https://github.com/siderolabs/sbc-rockchip/issues/103
I'm trying to apply this patch, but I think i'm doing something wrong it doesn't seem to be working. I'm getting the same behavior.
[    1.369895] rockchip-dw-pcie a41000000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G
[    2.224201] r8169 0003:31:00.0 eth0: jumbo features [frames: 16362 bytes, tx checksumming: ko]
[    1.504906] rockchip-dw-pcie a40800000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G
I tried putting the patch in:
build/userpatches/kernel/rockchip64-current/
Then I tried it in:
build/userpatches/kernel/archive/rockchip64-6.18/
because of this output:
[🌱] User patches directory for kernel [ /home/marv/rock5t/build/userpatches/kernel/archive/rockchip64-6.18 ]
Doesn't seem to get applied, when I transfer the 'new' rk3588-rock-5t.dtb file to my device, the 2ed interface doesn't turn on.
What am i doing wrong?
I tried logging it but doing a `|grep` or any `>  file.log` to `./compile.sh` and the script DOES NOT like it.  I had to CTRL+C out of the compile to get that log... it seems to build the dtb's at the beginning of the compilation (good thing for me)
At the very end of each compile.sh run there is a "curl" command which allows to upload the full build log to a paste service. This can also be done automatically by adding "SHARE_LOG=yes" to the command line. The URL is present at the very end of the process.
ok so here's what I did:
git clone https://github.com/armbian/build
cd build
./compile.sh BOARD=rock-5t BRANCH=current kernel-patch
edited build/cache/sources/linux-kernel-worktree/6.18__rockchip64__arm64/arch/arm64/boot/dts/rockchip/rk3588-rock-5t.dts
ended up with:
/home/marv/rock5t/build/output/patch/kernel-rockchip64-current.patch
cp output/patch/kernel-rockchip64-current.patch userpatches/kernel/rockchip64-current/
./compile.sh BOARD=rock-5t BRANCH=current RELEASE=trixie kernel-dtb
copied the new cache/sources/linux-kernel-worktree/6.18__rockchip64__arm64/arch/arm64/boot/dts/rockchip/rk3588-rock-5t.dtb over to my Rock5t /boot/dtb/rockchip/ folder, rebooted it, nothing changed, no 2ed nic.
https://paste.armbian.com/muwoxuqoza
