Hi everyone,
I hope this topic is in the right place and won't bother anyone.
I'm pretty new to the ARM world. In very first i would like to thanks all people and the communities who work hard on Armbian.
I successfully use a NanoPC T6 Plus / A NanoPi M6 and other forks on some TV Box with no major problems.
My curiosity pushed me to try using Armbian on a MinisForum MS-R1, so i bought one and tried to boot up the KDE or Gnome image on it.
In the two case, the installation is a fail at the step of launching the desktop environment, it's stuck here.
The uefi is up to date with the lastest version (cix_flash_all2_MGP1WSB_20260429.bin20260429).
Ubuntu Concept Cix P1 runs correctly - The proprietary Debian image runs very great but it's limited to the Cix 6.6.x kernel
I would like to know if anyone else has experienced the same issues with this board. I did search the forum and tried a few things (using different images) but I might have missed something.
Thanks in advance for your help.
Edited by MetallixX974
Change of the title.
  • MetallixX974 changed the title to MinisForum MS-R1 CIX P1 CP8180 Uefi-arm64 Armbian KDE / Gnome
@Werner Thanks for the clarification. The cix-acpi KDE image does boot successfully, but Ethernet and Wi-Fi are not detected. So, if I understand correctly, the official images for the MinisForum MS-R1 are designed to work with a specific BIOS version — not just any generic one?
I will wait and follow updates, please consider to close this topic, i will comeback later, i know the MinisForum MS-R1 (SkyP1 on "Meigao" motherboard and Cix P1) is again very experimental at this time.
Armbian is great, thanks again to everyone who contribute to it.😉
@Werner Okay, i I'm starting to understand :
-The last bios is cix_flash_all2_MGP1WSB_20260429 -> Not ARM SystemReady BIOS ? That's it ? (It's the last update i flashed).
-And the link you mentionned is and older BIOS the cix_flash_all2_MGP1WSB_20260312.bin -> Is ARM SystemReady BIOS ?
That's correct ?
Ah okay, didn't notice you did the flashing already.
Did not test against the latest bios yet, only the 0312 one. So while unlikely, there could be a regression.
Right, no problem.
I’ll keep the April BIOS for now since it works fine with Ubuntu Concept Cix P1
If I ever need to test the SystemReady path, I'll consider flashing the March version.
Wait and see, as the saying goes 🙃
Thanks again for your help!
Hi @Werner,
So i have some good news. I managed to install properly the CIX-acpi KDE image :
CIX-acpi images Armbian
1) At first, my network is a 2.5G LAN so the network is not functional at the very first boot / installation. Plugged it in a 1Gbit and the link is up. However, Wi-Fi and Bluetooth were still not detected.
2) I ran a full
sudo apt update / upgrade
The "magic trick" that made all network functions work was:
sudo apt install armbian-firmware-full
After that, Wi-Fi and BT are fully operational, and it seems to have activated the major ACPI devices. I can even connect my BT audio amplifier. Video acceleration also appears to be working well. ( For example I can take advantage of my 144Hz screen... and 2.5 Gbit LAN is fine... )
 So i can connect it my BT audio amplifier.
I'm attaching the dmesg debug output in case it can help. dmesg.txt
giovanni@cix-acpi:~$ lsmod | column -t
Module                     Size     Used  by
uinput                     28672    1
snd_seq_dummy              12288    0
snd_hrtimer                12288    1
snd_seq                    98304    7     snd_seq_dummy
rfcomm                     98304    4
snd_seq_device             16384    1     snd_seq
qrtr                       45056    2
algif_hash                 16384    1
algif_skcipher             12288    1
af_alg                     28672    6     algif_hash,algif_skcipher
bnep                       32768    2
dm_mod                     180224   0
bfq                        102400   10
sunrpc                     696320   1
snd_soc_hdmi_codec         24576    3
optee_rng                  12288    0
binfmt_misc                24576    1
zram                       53248    2
842_decompress             20480    1     zram
842_compress               24576    1     zram
lz4hc_compress             20480    1     zram
lz4_compress               24576    1     zram
btusb                      73728    0
btrtl                      32768    1     btusb
btintel                    69632    1     btusb
btbcm                      24576    1     btusb
btmtk                      28672    1     btusb
nls_ascii                  12288    1
bluetooth                  921600   40    btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
nls_cp437                  16384    1
vfat                       24576    1
fat                        98304    1     vfat
ecdh_generic               16384    2     bluetooth
aes_ce_blk                 32768    4
aes_ce_cipher              12288    1     aes_ce_blk
polyval_ce                 12288    0
ghash_ce                   20480    0
gf128mul                   16384    1     ghash_ce
sha3_ce                    16384    0
mt7921e                    24576    0
mt7921_common              77824    1     mt7921e
mt792x_lib                 65536    2     mt7921e,mt7921_common
mt76_connac_lib            86016    3     mt792x_lib,mt7921e,mt7921_common
mt76                       147456   4     mt792x_lib,mt7921e,mt7921_common,mt76_connac_lib
mac80211                   1314816  4     mt792x_lib,mt76,mt7921_common,mt76_connac_lib
cfg80211                   1159168  4     mt76,mac80211,mt7921_common,mt76_connac_lib
snd_hda_codec_alc269       131072   1
snd_hda_scodec_component   20480    1     snd_hda_codec_alc269
rfkill                     40960    9     mt7921e,bluetooth,cfg80211
snd_hda_codec_realtek_lib  57344    1     snd_hda_codec_alc269
libarc4                    12288    1     mac80211
snd_hda_codec_generic      106496   2     snd_hda_codec_realtek_lib,snd_hda_codec_alc269
ramoops                    28672    0
reed_solomon               20480    1     ramoops
snd_hda_cix_ipbloq         24576    1
optee                      69632    0
snd_hda_codec              184320   4     snd_hda_codec_generic,snd_hda_codec_realtek_lib,snd_hda_codec_alc269,snd_hda_cix_ipbloq
ffa_core                   20480    1     optee
trilin_dpsub               131072   0
snd_hwdep                  20480    1     snd_hda_codec
tee                        45056    2     optee,optee_rng
snd_hda_core               135168   5     snd_hda_codec_generic,snd_hda_codec,snd_hda_codec_realtek_lib,snd_hda_codec_alc269,snd_hda_cix_ipbloq
snd_soc_sky1_card          24576    0
snd_soc_cdns_i2s_mc        24576    6
drm_display_helper         233472   1     trilin_dpsub
snd_soc_rt5682s            90112    0
panthor                    176128   42
cec                        61440    1     drm_display_helper
amvx                       344064   0
drm_gpuvm                  40960    1     panthor
rc_core                    65536    1     cec
videobuf2_dma_sg           20480    1     amvx
linlon_dp                  147456   10
snd_soc_core               360448   4     snd_soc_sky1_card,snd_soc_hdmi_codec,snd_soc_cdns_i2s_mc,snd_soc_rt5682s
gpu_sched                  57344    1     panthor
videobuf2_memops           16384    1     videobuf2_dma_sg
drm_exec                   12288    2     drm_gpuvm,panthor
drm_client_lib             12288    1     linlon_dp
videobuf2_v4l2             32768    1     amvx
drm_shmem_helper           28672    1     panthor
drm_dma_helper             24576    2     linlon_dp
squashfs                   77824    9
videodev                   335872   2     videobuf2_v4l2,amvx
snd_compress               28672    1     snd_soc_core
drm_kms_helper             217088   6     drm_dma_helper,linlon_dp,trilin_dpsub,drm_shmem_helper,drm_display_helper,drm_client_lib
snd_pcm_dmaengine          16384    1     snd_soc_core
snd_pcm                    172032   8     snd_hda_codec,snd_soc_hdmi_codec,snd_compress,snd_soc_core,snd_soc_cdns_i2s_mc,snd_hda_core,snd_soc_rt5682s,snd_pcm_dmaengine
videobuf2_common           77824    4     videobuf2_v4l2,videobuf2_dma_sg,amvx,videobuf2_memops
snd_timer                  45056    3     snd_seq,snd_hrtimer,snd_pcm
loop                       32768    18
mc                         77824    3     videodev,videobuf2_v4l2,videobuf2_common
snd                        126976   17    snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hwdep,snd_hda_codec,snd_soc_hdmi_codec,snd_timer,snd_hda_codec_realtek_lib,snd_compress,snd_hda_codec_alc269,snd_soc_core,snd_hda_cix_ipbloq,snd_pcm
cppc_cpufreq               24576    0
soundcore                  16384    1     snd
sg                         40960    0
joydev                     32768    0
evdev                      28672    11
i2c_dev                    24576    0
efi_pstore                 12288    0
configfs                   57344    1
efivarfs                   24576    0
autofs4                    53248    2
btrfs                      1888256  0
blake2b_generic            20480    0
xor                        12288    1     btrfs
xor_neon                   16384    1     xor
raid6_pq                   106496   1     btrfs
nvme                       53248    0
i2c_hid_acpi               12288    0
sbsa_gwdt                  12288    0
i2c_hid                    40960    1     i2c_hid_acpi
drm                        712704   40    gpu_sched,i2c_hid,drm_kms_helper,drm_exec,drm_dma_helper,linlon_dp,drm_gpuvm,trilin_dpsub,drm_shmem_helper,drm_display_helper,drm_client_lib,panthor
nvme_core                  200704   1     nvme
nvme_keyring               20480    1     nvme_core
r8169                      118784   0
nvme_auth                  28672    1     nvme_core
hkdf                       12288    1     nvme_auth
fixed                      16384    0
realtek                    45056    2
pwm_bl                     16384    0
arm_dma350                 28672    3
cdns3_pci_wrap             16384    0
sd_mod                     73728    2
hid_generic                12288    0
usbhid                     77824    0
hid                        266240   3     i2c_hid,usbhid,hid_generic
uas                        28672    2
usb_storage                86016    1     uas
scsi_mod                   282624   4     sd_mod,usb_storage,uas,sg
scsi_common                16384    5     scsi_mod,sd_mod,usb_storage,uas,sg
One question: what is the real difference between the MinisForum dedicated section images and these CIX ACPI dedicated section board images? Normally, the MinisForum is considered a standard "UEFI-ACPI" type of computer, right?
Thanks,
See'ya
Are you aware that 1 version of the Cix P1 bootloader/firmware is just crippled in such a way that it got a certification?
Other versions of bootloader/firmware might expose more via ACPI and/or DeviceTree, so sort of hybrid. I only know that from BCM2711 and RK3588 EDK2 UEFI what you would get as potential options then (several then). Also one can select vendor or mainline for RK3588. No clue what is possible for Cix P1. But I see many potential options.
For RK3588 (and other SoC's) also U-Boot in EFI mode can boot UEFI images, but it seems not a complete spec implementation also depends on what the kernel 'knows' form the specific SoC/platform (what is enabled in .config).
I think you should determine for yourself what the computer shall do and based on that, make a selection on what you apply and run to the computer, so everything that is programmable or even HW. Like if for example audio would be very important for you, you might want to add a good quality USB audio stick instead of waiting for on-board audio drivers to mature or something via a speaker in a HDMI monitor.
Hi, @eselarm
Thanks for the detailed explanation. I understand that the CIX P1 platform is still evolving and that the choice of firmware depends on the use case. I'll keep your advice in mind—especially about using a USB audio stick if needed. For now, I'm just trying to get the most stable system for everyday use (web, office, light gaming via streaming). I'll stick with the Armbian CIX ACPI image which seems to work well. Thanks again for your insights.
Just make a kernel update to the 6.18.44-current-cix-p1 and i had a DTB interference at the boot, after Grub:
So to resolve it :
sudo rm -rf /boot/dtb-6.18.44-current-cix-p1
sudo update-initramfs -u -k 6.18.44-current-cix-p1
sudo update-grub
sudo reboot
See'ya
Best Regards.
Was this just there as a directory or was and is also package dtb-6.18.44-current-cix-p1 installed?
If pure/only  ACPI and not something with hybrid DeviceTree, this DTB package should not be there and you better remove it else next kernel update you will have the same issue.
Also in latest Linux, the DTBs are in /usr/lib/modules/dtb/ anyway, so for some testing/merging U-Boot and standard PC UEFI firmware, I get them from there (is on a NanoPi-NEO, 32-bit ARM).
There is likely a grub customization for Cix-P1 boards so DTB can be loaded, I saw the same for Radxa Q6A.
On RPI4, I use UEFI in ACPI mode, so can use the standard method for Debian (or other distro) as on PC's.
If ACPI implementation is not good enough for your use-case, then maybe have a closer look at it as I can imagine that you might want to keep the option to boot in DeviceTree mode some time in the future maybe.
Hi @eselarm,
Oh thanks to you,
Seems you're right here the culprit! The folder is indeed installed by a package:
Since I'm running in pure ACPI mode, this package is unnecessary? Can I removed it safely with :
sudo apt remove linux-dtb-current-cix-p1
sudo update-grub
Will the system will update without re-installing this package after that ?
Thanks again for pointing me in the right direction.
Yes sure, else things are wrong. I removed those linux-dtb packages for my ROCK5B and NanoPi-R6C (both using EDK2 UEFIv1.1 RK3588) already quite some time ago. They use standard grub, no devicetree loading as the one provided in the EDK2 is new enough so all works for what I want with those 2 computers.
I also removed it on other installations (ROCK3A, NanoPi-NEO) as those use extlinux bootscript so I can select various kernels and load the dtb just from /usr/lib
@eselarm Yes i will look it for my NanoPC T6 Plus, i know i can flash SPInor with the EDK II Uefi, seems interesting 🤔.
@Werner To get back to the original discussion, thanks again for all the help. All is now fine 😄
My Armbian setup on the MinisForum MS-R1 has exceeded my expectations; I absolutely love it !
Honestly? Given the current RAM prices, I’m really glad I managed to grab this MinisForum MS-R1 CIX P1 (with its CP8180 and 64 GB of RAM). I got it for a really good price, and as you can see in the screenshot, it runs KDE Plasma beautifully with 64 GB of headroom. It's a beast for homelab tasks! 🤗
