list ? Even if installed manually with apt-get ? yes Link to post Share on other sites More sharing options...
martinayotte 678 Posted November 1, 2018 Share Posted November 1, 2018 According to what I see in https://github.com/nextcloud/nextcloudpi , it seems that this software is using docker. Since docker is some kind of virtual environment, it is why you have PHP modules "already installed", but inside the docker, they are not present. You should ask @nachoparker some help to figure out how to fix this docker installation or how to add missing packages into it ... Link to post Share on other sites More sharing options...
yogui 1 Posted November 1, 2018 Share Posted November 1, 2018 29 minutes ago, martinayotte said: According to what I see in https://github.com/nextcloud/nextcloudpi , it seems that this software is using docker. Since docker is some kind of virtual environment, it is why you have PHP modules "already installed", but inside the docker, they are not present. You should ask @nachoparker some help to figure out how to fix this docker installation or how to add missing packages into it ... thanks for your answehre I anderstand that other way, that you can installal inside docker or directly I will try the docker image thank you for your help @nachoparker do you have an idea why it doesnt work on my opi PC plus Link to post Share on other sites More sharing options...
yogui 1 Posted November 1, 2018 Share Posted November 1, 2018 hello I try it inside docker it works but @nachoparker schoud'nt work over the softy menu on my opi pc+? regards Link to post Share on other sites More sharing options...
nachoparker 10 Posted November 2, 2018 Author Share Posted November 2, 2018 Hi everyone NextCloudPi has different variants. There is a docker version, there's the curl installer (the one included in softy), and the SD card versions (and the x86 VM). It seems that something broke with the curl installer. Maybe some packages changed upstream, I'll look into it when I have time. If possible, use the images because each release has been tested. You can use the docker version instead of the softy version in the meantime if there is no support for your board, or even better, you can help me support yet another board Adding a new board is pretty easy, what I need is people willing to briefly test each release (I have scripts for automated testing, there is info in the wiki). https://github.com/nextcloud/nextcloudpi/wiki/Testing-NextCloudPi Link to post Share on other sites More sharing options...
