ilmarietto Posted May 28 Posted May 28 Hi everyone, I downloaded a 6.12.68 image for my Bigtreetech Pi, compatible with CB1-sd. After apt update and apt upgrade, onboard ethernet disappears. During update got these messages: - Err: 16 http://deb.debian.org/debian trixie-backports/main arm64 Packages.diff/Index Could't find the start of the patch series - Notice: Repository 'http... InRelease' changed its 'Version' value from '13.3' to '13.5' Launching a new apt update, error and notice disappear. After upgrade and reboot there is no more ethernet device, just wifi. Investigating a little I found the kernel module sunxi_gmac.ko that was present in folder /usr/lib/modules/... current... /kernel/net/ethernet/allwinner before upgrade, is now missing after upgrade. There is just a sun4i-emac.ko after upgrade. Plugging in an usb to ethernet adapter (Realtek r8152) works immediately, get eth0 and connect. Can someone help to restore onboard ethernet? Thanks, Mario 0 Quote
Solution JohnTheCoolingFan Posted May 28 Solution Posted May 28 There's been a few changes to make etehrnet work on H6 that broek it for H616/H618 seemingly. Your best course of action for now would be to downgrade to 6.12 and lock the `linux-*` from being upgraded. 0 Quote
ilmarietto Posted May 31 Author Posted May 31 Also a small display with ST7796 and ADS7846 on shared SPI stopped working. Downgraded to 6.12 and all works. When you solve it, if you remember, give me a shout. Thanks 0 Quote
mattjm Posted June 3 Posted June 3 I ran into this as well. Downgrade to kernel 6.12.58 fixed the physical interface. My board that initially had Trixie required the NetworkManager fix to get wifi working even after reverting. Something about the upgrade and/or downgrade broke netplan. 0 Quote
Raj Srikrishnan Posted 10 hours ago Posted 10 hours ago Any updates on this H6 vs H616 ethernet issue? 0 Quote
Werner Posted 6 hours ago Posted 6 hours ago 4 hours ago, Raj Srikrishnan said: Any updates on this H6 vs H616 ethernet issue? Should work on all devices 0 Quote
