Which Linux is running?
Stefan Anderson
Can you please help me to find the used Linux Version?
This is the boot output via Serial.
I need the Linux Version which is used.
U-Boot SPL 2017.05-g64c4ffa (Oct 20 2017 - 15:30:13)
DRAM: 256 MiB
Trying to boot from MMC1
U-Boot 2017.05-g64c4ffa (Oct 20 2017 - 15:30:13 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi Zero
DRAM:  256 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
gpio: pin PA17 (gpio 17) value is 1
35424 bytes read in 128 ms (269.5 KiB/s)
4777536 bytes read in 745 ms (6.1 MiB/s)
Starting kernel ...
[sun8i_fixup]: From boot, get meminfo:
        Start:  0x40000000
ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1
ion_reserve_select: ion chipid  [0x2c00042!
ion_reserve_common: ion reserve: [0x47e00000, 0x50000000]!
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.113-sun8i (root@jenkins) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #24 SMP PREEMPT Fri Jul 21 13:20:01 CEST 2017
[    0.000000] cma: dma_declare_contiguous(266): ION reserve size should be 4m align! adjust size to 128MBytes
[    0.000000] cma: CMA: reserved 128 MiB at 48000000
[    0.000000] PERCPU: Embedded 8 pages/cpu @c0d18000 s11968 r8192 d12608 u32768
[    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p1 rootwait panic=10
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] allocated 524288 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 256MB = 256MB total
[    0.000000] Memory: 116304k/116304k available, 145840k reserved, 0K highmem
<5[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xd0800000 - 0xff000000   ( 744 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc08cd2cc   (8981 kB)
[    0.000000]       .init : 0xc08ce000 - 0xc0920ec0   ( 332 kB)
[    0.000000]       .data : 0xc0922000 - 0xc09924f0   ( 450 kB)
[    0.000000]        .bss : 0xc0992ca4 - 0xc0ac62c0   (1230 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:544
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000412] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000465] pid_max: default: 32768 minimum: 301
[    0.000789] Security Framework initialized
[    0.000835] AppArmor: AppArmor disabled by boot time parameter
[    0.001227] Mount-cache hash table entries: 512
[    0.003257] Initializing cgroup subsys cpuacct
[    0.003292] Initializing cgroup subsys memory
[    0.003384] Initializing cgroup subsys devices
[    0.003413] Initializing cgroup subsys freezer
[    0.003441] Initializing cgroup subsys blkio
[    0.003490] Initializing cgroup subsys perf_event
[    0.003657] CPU: Testing write buffer coherency: ok
[    0.003750] ftrace: allocating 24760 entries in 73 pages
[    0.060556] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.060594] [sunxi_smp_prepare_cpus] enter
<[    0.062578] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.062741] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.070967] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.080348] Brought up 4 CPUs
[    0.080383] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.081799] devtmpfs: initialized
[    0.087357] wakeup src cnt is : 2.
[    0.090043] sunxi pm init
[    0.090336] pinctrl core: initialized pinctrl subsystem
[    0.100804] NET: Registered protocol family 16
[    0.103091] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.103230] script_sysfs_init success
[    0.105123] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.105123] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.105123] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.105123] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.105123] script config pll_video to 297 Mhz
[    0.105123] script config pll_de to 864 Mhz
[    0.105123] script config pll_ve to 402 Mhz
<[    0.120431] bio: create slab <bio-0> at 0
[    0.120649] [ARISC] :sunxi-arisc driver v1.04
[    0.142478] [ARISC] :arisc version: [v0.1.58]
[    0.251424] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.254656] SCSI subsystem initialized
[    0.254656] usbcore: registered new interface driver usbfs
[    0.254656] usbcore: registered new interface driver hub
[    0.260092] usbcore: registered new device driver usb
[    0.260325] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.260354] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.260380] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.261883] Linux video capture interface: v2.00
[    0.262378] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.262378] cfg80211: Calling CRDA to update world regulatory domain
[    0.262378] NetLabel: Initializing
[    0.262378] NetLabel:  domain hash size = 128
[    0.262378] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.262378] NetLabel:  unlabeled traffic allowed by default
[    0.262378] Switching to clocksource arch_sys_counter
[    0.287142] FS-Cache: Loaded
[    0.287704] CacheFiles: Loaded
[    0.311424] NET: Registered protocol family 2
[    0.334862] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.335990] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.336276] TCP bind hash table entries: 8192 (order: 4, 98304 bytes)
[    0.336561] TCP: Hash tables configured (established 8192 bind 8192)
[    0.336586] TCP: reno registered
[    0.336610] UDP hash table entries: 128 (order: 0, 4096 bytes)
[    0.336673] UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
[    0.337359] NET: Registered protocol family 1
[    0.338192] RPC: Registered named UNIX socket transport module.
[    0.338219] RPC: Registered udp transport module.
[    0.338239] RPC: Registered tcp transport module.
[    0.338258] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.338988] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.339203] sunxi_reg_init enter
[    0.340934] audit: initializing netlink socket (disabled)
[    0.341038] type=2000 audit(0.340:1): initialized
[    0.343714] VFS: Disk quotas dquot_6.5.2
[    0.345225] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.346040] NFS: Registering the id_resolver key type
[    0.346831] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.346861] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.348379] NTFS driver 2.1.30 [Flags: R/W].
[    0.349006] fuse init (API version 7.18)
[    0.349853] msgmni has been set to 483
[    0.352821] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.352860] io scheduler noop registered (default)
[    0.353689] [DISP]disp_module_init
[    0.354284] cmdline,init_disp=
[    0.354341] cmdline,disp=
[    0.362940] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed!
[    0.379904] Console: switching to colour frame buffer device 90x36
[    0.399145] [DISP]disp_module_init finish
[    0.399612] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.399648] sw_uart_get_devinfo()1503 - uart1 has no uart_regulator.
[    0.399680] sw_uart_get_devinfo()1503 - uart2 has no uart_regulator.
[    0.400690] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.400721] sw_uart_pm()890 - uart0 clk is already enable
[    0.400759] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.513410] console [ttyS0] enabled
[    1.159701] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[    1.160325] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    1.170216] brd: module loaded
[    1.195587] loop: module loaded
[    1.199619] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    1.206811] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
[    1.215269] spi spi0: master is unqueued, this is deprecated
[    1.222883] spi spi1: master is unqueued, this is deprecated
[    1.231307] PPP generic driver version 2.4.2
[    1.236500] PPP BSD Compression module registered
[    1.241833] PPP Deflate Compression module registered
[    1.249125] PPP MPPE Compression module registered
[    1.254568] NET: Registered protocol family 24
[    1.259674] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.287188] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.296263] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    1.305878] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    1.330072] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    1.337964] hub 1-0:1.0: USB hub found
[    1.342264] hub 1-0:1.0: 1 port detected
[    1.367457] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.376526] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    1.386045] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    1.410083] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    1.417819] hub 2-0:1.0: USB hub found
[    1.422108] hub 2-0:1.0: 1 port detected
[    1.447285] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.456361] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3
[    1.465855] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    1.490078] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    1.497924] hub 3-0:1.0: USB hub found
[    1.502218] hub 3-0:1.0: 1 port detected
[    1.527419] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.536488] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4
[    1.546062] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000
[    1.570077] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    1.577833] hub 4-0:1.0: USB hub found
[    1.582114] hub 4-0:1.0: 1 port detected
[    1.587334] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.614450] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.623125] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5
[    1.631715] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    1.695202] hub 5-0:1.0: USB hub found
[    1.699445] hub 5-0:1.0: 1 port detected
[    1.724789] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.733475] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6
[    1.742058] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    1.805207] hub 6-0:1.0: USB hub found
[    1.809448] hub 6-0:1.0: 1 port detected
[    1.834711] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.843381] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7
[    1.851964] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    1.915154] hub 7-0:1.0: USB hub found
[    1.919397] hub 7-0:1.0: 1 port detected
[    1.944564] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.953296] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8
[    1.961899] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    2.025106] hub 8-0:1.0: USB hub found
[    2.029344] hub 8-0:1.0: 1 port detected
[    2.034532] Initializing USB Mass Storage driver...
[    2.040702] usbcore: registered new interface driver usb-storage
[    2.047461] USB Mass Storage support registered.
[    2.052799] usbcore: registered new interface driver ums-alauda
[    2.059539] usbcore: registered new interface driver ums-cypress
[    2.066414] usbcore: registered new interface driver ums-datafab
[    2.073286] usbcore: registered new interface driver ums_eneub6250
[    2.080370] usbcore: registered new interface driver ums-freecom
[    2.087208] usbcore: registered new interface driver ums-isd200
[    2.093998] usbcore: registered new interface driver ums-jumpshot
[    2.100981] usbcore: registered new interface driver ums-karma
[    2.107635] usbcore: registered new interface driver ums-onetouch
[    2.114633] usbcore: registered new interface driver ums-realtek
[    2.121524] usbcore: registered new interface driver ums-sddr09
[    2.128269] usbcore: registered new interface driver ums-sddr55
[    2.135121] usbcore: registered new interface driver ums-usbat
[    2.143503] mousedev: PS/2 mouse device common for all mice
[    2.150276] sunxikbd_init failed.
[    2.154133] ls_fetch_sysconfig_para: ls_unused.
[    2.159953] [RTC] WARNING: Rtc time will be wrong!!
[    2.165476] [RTC] WARNING: use *internal OSC* as clock source
[    2.172489] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    2.180052] i2c /dev entries driver
[    2.185658] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18)
[    2.195195] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19)
[    2.204720] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    2.214246] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29)
[    2.223786] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    2.233311] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    2.242829] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    2.252353] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    2.261871] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    2.271422] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
[    2.280958] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
[    2.290506] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    2.300037] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
[    2.300119] usb 7-1: new full-speed USB device number 2 using sunxi-ohci
[    2.317166] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    2.326709] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    2.336256] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    2.345820] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    2.355356] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    2.364691] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    2.372098] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    2.383590] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    2.391175] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    2.397447] timeout_to_interv, line 167
[    2.401790] interv_to_timeout, line 189
[    2.406108] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    2.416148] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    2.426113] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq
[    2.447262] no blue_led, ignore it!
[    2.451866] no led_0, ignore it!
[    2.455466] no led_1, ignore it!
[    2.459063] no led_2, ignore it!
[    2.462697] no led_3, ignore it!
[    2.466296] no led_4, ignore it!
[    2.469892] no led_5, ignore it!
[    2.473510] no led_6, ignore it!
[    2.477109] no led_7, ignore it!
[    2.482350] usbcore: registered new interface driver usbhid
[    2.488595] usbhid: USB HID core driver
[    2.500924] asoc: sndcodec <-> sunxi-codec mapping ok
[    2.508685] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    2.519441] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    2.523738] mmc0: new SD card at address 0001
[    2.524584] mmcblk0: mmc0:0001 SD 1.86 GiB
[    2.526634]  mmcblk0: p1 p2 p3
[    2.528306] mmcblk mmc0:0001: Card claimed for testing.
[    2.528330] mmc0:0001: SD 1.86 GiB
[    2.551863] [DAUDIO0] driver not init,just return.
[    2.563962] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    2.572698] oprofile: using arm/armv7-ca7
[    2.577515] u32 classifier
[    2.580576]     Performance counters on
[    2.584850]     input device check on
[    2.588929]     Actions configured
[    2.593313] TCP: bic registered
[    2.596820] TCP: cubic registered
[    2.600544] TCP: westwood registered
[    2.604530] TCP: highspeed registered
[    2.608611] TCP: hybla registered
[    2.612334] TCP: htcp registered
[    2.615932] TCP: vegas registered
[    2.619626] TCP: veno registered
[    2.623248] TCP: scalable registered
[    2.627234] TCP: lp registered
[    2.630662] TCP: yeah registered
[    2.634261] TCP: illinois registered
[    2.638244] Initializing XFRM netlink socket
[    2.643437] NET: Registered protocol family 10
[    2.650401] NET: Registered protocol family 17
[    2.655398] NET: Registered protocol family 15
[    2.660450] Registering the dns_resolver key type
[    2.665977] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    2.674578] ThumbEE CPU extension supported.
[    2.679364] Registering SWP/SWPB emulation handler
[    2.685826] registered taskstats version 1
[    2.691889] cmdline,disp=
[    2.695161] [DISP] disp_init_tv,line:539:screen 0 do not support TV TYPE!
[    2.702795] [DISP] bsp_disp_tv_register,line:998:'ptv is null
[    2.709279] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr1<-->device1, type=2, mode=11
[    2.715920] ths_fetch_sysconfig_para: type err  device_used = 1.
[    2.718143] CPU Budget:corekeeper enabled
[    2.718544] CPU Budget:Register notifier
[    2.718563] CPU Budget:register Success
[    2.718586] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    2.878854] mmc1: new high speed SDIO card at address 0001
[    2.925627] ALSA device list:
[    2.928937]   #0: audiocodec
[    2.932184]   #1: sndhdmi
[    2.937915] EXT4-fs (mmcblk0p1): mounting ext3 file system using the ext4 subsystem
[    2.969437] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    2.978595] VFS: Mounted root (ext3 filesystem) on device 179:1.
[    2.991927] devtmpfs: mounted
[    2.995883] Freeing init memory: 328K
INIT: version 2.88 booting
[    3.717246] EXT4-fs (mmcblk0p3): warning: mounting unchecked fs, running e2fsck is recommended
[    3.732946] EXT4-fs (mmcblk0p3): mounted filesystem without journal. Opts: data=ordered
Starting udev
[    3.953086] udevd[107]: starting version 3.2.1
[    4.059850] udevd[111]: starting eudev-3.2.1
[    4.281029] vmouse_input_dev_open
[    4.330277] vmouse_input_dev_close
[    5.034467] [XRADIO] Driver Label:L34M.01.08.0002  Aug 23 2017 12:45:26
[    5.042137] [XRADIO] Allocated hw_priv @ c6e23240
[    5.047612] [XRADIO_ERR] Access_file failed, path:/data/xr_wifi.conf!
[    5.055485] [SBUS] XRadio Device:sdio clk=50000000
[    5.061191] xradio wlan power on
[    5.216927] [XRADIO] Detect SDIO card 1
[    5.567651] [XRADIO_ERR] xradio_load_firmware: can't read config register, err=-110.
[    5.576358] [XRADIO_ERR] xradio_load_firmware failed(-110).
[    5.903842] xradio wlan power off
[    5.957614] [XRADIO] Remove SDIO card 1
[    5.957881] mmc1: card 0001 removed
[    6.064081] [XRADIO_ERR] xradio_host_dbg_init failed=2599
[    6.070179] [XRADIO] Driver Label:L34M.01.08.0002  Aug 23 2017 12:45:26
[    6.077654] [XRADIO] Allocated hw_priv @ c7189240
[    6.083122] [XRADIO_ERR] Access_file failed, path:/data/xr_wifi.conf!
[    6.090914] xradio wlan power on
[    6.246659] [XRADIO] Detect SDIO card 1
[    6.298829] mmc1: new high speed SDIO card at address 0001
[    6.305674] [SBUS] XRadio Device:sdio clk=50000000
[    6.312054] [XRADIO] XRADIO_HW_REV 1.0 detected.
[    6.449236] [XRADIO] Bootloader complete
[    6.564680] [XRADIO] Firmware completed.
[    6.571313] [WSM] Firmware Label:XR_C01.08.0043 Jun  6 2016 20:41:04
[    6.579913] [XRADIO] Firmware Startup Done.
[    6.717410] EXT4-fs (mmcblk0p1): re-mounted. Opts: data=ordered
[    6.883172] usb 7-1: USB disconnect, device number 2
[    7.900869] i2c i2c-0: new_device: Instantiated device pcf8523 at 0x68
[    7.917756] rtc-pcf8523 0-0068: rtc core: registered rtc-pcf8523 as rtc1
rm: can't remove '/tmp': Read-only file system
[    8.380205] usb 7-1: new full-speed USB device number 3 using sunxi-ohci
rm: can't remove '/etc/resolv.conf': Read-only file system
ln: /etc/resolv.conf: File exists
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting Connection Manager
Starting Dropbear SSH server: Starting watchdog: dropbear.
[  OK  ]
Starting bluetooth
bluetoothd
[   10.466257] gmac0: probed
[   10.469677] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00)
Starting ntpd: done
Starting radvd:
* /etc/radvd.conf does not exist or is empty.
* See /usr/share/doc/radvd/radvd.conf.example for a simple
* configuration suitable for most systems, and radvd.conf(5)
* for configuration file syntax. radvd will *not* be started.
Starting syslogd/klogd: done
Starting Telephony daemon
Starting crond: OK
vm.panic_on_oom = 1
kernel.panic = 5
56 minutes ago, Stefan Anderson said:
I cant use the latest Armbian for the Orange Pi Zero because after ~3h the eth0 is crashing.
Then you must use some experimental/development version of Armbian.  Use this image: https://dl.armbian.com/orangepizero/Ubuntu_xenial_default.7z or https://dl.armbian.com/orangepizero/Debian_jessie_default.7z if you prefer Debian.
I do run
ARMBIAN 5.41.180208 nightly Ubuntu 16.04.3 LTS 4.14.18-sunxi
on my OPi Zero now for weeks without crashing eth0 - I only restart it once a week after "apt upgrade"
(but I got the 512MiB-version of the OPi Zero)
