13 minutes ago, Igor said:
The problem affects only sunxi so reverting anything else is useless.
14 minutes ago, Igor said:
At least upstream those problems should be fixed by now.
It is mostly our problem that upstream changes break booting with our old boot script and that we have automated u-boot upgrade procedure instead of manual.
The problem was there too but different kind of. I switch dev and next which lead to troubles with OMV installations.
At least setting this to "yes"?
https://github.com/armbian/build/blob/master/config/templates/config-example.conf#L22
Replacing bootloader on your eMMC
Boot from SD card.
mkdir tmp
cd tmp
# replace this URL with the one for your board! This is for Orange pi plus 2e
wget http://apt.armbian.com/pool/main/l/linux-u-boot-orangepiplus2e-default/linux-u-boot-orangepiplus2e_5.39_armhf.deb
dpkg -x *.deb .
root_uuid=$(sed -e 's/^.*root=//' -e 's/ .*$//' < /proc/cmdline)
root_partition_device=$(blkid | tr -d '":' | grep ${root_uuid} | awk '{print $1}' | tr -d '"/dev')
emmc="/dev/"$(cat /proc/partitions | grep -v ${root_partition::-2} | grep mmcblk | awk '{print $4}' | head -1)
# adjust the path accordingly to your board - downloaded file
dd if=usr/lib/linux-u-boot-orangepiplus2e_5.35_armhf/u-boot-sunxi-with-spl.bin of=$emmc bs=1024 seek=8 status=noxfer
If you want to flash your SD card on external SD card reader:
sdcard=/dev/sda # make sure this is SD card and not your hard drive!!
dd if=usr/lib/linux-u-boot-orangepiplus2e_5.35_armhf/u-boot-sunxi-with-spl.bin of=$sdcard bs=1024 seek=8 status=noxfer
I just did an upgrade of my ODROID hc1:
root@hc1:/home/user#apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
  armbian-config armbian-firmware armbian-tools-jessie hostapd linux-dtb-next-odroidxu4 linux-jessie-root-next-odroidxu4 linux-u-boot-odroidxu4-next sunxi-tools
8 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 3,306 kB of archives.
After this operation, 137 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://apt.armbian.com/ jessie/main armbian-config all 5.38 [30.0 kB]
Get:8 http://apt.armbian.com/ jessie/jessie-utils sunxi-tools armhf 1.4.2-2~armbian5.38+1 [36.2 kB]
Fetched 3,306 kB in 12s (273 kB/s)
(Reading database ... 48425 files and directories currently installed.)
Preparing to unpack .../armbian-config_5.38_all.deb ...
Processing triggers for initramfs-tools (0.120+deb8u3) ...
update-initramfs: Generating /boot/initrd.img-4.9.61-odroidxu4
cryptsetup: WARNING: failed to detect canonical device of /dev/mmcblk1p2
W: mdadm: /etc/mdadm/mdadm.conf defines no arrays.
W: mdadm: no arrays defined in configuration file.
update-initramfs: Converting to u-boot format
Setting up armbian-config (5.38) ...
Setting up armbian-firmware (5.38) ...
Setting up armbian-tools-jessie (5.38) ...
Setting up hostapd (2:2.6-4~armbian5.38+1) ...
Setting up linux-dtb-next-odroidxu4 (5.38) ...
Setting up linux-jessie-root-next-odroidxu4 (5.38) ...
Setting up linux-u-boot-odroidxu4-next (5.38) ...
Updating u-boot on /dev/mmcblk1
Setting up sunxi-tools (1.4.2-2~armbian5.38+1) ...Shell-Script
Quellcode bearbeiten
    root@hc1:/home/user# ls /boot
    armbian_first_run.txt.template  boot-desktop.png  boot.ini.out             dtb                    dtb.old                      lost+found                   uInitrd                   vmlinuz-4.9.61-odroidxu4
    boot.bmp                        boot.ini          config-4.9.61-odroidxu4  dtb-4.14.15-odroidxu4  initrd.img-4.9.61-odroidxu4  System.map-4.9.61-odroidxu4  uInitrd-4.9.61-odroidxu4  zImage
    root@hc1:/home/user# reboot
After reboot I can not reach the machine any more via browser or ssh. The machine does not connect to my router any more.
LEDs look normal.
Power cycling did not help.
This happened to me once before when updating OMV itself. At that time I did a time consuming reinstallation via a new image loaded from Sourgeforge.
Note that kernel updates went smooth on this setup before and the cryptsetup error is to be expected since I have a LUKS-encrypted data storage (decrypted after boot via the web interface).
I speculate that the problem lies in getting a dtb (5.38) which does not fit the kernel 4.9.61 (5.earlier).
Is there anything I could do to avoid a new installation?
"it should be o.k."
yeah but it is/was NOT! pulling my leg?
I think I got caught between repository updates...
Manually (dissecting the deb-file) I installed linux-dtb-next-odroidxu4_5.39_armhf
Now it works again:
root@hc1:/# apt upgrade
  linux-dtb-next-odroidxu4 linux-u-boot-odroidxu4-next
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 343 kB of archives.
After this operation, 137 kB disk space will be freed.
Get:1 http://apt.armbian.com/ jessie/main linux-dtb-next-odroidxu4 armhf 5.39 [75.0 kB]
Get:2 http://apt.armbian.com/ jessie/main linux-u-boot-odroidxu4-next armhf 5.39 [268 kB]
Fetched 343 kB in 1s (214 kB/s)
(Reading database ... 48427 files and directories currently installed.)
Preparing to unpack .../linux-dtb-next-odroidxu4_5.39_armhf.deb ...
Unpacking linux-dtb-next-odroidxu4 (5.39) over (5.38) ...
Preparing to unpack .../linux-u-boot-odroidxu4-next_5.39_armhf.deb ...
Unpacking linux-u-boot-odroidxu4-next (5.39) over (5.38) ...
Setting up linux-dtb-next-odroidxu4 (5.39) ...
Setting up linux-u-boot-odroidxu4-next (5.39) ...
root@hc1:/# reboot
Boot from SD card.
mkdir tmpcd tmp# replace this URL with the one for your board! This is for Orange pi plus 2ewget http://apt.armbian.com/pool/main/l/linux-u-boot-orangepiplus2e-default/linux-u-boot-orangepiplus2e_5.39_armhf.debdpkg -x *.deb . root_uuid=$(sed -e 's/^.*root=//' -e 's/ .*$//' root_partition_device=$(blkid | tr -d '":' | grep ${root_uuid} | awk '{print $1}' | tr -d '"/dev')emmc="/dev/"$(cat /proc/partitions | grep -v ${root_partition::-2} | grep mmcblk | awk '{print $4}' | head -1)# adjust the path accordingly to your board - downloaded file        dd if=usr/lib/linux-u-boot-orangepiplus2e_5.35_armhf/u-boot-sunxi-with-spl.bin of=$emmc bs=1024 seek=8 status=noxfer
sdcard=/dev/sda # make sure this is SD card and not your hard drive!!dd if=usr/lib/linux-u-boot-orangepiplus2e_5.35_armhf/u-boot-sunxi-with-spl.bin of=$sdcard bs=1024 seek=8 status=noxfer
Where should it copy the extracted file
Sent from my AO5510 using Tapatalk
Somewhere between problem was recognized and fixed, yes. :wacko: When most people will just use this product, drop few pennies and not actively participating in testings, this will not change - we simply have too many different boards and variants. We can cut them down in half but the problem will remain. I recently developed a system for quick repository update, that packages can be quickly fixed in case of such problems, but that is all that I can do on the technical part of the problem.  At least you were able to solve this without step by step guides.
Of course, it is our my fault for providing this service with having sufficient resources.
Forget about changing u-boot, replace rather boot script. It is more simple and actually the fix for the problem.
1. Boot with SDcard
2. Mount /dev/mmcblk2p1 /mnt # on some cases it will be mmcblk1p1
3. cd /mnt/boot
4. wget https://raw.githubusercontent.com/armbian/build/master/config/bootscripts/boot-sunxi.cmd
5. mv boot-sunxi.cmd boot.cmd
6. mkimage -C none -A arm -T script -d boot.cmd boot.scr
7. power off,
8. remove SD and boot from eMMC
Igor - don't take it personally.
It is fixed now. Thank you!
I really do not want to test on my only/production hc1 and just happened to not test on my xu4 which I normally do - once a month.
This time I did an upgrade because Baikal does not come up.
That is the next problem I will have to fix ...
At least I will drop a "few pennies" like:
2017-09-01    OMV                  PayPal        50 EUR
Thanks, for me solution with manual download and "dd" to emmc works as well. Opi+2 is up & running now. For Opi+2e - tomorrow I will try (have a little more issues with physical access to device).
Replacing boot script with this one https://github.com/armbian/build/blob/master/config/bootscripts/boot-sunxi.cmd and its recompilation is another/proper solution. In case we forget to add a boot script to next update, the problem might resurface.
1. Boot with SDcard
3. cd /mnt/boot
6. mkimage -C none -A arm -T script -d boot.scr boot.cmd
7. power off,
error
mkimage: can't stat boot.scr: No such file or directory
typo
By mistake i gave command for /boot/boot.cmd and it's still give me error
Done "just in case" (on already up & running opi+2):
root@PKHELPER:/boot# ll
total 14276
-rw-r--r-- 1 root root    2372 Jun  5  2016 boot.cmd
-rw-r--r-- 1 root root    2444 Jun  5  2016 boot.scr
lrwxrwxrwx 1 root root      20 Aug  4 23:09 script.bin -> bin/orangepiplus.bin
-rwxr-xr-x 1 root root 4752384 Jan 24 22:10 vmlinuz-3.4.113-sun8i
-rw-r--r-- 1 root root 2056747 Jan 24 22:10 System.map-3.4.113-sun8i
-rw-r--r-- 1 root root   97199 Jan 24 22:10 config-3.4.113-sun8i
drwxr-xr-x 2 root root    4096 Jan 29 17:57 bin
lrwxrwxrwx 1 root root      21 Jan 29 17:59 zImage -> vmlinuz-3.4.113-sun8i
-rw-r--r-- 1 root root 3839674 Jan 29 17:59 initrd.img-3.4.113-sun8i
-rw-r--r-- 1 root root 3839738 Jan 29 17:59 uInitrd-3.4.113-sun8i
lrwxrwxrwx 1 root root      21 Jan 29 17:59 uInitrd -> uInitrd-3.4.113-sun8i
root@PKHELPER:/boot# wget https://raw.githubusercontent.com/armbian/build/master/config/bootscripts/boot-sunxi.cmd
--2018-01-30 17:32:16--  https://raw.githubusercontent.com/armbian/build/master/config/bootscripts/boot-sunxi.cmd
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 3636 (3.6K) [text/plain]
Saving to: ‘boot-sunxi.cmd’
boot-sunxi.cmd                            100%[=======================================================================================>]   3.55K  --.-KB/s   in 0.001s
2018-01-30 17:32:16 (6.88 MB/s) - ‘boot-sunxi.cmd’ saved [3636/3636]
total 14280
-rw-r--r-- 1 root root    3636 Jan 30 17:32 boot-sunxi.cmd
root@PKHELPER:/boot# mv boot-sunxi.cmd boot.cmd
root@PKHELPER:/boot# mkimage -C none -A arm -T script -d boot.cmd boot.scr
Image Name:
Created:      Tue Jan 30 17:33:53 2018
Image Type:   ARM Linux Script (uncompressed)
Data Size:    3644 Bytes = 3.56 kB = 0.00 MB
Load Address: 00000000
Entry Point:  00000000
Contents:
   Image 0: 3636 Bytes = 3.55 kB = 0.00 MB
total 14276
-rw-r--r-- 1 root root    3636 Jan 30 17:32 boot.cmd
-rw-r--r-- 1 root root    3708 Jan 30 17:33 boot.scr
Device is still booting - OK :)...
Preparing such copy/paste instruction is a nightmare :( You need to be in /mnt/boot/ and there you run mkimage without a path.
I have not updated yet.
I can't understand if this can affect my OPI zero or not. Can you please point this out?
you could.... by reading this thread..
On 29.1.2018 at 7:56 PM, guidol said:
All my Boards did boot after the 5.38 update
- NPi Neo2
- NPi Duo
- NPi Neo Core2
- OPi Zero
- OPi Zero Plus H5
- OPi One
Dear,
Thanks for all your guidance/help.
U help me get my pi working back normally,
Thanks
For now and to be realistic, we can further minimize possibility:
- split u-boot package and kernel for updating.
- create a bulletproof recovery method: perhaps even auto-revert if booting after update not successful
- release one kernel(images) at once
