It seems the Armbian test image for the NanoPi-K2 only works on an SD card.  At least mine doesn't seem to boot when I put it on the 8GB eMMC module.  Is there an eMMC armbian image for the NanoPi-K2 or is there something I need to do to get the existing image to boot on the eMMC module?
I'm afraid there is not, eMMC requires a few changes to files that I haven't worked through, and I don't have an eMMC for the K2 available.
I also don't have eMMC for K2 but I know that this function is also broken on Odroid C2, which is almost identical to K2. Most eMMC cards don't work ... well, except mine :)
Unfortunately, there is no known quick fix for this problem.
That's a bummer.  It wasn't an expensive little bit to add to it, but I would like to use it.  They do have a ubuntu-core eMMC image out there, but that doesn't have a desktop ui.  :(
