Abelard Posted February 26, 2018 Posted February 26, 2018 HowTo: Setting up resolution 1600x900 & 1366x768 ? &how can i set up other resolutions those are not in h3disp like 1600x900 board is orangepi-pc
tommy Posted March 1, 2018 Posted March 1, 2018 There is no official support for those resolution on legacy kernel. Only mainline kernel supports those resolutions.
Igor Posted March 1, 2018 Posted March 1, 2018 ... but by observing this patch and doing some search and reading results, one can add new screen resolution on his own. 1
Abelard Posted March 3, 2018 Author Posted March 3, 2018 On 2018/3/1 at 6:41 PM, Igor said: ... but by observing this patch and doing some search and reading results, one can add new screen resolution on his own. which patch can add 1600x900 ?
jernej Posted March 3, 2018 Posted March 3, 2018 3 hours ago, Abelard said: which patch can add 1600x900 ? I'm not sure there is one. Igor just gave you pointers to create it.
Abelard Posted March 3, 2018 Author Posted March 3, 2018 I have already downloaded the patch,but there is no 1600*900.Can you help me add 1600*900 to the patch or tell me the way how to create it.Thanks
Tido Posted March 3, 2018 Posted March 3, 2018 1 hour ago, Abelard said: tell me the way how to create it. you go here https://docs.armbian.com/Process_Contribute/ to: How? on Igor's link I have collected the headlines per section: The lines 153, 190 and 301 table look like the bit it is needed to add your screen. Now look at those lines and ask your Monitor Vendor, the manual of your Monitor, Google, Yahoo or Bing about this information for your device. Once you have this information: you go here https://docs.armbian.com/Process_Contribute/ to: How? and Booooom everything works.
Abelard Posted March 3, 2018 Author Posted March 3, 2018 I dont know how to add in line 153,190 and 301.And i dont know how to use the link you gave,https://docs.armbian.com/Process_Contribute/, Can you help me plz.The patch i downloaded from the link that Igor gave. I really need more heip,thanks.
Tido Posted March 3, 2018 Posted March 3, 2018 give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime I showed you how to fish ;-)
Abelard Posted March 3, 2018 Author Posted March 3, 2018 I'm trying to add something in line 153,190 and 301.But how can i get the information about those line with the resolution i want(1600*900),Can you tell me how to find these informations,thanks.
Tido Posted March 3, 2018 Posted March 3, 2018 Good - you got it. Well, I am self are looking for such information for 800x600 1024x600 1920x1200 I search for display timing and the resolution.. it is a bit of a pain - but I don't know any better
Tido Posted March 3, 2018 Posted March 3, 2018 Is your display connected to a Linux Desktop where everything works, than you can try that: === Commands to read out the EDID of the Monitor - open two terminal windows and try: in one: man xrandr (here you can find a lot) in the other: xrandr --verbose
Tido Posted March 3, 2018 Posted March 3, 2018 Haven't read it yet, looks interesting: https://en.wikipedia.org/wiki/Extended_Display_Identification_Data
Tido Posted March 4, 2018 Posted March 4, 2018 coming closer to the solution: http://www.arunviswanathan.com/node/53 Using xrandr and gtf to add a new mode to your X configuration at runtime. Now I don't know how much the difference is between x86 & ARM in that regard, but that tool seems to calculate the appropriate numbers..
Abelard Posted March 5, 2018 Author Posted March 5, 2018 I cant open the website:http://www.arunviswanathan.com/node/53,And have you find the way to add?
Abelard Posted March 14, 2018 Author Posted March 14, 2018 On 2018/3/1 at 6:41 PM, Igor said: ... but by observing this patch and doing some search and reading results, one can add new screen resolution on his own. Hi,Igor. I got some informations about 1600*900, but i dont know how to build a new patch, can you help me to build? Thanks + {{42(I'm not sure) , 4 , 0, 0, 6, 3, 3, 1, 3, 0, 0, 64, 96, 24, 168, 132, 37, 1, 1 }}, + {HDMI1600_900P, 0,119000000, 0, 1600, 900, 2128, 264, 96, 168, 932, 28, 1, 3, 0, 1, 0, 0, 0}, pll_video = 476
