tkaiser Posted April 19, 2018 Posted April 19, 2018 http://wiki.friendlyarm.com/wiki/index.php/NanoPi_K1_Plus RPi 3 form factor like their K2, maximum DRAM (2GB), Gigabit Ethernet, Wi-Fi with onboard aerial provided by RTL8189ETV, still using their own/new eMMC socket. According to schematics and their Github repo a SY8106A voltage regulator is used which is great news since then it's possible to clock the H5 well above 1.3 GHz. 2
guidol Posted April 19, 2018 Posted April 19, 2018 1 hour ago, tkaiser said: Gigabit Ethernet provided by RTL8211E like on the NanoPi A64 or the Banana Pi M64
tkaiser Posted April 19, 2018 Author Posted April 19, 2018 10 minutes ago, guidol said: RTL8211E like on the NanoPi A64 or the Banana Pi M64 RTL8211 is used as PHY on all GbE capable SBC I know. The majority of boards uses RTL8211E, some RTL8211F and Olimex used also RTL8211CL a while ago. Pretty much irrelevant since always the GbE MAC implementation lives inside the SoC and the RTL8211 PHY is just attached via RGMII (so the MAC and PCIe parts of these RealTek chips are not used on SBC anyway. Might change soon since more and more SoCs are PCIe equipped). But even on the soon to be released Orange Pi R2 the two RTL8211E are only used as PHY and attached via RGMII (RTD1296 has 3 GbE MACs but only one internal GbE PHY so for the two additional GbE interfaces external PHYs are needed): 1
TonyMac32 Posted April 20, 2018 Posted April 20, 2018 Very nice. They dropped the 5V barrel jack though I see... 1
Tido Posted April 20, 2018 Posted April 20, 2018 4 hours ago, TonyMac32 said: They dropped the 5V barrel jack though I was also wondering, TK promotes Micro USB with H5??
tkaiser Posted April 20, 2018 Author Posted April 20, 2018 6 hours ago, TonyMac32 said: They dropped the 5V barrel jack though I see Not really. A barrel jack was only on the K2, all other FriendlyELEC boards only have Micro USB for DC-IN (they sell a very good Micro USB cable for as less than 2 bucks) a 4 pin connector suitable to be combined with their PSU-ONECOM module (allowing to attach a 4.0/1.7mm barrel PSU) Just check http://www.friendlyarm.com/index.php?route=product/product&path=69&product_id=176, scroll to the bottom and check Shipping List. The more expensive boards ready to attach a lot of USB consumers are always sold with their great Micro USB cable (20 AWG rated or something like that. Pretty safe wrt voltage drops)
TonyMac32 Posted April 20, 2018 Posted April 20, 2018 It was said only in relation to 20 hours ago, tkaiser said: RPi 3 form factor like their K2
TonyMac32 Posted May 11, 2018 Posted May 11, 2018 I should have one early next week, I'm a sucker for new toys, and have been an on and off customer of FriendlyARM for a long time. :-)
Igor Posted May 11, 2018 Posted May 11, 2018 1 hour ago, TonyMac32 said: I should have one early next week, I'm a sucker for new toys, and have been an on and off customer of FriendlyARM for a long time. :-) Mine is also on the way and I will have one spare.
@lex Posted May 16, 2018 Posted May 16, 2018 (edited) On 4/19/2018 at 12:05 PM, tkaiser said: Wi-Fi with onboard aerial provided by RTL8189ETV I don't see a driver for it on the mainline kernel, any ideas? ahh, ok, seems to be RTL8189ES... Edited May 16, 2018 by @lex
TonyMac32 Posted May 16, 2018 Posted May 16, 2018 Mine arrived, no time to play with it yet, been putting in 10-12 hours a day at my regular job... :-(
cycologist Posted May 18, 2018 Posted May 18, 2018 I tried the Friendlyelec Nanopi Neo 2 Armbian image and booting initiated, a few messages were printed on the screen, but after the 'now loading kernel' message, the board froze. Based on this, I assume adapting Armbian to the K1 Plus should not be too difficult. Is there a good tutorial on how to do this? I am comfortable with configuring and compiling / installing Linux kernels on Ubuntu and Arch Linux, but have limited experience with preparing images for arm based SoC boards.
TonyMac32 Posted May 18, 2018 Posted May 18, 2018 3 hours ago, cycologist said: how to do this I experimentally booted an orange pi PC 2 image on mine. Starting from there and correcting the device tree to match the actual hardware should be sufficient 1
@lex Posted May 19, 2018 Posted May 19, 2018 6 hours ago, TonyMac32 said: I experimentally booted an orange pi PC 2 image on mine. Starting from there and correcting the device tree to match the actual hardware should be sufficient I think that was the FE approach. I took a step further, i pulled linus 4.17.rc5, applied the 8189es patch and sy8189a patch, adjusted DT and it's working smooth. Just a small note, i could not get SPI to work, i suspect there is something with rtl8189etv. I wired the 2.8" LCD and wlan stopped working but could be some of my mistakes. the rtl wifi keeps spitting ==> rtl8188e_iol_efuse_patch , removing the LCD wlan worked again. [ 6.767828] RTL8211E Gigabit Ethernet 0.2:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=0.2:00, irq=POLL) [ 6.769361] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available [ 6.769375] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW [ 6.769932] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 6.899748] random: crng init done [ 6.899755] random: 7 urandom warning(s) missed due to ratelimiting [ 7.193944] ==> rtl8188e_iol_efuse_patch [ 7.481112] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 7.965815] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0 [ 7.972452] rtc-ds1307: probe of 0-0068 failed with error -110 [ 34.781921] ==> rtl8188e_iol_efuse_patch [ 39.737899] ==> rtl8188e_iol_efuse_patch [ 52.573897] ==> rtl8188e_iol_efuse_patch [ 62.545893] ==> rtl8188e_iol_efuse_patch [ 76.741896] ==> rtl8188e_iol_efuse_patch [ 81.502589] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx [ 81.502625] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 96.705898] ==> rtl8188e_iol_efuse_patch [ 111.133896] ==> rtl8188e_iol_efuse_patch i have chosen ubuntu 18.04 but i found it bloated, systemd has a lot of useless or unnecessary services , ubuntu 16.04 still better tuned. Without hdmi (enabled) Temp is way low in idle node. Unfortunately, i could not grab any info from this kernel... I think NEO2 with sy8189 will really shine.
@lex Posted May 25, 2018 Posted May 25, 2018 (edited) I would like to throw some numbers here gathered with kernel 4.17.rc6 though i don't know if it is good or bad. Seems to be very conservative. I did not find any suitable cpuburn on ubuntu 18.04. sudo sysbench --test=cpu --cpu-max-prime=20000 --threads=4 run && cat /sys/devices/virtual/thermal/thermal_zone0/temp WARNING: the --test option is deprecated. You can pass a script name or path on the command line without any options. sysbench 1.0.11 (using system LuaJIT 2.1.0-beta3) Running the test with following options: Number of threads: 4 Initializing random number generator from current time Prime numbers limit: 20000 Initializing worker threads... Threads started! CPU speed: events per second: 1081.94 General statistics: total time: 10.0031s total number of events: 10829 Latency (ms): min: 3.67 avg: 3.69 max: 23.10 95th percentile: 3.68 sum: 39997.95 Threads fairness: events (avg/stddev): 2707.2500/10.85 execution time (avg/stddev): 9.9995/0.00 44700 cpufreq-info -c 1 cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 1: driver: cpufreq-dt CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 maximum transition latency: 2.54 ms. hardware limits: 120 MHz - 1.37 GHz available frequency steps: 120 MHz, 240 MHz, 480 MHz, 528 MHz, 648 MHz, 672 MHz, 720 MHz, 768 MHz, 792 MHz, 816 MHz, 864 MHz, 912 MHz, 936 MHz, 960 MHz, 1.01 GHz, 1.06 GHz, 1.08 GHz, 1.10 GHz, 1.15 GHz, 1.20 GHz, 1.22 GHz, 1.25 GHz, 1.30 GHz, 1.34 GHz, 1.37 GHz available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil current policy: frequency should be within 120 MHz and 1.37 GHz. The governor "ondemand" may decide which speed to use within this range. current CPU frequency is 648 MHz. cpufreq stats: 120 MHz:41.54%, 240 MHz:20.22%, 480 MHz:9.63%, 528 MHz:5.36%, 648 MHz:2.36%, 672 MHz:1.31%, 720 MHz:1.67%, 768 MHz:0.65%, 792 MHz:0.57%, 816 MHz:1.10%, 864 MHz:1.34%, 912 MHz:0.60%, 936 MHz:0.36%, 960 MHz:0.43%, 1.01 GHz:0.58%, 1.06 GHz:0.30%, 1.08 GHz:0.26%, 1.10 GHz:0.32%, 1.15 GHz:0.52%, 1.20 GHz:0.57%, 1.22 GHz:0.32%, 1.25 GHz:0.69%, 1.30 GHz:0.34%, 1.34 GHz:0.00%, 1.37 GHz:8.98% (12516) running 12 x sysbench sudo sysbench --test=cpu --cpu-max-prime=20000 --threads=4 run && cat /sys/devices/virtual/thermal/thermal_zone0/temp WARNING: the --test option is deprecated. You can pass a script name or path on the command line without any options. sysbench 1.0.11 (using system LuaJIT 2.1.0-beta3) Running the test with following options: Number of threads: 4 Initializing random number generator from current time Prime numbers limit: 20000 Initializing worker threads... Threads started! CPU speed: events per second: 1078.11 General statistics: total time: 10.0034s total number of events: 10791 Latency (ms): min: 3.67 avg: 3.71 max: 23.34 95th percentile: 3.68 sum: 39996.37 Threads fairness: events (avg/stddev): 2697.7500/23.50 execution time (avg/stddev): 9.9991/0.00 58513 cpufreq-info -c 1 cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 1: driver: cpufreq-dt CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 maximum transition latency: 2.54 ms. hardware limits: 120 MHz - 1.37 GHz available frequency steps: 120 MHz, 240 MHz, 480 MHz, 528 MHz, 648 MHz, 672 MHz, 720 MHz, 768 MHz, 792 MHz, 816 MHz, 864 MHz, 912 MHz, 936 MHz, 960 MHz, 1.01 GHz, 1.06 GHz, 1.08 GHz, 1.10 GHz, 1.15 GHz, 1.20 GHz, 1.22 GHz, 1.25 GHz, 1.30 GHz, 1.34 GHz, 1.37 GHz available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil current policy: frequency should be within 120 MHz and 1.37 GHz. The governor "ondemand" may decide which speed to use within this range. current CPU frequency is 1.37 GHz. cpufreq stats: 120 MHz:45.29%, 240 MHz:20.85%, 480 MHz:8.56%, 528 MHz:4.79%, 648 MHz:2.15%, 672 MHz:1.32%, 720 MHz:1.37%, 768 MHz:0.72%, 792 MHz:0.51%, 816 MHz:0.94%, 864 MHz:1.01%, 912 MHz:0.42%, 936 MHz:0.25%, 960 MHz:0.34%, 1.01 GHz:0.40%, 1.06 GHz:0.19%, 1.08 GHz:0.18%, 1.10 GHz:0.16%, 1.15 GHz:0.27%, 1.20 GHz:0.35%, 1.22 GHz:0.31%, 1.25 GHz:0.63%, 1.30 GHz:0.21%, 1.34 GHz:0.00%, 1.37 GHz:8.78% (37950) Edited May 25, 2018 by @lex running > 10 times
@lex Posted May 25, 2018 Posted May 25, 2018 Tweaked DTS, some other numbers: cryptsetup benchmark # Tests are approximate using memory only (no storage IO). PBKDF2-sha1 294543 iterations per second for 256-bit key PBKDF2-sha256 525865 iterations per second for 256-bit key PBKDF2-sha512 215578 iterations per second for 256-bit key PBKDF2-ripemd160 171335 iterations per second for 256-bit key PBKDF2-whirlpool 75328 iterations per second for 256-bit key argon2i 4 iterations, 229155 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time) argon2id 4 iterations, 231680 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time) # Algorithm | Key | Encryption | Decryption aes-cbc 128b 328.1 MiB/s 378.3 MiB/s serpent-cbc 128b 29.1 MiB/s 31.2 MiB/s twofish-cbc 128b 43.4 MiB/s 47.1 MiB/s aes-cbc 256b 287.6 MiB/s 351.6 MiB/s serpent-cbc 256b 29.1 MiB/s 31.2 MiB/s twofish-cbc 256b 43.4 MiB/s 47.1 MiB/s aes-xts 256b 344.4 MiB/s 345.0 MiB/s serpent-xts 256b 31.0 MiB/s 31.9 MiB/s twofish-xts 256b 47.7 MiB/s 48.4 MiB/s aes-xts 512b 321.7 MiB/s 322.3 MiB/s serpent-xts 512b 31.0 MiB/s 31.9 MiB/s twofish-xts 512b 47.6 MiB/s 48.4 MiB/s
@lex Posted May 25, 2018 Posted May 25, 2018 ./tinymembench tinymembench v0.4.9 (simple benchmark for memory throughput and latency) ========================================================================== == Memory bandwidth tests == == == == Note 1: 1MB = 1000000 bytes == == Note 2: Results for 'copy' tests show how many bytes can be == == copied per second (adding together read and writen == == bytes would have provided twice higher numbers) == == Note 3: 2-pass copy means that we are using a small temporary buffer == == to first fetch data into it, and only then write it to the == == destination (source -> L1 cache, L1 cache -> destination) == == Note 4: If sample standard deviation exceeds 0.1%, it is shown in == == brackets == ========================================================================== C copy backwards : 1099.0 MB/s (0.9%) C copy backwards (32 byte blocks) : 1095.5 MB/s (0.9%) C copy backwards (64 byte blocks) : 1086.3 MB/s (0.4%) C copy : 1097.6 MB/s (1.2%) C copy prefetched (32 bytes step) : 892.8 MB/s (0.3%) C copy prefetched (64 bytes step) : 993.4 MB/s C 2-pass copy : 1096.8 MB/s C 2-pass copy prefetched (32 bytes step) : 758.1 MB/s C 2-pass copy prefetched (64 bytes step) : 714.6 MB/s C fill : 3859.1 MB/s (0.1%) C fill (shuffle within 16 byte blocks) : 3856.1 MB/s C fill (shuffle within 32 byte blocks) : 3856.9 MB/s C fill (shuffle within 64 byte blocks) : 3854.5 MB/s --- standard memcpy : 1116.0 MB/s (0.3%) standard memset : 3858.4 MB/s (0.1%) --- NEON LDP/STP copy : 1124.8 MB/s (0.2%) NEON LDP/STP copy pldl2strm (32 bytes step) : 799.7 MB/s (0.4%) NEON LDP/STP copy pldl2strm (64 bytes step) : 963.3 MB/s NEON LDP/STP copy pldl1keep (32 bytes step) : 1164.5 MB/s NEON LDP/STP copy pldl1keep (64 bytes step) : 1164.5 MB/s NEON LD1/ST1 copy : 1109.6 MB/s (0.5%) NEON STP fill : 3860.1 MB/s (0.1%) NEON STNP fill : 3584.2 MB/s (0.7%) ARM LDP/STP copy : 1126.1 MB/s (0.2%) ARM STP fill : 3858.9 MB/s ARM STNP fill : 3584.7 MB/s (0.8%) ========================================================================== == Memory latency test == == == == Average time is measured for random memory accesses in the buffers == == of different sizes. The larger is the buffer, the more significant == == are relative contributions of TLB, L1/L2 cache misses and SDRAM == == accesses. For extremely large buffer sizes we are expecting to see == == page table walk with several requests to SDRAM for almost every == == memory access (though 64MiB is not nearly large enough to experience == == this effect to its fullest). == == == == Note 1: All the numbers are representing extra time, which needs to == == be added to L1 cache latency. The cycle timings for L1 cache == == latency can be usually found in the processor documentation. == == Note 2: Dual random read means that we are simultaneously performing == == two independent memory accesses at a time. In the case if == == the memory subsystem can't handle multiple outstanding == == requests, dual random read has the same timings as two == == single reads performed one after another. == ========================================================================== block size : single random read / dual random read, [MADV_NOHUGEPAGE] 1024 : 0.0 ns / 0.0 ns 2048 : 0.0 ns / 0.0 ns 4096 : 0.0 ns / 0.0 ns 8192 : 0.0 ns / 0.0 ns 16384 : 0.0 ns / 0.0 ns 32768 : 0.0 ns / 0.0 ns 65536 : 5.0 ns / 8.4 ns 131072 : 7.7 ns / 11.7 ns 262144 : 9.0 ns / 13.1 ns 524288 : 10.6 ns / 15.0 ns 1048576 : 94.4 ns / 145.3 ns 2097152 : 139.6 ns / 187.6 ns 4194304 : 168.3 ns / 208.4 ns 8388608 : 183.7 ns / 217.9 ns 16777216 : 192.6 ns / 224.3 ns 33554432 : 197.2 ns / 228.1 ns 67108864 : 201.0 ns / 232.2 ns block size : single random read / dual random read, [MADV_HUGEPAGE] 1024 : 0.0 ns / 0.0 ns 2048 : 0.0 ns / 0.0 ns 4096 : 0.0 ns / 0.0 ns 8192 : 0.0 ns / 0.0 ns 16384 : 0.0 ns / 0.0 ns 32768 : 0.0 ns / 0.0 ns 65536 : 5.0 ns / 8.4 ns 131072 : 7.7 ns / 11.7 ns 262144 : 9.0 ns / 13.1 ns 524288 : 10.6 ns / 14.8 ns 1048576 : 94.4 ns / 145.3 ns 2097152 : 139.0 ns / 186.9 ns 4194304 : 161.5 ns / 200.8 ns 8388608 : 172.7 ns / 205.8 ns 16777216 : 177.9 ns / 208.0 ns 33554432 : 180.3 ns / 209.1 ns 67108864 : 181.5 ns / 209.6 n cpufreq-info -c 1 cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 1: driver: cpufreq-dt CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 maximum transition latency: 2.54 ms. hardware limits: 480 MHz - 1.37 GHz available frequency steps: 480 MHz, 648 MHz, 720 MHz, 768 MHz, 912 MHz, 1.08 GHz, 1.20 GHz, 1.37 GHz available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil current policy: frequency should be within 480 MHz and 1.37 GHz. The governor "performance" may decide which speed to use within this range. current CPU frequency is 1.37 GHz. cpufreq stats: 480 MHz:7.33%, 648 MHz:2.53%, 720 MHz:0.54%, 768 MHz:0.92%, 912 MHz:0.75%, 1.08 GHz:0.68%, 1.20 GHz:0.59%, 1.37 GHz:86.66% (3239)
@lex Posted May 25, 2018 Posted May 25, 2018 last numbers: openssl speed -elapsed -evp aes-256-cbc You have chosen to measure elapsed time instead of user CPU time. Doing aes-256-cbc for 3s on 16 size blocks: 21097762 aes-256-cbc's in 3.00s Doing aes-256-cbc for 3s on 64 size blocks: 13885050 aes-256-cbc's in 3.00s Doing aes-256-cbc for 3s on 256 size blocks: 5712407 aes-256-cbc's in 3.00s Doing aes-256-cbc for 3s on 1024 size blocks: 1744124 aes-256-cbc's in 3.00s Doing aes-256-cbc for 3s on 8192 size blocks: 232965 aes-256-cbc's in 3.00s Doing aes-256-cbc for 3s on 16384 size blocks: 116966 aes-256-cbc's in 3.00s OpenSSL 1.1.0g 2 Nov 2017 built on: reproducible build, date unspecified options:bn(64,64) rc4(char) des(int) aes(partial) blowfish(ptr) compiler: gcc -DDSO_DLFCN -DHAVE_DLFCN_H -DNDEBUG -DOPENSSL_THREADS -DOPENSSL_NO_STATIC_ENGINE -DOPENSSL_PIC -DOPENSSL_BN_ASM_MONT -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DVPAES_ASM -DECP_NISTZ256_ASM -DPOLY1305_ASM -DOPENSSLDIR="\"/usr/lib/ssl\"" -DENGINESDIR="\"/usr/lib/aarch64-linux-gnu/engines-1.1\"" The 'numbers' are in 1000s of bytes per second processed. type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes 16384 bytes aes-256-cbc 112521.40k 296214.40k 487458.73k 595327.66k 636149.76k cpufreq-info -c 1 cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 1: driver: cpufreq-dt CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 maximum transition latency: 2.54 ms. hardware limits: 480 MHz - 1.37 GHz available frequency steps: 480 MHz, 648 MHz, 720 MHz, 768 MHz, 912 MHz, 1.08 GHz, 1.20 GHz, 1.37 GHz available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil current policy: frequency should be within 480 MHz and 1.37 GHz. The governor "performance" may decide which speed to use within this range. current CPU frequency is 1.37 GHz. cpufreq stats: 480 MHz:4.74%, 648 MHz:1.64%, 720 MHz:0.35%, 768 MHz:0.59%, 912 MHz:0.48%, 1.08 GHz:0.44%, 1.20 GHz:0.38%, 1.37 GHz:91.36% (3239) at least, 4.17 pretty stable... I think there is room for improvement, board does not get Temp over 54 ºC so lets the experts handle this... 1
cmcgaha Posted June 20, 2018 Posted June 20, 2018 Any news on an Armbian OS for the Nano Pi K1 Plus? Thanks
guidol Posted June 30, 2018 Posted June 30, 2018 On 5/11/2018 at 9:53 AM, Igor said: Mine is also on the way and I will have one spare. I ordered my NanoPi K1 Plus today. I like the H5 CPU (OPi Zero Plus2 H5, OPi Zero Plus H5, NanoPi Neo2, NanoPi Neo Core2) and with the K1 Plus = 2GB of Ram. That will be much better vor Headless-usage...I didnt use a Desktop at SBCs. Also Gigabit-Ethernet I did think the last weeks (after my OPi Zerp Plus2 H5) which SBC to buy.... I did leave behind the NanoPi Fire3 - and the Nano K2 wouldnt have a new CPU for me (S905 = my Ordoid C2).... The H5 is well known to me and new boards does run cooler for me (Opi Zero Plus2 H5 at around 30 degree here in the summer time) Hoping for DVFS in 4.18 as igor said
@lex Posted June 30, 2018 Posted June 30, 2018 17 minutes ago, guidol said: Hoping for DVFS in 4.18 as igor said How do you test it to make sure it is working as expected?
guidol Posted June 30, 2018 Posted June 30, 2018 8 minutes ago, @lex said: How do you test it to make sure it is working as expected? I cant test it, because 4.18 isnt released and I do only hope that it will be tue in the "near" future of 4.18
@lex Posted June 30, 2018 Posted June 30, 2018 (edited) I mean what tests you would do in order to make sure DVFS is indeed working, think of the any actual board that is supposed to have DVFS working. Edited June 30, 2018 by @lex * any
guidol Posted June 30, 2018 Posted June 30, 2018 1 hour ago, @lex said: I mean what tests you would do in order to make sure DVFS is indeed working, think of the any actual board that is supposed to have DVFS working. I would do some (stress)-tests which do need a high cpu load and see if it will switch the frequency up & down the right way and take a look at the cpu temperatures meanwhile. The guy - Christopher Barnatt - from ExplainingComputers at Youtube often check the speed and heat from many SBCs.... so I think this tests are a good idea to test the board, the DVFS switching, performance and temperature.https://www.youtube.com/channel/UCbiGcwDWZjz05njNPrJU7jAhttps://www.explainingcomputers.com/sbc.html
@lex Posted June 30, 2018 Posted June 30, 2018 1 hour ago, guidol said: I would do some (stress)-tests which do need a high cpu load and see if it will switch the frequency up & down the right way and take a look at the cpu temperatures meanwhile. This is already working on 4.17.3. The question is what is "right way" . I think is necessary to measure the CPU voltage point for each CPU at peak times. Here is the 7z b after uptime for 22:30:00: 7-Zip [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,4 CPUs LE) LE CPU Freq: 794 1365 1363 1365 1365 1364 1365 1364 1364 RAM size: 1999 MB, # CPU hardware threads: 4 RAM usage: 882 MB, # Benchmark threads: 4 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 2113 328 626 2056 | 57763 395 1248 4928 23: 2089 331 643 2129 | 54905 392 1212 4751 24: 2056 332 667 2211 | 48069 356 1185 4220 25: 2009 331 692 2294 | 49941 390 1140 4445 ---------------------------------- | ------------------------------ Avr: 331 657 2172 | 383 1196 4586 Tot: 357 927 3379 Screenshot before the test (idle.png) Screenshot during the test (7zb.png ) Screenshot after the test (idle2.png) During the test: Every 2.0s: ../h5-monitor.sh nanopi-k1-plus: Sat Jun 30 21:05:16 2018 CPU1 freq : 1248 MHz CPU2 freq : 1248 MHz CPU3 freq : 1248 MHz CPU4 freq : 1248 MHz CPU5 count : 4 Governor : ondemand SOC Temp : 66 C Idle after the test: Every 2.0s: ../h5-monitor.sh nanopi-k1-plus: Sat Jun 30 21:12:23 2018 CPU1 freq : 648 MHz CPU2 freq : 648 MHz CPU3 freq : 936 MHz CPU4 freq : 1008 MHz CPU count : 4 Governor : ondemand SOC Temp : 38 C For whatever reason reading CPU freq in straight C always get the peak freq.
guidol Posted July 14, 2018 Posted July 14, 2018 Today I received my K1 Plus (and also a black ICY BOX IB-RP102 Case) I booted Armbian_5.47_Nanopik1plus_Debian_stretch_next_4.14.51 and Armbian_5.46.180622_Nanopik1plus_Debian_stretch_dev_4.17.2 but doesnt get a DHCP-request from the K1 Plus So I used a USB-Ethernet-Dongle...which did request a IP via DHCP After that I configured eth0 as static and now my K1 Plus is useable with both images. Armbian_5.46.180622_Nanopik1plus_Debian_stretch_dev_4.17.2 did update to ARMBIAN 5.52.180712 nightly Debian GNU/Linux 9 (stretch) 4.18.0-rc4-sunxi64 Linux npi-k1-plus 4.18.0-rc4-sunxi64 #214 SMP Fri Jul 13 00:03:19 UTC 2018 aarch64 GNU/Linux
Igor Posted July 14, 2018 Posted July 14, 2018 1 hour ago, guidol said: but doesnt get a DHCP-request from the K1 Plus Huh, you mean none, not even non-nightly build? IIRC it was working for me when I tried ... armbianmonitor -u
TonyMac32 Posted July 14, 2018 Posted July 14, 2018 2 hours ago, guidol said: and also a black ICY BOX IB-RP102 Case I see that on Amazon.de, but not amazon.com for us colonists... top and bottom have no holes, but that certainly looks sharp. Add it to the "Pi-factor cases" topic?
guidol Posted July 14, 2018 Posted July 14, 2018 3 hours ago, Igor said: Huh, you mean none, not even non-nightly build? IIRC it was working for me when I tried ... yes on both I he didnt request a IP via DHCP - so I used a USB-Ethernet-Dongle.... (also had the chance for using HDMI-console and Keyboard) before the Dongle I checked several times with nmap - but no IP in my DHCP-Range (.150-.200) Here the output of armbianmonitor -u: System diagnosis information will now be uploaded to http://ix.io/1hbi
