Dante4 Posted December 16, 2018 Posted December 16, 2018 (edited) On 12/16/2018 at 7:49 PM, JMCC said: You can copy-paste this code into a root console, and it will give you a Qt5 player using the RK GStreamer plugin: apt-get -y install qtgstreamer-plugins-qt5 gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-plugins-good gstreamer1.0-plugins-base libqt5opengl5 libqt5qml5 libqt5quick5 libqt5widgets5 libqt5gui5 libqt5core5a qml-module-qtquick2 libqt5multimedia5 libqt5multimedia5-plugins libqt5multimediaquick-p5 qtmultimedia5-examples qtmultimedia5-doc-html echo '#!/usr/bin/env xdg-open [Desktop Entry] Type=Application Name=Rockchip Gst Player GenericName=Media Player Comment=A gstreamer base player Exec=env QT_GSTREAMER_WIDGET_VIDEOSINK=rkximagesink /usr/lib/arm-linux-gnueabihf/qt5/examples/multimediawidgets/player/player --geometry 960x640+0+0 Icon=/usr/share/icons/gnome/48x48/categories/applications-multimedia.png Terminal=false Categories=Qt;AudioVideo;Player;Video; MimeType=application/ogg;application/x-ogg;application/mxf;application/sdp;application/smil;application/x-smil;application/streamingmedia;application/x-streamingmedia;application/vnd.rn-realmedia;application/vnd.rn-realmedia-vbr;audio/aac;audio/x-aac;audio/vnd.dolby.heaac.1;audio/vnd.dolby.heaac.2;audio/aiff;audio/x-aiff;audio/m4a;audio/x-m4a;application/x-extension-m4a;audio/mp1;audio/x-mp1;audio/mp2;audio/x-mp2;audio/mp3;audio/x-mp3;audio/mpeg;audio/mpeg2;audio/mpeg3;audio/mpegurl;audio/x-mpegurl;audio/mpg;audio/x-mpg;audio/rn-mpeg;audio/musepack;audio/x-musepack;audio/ogg;audio/scpls;audio/x-scpls;audio/vnd.rn-realaudio;audio/wav;audio/x-pn-wav;audio/x-pn-windows-pcm;audio/x-realaudio;audio/x-pn-realaudio;audio/x-ms-wma;audio/x-pls;audio/x-wav;video/mpeg;video/x-mpeg2;video/x-mpeg3;video/mp4v-es;video/x-m4v;video/mp4;application/x-extension-mp4;video/divx;video/vnd.divx;video/msvideo;video/x-msvideo;video/ogg;video/quicktime;video/vnd.rn-realvideo;video/x-ms-afs;video/x-ms-asf;audio/x-ms-asf;application/vnd.ms-asf;video/x-ms-wmv;video/x-ms-wmx;video/x-ms-wvxvideo;video/x-avi;video/avi;video/x-flic;video/fli;video/x-flc;video/flv;video/x-flv;video/x-theora;video/x-theora+ogg;video/x-matroska;video/mkv;audio/x-matroska;application/x-matroska;video/webm;audio/webm;audio/vorbis;audio/x-vorbis;audio/x-vorbis+ogg;video/x-ogm;video/x-ogm+ogg;application/x-ogm;application/x-ogm-audio;application/x-ogm-video;application/x-shorten;audio/x-shorten;audio/x-ape;audio/x-wavpack;audio/x-tta;audio/AMR;audio/ac3;audio/eac3;audio/amr-wb;video/mp2t;audio/flac;audio/mp4;application/x-mpegurl;video/vnd.mpegurl;application/vnd.apple.mpegurl;audio/x-pn-au;video/3gp;video/3gpp;video/3gpp2;audio/3gpp;audio/3gpp2;video/dv;audio/dv;audio/opus;audio/vnd.dts;audio/vnd.dts.hd;audio/x-adpcm;application/x-cue;audio/m3u; ' > /usr/share/applications/demo-player.desktop Expand Well, i've seen this (oh, yeah, in your guide), but i guess my ./player did not worked because i forgot this "env QT_GSTREAMER_WIDGET_VIDEOSINK=rkximagesink" before executing it. Thank you once again Update: There is a problem with this shortcut, player execute, window opened, but it still shows error "unknown" (in window name). So i guess i need to found env QT_GSTREAMER_WIDGET_VIDEOSINK=rkximagesink for rk3328 and Armbian Update 2: Yep, it solved the way as using gstreamer. Add path to rkximagesink (since it's installed to /usr/local/lib/gstreamer-1.0) solves my problem with qt5 player Edited December 16, 2018 by Dante4 Problem solved 0 Quote
JMCC Posted December 25, 2018 Posted December 25, 2018 On 12/16/2018 at 1:38 AM, Dante4 said: Now i can finally watch 1080p30fps10bits! Perfectly fine! Expand Can you share some details on the steps you followed, and which player you are using? It can be useful for a complete implementation into Armbian. Thanks, and Merry Christmas. 0 Quote
Dante4 Posted December 26, 2018 Posted December 26, 2018 (edited) On 12/25/2018 at 8:45 PM, JMCC said: Can you share some details on the steps you followed, and which player you are using? It can be useful for a complete implementation into Armbian. Thanks, and Merry Christmas. Expand Yes, i will be happy to. A very small guide how to use any gstreamer player with rk3328 (Thanks to @JMCC): After installation switch to nightly builds (may be unnecessary). From now on or add sudo to each command or do sudo su Then apt-get update && apt-get upgrade -y && apt-get install -y libqt5opengl5 libqt5qml5 libqt5quick5 libqt5widgets5 libqt5gui5 libqt5core5a qml-module-qtquick2 libqt5multimedia5 libqt5multimedia5-plugins libqt5multimediaquick-p5 qtmultimedia5-examples qtmultimedia5-doc-html pkg-config gcc make git unzip wget xz-utils cmake devscripts equivs build-essential docutils-common mercurial cmake-curses-gui build-essential yasm mercurial cmake cmake-curses-gui build-essential gcc-arm-linux-gnueabi g++-arm-linux-gnueabi texinfo nasm automake pkg-config Then install necessary components for gstreamer apt-get install gstreamer1.0-tools qtgstreamer-plugins-qt5 gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-plugins-good gstreamer1.0-plugins-base gstreamer1.0-plugins-base-apps glib-2.0 libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev libgtk2.0-dev libperl-dev Now download libmali, mpp, gstreamer-rockchip and gstreamer-rockchip-extra from rockchip github mkdir build && cd build && git clone -b master https://github.com/rockchip-linux/libmali && git clone https://github.com/rockchip-linux/mpp && git clone -b master https://github.com/rockchip-linux/gstreamer-rockchip && git clone https://github.com/rockchip-linux/gstreamer-rockchip-extra Now apply patch from libreelec github to drm_fourcc nano /usr/include/drm/drm_fourcc.h and insert this #define DRM_FORMAT_NV12_10 fourcc_code('N', 'A', '1', '2') /* 2x2 subsampled Cr:Cb plane */ #define DRM_FORMAT_NV21_10 fourcc_code('N', 'A', '2', '1') /* 2x2 subsampled Cb:Cr plane */ #define DRM_FORMAT_NV16_10 fourcc_code('N', 'A', '1', '6') /* 2x1 subsampled Cr:Cb plane */ #define DRM_FORMAT_NV61_10 fourcc_code('N', 'A', '6', '1') /* 2x1 subsampled Cb:Cr plane */ #define DRM_FORMAT_NV24_10 fourcc_code('N', 'A', '2', '4') /* non-subsampled Cr:Cb plane */ #define DRM_FORMAT_NV42_10 fourcc_code('N', 'A', '4', '2') /* non-subsampled Cb:Cr plane */ after line 138 which is #define DRM_FORMAT_NV42 fourcc_code('N', 'V', '4', '2') /* non-subsampled Cb:Cr plane */ close and safe file (may be unnecessary) Since we already added all this type of DRM_FORMAT we could add them to gstreamer also. To do this, add to this files gstreamer-rockchip/gst/rkximage/rkx_kmsutils.c gstreamer-rockchip-extra/gst/rkximage/rkx_kmsutils.c gstreamer-rockchip-extra/gst/kms/gstkmsutils.c after lines 65-66 (for gstreamer-rockchip) and 62-63 (for gstreamer-rockchip-extra) which are /* FIXME should be renamed to P010_* */ DEF_FMT (NV12_10, P010_10LE), this lines DEF_FMT (NV21_10, P010_10LE), DEF_FMT (NV21_10, P010_10LE), DEF_FMT (NV16_10, P010_10LE), DEF_FMT (NV61_10, P010_10LE), DEF_FMT (NV24_10, P010_10LE), DEF_FMT (NV42_10, P010_10LE), Now do (from directory "build") cd libmali && cmake CMakeLists.txt && make && make install && ldconfig && / LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib && LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/include && / cd ../mpp && cmake -DRKPLATFORM=ON -DHAVE_DRM=ON && make -j4 && make install && / cd ../gstreamer-rockchip && ./autogen.sh && make -j4 && make install && ldconfig && / cd ../gstreamer-rockchip-extra && ./autogen.sh && make clean && make -j4 && make install && ldconfig To check if everything is correct do gst-inspect-1.0 --gst-plugin-path=/usr/local/lib/gstreamer-1.0 | grep mpp expected output rockchipmpp: mppjpegdec: Rockchip's MPP JPEG image decoder rockchipmpp: mppjpegenc: Rockchip Mpp JPEG Encoder rockchipmpp: mpph264enc: Rockchip Mpp H264 Encoder rockchipmpp: mppvideodec: Rockchip's MPP video decoder and gst-inspect-1.0 --gst-plugin-path=/usr/local/lib/gstreamer-1.0 rkximage expected output Plugin Details: Name rkximage Description Rockchip X/DRM Video Sink Filename /usr/local/lib/gstreamer-1.0/libgstrkximage.so Version 1.1.0 License GPL Source module gstreamer-rockchip-extra Binary package GStreamer Plug-ins source release Origin URL Unknown package origin rkximagesink: Video sink 1 features: +-- 1 elements To start use gst-play-1.0 do this gst-play-1.0 --gst-plugin-path=/usr/local/lib/gstreamer-1.0 --videosink=rkximagesink <path/to/videofile> To use QT5 example player you need to do this env GST_PLUGIN_PATH=/usr/local/lib/gstreamer-1.0 QT_GSTREAMER_WIDGET_VIDEOSINK=rkximagesink /usr/lib/aarch64-linux-gnu/qt5/examples/multimediawidgets/player/player I hope it helped! P.S. Merry Christmas and Happy New Year Edited December 27, 2018 by Dante4 Merry Xmas 0 Quote
Dante4 Posted December 28, 2018 Posted December 28, 2018 P.S. If someone wanna fast way to have mpv+ffmpeg this works on Renegade too (You need to add ayufan ppa) and do steps from "For older releases (< 0.6.25)". P.S.S. Can someone explain, does this repo have some heavy modified mpv? ffmpeg for now with proper flags should be able to use HW even from official repo, libmali-rk-utgard-450-r7p0-gbm can be build from official repo too. But with just that i still get software decoding 0 Quote
JMCC Posted December 28, 2018 Posted December 28, 2018 On 12/28/2018 at 7:47 PM, Dante4 said: P.S. If someone wanna fast way to have mpv+ffmpeg this works on Renegade too (You need to add ayufan ppa) and do steps from "For older releases (< 0.6.25)". P.S.S. Can someone explain, does this repo have some heavy modified mpv? ffmpeg for now with proper flags should be able to use HW even from official repo, libmali-rk-utgard-450-r7p0-gbm can be build from official repo too. But with just that i still get software decoding Expand I'm not sure about ayufan's mpv version. I can tell you that I am working on a script for Armbian that has RKMPP enabled mpv. The proper way to start mpv with hardware decoding is like this: LD_LIBRARY_PATH=/path/to/your/libmali-gbm mpv --hwdec=rkmpp --vo=gpu --gpu-api=opengl --gpu-context=drm "<filename.mkv>" It works with my mpv, not sure about ayufan's 1 Quote
Dante4 Posted December 29, 2018 Posted December 29, 2018 On 12/28/2018 at 9:45 PM, JMCC said: I'm not sure about ayufan's mpv version. I can tell you that I am working on a script for Armbian that has RKMPP enabled mpv. The proper way to start mpv with hardware decoding is like this: LD_LIBRARY_PATH=/path/to/your/libmali-gbm mpv --hwdec=rkmpp --vo=gpu --gpu-api=opengl --gpu-context=drm "<filename.mkv>" It works with my mpv, not sure about ayufan's Expand Seems like i build libmali in wrong way (are there any other way to build it?) and i need to add some options, just cmake && make && make install doesn't allow me to get gbm installed. And looking at output of mpv and google [autoconvert] can't find video conversion for drm_prime/unknown Maybe I'm missing some files or links (just coping libmali-utgard-450-r7p0-gbm.so and creating links with name: libMali.so libgbm.so libgbm.so.1 and libgbm.so.1.0.0 to specific patch and then LD_LIBRARY_PATH to this folder doesn't seems to work). Maybe i need mpv from LongChair repo and not official one Solution. Yes i need to use LongChair repo. Now i'm interested can this be solved with just patch 0 Quote
JMCC Posted December 29, 2018 Posted December 29, 2018 On 12/29/2018 at 1:10 PM, Dante4 said: Yes i need to use LongChair repo. Now i'm interested can this be solved with just patch Expand You can have a look at my script when I release it. It includes info about the sources. 1 Quote
xorro Posted January 4, 2019 Posted January 4, 2019 On 12/29/2018 at 1:51 PM, JMCC said: You can have a look at my script when I release it. It includes info about the sources. Expand @JMCC I would very much be interested in the script you've mentioned, do you have a n idea on the timeframe you are looking at for it's release? I have an roc-rk3328-cc device, and believe I could benefit from your research and code, as many others with this SBC. thank you both @JMCC and @Dante4, and others on this thread. it has been very informative! 0 Quote
Dante4 Posted January 7, 2019 Posted January 7, 2019 On 1/4/2019 at 11:45 PM, xorro said: @JMCC I would very much be interested in the script you've mentioned, do you have a n idea on the timeframe you are looking at for it's release? I have an roc-rk3328-cc device, and believe I could benefit from your research and code, as many others with this SBC. thank you both @JMCC and @Dante4, and others on this thread. it has been very informative! Expand Your pings a bit broken, not sure why... As for his script, maybe you can ask about this in PM last information was this 0 Quote
Dante4 Posted January 7, 2019 Posted January 7, 2019 FFmpeg+mpv For a reason (which i don't know) mpv can't work in pseudo-gui-mode (it just crash desktop) and always opens fullscreen, maybe it can be fixed with custom x11 server, but that's already beyond my limited knowledge. So gstreamer can work in windowed and fullscreen. Mpv only fullscreen. That guide about how to build ffmpeg (with alot of stuff) and mpv to make it work with hw acceleration. Switch to night builds using armbian-config (sudo armbian-config --> Install --> Nightly) This "guide" contains a lot of sudo so it will be better to do sudo su before using it. sudo su Delete any mpv and ffmpeg you have in system apt-get remove mpv ffmpeg This will download necessary libs and FFmpeg with custom mpv (and mpv-build contains all necessary dependencies for usual mpv) that's made for rockchip mkdir build && \ git clone -b master https://github.com/rockchip-linux/libmali && \ git clone -b master https://github.com/FFmpeg/FFmpeg && \ git clone -b master https://github.com/LongChair/mpv && \ git clone -b master https://github.com/mpv-player/mpv-build Do apt-get install autoconf automake build-essential cmake git-core libass-dev libfreetype6-dev libsdl2-dev libtool libva-dev libvdpau-dev libvorbis-dev libxcb1-dev libxcb-shm0-dev libxcb-xfixes0-dev pkg-config texinfo wget zlib1g-dev yasm libx264-dev libx265-dev libnuma-dev libvpx-dev libfdk-aac-dev libmp3lame-dev libopus-dev mc locate libghc-bzlib-dev libfdk-aac-dev fdkaac aac-enc libfdk-aac1 libass-dev libdrm2 libva-drm2 xterm cd ./mpv-build && mk-build-deps -s -i && apt-get install -f -y && cd ../ Patch drm_fourcc.h with this (just in case, this lines to add 10bit video, i will test later does they affect ffmpeg) find /usr/include/drm -name drm_fourcc.h -exec sed -i "143 i #define DRM_FORMAT_NV12_10\ fourcc_code('N', 'A', '1', '2') /* 2x2 subsampled Cr:Cb plane */\n#define DRM_FORMAT_NV21_10 fourcc_code('N', 'A', '2', '1') /* 2x2 subsampled Cb:Cr plane */\n#define DRM_FORMAT_NV16_10 fourcc_code('N', 'A', '1', '6') /* 2x1 subsampled Cr:Cb plane */\n#define DRM_FORMAT_NV61_10 fourcc_code('N', 'A', '6', '1') /* 2x1 subsampled Cb:Cr plane */\n#define DRM_FORMAT_NV24_10 fourcc_code('N', 'A', '2', '4') /* non-subsampled Cr:Cb plane */\n#define DRM_FORMAT_NV42_10 fourcc_code('N', 'A', '4', '2') /* non-subsampled Cb:Cr plane */" {} + find /usr/include/libdrm -name drm_fourcc.h -exec sed -i "143 i #define DRM_FORMAT_NV12_10\ fourcc_code('N', 'A', '1', '2') /* 2x2 subsampled Cr:Cb plane */\n#define DRM_FORMAT_NV21_10 fourcc_code('N', 'A', '2', '1') /* 2x2 subsampled Cb:Cr plane */\n#define DRM_FORMAT_NV16_10 fourcc_code('N', 'A', '1', '6') /* 2x1 subsampled Cr:Cb plane */\n#define DRM_FORMAT_NV61_10 fourcc_code('N', 'A', '6', '1') /* 2x1 subsampled Cb:Cr plane */\n#define DRM_FORMAT_NV24_10 fourcc_code('N', 'A', '2', '4') /* non-subsampled Cr:Cb plane */\n#define DRM_FORMAT_NV42_10 fourcc_code('N', 'A', '4', '2') /* non-subsampled Cb:Cr plane */" {} + Now we need to build this all. To do this do cd libmali && cmake CMakeLists.txt && make -j4 && make install && ldconfig && \ cd ../FFmpeg && \ ./configure \ --cpu="cortex-a53" \ --arch="aarch64" \ --extra-libs="-Lpthread -Lm"\ --extra-cflags="-I\home\dante4\video\include" \ --extra-ldflags="-L\home\dante4\video\lib" \ --disable-debug \ --enable-libaom \ --enable-stripping \ --enable-gpl \ --enable-nonfree \ --enable-logging \ --disable-doc \ --enable-pic \ --enable-optimizations \ --enable-ffmpeg \ --enable-avdevice \ --enable-avcodec \ --enable-avformat \ --enable-swscale \ --enable-postproc \ --enable-avfilter \ --disable-devices \ --enable-pthreads \ --disable-w32threads \ --enable-network \ --disable-gnutls \ --disable-gray \ --enable-swscale-alpha \ --disable-small \ --enable-dct \ --enable-fft \ --enable-mdct \ --enable-rdft \ --disable-crystalhd \ --disable-vaapi \ --disable-vdpau \ --enable-rkmpp \ --enable-libdrm \ --enable-version3 \ --enable-runtime-cpudetect \ --enable-hardcoded-tables \ --enable-encoder=ac3 \ --enable-encoder=aac \ --enable-encoder=wmav2 \ --enable-encoder=mjpe \ --enable-encoder=png \ --enable-hwaccels \ --enable-muxer=spdif \ --enable-muxer=adts \ --enable-muxer=asf \ --enable-muxer=ipod \ --enable-muxer=mpegts \ --enable-demuxers \ --enable-parsers \ --enable-bsfs \ --enable-filters \ --enable-bzlib \ --enable-libspeex \ --enable-libx264 \ --enable-libx265 \ --enable-zlib \ --enable-asm \ --enable-neon \ --enable-libass \ --enable-libfdk-aac \ --enable-libfreetype \ --enable-libmp3lame \ --enable-libopus \ --enable-libvorbis \ --enable-libvpx make -j4 && make install && ldconfig && \ cd ../mpv && wget -q --show-progress --no-use-server-timestamps http://www.freehackers.org/~tnagy/release/waf-2.0.13 && \ mv waf-* waf && \ chmod u+x waf && \ ./waf configure && \ ./waf build -j4 && ./waf install && ldconfig Now copy necessary libs for mpv with this command cd ../ && cp libmali/lib/aarch64-linux-gnu/libmali-utgard-450-r7p0-gbm.so /usr/lib/aarch64-linux-gnu/gbm/libmali-utgard-450-r7p0-gbm.so && \ ln -sf /usr/lib/aarch64-linux-gnu/gbm/libmali-utgard-450-r7p0-gbm.so /usr/lib/aarch64-linux-gnu/gbm/libMali.so && \ ln -sf /usr/lib/aarch64-linux-gnu/gbm/libmali-utgard-450-r7p0-gbm.so /usr/lib/aarch64-linux-gnu/gbm/libgbm.so && \ ln -sf /usr/lib/aarch64-linux-gnu/gbm/libmali-utgard-450-r7p0-gbm.so /usr/lib/aarch64-linux-gnu/gbm/libgbm.so.1 && \ ln -sf /usr/lib/aarch64-linux-gnu/gbm/libmali-utgard-450-r7p0-gbm.so /usr/lib/aarch64-linux-gnu/gbm/libgbm.so.1.0.0 To start mpv you need command LD_LIBRARY_PATH=/usr/lib/aarch64-linux-gnu/gbm sudo mpv --hwdec=rkmpp --vo=gpu --gpu-api=opengl --gpu-context=drm <videofile> To use mpv with shortcut you need to add mpv to sudo list with this commands sudo visudo At the end of file add this lines, where USERNAME is your username USERNAME ALL=(ALL) NOPASSWD: /usr/local/bin/mpv USERNAME ALL=(ALL) NOPASSWD: /usr/local/etc/mpv then click ctrl+x and press y Now to create shortcut do this echo "[Desktop Entry] Type=Application Name=MPV Icon=mpv Exec=env LD_LIBRARY_PATH=/usr/lib/aarch64-linux-gnu/gbm sudo mpv --hwdec=rkmpp --vo=gpu --gpu-api=opengl --gpu-context=drm -- %f Icon=/usr/share/icons/gnome/48x48/categories/applications-multimedia.png Terminal=true Categories=Qt;AudioVideo;Player;Video; MimeType=application/ogg;application/x-ogg;application/mxf;application/sdp;application/smil;application/x-smil;application/streamingmedia;application/x-streamingmedia;application/vnd.rn-realmedia;application/vnd.rn-realmedia-vbr;audio/aac;audio/x-aac;audio/vnd.dolby.heaac.1;audio/vnd.dolby.heaac.2;audio/aiff;audio/x-aiff;audio/m4a;audio/x-m4a;application/x-extension-m4a;audio/mp1;audio/x-mp1;audio/mp2;audio/x-mp2;audio/mp3;audio/x-mp3;audio/mpeg;audio/mpeg2;audio/mpeg3;audio/mpegurl;audio/x-mpegurl;audio/mpg;audio/x-mpg;audio/rn-mpeg;audio/musepack;audio/x-musepack;audio/ogg;audio/scpls;audio/x-scpls;audio/vnd.rn-realaudio;audio/wav;audio/x-pn-wav;audio/x-pn-windows-pcm;audio/x-realaudio;audio/x-pn-realaudio;audio/x-ms-wma;audio/x-pls;audio/x-wav;video/mpeg;video/x-mpeg2;video/x-mpeg3;video/mp4v-es;video/x-m4v;video/mp4;application/x-extension-mp4;video/divx;video/vnd.divx;video/msvideo;video/x-msvideo;video/ogg;video/quicktime;video/vnd.rn-realvideo;video/x-ms-afs;video/x-ms-asf;audio/x-ms-asf;application/vnd.ms-asf;video/x-ms-wmv;video/x-ms-wmx;video/x-ms-wvxvideo;video/x-avi;video/avi;video/x-flic;video/fli;video/x-flc;video/flv;video/x-flv;video/x-theora;video/x-theora+ogg;video/x-matroska;video/mkv;audio/x-matroska;application/x-matroska;video/webm;audio/webm;audio/vorbis;audio/x-vorbis;audio/x-vorbis+ogg;video/x-ogm;video/x-ogm+ogg;application/x-ogm;application/x-ogm-audio;application/x-ogm-video;application/x-shorten;audio/x-shorten;audio/x-ape;audio/x-wavpack;audio/x-tta;audio/AMR;audio/ac3;audio/eac3;audio/amr-wb;video/mp2t;audio/flac;audio/mp4;application/x-mpegurl;video/vnd.mpegurl;application/vnd.apple.mpegurl;audio/x-pn-au;video/3gp;video/3gpp;video/3gpp2;audio/3gpp;audio/3gpp2;video/dv;audio/dv;audio/opus;audio/vnd.dts;audio/vnd.dts.hd;audio/x-adpcm;application/x-cue;audio/m3u;" > /usr/share/applications/demo-player.desktop 0 Quote
Dante4 Posted January 7, 2019 Posted January 7, 2019 @xorro, not as automated as script, but to be fair, what i wrote is mostly automated, except adding mpv to sudo for it to be able to start with root access 0 Quote
JMCC Posted January 7, 2019 Posted January 7, 2019 On 1/7/2019 at 12:36 PM, Dante4 said: So gstreamer can work in windowed and fullscreen. Mpv only fullscreen Expand Correct, there is no way to use windowed accelerated mpv. Gstreamer uses a hack to simulate X11 windowed playing. 1 Quote
Dante4 Posted January 7, 2019 Posted January 7, 2019 On 1/7/2019 at 1:00 PM, JMCC said: Correct, there is no way to use windowed accelerated mpv. Gstreamer uses a hack to simulate X11 windowed playing. Expand Thank you, that's interesting! That's interesting information. So that's why gstreamer is on 0 layers always. Is it possible to do something like this to get HW acceleration in browser? 0 Quote
xorro Posted January 11, 2019 Posted January 11, 2019 On 1/7/2019 at 12:42 PM, Dante4 said: @xorro, not as automated as script, but to be fair, what i wrote is mostly automated, except adding mpv to sudo for it to be able to start with root access Expand @Dante4, glorious. seriously, thank u for the in-depth walkthrough, I hope to give this a go this weekend. On 1/7/2019 at 11:57 AM, JMCC said: Be patient, guys, it's coming… Expand @JMCC, gracias. "Patience is bitter, but its fruit is sweet" 0 Quote
JMCC Posted January 15, 2019 Posted January 15, 2019 So the Media Script is finally released: 3 Quote
fanbowo Posted March 21, 2019 Posted March 21, 2019 On 12/8/2017 at 7:23 AM, Igor said: WIP https://libre.computer/products/boards/roc-rk3328-cc/ Pro: - yet another RK3328 Cons: - micro USB powering Expand Hello, Do you know whether this board really support eMMC5.x, or it just has that interface but can only reach the speed of eMMC4.x. Have you test the speed of writing to eMMC with this board. Thank you. 0 Quote
cibolajerry Posted December 4, 2020 Posted December 4, 2020 (edited) Please, can anyone explain to me how to flash Armbian to Libre Renegade emmc. It seems I've bought an unsupported by anyone computer. I at least have Armbian renegade current running off microsd. Edited December 4, 2020 by cibolajerry 0 Quote
jpegxguy Posted December 4, 2020 Posted December 4, 2020 Easiest way is to boot Armbian SD card and flash armbian to emmc from the board itself, honestly (It will show up as /dev/mmcblk0 - the one with the boot0 and boot1 sections) Librecomputer doesn't provide an easy external way to access the emmc. (Like SD adapter or something) I have noticed something very useful. If your u-boot supports it you can use ums command to get Renegade to act like a usb stick and access the emmc. But if you're asking how to flash, you'll probably be ok with the first option 0 Quote
JMCC Posted December 4, 2020 Posted December 4, 2020 On 12/4/2020 at 10:08 AM, cibolajerry said: Please, can anyone explain to me how to flash Armbian to Libre Renegade emmc. It seems I've bought an unsupported by anyone computer. I at least have Armbian renegade current running off microsd. Expand Did you try the standard Armbian method to install to emmc? Just type in the terminal sudo armbian-config Navigate through the menu to "System > Install" 0 Quote
JMCC Posted December 4, 2020 Posted December 4, 2020 Also notice that if you install Debian Buster + Legacy kernel, you can get 4k video play + X11 GPU acceleration + Kodi 18.9 with full acceleration, by typing sudo sudo apt install media-buster-legacy-rk3328 --install-recommends 0 Quote
EndtheFED Posted December 4, 2020 Posted December 4, 2020 You already have the sudo command to launch from terminal. Alternatively go to Panel menu and find Armbian-config. Launch it. Look for install. There is an option for emmc and SATA install. 0 Quote
cibolajerry Posted December 11, 2020 Posted December 11, 2020 On 12/4/2020 at 10:08 AM, cibolajerry said: Please, can anyone explain to me how to flash Armbian to Libre Renegade emmc. It seems I've bought an unsupported by anyone computer. I at least have Armbian renegade current running off microsd. Expand So, as you probably figured out, I'm new to armbian. Your information was helpful. I couldn't get the legacy version to boot; I did check the SHA sum on the download was valid. I did get current to boot and was successful at flashing it to emmc. Very good. I loaded LXQT. I have 2 problems: 1) USB flashdrives do not show up on device notifier 2) No sound on video playnack, I assume all audio via HDMI is out. As I see it my options are: A) retry and reflash legacy try to fix my current (current) setup - I'd like this if it isn't crazy C) armbian-config had option to switch to other kernel. It had disclaimer warnings and a number of kernels to select from, which one will work, work best? Will I need to fix the same problem on that? What do you all think is the easiest path for me? I would like to thank you all again; I was very pleased to get the renegade to run off the emmc. 0 Quote
JMCC Posted December 11, 2020 Posted December 11, 2020 On 12/11/2020 at 10:37 AM, cibolajerry said: What do you all think is the easiest path for me? Expand You can try to flash legacy directly to emmc. This method should work: Boot your board from a SD card with current. Login as root, typing `sudo -i` Flash legacy on emmc with this one-liner: wget https://redirect.armbian.com/renegade/Buster_legacy -O - | xzcat | dd of=/dev/mmcblk0 bs=1M You should be able to boot now from legacy on emmc. If you want to install desktop, you can do this: sudo apt update && sudo apt install armbian-buster-desktop media-buster-legacy-rk3328 --install-recommends ------------------------ Now, I'm going to ask a favor from you. Please describe the exact problem you were having when trying to boot legacy from SD card. I was also unable to do it, but I thought it was a failure on my board. Your testing can help us to fix a potential problem. Thanks. 0 Quote
cibolajerry Posted December 29, 2020 Posted December 29, 2020 On 12/11/2020 at 1:16 PM, JMCC said: You can try to flash legacy directly to emmc. This method should work: Boot your board from a SD card with current. Login as root, typing `sudo -i` Flash legacy on emmc with this one-liner: wget https://redirect.armbian.com/renegade/Buster_legacy -O - | xzcat | dd of=/dev/mmcblk0 bs=1M You should be able to boot now from legacy on emmc. If you want to install desktop, you can do this: sudo apt update && sudo apt install armbian-buster-desktop media-buster-legacy-rk3328 --install-recommends ------------------------ Now, I'm going to ask a favor from you. Please describe the exact problem you were having when trying to boot legacy from SD card. I was also unable to do it, but I thought it was a failure on my board. Your testing can help us to fix a potential problem. Thanks. Expand 0 Quote
cibolajerry Posted December 29, 2020 Posted December 29, 2020 Thanks for your last advice. I have not tried it yet but will. On booting legacy off sd card: after pulling emmc and flashing sdcard with legacy. and verifying sdcard by reading back and also doing sha256sum on download , I tried several times by repeating whole thing three or four times, The renegade does nothing to be seen except red and green LEDs, near power-in usb port, turn on and remain lit. waited for boot for minutes each time 0 Quote
cibolajerry Posted December 30, 2020 Posted December 30, 2020 On 12/11/2020 at 1:16 PM, JMCC said: You can try to flash legacy directly to emmc. This method should work: Boot your board from a SD card with current. Login as root, typing `sudo -i` Flash legacy on emmc with this one-liner: wget https://redirect.armbian.com/renegade/Buster_legacy -O - | xzcat | dd of=/dev/mmcblk0 bs=1M You should be able to boot now from legacy on emmc. If you want to install desktop, you can do this: sudo apt update && sudo apt install armbian-buster-desktop media-buster-legacy-rk3328 --install-recommends ------------------------ Now, I'm going to ask a favor from you. Please describe the exact problem you were having when trying to boot legacy from SD card. I was also unable to do it, but I thought it was a failure on my board. Your testing can help us to fix a potential problem. Thanks. Expand So I tried the one liner, it's not booting either, Now I'm going to try to reflash with current image. 0 Quote
cibolajerry Posted December 30, 2020 Posted December 30, 2020 On 12/11/2020 at 1:16 PM, JMCC said: You can try to flash legacy directly to emmc. This method should work: Boot your board from a SD card with current. Login as root, typing `sudo -i` Flash legacy on emmc with this one-liner: wget https://redirect.armbian.com/renegade/Buster_legacy -O - | xzcat | dd of=/dev/mmcblk0 bs=1M You should be able to boot now from legacy on emmc. If you want to install desktop, you can do this: sudo apt update && sudo apt install armbian-buster-desktop media-buster-legacy-rk3328 --install-recommends ------------------------ Now, I'm going to ask a favor from you. Please describe the exact problem you were having when trying to boot legacy from SD card. I was also unable to do it, but I thought it was a failure on my board. Your testing can help us to fix a potential problem. Thanks. Expand Shoot I failed. I did your one liner booting from emmc. I'll try the one liner again. 0 Quote
cibolajerry Posted December 31, 2020 Posted December 31, 2020 On 12/11/2020 at 1:16 PM, JMCC said: You can try to flash legacy directly to emmc. This method should work: Boot your board from a SD card with current. Login as root, typing `sudo -i` Flash legacy on emmc with this one-liner: wget https://redirect.armbian.com/renegade/Buster_legacy -O - | xzcat | dd of=/dev/mmcblk0 bs=1M You should be able to boot now from legacy on emmc. If you want to install desktop, you can do this: sudo apt update && sudo apt install armbian-buster-desktop media-buster-legacy-rk3328 --install-recommends ------------------------ Now, I'm going to ask a favor from you. Please describe the exact problem you were having when trying to boot legacy from SD card. I was also unable to do it, but I thought it was a failure on my board. Your testing can help us to fix a potential problem. Thanks. Expand So to remind, I'm trying to reflash the emmc with legacy, it currently boots properly to current. If i pull emmc i can boot to current on sdcard. After booting and plugging in emmc while running and trying out your one liner I get a " error writing to '/dev/mmcblk0': No space left on device". On looking at /dev/disk, mmcblk1 is only drive showing. Do you have any idea hot to proceed? 0 Quote
JMCC Posted December 31, 2020 Posted December 31, 2020 Show the output of lsblk and dfEnviado desde mi moto g(6) plus mediante Tapatalk 0 Quote
