Guilherme Posted 1 hour ago Posted 1 hour ago I need help. Every version I generate for Raspberry Pi 5 Armbian-unofficial_25.08.0-trunk_Rpi4b_noble_current_6.12.32_minimal shows the error shown in the photo. 0 Quote
Werner Posted 1 hour ago Posted 1 hour ago moved Cannot reproduce. Download image works just fine https://dl.armbian.com/rpi4b/Noble_current_minimal Quote generate [...] 25.08.0 outdated tag, unsupported 0 Quote
Guilherme Posted 33 minutes ago Author Posted 33 minutes ago (edited) The image is generated, but when I put it in the Raspberry Pi, it displays the screen. Edited 32 minutes ago by Guilherme 0 Quote
Guilherme Posted 30 minutes ago Author Posted 30 minutes ago I'm using the command ./compile.sh build BOARD=rpi4b BRANCH=current KERNELBRANCH=current SKIP_ARMBIAN_REPO=yes SKIP_ARMBIAN_CONFIG=yes SKIP_EXTERNAL_TOOLCHAINS=yes BUILD_DESKTOP=no BUILD_MINIMAL=yes CLEAN_LEVEL=make-kernel,alldebs,images,cache EXPERT=yes KERNEL_CONFIGURE=no NEWPKG=true OFFLINE_WORK=no KERNEL_BTF=no RELEASE=noble 0 Quote
