Igor Posted Tuesday at 11:23 PM Posted Tuesday at 11:23 PM We are opening public testing for upcoming Armbian images. The goal is to verify that the right images are built and that basic functionality works before boards are moved to the main download pages. You don’t need to be a developer. Simple testing and short reports are enough. 1. Download testing images Testing images are available here: https://fi.mirror.armbian.de/incoming/igorpecovnik/ Pick the image matching your board and choose desktop if applicable. Once image is confirmed working, the board will be: Moved to the main download pages Added to Armbian Imager 2. Check that expected images exist Before testing, please verify that: Your board is listed The expected image variants exist If an image (variant) seems to be missing: Check the release target definitions: https://github.com/armbian/armbian.github.io/tree/main/release-targets If the image should exist, check build logs to see if it failed: https://github.com/armbian/os/actions/runs/21642728389 If you are unsure, report it anyway. 3. Flash and boot Flash the image using Armbian Imager: https://imager.armbian.com Boot the board and check whether it reaches: Login prompt (CLI images) Desktop (Desktop images) If the board does not boot, serial output or photos help. 4. What to test Please focus on basic functionality: Boot reliability and reboot Networking (Ethernet, Wi-Fi, Bluetooth) Display and GPU, if applicable Installer and first-boot experience Advanced features can wait. Stability comes first. 5. UEFI ARM64 images If your board might support UEFI on ARM64, please test those images on them. Working UEFI images allow us to reuse targets and reduce the number of generated images. Reference: https://github.com/armbian/armbian.github.io/blob/main/release-targets/reusable.yml 6. Community-supported boards Some boards are currently released as community-supported: https://github.com/armbian/community/releases We want to promote suitable boards to standard support which brings more image variants and much faster download. This requires: Confirmation that basic functionality works Send a PR to change status from .csc to .conf A community member willing to step up as maintainer If you rely on such a board and want it promoted, this is the time to help. 7. Reporting (here in this topic!) When reporting test results, please include: Board model Image name and variant What works and what does not Logs or serial output if available Even short reports like “Board X, image Y, boots and networking works” are useful. Thanks to everyone helping with testing. Early feedback directly improves the release quality! 1 Quote
Igor Posted yesterday at 03:17 PM Author Posted yesterday at 03:17 PM What was already tested: UEFI x86 KDE Neon, Gnome, Ubuntu minimal MusePI Pro Xfce Odroid M1 KDE Neon Odroid N2 Xfce https://paste.armbian.com/oqegebaqey Orangepi 5 Nanopi M4V2 Odroid M2 Radxa E54 Rock 5C Orangepi 3LTS 0 Quote
Walter Zambotti Posted 19 hours ago Posted 19 hours ago (edited) I am currently on the community Odroid M2 CURRENT (6.18) (not edge 6.19) rolling release. Does this differ significantly enough from the images provided here: https://fi.mirror.armbian.de/incoming/igorpecovnik/ that I should download afresh and re-install before submitting any test results? Reporting! Where? (Every other section 1 - 7 had a necessary link) Much appreciated in advance. Willing to help or donate a M2 board if necessary. Edited 19 hours ago by Walter Zambotti 0 Quote
Walter Zambotti Posted 17 hours ago Posted 17 hours ago (edited) I download Armbian_26.2.1_Odroidm2_noble_current_6.18.8_gnome_desktop.img.xz and burnt to a new SD card. Tested: Install OK Initial startup to desktop OK shutdown OK boot OK HDMI OK HDMI audio FAILED only dummy sound device Wifi via PCI M-key to E-key adapter Intel Wifi 6 AX200 OK USB-2 OK multiple devices including HUB USB-3 OK thumb drive USB-C FAILED nil buses detected or exposed I have managed to add a user device tree overlay to expose the USB-C port in non OTG mode and get some USB-C devices working. A USB-C thumb drive was consistent. But I only managed to connect my Pixel 8a successfully once at 480m speed. Edited 15 hours ago by Walter Zambotti 0 Quote
Igor Posted 8 hours ago Author Posted 8 hours ago 10 hours ago, Walter Zambotti said: Reporting! Where? Here, yes. Thank you! 10 hours ago, Walter Zambotti said: Does this differ significantly No, but we need to test images made for release. There is another last minute change https://github.com/armbian/build/commit/1890d7f6566a65202f73730b469d024c20f863b8 than can, in theory, make unbootable image. 8 hours ago, Walter Zambotti said: USB-C FAILED nil buses detected or exposed I have managed to add a user device tree overlay to expose the USB-C port in non OTG mode and get some USB-C devices working. A USB-C thumb drive was consistent. But I only managed to connect my Pixel 8a successfully once at 480m speed. OK. Bugs will be present and we won't be fixing them at this stage. Here - if basic things works - that image boots, have connectivity and video output ... its ready to ship. All other things can be fixed with an update. If / when they are fixed. 10 hours ago, Walter Zambotti said: or donate a M2 board if necessary. Armbian exists to save users time so you don't need to waste your private time dealing with bad software experience which would exists without our work. Sadly most people don't understand the value Armbian projecst make. Average Armbian developer have 100+ boards. We drown in issues they generate. All board manufacturer are happy to send us board for free and we decline many of their offers. I still have many unpacked boxes ... Without your help / engagement, we have no alternative but to keep images in automated untested (theoretically community maintained images) loop. Standard support costs us more then automated unchecked images. 0 Quote
JFL Posted 1 hour ago Posted 1 hour ago Device: Orange Pi 5 Plus Image: Armbian_26.2.1_Orangepi5-plus_noble_current_6.18.8_kde-neon_desktop.img.xz Installation on SD Card without issue. Ethernet works WiFi (RTW89_8852BE): Works Bluetooth: Available but did not test pairing with bluetooth device Chromium_v144: vpu hardware acceleration working USB-3.0 & USB-2.0 Ports working PCIE-NVMe: Accessible HDMI Display: working HDMI-Audio: working Headphone Jack-Audio: Working (After using alsamixer to increase "output1" volume") Out of the box, konsole (terminal-emulator) and dolphin (file manager) not pre-installed. 0 Quote
