GFXTMU Posted May 24, 2018 Posted May 24, 2018 I have installed Armbian_5.38_Nanopineo2_Debian_stretch_next_4.14.14.7z on NanoPINeo Core2 H5. Welcome to ARMBIAN 5.38 stable Debian GNU/Linux 9 (stretch) 4.14.0 uname -a Linux ntp169992 4.14.0 #25 SMP Fri May 11 16:57:53 CST 2018 aarch64 GNU/Linux ls /lib/modules 4.14.18-sunxi64 lsmod Module Size Used by No modules are loaded modprobe tun modprobe: ERROR: ../libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file '/lib/modules/4.14.0/modules.dep.bin' modprobe: FATAL: Module tun not found in directory /lib/modules/4.14.0 It seems there is a problem in the build ?
Igor Posted May 24, 2018 Posted May 24, 2018 27 minutes ago, GFXTMU said: It seems there is a problem in the build ? H5 images are still experimental, while Core2 got on my desk this week Try rather those images:https://dl.armbian.com/nanopineo2/nightly/
guidol Posted May 24, 2018 Posted May 24, 2018 2 hours ago, Igor said: Try rather those images:https://dl.armbian.com/nanopineo2/nightly/ because of the emmc of the Core2 I do use image of the NanoPi Neo Plus2 (also H5 CPU) https://dl.armbian.com/nanopineoplus2/ but @Igor the NanoPi Neo Plus2 isnt at the Download-page https://www.armbian.com/download/?tx_maker=friendlyelec
JulienAR Posted June 5, 2018 Posted June 5, 2018 Hello, Do you know when the NanoPi Neo Plus2 will be supported? And will be in add to the download-page ? Thanks. @+
Andy Posted June 6, 2018 Posted June 6, 2018 On 5/24/2018 at 5:38 PM, guidol said: because of the emmc of the Core2 I do use image of the NanoPi Neo Plus2 (also H5 CPU) https://dl.armbian.com/nanopineoplus2/ but @Igor the NanoPi Neo Plus2 isnt at the Download-page https://www.armbian.com/download/?tx_maker=friendlyelec hmm ok I use the "Nanopi Neo 2" image on my "NanoPi NEO Core2" and it works too. So what is the difference to the "NanoPi Neo Plus2" image? Is the Plus2 image better supported do to its emmc? Andy
guidol Posted June 6, 2018 Posted June 6, 2018 3 hours ago, Andy said: hmm ok I use the "Nanopi Neo 2" image on my "NanoPi NEO Core2" and it works too. So what is the difference to the "NanoPi Neo Plus2" image? Is the Plus2 image better supported do to its emmc? at the time when I did get my Core2 I asked Igor which image would be the best.... so I ended up with the Neo Plus2 Image because of the emmc support - then the normal Neo2 hasnt a emmc. I dont know if the actual Neo2 image does support emmc. With the Neo Plus2 image I did install armbian on the emmc of the Core2 successfully.
JulienAR Posted June 6, 2018 Posted June 6, 2018 Neo Plus 2 is back to download page But the image H5 and A64 boards are still experimental. Does anyone know when they will be stable? Today, what is the best and stable image for the Neo Plus 2 ? Debian_stretch_next, Debian_stretch_next_nightly Ubuntu_bionic_dev_nightly nanopi-neo-plus2_friendlycore-xenial_4.14.0_20180511 I need to deploy an application with Nano PI in the days to come and I do not know what image to take for have a stable OS. Thanks. @+
zador.blood.stained Posted June 6, 2018 Posted June 6, 2018 23 minutes ago, JulienAR said: But the image H5 and A64 boards are still experimental. Does anyone know when they will be stable? No, but you can keep an eye on this and decide for yourself when H5 and especially A64 get enough features supported upstream to be considered "stable" for your needs.
