zjd Posted February 8 Posted February 8 (edited) I updated to Armbian 26.2.1 on OPi5, and it can't boot from MTD (rootfs at NVMe), and I have to use SD card to boot to NVMe as workaround. After looking into this issue, I found rkspi_loader.img is no longer available for current (6.18.8 kernel) u-boot pkg and armbian-config flashes u-boot-rockchip-spi.bin ( or similar sata version) to /dev/mtdblock0 and I think this is wrong image for MTD bootloader. If I use older vendor image, which u-boot pkg has rkspi_loader.img, system can boot to NVMe rootfs and I notice that /dev/mtdblock0 has several gpt partitions including u-boot one, and flashing u-boot-rockchip-spi.bin erases partitions in SPI flash. I noticed that several related changes were introduced since 25.11, such as https://github.com/armbian/build/commit/e5b845f9432abb0408287599bba5889a86e6d068 , but I couldn't do quick fix to bring back working rkspi_loader.img because I am not familiar with whole armbian build. One thing to note that if board was flashed with old rkspi_loader.img and not updated with 26.2 MTD image, it still boots to NVMe rootfs, but I have other issues such as video playback not working with 6.18 kernel likely due to mismatch u-boot and kernel version leading to wrong HW initialization. BTW, I checked 26.2 u-boot pkg for Rock 5B (similar rk3588 board), and rkspi_loader.img is still included. Edited February 8 by zjd 0 Quote
zjd Posted February 9 Author Posted February 9 After digging into more details, I think Armbian has moved to use new U-Boot generated FIT image u-boot-rockchip-spi.bin for SPI boot, however, it doesn't work to boot NVMe rootfs and sometimes breaks the board and I have to erase SPI to get SD card booting. Couldn't find more information how Armbian does MTD boot now. Note that older vendor SPI bootloader can boot kernel 6.18.8 but I ran into other issue like freezing system for a couple of minutes so that I'd say to avoid use old MTD image with 26.2 6.18 kernel. 0 Quote
zjd Posted February 13 Author Posted February 13 I connected UART today and did some debugging, and it looks like that this u-boot 2025.10 for Armbian 26.02 doesn't see NVMe drive, i.e. 'nvme scan' returns nothing. Is OPi5 NVMe support included in upstream mainline u-boot? 0 Quote
Werner Posted February 13 Posted February 13 The related PR states this was tested. @Efe Çetin can you confirm this still works as expected? 0 Quote
Efe Çetin Posted February 16 Posted February 16 On 2/13/2026 at 7:43 AM, Werner said: The related PR states this was tested. @Efe Çetin can you confirm this still works as expected Will check it when i back to PC, will be away from pc for around a week 2 Quote
xsetiadi Posted February 27 Posted February 27 (edited) how about armbian 26.2.1 but still using vendor kernel? did we still have this problem? Edited Saturday at 07:45 AM by xsetiadi 0 Quote
zjd Posted Sunday at 04:24 PM Author Posted Sunday at 04:24 PM If you have flashed working rkspi_loader.img to MTD before, i.e. from previous releases, you can keep using it with vendor kernel w/o updating MTD. The 26.2.1 image with vendor kernel uses new FIT u-boot loader as well, I doubt it will work with NVMe. BTW, I need 6.18 kernel and new u-boot and noticed that 26.2.1 image default to vendor kernel instead of 6.18 kernel now. 0 Quote
xsetiadi Posted Sunday at 05:02 PM Posted Sunday at 05:02 PM ok, i guess i just dd new image then. have you read github release a few minutes ago? orangepi5: bump u-boot to v2026.04-rc3 0 Quote
Igor Posted Sunday at 05:14 PM Posted Sunday at 05:14 PM On 2/27/2026 at 7:28 PM, xsetiadi said: but still using vendor kernel? Vendor kernel will stay for awhile (this year for sure) as mainline is not on this level yet. 10 minutes ago, xsetiadi said: orangepi5: bump u-boot to v2026.04-rc3 This part might not be part of the release - you can grab it from nightly release - but most likely it won't have any affect to this topic. 1 Quote
