BTT Pi - ethernet not working after upgrade from 6.12.68 to 6.18.33
Go to solution Solved by JohnTheCoolingFan,
Hi everyone,
I downloaded a 6.12.68 image for my Bigtreetech Pi, compatible with CB1-sd.
After apt update and apt upgrade, onboard ethernet disappears.
During update got these messages:
- Err: 16 http://deb.debian.org/debian trixie-backports/main arm64 Packages.diff/Index      Could't find the start of the patch series
- Notice: Repository 'http... InRelease' changed its 'Version' value from '13.3' to '13.5'
Launching a new apt update, error and notice disappear.
After upgrade and reboot there is no more ethernet device, just wifi.
Investigating a little I found the kernel module sunxi_gmac.ko that was present in folder /usr/lib/modules/... current... /kernel/net/ethernet/allwinner before upgrade, is now missing after upgrade. There is just a sun4i-emac.ko after upgrade.
Plugging in an usb to ethernet adapter (Realtek r8152) works immediately, get eth0 and connect.
Can someone help to restore onboard ethernet?
Thanks, Mario
Also a small display with ST7796 and ADS7846 on shared SPI stopped working.
Downgraded to 6.12 and all works.
When you solve it, if you remember, give me a shout.
Thanks
