codnoscope Posted July 14, 2018 Posted July 14, 2018 Hey I've seen some reports that the on board XOR flash will be flashed with GUI enabled uEFI firmware, is this true?
gounthar Posted September 9, 2018 Posted September 9, 2018 Still a few days to go, and there only one choice for eMMC, which is the 128GB.
emk2203 Posted September 10, 2018 Posted September 10, 2018 On 9/9/2018 at 11:30 AM, gounthar said: Still a few days to go, and there only one choice for eMMC, which is the 128GB. They probably think that if you want it, you want the maximum amount. Quite similar to high-end phones now. That said, I hope for Armbian support soon. I bit the bullet and bought one, maybe I sell my old Firefly RK3399 instead.
tkaiser Posted September 10, 2018 Author Posted September 10, 2018 On 9/9/2018 at 11:30 AM, gounthar said: only one choice for eMMC, which is the 128GB Honestly: if I have a RK3399 device and want 128 GB storage I choose something different. I ordered a cheap DRAM less NVMe SSD for 40€ (VAT/shipping included), inserted it into the M.2 slot, transferred the rootfs as easy as always with nand-sata-install and now my NanoPC-T4 runs directly off the NVMe SSD. I've no doubt that the eMMC performs nicely. But I doubt it's as fast as an NVMe SSD and what I like the most with SSDs: the good ones tell you when they start to wear out: root@nanopct4:/home/tk# smartctl -x /dev/nvme0n1 smartctl 6.6 2016-05-31 r4324 [aarch64-linux-4.4.153-rk3399] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Number: TS128GMTE110S Serial Number: AC2153AAE531202E0165 Firmware Version: R0515A0 PCI Vendor/Subsystem ID: 0x126f IEEE OUI Identifier: 0x000000 Controller ID: 1 Number of Namespaces: 1 Namespace 1 Size/Capacity: 128,035,676,160 [128 GB] Namespace 1 Formatted LBA Size: 512 Local Time is: Mon Sep 10 18:38:24 2018 UTC Firmware Updates (0x14): 2 Slots, no Reset required Optional Admin Commands (0x0006): Format Frmw_DL Optional NVM Commands (0x005f): Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat *Other* Maximum Data Transfer Size: 64 Pages Warning Comp. Temp. Threshold: 70 Celsius Critical Comp. Temp. Threshold: 80 Celsius Supported Power States St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat 0 + 9.00W - - 0 0 0 0 0 0 Supported LBA Sizes (NSID 0x1) Id Fmt Data Metadt Rel_Perf 0 + 512 0 0 === START OF SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED SMART/Health Information (NVMe Log 0x02, NSID 0x1) Critical Warning: 0x00 Temperature: 28 Celsius Available Spare: 100% Available Spare Threshold: 10% Percentage Used: 0% Data Units Read: 110,342 [56.4 GB] Data Units Written: 289,050 [147 GB] Host Read Commands: 11,897,227 Host Write Commands: 22,892,268 Controller Busy Time: 126 Power Cycles: 10 Power On Hours: 1 Unsafe Shutdowns: 4 Media and Data Integrity Errors: 0 Error Information Log Entries: 0 Warning Comp. Temperature Time: 0 Critical Comp. Temperature Time: 0 The 'Percentage Used' line is the important one. As long as this is below 90 everything's fine. An eMMC will die suddenly without any prior warning... 1
TonyMac32 Posted September 11, 2018 Posted September 11, 2018 7 hours ago, emk2203 said: That said, I hope for Armbian support soon. We would need the hardware to do that, and the time. That said it looks like a board with promise, I think it would be a nice addition.
gounthar Posted September 11, 2018 Posted September 11, 2018 As I bought it, I may run some tests to help... But for building and all, I have already proved I am useless for the time being (AllWinner H6 for example).
tkaiser Posted September 11, 2018 Author Posted September 11, 2018 4 hours ago, gounthar said: I may run some tests to help... Well, if Libre Computer is interested in getting Armbian on their boards at least some developers need samples. And wrt testing: It's a RK3399 thing so almost everything is already known. Only interesting: how fast is memory access (are different DRAM initialization BLOBs used or not?), how fast is the eMMC and how well works heat dissipation. So iozone and sbc-bench and done. To me Renegade Elite looks more like an ARM device for a couple of professional use cases (mainly dealing with cameras and imaging) running Android. But it seems enthousiasts are not scared away by costs and want to run Linux for whatever reasons... Almost forgot: Of course compatibility testing with various USB-C PSUs might be interesting as well. @gounthar which USB-C chargers do you own? 'Good' ones from this list?
emk2203 Posted September 11, 2018 Posted September 11, 2018 7 hours ago, tkaiser said: Well, if Libre Computer is interested in getting Armbian on their boards at least some developers need samples. And wrt testing: It's a RK3399 thing so almost everything is already known. Only interesting: how fast is memory access (are different DRAM initialization BLOBs used or not?), how fast is the eMMC and how well works heat dissipation. So iozone and sbc-bench and done. To me Renegade Elite looks more like an ARM device for a couple of professional use cases (mainly dealing with cameras and imaging) running Android. But it seems enthousiasts are not scared away by costs and want to run Linux for whatever reasons... Almost forgot: Of course compatibility testing with various USB-C PSUs might be interesting as well. @gounthar which USB-C chargers do you own? 'Good' ones from this list? It wouldn't hurt to ask Libre Computer and point out that their not-so-successful campaign (around 68% of target reached) might have been successful if they would have broad and stable support from Armbian. That was the main road block for me - the software. The fact that they promise mainline kernel, starting from 4.19, actually made me buy it. All ARM devices are sketchy in this regard. With mainline support, I can use the device as long as I like, without falling behind and stuck with old kernels. 1
tkaiser Posted September 11, 2018 Author Posted September 11, 2018 6 minutes ago, emk2203 said: The fact that they promise mainline kernel, starting from 4.19, actually made me buy it. All ARM devices are sketchy in this regard. Well, depends solely on the SoC used. I just did some benchmarks with 4.19 on one of my RK3399 devices yesterday: https://forum.armbian.com/topic/8161-swap-on-sbc/?do=findComment&comment=61637 Wrt features I'm not that much interested in (anything that requires adding a display to the boards) I wouldn't count on every feature available with mainline Linux (or Linux at all) regardless of SoC. But honestly I don't know enough about these areas and even managed to spread BS already.
hjc Posted September 11, 2018 Posted September 11, 2018 On 7/14/2018 at 6:59 PM, codnoscope said: Hey I've seen some reports that the on board XOR flash will be flashed with GUI enabled uEFI firmware, is this true? That might be true, since there's already an RK3399Pkg (haven't tried myself), but I'd still recommend u-boot, unless you are interested in one of the following use cases: 1. CentOS/Fedora/openSUSE, based on UEFI and grub on ARM64. These distros are mostly made for servers, instead of IoT stuff, so if you want something like KVM on ARM64, you could try to use them. But I doubt RK3399's 4G RAM could ever handle virtual machines. If you really want an ARM64 server, I recommend more serious solutions like Qualcomm centriq or Cavium ThunderX. If you just want to isolate your own code into different environments, use lxc/lxd or docker on (u-boot based) Armbian. 2. Windows on ARM64, requires UEFI and ACPI. I'd admit it's quite attractive lightweight desktop solution, and it can even handle simple x86 programs as well. There's already someone made this for Raspberry Pi 3, but just forget it, that's definitely unusable, considering the horribly slow IO of RPi and the crazy (heavily IO bounded) background tasks of the most bloated desktop OS on the earth. On RK3399, yes, I think it is possible to handle Windows' crazy background IO with a USB or SATA or even NVMe SSD (actually a good eMMC could handle that as well), but you'll need to write a lot of Windows drivers to bring up a new platform, including SDIO, eMMC, USB, GMAC, PCIe, and the most difficult part, display drivers (like Rockchip DRM on Linux) on your own or you have to use the (probably slow as hell) UEFI GOP for display. GPU is actually not needed to run Windows desktop, and probably not possible unless you are an employee of ARM Holdings and has the source code of the Mali GPU Windows drivers which has never been released before but actually does exist. The assumptions above are all based on the fact that ACPI was implemented properly, and I don't think this would be true. You can implement ACPI on your own, though. I don't have any other idea to convince myself that UEFI would be useful on this platform. What's the exact use case you're expecting to do with UEFI? 4 minutes ago, emk2203 said: It wouldn't hurt to ask Libre Computer and point out that their not-so-successful campaign (around 68% of target reached) might have been successful if they would have broad and stable support from Armbian. IMO The biggest and only problem so far for all RK3399 boards is pricing. And this was the reason that I was excited about NanoPi M4, since it had a much lower price while keeping the essential components on board (like WiFi/BT). Unfortunately, people around me still think $65 is a little too high for an SBC when I recommend the board to them. For most people, purchasing a $99 (or higher) SBC is really a crazy idea, even if Armbian has great support for it. 3
gounthar Posted September 11, 2018 Posted September 11, 2018 8 hours ago, tkaiser said: Almost forgot: Of course compatibility testing with various USB-C PSUs might be interesting as well. @gounthar which USB-C chargers do you own? 'Good' ones from this list? I have nothing regarding USB-C. So I chose a perk which contained their USB-C charger to avoid any problem.
tkaiser Posted September 11, 2018 Author Posted September 11, 2018 1 hour ago, hjc said: IMO The biggest and only problem so far for all RK3399 boards is pricing Couldn't agree more and still ask myself what I did the first time I heard of RK3399 boards: 'what's the use case for an ARM board that costs as much as a real Mini PC?' If the special capabilities of such devices (dual camera input, image processing, attaching a bunch of displays -- no idea what works with Linux and what only with Android) aren't used what's the point of spending huge amounts of money on these things? But maybe it's only me. At least I don't want to spend ~40 bucks just on a PSU (USB-C PD compliant) for such a device or +20 bucks to get appropriate heat dissipation (applies to Khadas Edge/Edge-V -- ~60 bucks for 'basic' accessories but users seem happy) 1 hour ago, gounthar said: So I chose a perk which contained their USB-C charger to avoid any problem. Wow, 100 bucks (with a 20% Indiegogo discount) for 128GB storage and the PSU.
chwe Posted September 11, 2018 Posted September 11, 2018 4 minutes ago, tkaiser said: no idea what works with Linux and what only with Android) aren't used what's the point of spending huge amounts of money on these things? at least one camera should be possible with the ISP1 driver, going through the related issues on rockchips github, people did it. For sure it would involve some DT work and some kernelconfig work due to 'ISP1 is prone to crash your kernel'.. Why spend so much money? Hmm things I can imagine is power-consumption (to be clear, that's your domain, so you might compare it with some of this NUC or whatever minicomputer is on the market now). It your little computer runs 24/7 this might have an impact (especially when you're able to run your decoding stuff on it)... For my desktop use-cases at home an RK3399 could probably replace an AMD64 machine mostly (I need 20 tabs in chrome, some simple editors and a console ). For my professional needs, well different story, even something as simple as an editor to draw chemical structures isn't available for Linux (there are some, but development stopped mostly since years). Most professional applications are available for Windows/Mac (yeah, somehow chemists like mac... ) and if there's a linux version, it's precompiled for x86, amd64 even it wouldn't be much efforts to build arm versions for it.. But you don't get sources for software which has an annual fee of >3000$...
gounthar Posted September 12, 2018 Posted September 12, 2018 20 hours ago, tkaiser said: Wow, 100 bucks (with a 20% Indiegogo discount) for 128GB storage and the PSU. Yes, I know, I'm not proud of that. I have tons of personal and professional uses for this board (video, Docker, ci...).
codnoscope Posted September 13, 2018 Posted September 13, 2018 On 9/12/2018 at 4:50 AM, hjc said: That might be true, since there's already an RK3399Pkg (haven't tried myself), but I'd still recommend u-boot, unless you are interested in one of the following use cases: I don't have any other idea to convince myself that UEFI would be useful on this platform. What's the exact use case you're expecting to do with UEFI? Thanks for the github link, I should try it. I don't have any UEFI specific use case, just want to tinker.
tkaiser Posted September 13, 2018 Author Posted September 13, 2018 1 hour ago, codnoscope said: I don't have any UEFI specific use case, just want to tinker With something that's broken by design? Adding tons of complexity for no real reason and allowing to backdoor your system at a level the OS can never detect? Ever done a simple web search for 'uefi security vulnerabilities issue' or something like that?
hjc Posted September 13, 2018 Posted September 13, 2018 1 hour ago, tkaiser said: With something that's broken by design? Adding tons of complexity for no real reason and allowing to backdoor your system at a level the OS can never detect? Ever done a simple web search for 'uefi security vulnerabilities issue' or something like that? Speaking about firmware backdoor, x86 PC OEMs have never stopped doing that. Actually chip vendors and OEMs always have their methods to plant backdoors, regardless it's a UEFI system or not. on x86 they could use SMM, on ARMv8 nowadays, EL3 is used. Although we love those boards with open source ATF implementation, most ARM devices don't open their firmware, like Qualcomm chips will never allow you to modify code running in EL3, and they only provide the firmware in the form of binary blobs. But, well, I do agree that UEFI is a complex broken design. UEFI firmware nowadays is even more over-sized than regular operating systems in the good old days (when BIOS was used)
gounthar Posted October 8, 2018 Posted October 8, 2018 No news since the end of the campaign. I don't know when it will be shipped.
gounthar Posted December 7, 2018 Posted December 7, 2018 No news for the time being, I don't know when backers will get their cards.
Redferne Posted February 2, 2019 Posted February 2, 2019 I have the board in my hand now Tried SD booting the Firefly RK3399 armbian image but the ethernet interface does not come up. I have no serial or HDMI at the moment, was hoping I could at least SSH into the machine, but alas no. Has anybody brought life to this board yet? The Firefly Ubuntu18.04 image does boot but it is very old, SD hardly works and kernel is without .ko support.
TonyMac32 Posted February 14, 2019 Posted February 14, 2019 Mine booted quickly and easily with the Firefly image, I need to try to make an Armbian image for it at this point. The case/heat sink are also very nice
Redferne Posted February 14, 2019 Posted February 14, 2019 Yeah. I built the Firefly-RK3399 Armbian image but I got sidetracked with work before I got the chance to test it. Hopefully I'll have some energy left this weekend to play with the board again.
gounthar Posted February 16, 2019 Posted February 16, 2019 I haven't been able to start mine for the time being with the Firefly image. Not one led ever blinked, no output, nothing...
frauhottelmann Posted February 19, 2019 Posted February 19, 2019 (edited) I've got mine in the mail two weeks ago. I had to pay customs Today I've flashed an A1 SD-Card and tried the Firefly Ubuntu image. It runs ok. sbc-bench: Spoiler sbc-bench v0.6.5 Firefly roc-rk3399-pc (Tue, 19 Feb 2019 19:33:18 +0100) Distributor ID: Ubuntu Description: Ubuntu 18.04.2 LTS Release: 18.04 Codename: bionic Architecture: arm64 /usr/bin/gcc (Ubuntu/Linaro 7.3.0-27ubuntu1~18.04) 7.3.0 Uptime: 19:33:18 up 42 min, 1 user, load average: 1,11, 0,75, 0,51 Linux 4.4.154 (firefly) 19.02.2019 _aarch64_ (6 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 4,20 0,32 1,29 0,31 0,00 93,88 Device tps kB_read/s kB_wrtn/s kB_read kB_wrtn loop0 0,00 0,00 0,00 8 0 mmcblk0 18,22 289,45 262,12 744685 674359 total used free shared buff/cache available Mem: 3,8G 195M 2,5G 43M 1,1G 3,5G Swap: 0B 0B 0B ########################################################################## Checking cpufreq OPP for cluster 0: Cpufreq OPP: 1416 Measured: 1407.933/1407.764/1407.795 Cpufreq OPP: 1200 Measured: 1190.717/1191.431/1191.898 Cpufreq OPP: 1008 Measured: 999.485/999.594/999.436 Cpufreq OPP: 816 Measured: 807.884/808.052/808.022 Cpufreq OPP: 600 Measured: 573.639/590.897/592.612 Cpufreq OPP: 408 Measured: 399.401/399.759/398.742 Checking cpufreq OPP for cluster 1: Cpufreq OPP: 1800 Measured: 1794.129/1794.229/1793.710 Cpufreq OPP: 1608 Measured: 1602.430/1602.271/1602.291 Cpufreq OPP: 1416 Measured: 1410.147/1409.855/1410.502 Cpufreq OPP: 1200 Measured: 1194.213/1193.730/1194.337 Cpufreq OPP: 1008 Measured: 1002.455/1002.516/1002.370 Cpufreq OPP: 816 Measured: 810.360/810.409/810.290 Cpufreq OPP: 600 Measured: 593.483/594.317/594.243 Cpufreq OPP: 408 Measured: 401.766/401.828/401.885 ########################################################################## Executing tinymembench on a little core: tinymembench v0.4.9 (simple benchmark for memory throughput and latency) ========================================================================== == Memory bandwidth tests == == == == Note 1: 1MB = 1000000 bytes == == Note 2: Results for 'copy' tests show how many bytes can be == == copied per second (adding together read and writen == == bytes would have provided twice higher numbers) == == Note 3: 2-pass copy means that we are using a small temporary buffer == == to first fetch data into it, and only then write it to the == == destination (source -> L1 cache, L1 cache -> destination) == == Note 4: If sample standard deviation exceeds 0.1%, it is shown in == == brackets == ========================================================================== C copy backwards : 1248.6 MB/s (3.1%) C copy backwards (32 byte blocks) : 1278.4 MB/s (2.0%) C copy backwards (64 byte blocks) : 1274.4 MB/s C copy : 1337.4 MB/s (0.9%) C copy prefetched (32 bytes step) : 999.8 MB/s (0.4%) C copy prefetched (64 bytes step) : 1081.8 MB/s (2.5%) C 2-pass copy : 1174.7 MB/s (1.2%) C 2-pass copy prefetched (32 bytes step) : 804.3 MB/s (0.2%) C 2-pass copy prefetched (64 bytes step) : 733.7 MB/s (0.2%) C fill : 4742.8 MB/s C fill (shuffle within 16 byte blocks) : 4743.3 MB/s (0.2%) C fill (shuffle within 32 byte blocks) : 4746.5 MB/s (1.6%) C fill (shuffle within 64 byte blocks) : 4743.9 MB/s (1.7%) --- standard memcpy : 1310.7 MB/s standard memset : 4744.3 MB/s --- NEON LDP/STP copy : 1339.7 MB/s NEON LDP/STP copy pldl2strm (32 bytes step) : 908.3 MB/s (0.4%) NEON LDP/STP copy pldl2strm (64 bytes step) : 1117.2 MB/s (0.2%) NEON LDP/STP copy pldl1keep (32 bytes step) : 1450.7 MB/s (2.4%) NEON LDP/STP copy pldl1keep (64 bytes step) : 1451.3 MB/s (1.0%) NEON LD1/ST1 copy : 1337.2 MB/s NEON STP fill : 4751.5 MB/s NEON STNP fill : 2131.1 MB/s (1.4%) ARM LDP/STP copy : 1347.3 MB/s (0.3%) ARM STP fill : 4745.8 MB/s ARM STNP fill : 2124.3 MB/s (2.5%) ========================================================================== == Framebuffer read tests. == == == == Many ARM devices use a part of the system memory as the framebuffer, == == typically mapped as uncached but with write-combining enabled. == == Writes to such framebuffers are quite fast, but reads are much == == slower and very sensitive to the alignment and the selection of == == CPU instructions which are used for accessing memory. == == == == Many x86 systems allocate the framebuffer in the GPU memory, == == accessible for the CPU via a relatively slow PCI-E bus. Moreover, == == PCI-E is asymmetric and handles reads a lot worse than writes. == == == == If uncached framebuffer reads are reasonably fast (at least 100 MB/s == == or preferably >300 MB/s), then using the shadow framebuffer layer == == is not necessary in Xorg DDX drivers, resulting in a nice overall == == performance improvement. For example, the xf86-video-fbturbo DDX == == uses this trick. == ========================================================================== NEON LDP/STP copy (from framebuffer) : 183.1 MB/s NEON LDP/STP 2-pass copy (from framebuffer) : 173.1 MB/s (1.3%) NEON LD1/ST1 copy (from framebuffer) : 45.5 MB/s NEON LD1/ST1 2-pass copy (from framebuffer) : 44.7 MB/s (0.1%) ARM LDP/STP copy (from framebuffer) : 91.5 MB/s (0.7%) ARM LDP/STP 2-pass copy (from framebuffer) : 88.6 MB/s ========================================================================== == Memory latency test == == == == Average time is measured for random memory accesses in the buffers == == of different sizes. The larger is the buffer, the more significant == == are relative contributions of TLB, L1/L2 cache misses and SDRAM == == accesses. For extremely large buffer sizes we are expecting to see == == page table walk with several requests to SDRAM for almost every == == memory access (though 64MiB is not nearly large enough to experience == == this effect to its fullest). == == == == Note 1: All the numbers are representing extra time, which needs to == == be added to L1 cache latency. The cycle timings for L1 cache == == latency can be usually found in the processor documentation. == == Note 2: Dual random read means that we are simultaneously performing == == two independent memory accesses at a time. In the case if == == the memory subsystem can't handle multiple outstanding == == requests, dual random read has the same timings as two == == single reads performed one after another. == ========================================================================== block size : single random read / dual random read 1024 : 0.0 ns / 0.0 ns 2048 : 0.0 ns / 0.0 ns 4096 : 0.0 ns / 0.0 ns 8192 : 0.0 ns / 0.0 ns 16384 : 0.0 ns / 0.0 ns 32768 : 0.1 ns / 0.1 ns 65536 : 4.9 ns / 8.2 ns 131072 : 7.5 ns / 11.4 ns 262144 : 8.8 ns / 12.7 ns 524288 : 16.1 ns / 23.1 ns 1048576 : 109.2 ns / 164.8 ns 2097152 : 157.0 ns / 207.6 ns 4194304 : 184.8 ns / 227.4 ns 8388608 : 198.3 ns / 235.2 ns 16777216 : 202.3 ns / 239.7 ns 33554432 : 210.8 ns / 248.8 ns 67108864 : 218.1 ns / 259.0 ns Executing tinymembench on a big core: tinymembench v0.4.9 (simple benchmark for memory throughput and latency) ========================================================================== == Memory bandwidth tests == == == == Note 1: 1MB = 1000000 bytes == == Note 2: Results for 'copy' tests show how many bytes can be == == copied per second (adding together read and writen == == bytes would have provided twice higher numbers) == == Note 3: 2-pass copy means that we are using a small temporary buffer == == to first fetch data into it, and only then write it to the == == destination (source -> L1 cache, L1 cache -> destination) == == Note 4: If sample standard deviation exceeds 0.1%, it is shown in == == brackets == ========================================================================== C copy backwards : 2678.9 MB/s C copy backwards (32 byte blocks) : 2679.8 MB/s C copy backwards (64 byte blocks) : 2671.0 MB/s C copy : 2558.0 MB/s C copy prefetched (32 bytes step) : 2599.3 MB/s (0.6%) C copy prefetched (64 bytes step) : 2599.8 MB/s C 2-pass copy : 2383.9 MB/s C 2-pass copy prefetched (32 bytes step) : 2416.6 MB/s C 2-pass copy prefetched (64 bytes step) : 2416.2 MB/s C fill : 4864.8 MB/s (0.3%) C fill (shuffle within 16 byte blocks) : 4868.8 MB/s (0.5%) C fill (shuffle within 32 byte blocks) : 4864.8 MB/s (0.1%) C fill (shuffle within 64 byte blocks) : 4861.4 MB/s --- standard memcpy : 2647.1 MB/s standard memset : 4864.5 MB/s (0.3%) --- NEON LDP/STP copy : 2644.3 MB/s (0.6%) NEON LDP/STP copy pldl2strm (32 bytes step) : 2652.1 MB/s NEON LDP/STP copy pldl2strm (64 bytes step) : 2653.1 MB/s NEON LDP/STP copy pldl1keep (32 bytes step) : 2613.1 MB/s (0.4%) NEON LDP/STP copy pldl1keep (64 bytes step) : 2599.0 MB/s NEON LD1/ST1 copy : 2641.9 MB/s NEON STP fill : 4863.6 MB/s (0.3%) NEON STNP fill : 4808.7 MB/s ARM LDP/STP copy : 2643.6 MB/s ARM STP fill : 4863.2 MB/s (0.3%) ARM STNP fill : 4814.7 MB/s (0.1%) ========================================================================== == Framebuffer read tests. == == == == Many ARM devices use a part of the system memory as the framebuffer, == == typically mapped as uncached but with write-combining enabled. == == Writes to such framebuffers are quite fast, but reads are much == == slower and very sensitive to the alignment and the selection of == == CPU instructions which are used for accessing memory. == == == == Many x86 systems allocate the framebuffer in the GPU memory, == == accessible for the CPU via a relatively slow PCI-E bus. Moreover, == == PCI-E is asymmetric and handles reads a lot worse than writes. == == == == If uncached framebuffer reads are reasonably fast (at least 100 MB/s == == or preferably >300 MB/s), then using the shadow framebuffer layer == == is not necessary in Xorg DDX drivers, resulting in a nice overall == == performance improvement. For example, the xf86-video-fbturbo DDX == == uses this trick. == ========================================================================== NEON LDP/STP copy (from framebuffer) : 586.4 MB/s NEON LDP/STP 2-pass copy (from framebuffer) : 541.3 MB/s (0.3%) NEON LD1/ST1 copy (from framebuffer) : 648.8 MB/s NEON LD1/ST1 2-pass copy (from framebuffer) : 599.5 MB/s ARM LDP/STP copy (from framebuffer) : 429.6 MB/s ARM LDP/STP 2-pass copy (from framebuffer) : 413.2 MB/s ========================================================================== == Memory latency test == == == == Average time is measured for random memory accesses in the buffers == == of different sizes. The larger is the buffer, the more significant == == are relative contributions of TLB, L1/L2 cache misses and SDRAM == == accesses. For extremely large buffer sizes we are expecting to see == == page table walk with several requests to SDRAM for almost every == == memory access (though 64MiB is not nearly large enough to experience == == this effect to its fullest). == == == == Note 1: All the numbers are representing extra time, which needs to == == be added to L1 cache latency. The cycle timings for L1 cache == == latency can be usually found in the processor documentation. == == Note 2: Dual random read means that we are simultaneously performing == == two independent memory accesses at a time. In the case if == == the memory subsystem can't handle multiple outstanding == == requests, dual random read has the same timings as two == == single reads performed one after another. == ========================================================================== block size : single random read / dual random read 1024 : 0.0 ns / 0.0 ns 2048 : 0.0 ns / 0.0 ns 4096 : 0.0 ns / 0.0 ns 8192 : 0.0 ns / 0.0 ns 16384 : 0.0 ns / 0.0 ns 32768 : 0.0 ns / 0.0 ns 65536 : 4.5 ns / 7.2 ns 131072 : 6.8 ns / 9.7 ns 262144 : 9.8 ns / 12.8 ns 524288 : 11.4 ns / 14.7 ns 1048576 : 16.5 ns / 22.6 ns 2097152 : 115.4 ns / 174.9 ns 4194304 : 164.5 ns / 221.0 ns 8388608 : 193.5 ns / 243.2 ns 16777216 : 208.4 ns / 252.8 ns 33554432 : 216.9 ns / 260.3 ns 67108864 : 228.6 ns / 273.6 ns ########################################################################## OpenSSL 1.1.0g, built on 2 Nov 2017 type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes 16384 bytes aes-128-cbc 126459.00k 373459.18k 713951.49k 951994.37k 1055364.44k 1058941.61k aes-128-cbc 363236.74k 817097.62k 1164749.06k 1285497.51k 1344632.15k 1347807.91k aes-192-cbc 120216.01k 332262.46k 581627.90k 733920.94k 794050.56k 787180.20k aes-192-cbc 341461.84k 750382.91k 1014092.12k 1138003.97k 1172103.17k 1185944.92k aes-256-cbc 116545.49k 303862.27k 503337.05k 611672.75k 643735.55k 633279.83k aes-256-cbc 333653.59k 679326.61k 909368.58k 982170.28k 1009467.39k 1010166.44k ########################################################################## 7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,6 CPUs LE) LE CPU Freq: 1403 1406 1407 1407 1407 1407 1406 1402 1407 RAM size: 3845 MB, # CPU hardware threads: 6 RAM usage: 1323 MB, # Benchmark threads: 6 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 690 100 675 672 | 14817 100 1269 1264 23: 666 100 681 679 | 14493 100 1258 1254 24: 640 100 691 689 | 14107 99 1246 1238 25: 611 100 701 699 | 13649 100 1218 1215 ---------------------------------- | ------------------------------ Avr: 100 687 685 | 100 1248 1243 Tot: 100 967 964 7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,6 CPUs LE) LE CPU Freq: 1793 1793 1794 1794 1794 1794 1794 1794 1794 RAM size: 3845 MB, # CPU hardware threads: 6 RAM usage: 1323 MB, # Benchmark threads: 6 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 1381 100 1344 1344 | 21673 100 1849 1848 23: 1305 100 1330 1330 | 21188 100 1834 1833 24: 1240 100 1334 1333 | 20676 100 1815 1815 25: 1192 100 1362 1362 | 20076 100 1787 1787 ---------------------------------- | ------------------------------ Avr: 100 1342 1342 | 100 1821 1821 Tot: 100 1582 1582 ########################################################################## 7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,6 CPUs LE) LE CPU Freq: 1766 1791 1789 1790 1794 1793 1794 1794 1794 RAM size: 3845 MB, # CPU hardware threads: 6 RAM usage: 1323 MB, # Benchmark threads: 6 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 4181 474 858 4068 | 93817 526 1522 8001 23: 4171 505 842 4250 | 90926 523 1504 7868 24: 4069 528 828 4375 | 88805 525 1485 7795 25: 3877 534 829 4427 | 86041 526 1457 7657 ---------------------------------- | ------------------------------ Avr: 510 839 4280 | 525 1492 7830 Tot: 518 1165 6055 7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,6 CPUs LE) LE CPU Freq: 1792 1794 1794 1794 1793 1794 1794 1794 1794 RAM size: 3845 MB, # CPU hardware threads: 6 RAM usage: 1323 MB, # Benchmark threads: 6 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 4501 518 845 4379 | 93603 525 1519 7983 23: 4149 504 839 4228 | 90817 523 1502 7858 24: 4097 535 823 4406 | 88966 526 1486 7809 25: 3978 550 827 4542 | 85996 525 1458 7653 ---------------------------------- | ------------------------------ Avr: 527 833 4389 | 525 1491 7826 Tot: 526 1162 6107 7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,6 CPUs LE) LE CPU Freq: 1786 1794 1794 1793 1794 1794 1794 1793 1794 RAM size: 3845 MB, # CPU hardware threads: 6 RAM usage: 1323 MB, # Benchmark threads: 6 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 4323 487 864 4206 | 92944 522 1518 7926 23: 4076 495 839 4154 | 91252 526 1502 7896 24: 4131 526 845 4443 | 88518 524 1483 7769 25: 3925 546 822 4482 | 85510 523 1455 7610 ---------------------------------- | ------------------------------ Avr: 513 842 4321 | 524 1489 7800 Tot: 519 1166 6061 Compression: 4280,4389,4321 Decompression: 7830,7826,7800 Total: 6055,6107,6061 ########################################################################## ** cpuminer-multi 1.3.3 by tpruvot@github ** BTC donation address: 1FhDPLPpw18X4srecguG3MxJYe4a1JsZnd (tpruvot) [2019-02-19 20:05:30] 6 miner threads started, using 'scrypt' algorithm. [2019-02-19 20:05:30] CPU #4: 2.08 kH/s [2019-02-19 20:05:30] CPU #5: 2.05 kH/s [2019-02-19 20:05:30] CPU #1: 1.36 kH/s [2019-02-19 20:05:30] CPU #2: 1.37 kH/s [2019-02-19 20:05:30] CPU #0: 1.35 kH/s [2019-02-19 20:05:30] CPU #3: 1.37 kH/s [2019-02-19 20:05:35] Total: 9.52 kH/s [2019-02-19 20:05:40] CPU #2: 1.37 kH/s [2019-02-19 20:05:40] CPU #3: 1.37 kH/s [2019-02-19 20:05:40] CPU #0: 1.33 kH/s [2019-02-19 20:05:40] CPU #5: 1.96 kH/s [2019-02-19 20:05:40] Total: 9.34 kH/s [2019-02-19 20:05:40] CPU #1: 1.32 kH/s [2019-02-19 20:05:40] CPU #4: 1.95 kH/s [2019-02-19 20:05:45] Total: 9.29 kH/s [2019-02-19 20:05:50] CPU #2: 1.37 kH/s [2019-02-19 20:05:50] CPU #3: 1.37 kH/s [2019-02-19 20:05:50] CPU #0: 1.34 kH/s [2019-02-19 20:05:50] CPU #1: 1.32 kH/s [2019-02-19 20:05:50] CPU #5: 1.91 kH/s [2019-02-19 20:05:50] Total: 9.25 kH/s [2019-02-19 20:05:50] CPU #4: 1.91 kH/s [2019-02-19 20:05:55] Total: 9.20 kH/s [2019-02-19 20:06:00] CPU #2: 1.37 kH/s [2019-02-19 20:06:00] CPU #3: 1.37 kH/s [2019-02-19 20:06:00] CPU #0: 1.34 kH/s [2019-02-19 20:06:00] CPU #1: 1.32 kH/s [2019-02-19 20:06:00] CPU #5: 1.88 kH/s [2019-02-19 20:06:00] Total: 9.17 kH/s [2019-02-19 20:06:00] CPU #4: 1.89 kH/s [2019-02-19 20:06:05] Total: 9.18 kH/s [2019-02-19 20:06:10] CPU #2: 1.37 kH/s [2019-02-19 20:06:10] CPU #3: 1.37 kH/s [2019-02-19 20:06:10] CPU #0: 1.33 kH/s [2019-02-19 20:06:10] CPU #1: 1.32 kH/s [2019-02-19 20:06:10] CPU #5: 1.87 kH/s [2019-02-19 20:06:10] Total: 9.14 kH/s [2019-02-19 20:06:10] CPU #4: 1.87 kH/s [2019-02-19 20:06:15] Total: 9.13 kH/s [2019-02-19 20:06:20] CPU #2: 1.37 kH/s [2019-02-19 20:06:20] CPU #3: 1.37 kH/s [2019-02-19 20:06:20] CPU #0: 1.34 kH/s [2019-02-19 20:06:20] CPU #1: 1.32 kH/s [2019-02-19 20:06:20] CPU #5: 1.85 kH/s [2019-02-19 20:06:20] Total: 9.11 kH/s [2019-02-19 20:06:20] CPU #4: 1.86 kH/s [2019-02-19 20:06:25] Total: 9.11 kH/s [2019-02-19 20:06:30] CPU #2: 1.37 kH/s [2019-02-19 20:06:30] CPU #3: 1.37 kH/s [2019-02-19 20:06:30] CPU #0: 1.34 kH/s [2019-02-19 20:06:30] CPU #1: 1.32 kH/s [2019-02-19 20:06:30] CPU #5: 1.85 kH/s [2019-02-19 20:06:30] Total: 9.10 kH/s [2019-02-19 20:06:30] CPU #4: 1.84 kH/s [2019-02-19 20:06:35] Total: 9.09 kH/s [2019-02-19 20:06:40] CPU #2: 1.37 kH/s [2019-02-19 20:06:40] CPU #3: 1.37 kH/s [2019-02-19 20:06:40] CPU #0: 1.33 kH/s [2019-02-19 20:06:40] CPU #1: 1.32 kH/s [2019-02-19 20:06:40] CPU #5: 1.84 kH/s [2019-02-19 20:06:40] Total: 9.07 kH/s [2019-02-19 20:06:41] CPU #4: 1.83 kH/s [2019-02-19 20:06:45] Total: 9.07 kH/s [2019-02-19 20:06:50] CPU #2: 1.37 kH/s [2019-02-19 20:06:50] CPU #3: 1.37 kH/s [2019-02-19 20:06:50] CPU #0: 1.34 kH/s [2019-02-19 20:06:50] CPU #1: 1.32 kH/s [2019-02-19 20:06:50] CPU #5: 1.84 kH/s [2019-02-19 20:06:50] Total: 9.07 kH/s [2019-02-19 20:06:50] CPU #4: 1.84 kH/s [2019-02-19 20:06:55] Total: 9.07 kH/s [2019-02-19 20:06:56] CPU #4: 1.83 kH/s [2019-02-19 20:07:00] CPU #2: 1.37 kH/s [2019-02-19 20:07:00] CPU #3: 1.37 kH/s [2019-02-19 20:07:00] CPU #0: 1.34 kH/s [2019-02-19 20:07:00] CPU #1: 1.32 kH/s [2019-02-19 20:07:00] CPU #5: 1.81 kH/s [2019-02-19 20:07:00] Total: 9.03 kH/s [2019-02-19 20:07:05] CPU #4: 1.81 kH/s [2019-02-19 20:07:05] Total: 9.03 kH/s [2019-02-19 20:07:10] CPU #2: 1.37 kH/s [2019-02-19 20:07:10] CPU #3: 1.37 kH/s [2019-02-19 20:07:10] CPU #0: 1.34 kH/s [2019-02-19 20:07:10] CPU #1: 1.32 kH/s [2019-02-19 20:07:10] CPU #5: 1.82 kH/s [2019-02-19 20:07:10] Total: 9.03 kH/s [2019-02-19 20:07:15] CPU #4: 1.81 kH/s [2019-02-19 20:07:15] Total: 9.02 kH/s [2019-02-19 20:07:20] CPU #2: 1.37 kH/s [2019-02-19 20:07:20] CPU #3: 1.37 kH/s [2019-02-19 20:07:20] CPU #1: 1.34 kH/s [2019-02-19 20:07:20] CPU #0: 1.30 kH/s [2019-02-19 20:07:20] CPU #5: 1.81 kH/s [2019-02-19 20:07:20] Total: 9.00 kH/s [2019-02-19 20:07:25] CPU #4: 1.80 kH/s [2019-02-19 20:07:26] CPU #5: 1.79 kH/s [2019-02-19 20:07:26] Total: 8.96 kH/s [2019-02-19 20:07:30] Total: 8.97 kH/s [2019-02-19 20:07:30] CPU #1: 1.36 kH/s [2019-02-19 20:07:30] CPU #2: 1.37 kH/s [2019-02-19 20:07:30] CPU #3: 1.37 kH/s [2019-02-19 20:07:30] CPU #0: 1.29 kH/s [2019-02-19 20:07:35] CPU #5: 1.80 kH/s [2019-02-19 20:07:35] Total: 8.99 kH/s [2019-02-19 20:07:35] CPU #4: 1.79 kH/s [2019-02-19 20:07:40] Total: 8.98 kH/s [2019-02-19 20:07:40] CPU #2: 1.37 kH/s [2019-02-19 20:07:40] CPU #3: 1.37 kH/s [2019-02-19 20:07:40] CPU #1: 1.36 kH/s [2019-02-19 20:07:40] CPU #0: 1.29 kH/s [2019-02-19 20:07:45] CPU #5: 1.79 kH/s [2019-02-19 20:07:45] Total: 8.97 kH/s [2019-02-19 20:07:45] CPU #4: 1.78 kH/s [2019-02-19 20:07:50] Total: 8.95 kH/s [2019-02-19 20:07:50] CPU #1: 1.36 kH/s [2019-02-19 20:07:50] CPU #2: 1.37 kH/s [2019-02-19 20:07:50] CPU #3: 1.37 kH/s [2019-02-19 20:07:50] CPU #0: 1.29 kH/s [2019-02-19 20:07:55] CPU #5: 1.78 kH/s [2019-02-19 20:07:55] Total: 8.94 kH/s [2019-02-19 20:07:55] CPU #4: 1.78 kH/s [2019-02-19 20:08:00] Total: 8.92 kH/s [2019-02-19 20:08:00] CPU #2: 1.37 kH/s [2019-02-19 20:08:00] CPU #3: 1.37 kH/s [2019-02-19 20:08:00] CPU #1: 1.36 kH/s [2019-02-19 20:08:00] CPU #0: 1.30 kH/s [2019-02-19 20:08:05] CPU #5: 1.76 kH/s [2019-02-19 20:08:05] Total: 8.93 kH/s [2019-02-19 20:08:05] CPU #4: 1.77 kH/s [2019-02-19 20:08:10] Total: 8.92 kH/s [2019-02-19 20:08:10] CPU #2: 1.37 kH/s [2019-02-19 20:08:10] CPU #1: 1.36 kH/s [2019-02-19 20:08:10] CPU #3: 1.37 kH/s [2019-02-19 20:08:10] CPU #0: 1.30 kH/s [2019-02-19 20:08:15] CPU #5: 1.76 kH/s [2019-02-19 20:08:15] Total: 8.91 kH/s [2019-02-19 20:08:15] CPU #4: 1.76 kH/s [2019-02-19 20:08:20] Total: 8.91 kH/s [2019-02-19 20:08:20] CPU #2: 1.37 kH/s [2019-02-19 20:08:20] CPU #1: 1.36 kH/s [2019-02-19 20:08:20] CPU #3: 1.37 kH/s [2019-02-19 20:08:20] CPU #0: 1.30 kH/s [2019-02-19 20:08:25] CPU #5: 1.75 kH/s [2019-02-19 20:08:25] Total: 8.91 kH/s [2019-02-19 20:08:25] CPU #4: 1.75 kH/s [2019-02-19 20:08:30] Total: 8.91 kH/s [2019-02-19 20:08:30] CPU #2: 1.37 kH/s [2019-02-19 20:08:30] CPU #3: 1.37 kH/s [2019-02-19 20:08:30] CPU #1: 1.35 kH/s [2019-02-19 20:08:30] CPU #0: 1.29 kH/s [2019-02-19 20:08:35] CPU #5: 1.74 kH/s [2019-02-19 20:08:35] Total: 8.87 kH/s [2019-02-19 20:08:35] CPU #4: 1.73 kH/s [2019-02-19 20:08:40] Total: 8.87 kH/s [2019-02-19 20:08:40] CPU #2: 1.37 kH/s [2019-02-19 20:08:40] CPU #1: 1.36 kH/s [2019-02-19 20:08:40] CPU #3: 1.37 kH/s [2019-02-19 20:08:40] CPU #0: 1.30 kH/s [2019-02-19 20:08:45] CPU #5: 1.74 kH/s [2019-02-19 20:08:45] Total: 8.89 kH/s [2019-02-19 20:08:45] CPU #4: 1.74 kH/s [2019-02-19 20:08:50] Total: 8.89 kH/s [2019-02-19 20:08:50] CPU #2: 1.37 kH/s [2019-02-19 20:08:50] CPU #3: 1.37 kH/s [2019-02-19 20:08:50] CPU #1: 1.36 kH/s [2019-02-19 20:08:50] CPU #0: 1.31 kH/s [2019-02-19 20:08:55] CPU #5: 1.73 kH/s [2019-02-19 20:08:55] Total: 8.88 kH/s [2019-02-19 20:08:55] CPU #4: 1.72 kH/s [2019-02-19 20:09:00] Total: 8.85 kH/s [2019-02-19 20:09:00] CPU #2: 1.37 kH/s [2019-02-19 20:09:00] CPU #1: 1.36 kH/s [2019-02-19 20:09:00] CPU #3: 1.37 kH/s [2019-02-19 20:09:00] CPU #0: 1.31 kH/s [2019-02-19 20:09:05] CPU #5: 1.72 kH/s [2019-02-19 20:09:05] Total: 8.86 kH/s [2019-02-19 20:09:05] CPU #4: 1.73 kH/s [2019-02-19 20:09:10] Total: 8.84 kH/s [2019-02-19 20:09:10] CPU #2: 1.37 kH/s [2019-02-19 20:09:10] CPU #3: 1.37 kH/s [2019-02-19 20:09:10] CPU #1: 1.36 kH/s [2019-02-19 20:09:10] CPU #0: 1.31 kH/s [2019-02-19 20:09:15] CPU #5: 1.73 kH/s [2019-02-19 20:09:15] Total: 8.86 kH/s [2019-02-19 20:09:15] CPU #4: 1.72 kH/s [2019-02-19 20:09:20] Total: 8.85 kH/s [2019-02-19 20:09:20] CPU #2: 1.37 kH/s [2019-02-19 20:09:20] CPU #1: 1.36 kH/s [2019-02-19 20:09:20] CPU #3: 1.37 kH/s [2019-02-19 20:09:20] CPU #0: 1.31 kH/s [2019-02-19 20:09:25] CPU #5: 1.72 kH/s [2019-02-19 20:09:25] Total: 8.83 kH/s [2019-02-19 20:09:25] CPU #4: 1.72 kH/s [2019-02-19 20:09:30] Total: 8.85 kH/s [2019-02-19 20:09:30] CPU #2: 1.37 kH/s [2019-02-19 20:09:30] CPU #3: 1.37 kH/s [2019-02-19 20:09:30] CPU #1: 1.36 kH/s [2019-02-19 20:09:30] CPU #0: 1.32 kH/s [2019-02-19 20:09:35] CPU #5: 1.71 kH/s [2019-02-19 20:09:35] Total: 8.85 kH/s [2019-02-19 20:09:35] CPU #4: 1.71 kH/s [2019-02-19 20:09:40] Total: 8.83 kH/s [2019-02-19 20:09:40] CPU #2: 1.37 kH/s [2019-02-19 20:09:40] CPU #3: 1.37 kH/s [2019-02-19 20:09:40] CPU #1: 1.35 kH/s [2019-02-19 20:09:40] CPU #0: 1.30 kH/s [2019-02-19 20:09:45] CPU #5: 1.71 kH/s [2019-02-19 20:09:45] Total: 8.80 kH/s [2019-02-19 20:09:45] CPU #4: 1.71 kH/s [2019-02-19 20:09:50] Total: 8.83 kH/s [2019-02-19 20:09:50] CPU #2: 1.37 kH/s [2019-02-19 20:09:50] CPU #3: 1.37 kH/s [2019-02-19 20:09:50] CPU #1: 1.36 kH/s [2019-02-19 20:09:50] CPU #0: 1.32 kH/s [2019-02-19 20:09:55] CPU #5: 1.70 kH/s [2019-02-19 20:09:55] Total: 8.83 kH/s [2019-02-19 20:09:55] CPU #4: 1.70 kH/s [2019-02-19 20:10:00] Total: 8.83 kH/s [2019-02-19 20:10:00] CPU #2: 1.37 kH/s [2019-02-19 20:10:00] CPU #3: 1.37 kH/s [2019-02-19 20:10:00] CPU #1: 1.36 kH/s [2019-02-19 20:10:00] CPU #0: 1.32 kH/s [2019-02-19 20:10:05] CPU #5: 1.68 kH/s [2019-02-19 20:10:05] Total: 8.80 kH/s [2019-02-19 20:10:05] CPU #4: 1.69 kH/s [2019-02-19 20:10:10] Total: 8.80 kH/s [2019-02-19 20:10:10] CPU #2: 1.37 kH/s [2019-02-19 20:10:10] CPU #3: 1.37 kH/s [2019-02-19 20:10:10] CPU #1: 1.36 kH/s [2019-02-19 20:10:10] CPU #0: 1.32 kH/s [2019-02-19 20:10:15] CPU #5: 1.69 kH/s [2019-02-19 20:10:15] Total: 8.82 kH/s [2019-02-19 20:10:15] CPU #4: 1.69 kH/s [2019-02-19 20:10:20] Total: 8.78 kH/s [2019-02-19 20:10:20] CPU #2: 1.37 kH/s [2019-02-19 20:10:20] CPU #3: 1.37 kH/s [2019-02-19 20:10:20] CPU #1: 1.36 kH/s [2019-02-19 20:10:20] CPU #0: 1.32 kH/s [2019-02-19 20:10:25] CPU #5: 1.69 kH/s [2019-02-19 20:10:25] Total: 8.80 kH/s [2019-02-19 20:10:25] CPU #4: 1.68 kH/s Total Scores: 9.52,9.34,9.29,9.25,9.20,9.18,9.17,9.14,9.13,9.11,9.10,9.09,9.07,9.03,9.02,9.00,8.99,8.98,8.97,8.96,8.95,8.94,8.93,8.92,8.91,8.89,8.88,8.87,8.86,8.85,8.84,8.83,8.82,8.80,8.78 ########################################################################## Testing clockspeeds again. System health now: Time big.LITTLE load %cpu %sys %usr %nice %io %irq Temp 20:10:26: 1416/1416MHz 6.21 100% 0% 99% 0% 0% 0% 71.1°C Checking cpufreq OPP for cluster 0: Cpufreq OPP: 1416 Measured: 1407.550/1407.626/1407.473 Cpufreq OPP: 1200 Measured: 1189.729/1191.252/1191.128 Cpufreq OPP: 1008 Measured: 998.615/998.845/999.436 Cpufreq OPP: 816 Measured: 804.463/804.267/804.972 Cpufreq OPP: 600 Measured: 591.618/591.968/591.340 Cpufreq OPP: 408 Measured: 400.104/400.095/398.292 Checking cpufreq OPP for cluster 1: Cpufreq OPP: 1800 Measured: 1628.704/1483.275/1668.871 Cpufreq OPP: 1608 Measured: 1062.427/1469.459/1600.356 Cpufreq OPP: 1416 Measured: 1408.148/1408.717/1352.642 Cpufreq OPP: 1200 Measured: 814.461/755.857/1192.228 Cpufreq OPP: 1008 Measured: 578.582/999.243/1000.053 Cpufreq OPP: 816 Measured: 806.878/807.726/384.431 Cpufreq OPP: 600 Measured: 495.784/667.919/585.403 Cpufreq OPP: 408 Measured: 523.108/402.209/400.444 ########################################################################## System health while running tinymembench: Time big.LITTLE load %cpu %sys %usr %nice %io %irq Temp 19:33:28: 1800/1416MHz 1.10 6% 1% 4% 0% 0% 0% 50.0°C 19:35:28: 1800/1416MHz 1.01 16% 0% 16% 0% 0% 0% 47.5°C 19:37:28: 1800/1416MHz 1.00 16% 0% 16% 0% 0% 0% 47.5°C 19:39:28: 1800/1416MHz 1.00 16% 0% 16% 0% 0% 0% 46.9°C 19:41:28: 1800/1416MHz 1.06 16% 0% 16% 0% 0% 0% 46.9°C 19:43:28: 1800/1416MHz 1.00 16% 0% 16% 0% 0% 0% 51.7°C 19:45:28: 1800/1416MHz 1.00 16% 0% 16% 0% 0% 0% 51.1°C 19:47:28: 1800/1416MHz 1.11 16% 0% 16% 0% 0% 0% 51.1°C 19:49:28: 1800/1416MHz 1.06 16% 0% 16% 0% 0% 0% 51.1°C System health while running OpenSSL benchmark: Time big.LITTLE load %cpu %sys %usr %nice %io %irq Temp 19:49:44: 1800/1416MHz 1.04 9% 0% 7% 0% 0% 0% 51.1°C 19:49:54: 1800/1416MHz 1.04 16% 0% 16% 0% 0% 0% 49.4°C 19:50:04: 1800/1416MHz 1.03 16% 0% 16% 0% 0% 0% 52.8°C 19:50:14: 1800/1416MHz 1.02 16% 0% 16% 0% 0% 0% 53.3°C 19:50:24: 1800/1416MHz 1.02 16% 0% 16% 0% 0% 0% 50.6°C 19:50:34: 1800/1416MHz 1.02 16% 0% 16% 0% 0% 0% 50.0°C 19:50:44: 1800/1416MHz 1.01 16% 0% 16% 0% 0% 0% 53.3°C 19:50:55: 1800/1416MHz 1.01 16% 0% 16% 0% 0% 0% 53.9°C 19:51:05: 1800/1416MHz 1.01 16% 0% 16% 0% 0% 0% 51.1°C 19:51:15: 1800/1416MHz 1.01 16% 0% 16% 0% 0% 0% 52.2°C 19:51:25: 1800/1416MHz 1.01 16% 0% 16% 0% 0% 0% 53.3°C System health while running 7-zip single core benchmark: Time big.LITTLE load %cpu %sys %usr %nice %io %irq Temp 19:51:32: 1800/1416MHz 1.00 9% 0% 7% 0% 0% 0% 55.6°C 19:52:32: 1800/1416MHz 3.53 16% 0% 16% 0% 0% 0% 50.0°C 19:53:32: 1800/1416MHz 3.95 16% 0% 16% 0% 0% 0% 48.8°C 19:54:32: 1800/1416MHz 3.53 16% 0% 16% 0% 0% 0% 48.8°C 19:55:32: 1800/1416MHz 3.80 16% 0% 16% 0% 0% 0% 48.8°C 19:56:33: 1800/1416MHz 3.66 16% 0% 16% 0% 0% 0% 48.8°C 19:57:33: 1800/1416MHz 3.81 16% 0% 16% 0% 0% 0% 48.8°C 19:58:33: 1800/1416MHz 4.87 16% 0% 16% 0% 0% 0% 52.8°C 19:59:33: 1800/1416MHz 4.51 16% 0% 16% 0% 0% 0% 52.8°C 20:00:33: 1800/1416MHz 4.38 16% 0% 16% 0% 0% 0% 53.3°C 20:01:33: 1800/1416MHz 4.13 16% 0% 16% 0% 0% 0% 52.8°C System health while running 7-zip multi core benchmark: Time big.LITTLE load %cpu %sys %usr %nice %io %irq Temp 20:01:58: 1800/1416MHz 4.71 10% 0% 9% 0% 0% 0% 53.9°C 20:02:18: 1800/1416MHz 5.21 78% 0% 77% 0% 0% 0% 64.4°C 20:02:38: 1800/1416MHz 5.21 78% 1% 77% 0% 0% 0% 57.2°C 20:02:59: 1800/1416MHz 5.73 93% 1% 92% 0% 0% 0% 63.1°C 20:03:19: 1800/1416MHz 5.50 74% 0% 73% 0% 0% 0% 65.6°C 20:03:39: 1800/1416MHz 5.49 84% 1% 82% 0% 0% 0% 63.1°C 20:04:00: 1800/1416MHz 5.71 84% 1% 83% 0% 0% 0% 63.8°C 20:04:20: 1800/1416MHz 5.86 87% 1% 86% 0% 0% 0% 58.9°C 20:04:40: 1800/1416MHz 5.18 80% 0% 79% 0% 0% 0% 67.8°C 20:05:00: 1800/1416MHz 5.36 78% 1% 76% 0% 0% 0% 63.1°C 20:05:20: 1800/1416MHz 5.51 94% 1% 92% 0% 0% 0% 65.6°C System health while running cpuminer: Time big.LITTLE load %cpu %sys %usr %nice %io %irq Temp 20:05:31: 1608/1416MHz 5.58 13% 0% 12% 0% 0% 0% 65.6°C 20:05:53: 1800/1416MHz 5.79 100% 0% 99% 0% 0% 0% 69.4°C 20:06:16: 1416/1416MHz 5.85 100% 0% 99% 0% 0% 0% 69.4°C 20:06:39: 1800/1416MHz 5.96 100% 0% 99% 0% 0% 0% 69.4°C 20:07:01: 1800/1416MHz 6.03 100% 0% 99% 0% 0% 0% 70.6°C 20:07:24: 1416/1416MHz 6.14 100% 0% 99% 0% 0% 0% 70.0°C 20:07:46: 1416/1416MHz 6.18 100% 0% 99% 0% 0% 0% 70.6°C 20:08:09: 1416/1416MHz 6.24 100% 0% 99% 0% 0% 0% 69.4°C 20:08:32: 1416/1416MHz 6.17 100% 0% 99% 0% 0% 0% 69.4°C 20:08:55: 1416/1416MHz 6.17 100% 0% 99% 0% 0% 0% 70.6°C 20:09:17: 1416/1416MHz 6.12 100% 0% 99% 0% 0% 0% 70.0°C 20:09:40: 1416/1416MHz 6.21 100% 0% 99% 0% 0% 0% 70.0°C 20:10:03: 1416/1416MHz 6.23 100% 0% 99% 0% 0% 0% 70.0°C 20:10:26: 1416/1416MHz 6.21 100% 0% 99% 0% 0% 0% 71.1°C Throttling statistics (time spent on each cpufreq OPP) for CPUs 4-5: 1800 MHz: 2007.26 sec 1608 MHz: 24.24 sec 1416 MHz: 190.40 sec 1200 MHz: 0 sec 1008 MHz: 0 sec 816 MHz: 0 sec 600 MHz: 0 sec 408 MHz: 0 sec ########################################################################## dmesg output while running the benchmarks: [ 2574.030270] adc_val,219 [ 2576.034291] adc_val,199 [ 2578.038097] adc_val,217 [ 2580.042358] adc_val,259 [ 2582.046131] adc_val,251 [ 2584.050196] adc_val,210 [ 2586.054575] adc_val,204 [ 2588.058450] adc_val,217 [ 2590.062446] adc_val,260 [ 2592.066464] adc_val,251 [ 2594.070495] adc_val,219 [ 2596.074483] adc_val,202 [ 2598.078555] adc_val,211 [ 2600.082518] adc_val,258 [ 2602.086522] adc_val,257 [ 2604.090529] adc_val,241 [ 2606.094519] adc_val,199 [ 2608.098546] adc_val,207 [ 2610.102533] adc_val,232 [ 2612.106570] adc_val,257 [ 2614.110606] adc_val,248 [ 2616.114563] adc_val,210 [ 2618.118588] adc_val,200 [ 2620.122590] adc_val,215 [ 2622.126587] adc_val,259 [ 2624.130605] adc_val,256 [ 2626.134622] adc_val,231 [ 2628.138478] adc_val,200 [ 2630.143804] adc_val,212 [ 2632.150592] adc_val,256 [ 2634.154704] adc_val,228 [ 2636.158650] adc_val,200 [ 2638.162659] adc_val,213 [ 2640.166690] adc_val,260 [ 2642.170534] adc_val,252 [ 2644.174698] adc_val,214 [ 2646.178684] adc_val,202 [ 2648.182707] adc_val,219 [ 2650.186798] adc_val,261 [ 2652.190798] adc_val,256 [ 2654.194820] adc_val,205 [ 2656.198818] adc_val,206 [ 2658.202831] adc_val,223 [ 2660.206853] adc_val,260 [ 2662.210716] adc_val,247 [ 2664.214845] adc_val,202 [ 2666.218860] adc_val,207 [ 2668.222860] adc_val,237 [ 2670.226879] adc_val,259 [ 2672.230877] adc_val,243 [ 2674.234918] adc_val,200 [ 2676.238911] adc_val,212 [ 2678.242934] adc_val,258 [ 2680.246913] adc_val,252 [ 2682.250491] adc_val,219 [ 2684.254938] adc_val,203 [ 2686.258922] adc_val,223 [ 2688.262938] adc_val,260 [ 2690.266676] adc_val,248 [ 2692.270943] adc_val,201 [ 2694.274960] adc_val,206 [ 2696.278968] adc_val,220 [ 2698.282975] adc_val,260 [ 2700.286990] adc_val,253 [ 2702.291004] adc_val,230 [ 2704.295049] adc_val,200 [ 2706.299039] adc_val,209 [ 2708.303049] adc_val,241 [ 2710.307063] adc_val,260 [ 2712.311073] adc_val,246 [ 2714.315079] adc_val,205 [ 2716.319087] adc_val,205 [ 2718.323086] adc_val,219 [ 2720.327113] adc_val,260 [ 2722.331114] adc_val,251 [ 2724.335130] adc_val,213 [ 2726.339349] adc_val,203 [ 2728.343364] adc_val,216 [ 2730.347385] adc_val,261 [ 2732.351108] adc_val,253 [ 2734.355135] adc_val,221 [ 2736.359124] adc_val,201 [ 2738.363149] adc_val,244 [ 2740.367171] adc_val,254 [ 2742.371139] adc_val,250 [ 2744.375399] adc_val,233 [ 2746.379476] adc_val,197 [ 2748.383471] adc_val,207 [ 2750.387103] adc_val,232 [ 2752.391112] adc_val,256 [ 2754.395113] adc_val,247 [ 2756.399119] adc_val,207 [ 2758.403122] adc_val,199 [ 2760.407127] adc_val,213 [ 2762.411129] adc_val,258 [ 2764.415137] adc_val,252 [ 2766.419137] adc_val,239 [ 2768.423142] adc_val,200 [ 2770.427147] adc_val,207 [ 2772.431152] adc_val,230 [ 2774.435182] adc_val,258 [ 2776.439190] adc_val,250 [ 2778.443195] adc_val,211 [ 2780.447198] adc_val,201 [ 2782.451209] adc_val,213 [ 2784.455219] adc_val,258 [ 2786.459224] adc_val,256 [ 2788.463230] adc_val,244 [ 2790.467236] adc_val,200 [ 2792.471219] adc_val,208 [ 2794.475222] adc_val,250 [ 2796.479228] adc_val,253 [ 2798.483231] adc_val,246 [ 2800.487239] adc_val,209 [ 2802.491247] adc_val,200 [ 2804.495253] adc_val,214 [ 2806.499260] adc_val,259 [ 2808.503224] adc_val,248 [ 2810.507272] adc_val,206 [ 2812.511280] adc_val,204 [ 2814.515289] adc_val,222 [ 2816.519294] adc_val,257 [ 2818.523297] adc_val,249 [ 2820.527310] adc_val,202 [ 2822.531318] adc_val,203 [ 2824.535321] adc_val,227 [ 2826.539346] adc_val,259 [ 2828.543349] adc_val,246 [ 2830.547406] adc_val,202 [ 2832.551412] adc_val,206 [ 2834.555415] adc_val,240 [ 2836.559416] adc_val,258 [ 2838.563375] adc_val,241 [ 2840.567446] adc_val,201 [ 2842.571404] adc_val,235 [ 2844.575443] adc_val,253 [ 2846.579455] adc_val,249 [ 2848.583355] adc_val,218 [ 2850.587483] adc_val,197 [ 2852.591487] adc_val,212 [ 2854.595546] adc_val,256 [ 2856.599513] adc_val,251 [ 2858.603506] adc_val,211 [ 2860.607482] adc_val,202 [ 2862.611525] adc_val,219 [ 2864.615530] adc_val,259 [ 2866.619506] adc_val,248 [ 2868.623484] adc_val,205 [ 2870.627513] adc_val,203 [ 2872.631551] adc_val,217 [ 2874.635549] adc_val,260 [ 2876.639551] adc_val,253 [ 2878.643542] adc_val,233 [ 2880.647562] adc_val,201 [ 2882.651555] adc_val,207 [ 2884.655590] adc_val,229 [ 2886.659584] adc_val,260 [ 2888.663598] adc_val,250 [ 2890.667590] adc_val,217 [ 2892.671616] adc_val,202 [ 2894.675608] adc_val,243 [ 2896.679633] adc_val,254 [ 2898.683618] adc_val,249 [ 2900.687636] adc_val,221 [ 2902.691659] adc_val,198 [ 2904.695665] adc_val,210 [ 2906.699643] adc_val,258 [ 2908.703685] adc_val,250 [ 2910.707669] adc_val,217 [ 2912.711698] adc_val,201 [ 2914.715674] adc_val,217 [ 2916.719711] adc_val,261 [ 2918.723712] adc_val,248 [ 2920.727697] adc_val,201 [ 2922.731720] adc_val,208 [ 2924.735712] adc_val,248 [ 2926.739724] adc_val,257 [ 2928.743723] adc_val,232 [ 2930.747744] adc_val,200 [ 2932.751739] adc_val,213 [ 2934.755753] adc_val,257 [ 2936.759786] adc_val,255 [ 2938.763784] adc_val,234 [ 2940.767794] adc_val,201 [ 2942.771607] adc_val,236 [ 2944.775812] adc_val,256 [ 2946.779821] adc_val,247 [ 2948.783822] adc_val,208 [ 2950.787874] adc_val,200 [ 2952.791827] adc_val,228 [ 2954.795837] adc_val,257 [ 2956.799815] adc_val,243 [ 2958.803852] adc_val,200 [ 2960.807841] adc_val,208 [ 2962.811872] adc_val,256 [ 2964.815867] adc_val,252 [ 2966.819897] adc_val,220 [ 2968.823896] adc_val,204 [ 2970.827882] adc_val,218 [ 2972.831871] adc_val,260 [ 2974.835887] adc_val,246 [ 2976.839911] adc_val,199 [ 2978.843906] adc_val,211 [ 2980.847924] adc_val,258 [ 2982.851924] adc_val,251 [ 2984.855932] adc_val,205 [ 2986.859938] adc_val,221 [ 2988.863961] adc_val,252 [ 2990.867984] adc_val,247 [ 2992.871972] adc_val,202 [ 2994.876002] adc_val,205 [ 2996.879993] adc_val,251 [ 2998.883980] adc_val,253 [ 3000.888003] adc_val,208 [ 3002.892000] adc_val,205 [ 3004.896019] adc_val,243 [ 3006.900021] adc_val,256 [ 3008.903992] adc_val,222 [ 3010.908048] adc_val,203 [ 3012.912037] adc_val,224 [ 3014.916056] adc_val,260 [ 3016.920041] adc_val,245 [ 3018.924029] adc_val,201 [ 3020.928059] adc_val,216 [ 3022.932089] adc_val,261 [ 3024.936094] adc_val,247 [ 3026.940185] adc_val,200 [ 3028.944163] adc_val,212 [ 3030.948100] adc_val,260 [ 3032.952126] adc_val,253 [ 3034.956151] adc_val,200 [ 3036.960122] adc_val,226 [ 3038.964143] adc_val,253 [ 3039.753401] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 2560x1440p60, type: 11 [ 3040.726876] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 2560x1440p60, type: 11 [ 3040.968136] adc_val,253 [ 3042.972192] adc_val,210 [ 3044.976149] adc_val,207 [ 3046.979894] adc_val,234 [ 3048.984152] adc_val,259 [ 3050.988191] adc_val,233 [ 3052.992213] adc_val,203 [ 3054.996099] adc_val,216 [ 3057.000221] adc_val,261 [ 3059.004190] adc_val,246 [ 3061.008223] adc_val,202 [ 3063.012263] adc_val,215 [ 3065.016275] adc_val,257 [ 3067.020254] adc_val,246 [ 3069.024295] adc_val,201 [ 3071.028268] adc_val,219 [ 3073.032276] adc_val,259 [ 3075.036276] adc_val,233 [ 3077.040297] adc_val,203 [ 3079.044288] adc_val,255 [ 3081.048296] adc_val,252 [ 3083.052306] adc_val,226 [ 3085.056316] adc_val,200 [ 3087.060328] adc_val,222 [ 3089.064283] adc_val,257 [ 3091.068351] adc_val,233 [ 3093.072358] adc_val,200 [ 3095.076390] adc_val,227 [ 3097.080381] adc_val,257 [ 3099.084354] adc_val,227 [ 3101.088384] adc_val,203 [ 3103.092278] adc_val,233 [ 3105.096437] adc_val,256 [ 3107.100428] adc_val,223 [ 3109.104399] adc_val,205 [ 3111.108402] adc_val,240 [ 3113.113749] adc_val,253 [ 3115.120459] adc_val,202 [ 3117.124444] adc_val,256 [ 3119.128245] adc_val,251 [ 3121.132487] adc_val,219 [ 3123.136471] adc_val,203 [ 3125.140466] adc_val,234 [ 3127.144495] adc_val,255 [ 3129.148533] adc_val,222 [ 3131.152486] adc_val,204 [ 3133.156554] adc_val,231 [ 3135.160505] adc_val,258 [ 3137.164537] adc_val,237 [ 3139.168391] adc_val,203 [ 3141.172536] adc_val,218 [ 3143.176566] adc_val,259 [ 3145.180799] adc_val,252 [ 3147.184698] adc_val,207 [ 3149.188756] adc_val,219 [ 3151.192933] adc_val,264 [ 3153.196836] adc_val,253 [ 3155.200779] adc_val,206 [ 3157.204828] adc_val,237 [ 3159.208738] adc_val,257 [ 3161.212849] adc_val,249 [ 3163.216827] adc_val,207 [ 3165.220931] adc_val,208 [ 3167.224764] adc_val,244 [ 3169.228820] adc_val,260 [ 3171.232913] adc_val,234 [ 3173.236896] adc_val,206 [ 3175.240499] adc_val,219 [ 3177.244672] adc_val,265 [ 3179.248668] adc_val,248 [ 3181.252705] adc_val,200 [ 3183.256770] adc_val,211 [ 3185.260588] adc_val,256 [ 3187.264634] adc_val,256 [ 3189.268657] adc_val,223 [ 3191.272649] adc_val,205 [ 3193.276768] adc_val,219 [ 3195.280684] adc_val,260 [ 3197.284780] adc_val,251 [ 3199.288704] adc_val,207 [ 3201.292862] adc_val,219 [ 3203.296955] adc_val,257 [ 3205.300633] adc_val,260 [ 3207.304813] adc_val,235 [ 3209.308875] adc_val,203 [ 3211.312846] adc_val,219 [ 3213.316855] adc_val,261 [ 3215.320981] adc_val,249 [ 3217.325003] adc_val,201 [ 3219.329008] adc_val,215 [ 3221.332995] adc_val,257 [ 3223.337021] adc_val,257 [ 3225.341081] adc_val,218 [ 3227.345105] adc_val,206 [ 3229.348903] adc_val,228 [ 3231.352900] adc_val,260 [ 3233.357048] adc_val,242 [ 3235.360893] adc_val,204 [ 3237.365096] adc_val,220 [ 3239.369082] adc_val,262 [ 3241.372903] adc_val,243 [ 3243.376908] adc_val,200 [ 3245.380887] adc_val,217 [ 3247.385215] adc_val,262 [ 3249.388806] adc_val,247 [ 3251.392909] adc_val,202 [ 3253.397137] adc_val,216 [ 3255.400931] adc_val,261 [ 3257.405025] adc_val,249 [ 3259.409011] adc_val,205 [ 3261.412964] adc_val,210 [ 3263.416967] adc_val,253 [ 3265.420953] adc_val,256 [ 3267.424982] adc_val,212 [ 3269.429003] adc_val,207 [ 3271.433071] adc_val,244 [ 3273.436905] adc_val,251 [ 3275.440854] adc_val,239 [ 3277.444868] adc_val,201 [ 3279.448868] adc_val,217 [ 3281.452887] adc_val,257 [ 3283.456897] adc_val,247 [ 3285.460892] adc_val,201 [ 3287.464953] adc_val,215 [ 3289.468980] adc_val,260 [ 3291.472950] adc_val,244 [ 3293.476953] adc_val,198 [ 3295.482873] adc_val,225 [ 3297.488971] adc_val,252 [ 3299.492981] adc_val,219 [ 3301.496982] adc_val,202 [ 3303.500913] adc_val,217 [ 3305.504963] adc_val,260 [ 3307.508968] adc_val,251 [ 3309.513023] adc_val,208 [ 3311.517059] adc_val,205 [ 3313.521069] adc_val,227 [ 3315.525080] adc_val,260 [ 3317.529161] adc_val,242 [ 3319.533160] adc_val,200 [ 3321.537163] adc_val,213 [ 3323.541160] adc_val,259 [ 3325.545198] adc_val,249 [ 3327.549199] adc_val,199 [ 3329.553214] adc_val,210 [ 3331.557221] adc_val,254 [ 3333.561223] adc_val,249 [ 3335.565225] adc_val,210 [ 3337.569240] adc_val,205 [ 3339.573255] adc_val,241 [ 3341.577190] adc_val,256 [ 3343.581187] adc_val,225 [ 3345.585281] adc_val,201 [ 3347.589292] adc_val,228 [ 3349.593291] adc_val,258 [ 3351.597304] adc_val,236 [ 3353.601303] adc_val,202 [ 3355.605313] adc_val,214 [ 3357.609330] adc_val,259 [ 3359.613334] adc_val,248 [ 3361.617343] adc_val,204 [ 3363.621356] adc_val,207 [ 3365.625359] adc_val,235 [ 3367.629367] adc_val,258 [ 3369.633363] adc_val,250 [ 3371.637381] adc_val,200 [ 3373.641380] adc_val,209 [ 3375.645400] adc_val,243 [ 3377.649398] adc_val,257 [ 3379.653409] adc_val,243 [ 3381.657411] adc_val,200 [ 3383.661361] adc_val,211 [ 3385.665433] adc_val,249 [ 3387.669453] adc_val,256 [ 3389.673452] adc_val,237 [ 3391.677466] adc_val,201 [ 3393.681460] adc_val,213 [ 3395.685480] adc_val,251 [ 3397.689472] adc_val,254 [ 3399.693485] adc_val,235 [ 3401.697495] adc_val,200 [ 3403.701522] adc_val,209 [ 3405.705524] adc_val,250 [ 3407.709523] adc_val,253 [ 3409.713540] adc_val,243 [ 3411.717537] adc_val,199 [ 3413.721559] adc_val,207 [ 3415.725559] adc_val,218 [ 3417.731633] adc_val,259 [ 3419.737578] adc_val,236 [ 3421.741585] adc_val,200 [ 3423.745529] adc_val,203 [ 3425.749526] adc_val,213 [ 3427.753617] adc_val,247 [ 3429.757462] adc_val,257 [ 3431.761561] adc_val,247 [ 3433.765556] adc_val,209 [ 3435.769573] adc_val,200 [ 3437.773666] adc_val,213 [ 3439.777656] adc_val,254 [ 3441.781662] adc_val,256 [ 3443.785680] adc_val,240 [ 3445.789694] adc_val,199 [ 3447.793692] adc_val,205 [ 3449.797695] adc_val,216 [ 3451.801721] adc_val,257 [ 3453.805716] adc_val,254 [ 3455.809721] adc_val,246 [ 3457.813731] adc_val,204 [ 3459.817747] adc_val,201 [ 3461.821754] adc_val,212 [ 3463.825765] adc_val,250 [ 3465.829773] adc_val,259 [ 3467.833696] adc_val,248 [ 3469.837722] adc_val,208 [ 3471.841730] adc_val,200 [ 3473.845796] adc_val,210 [ 3475.849844] adc_val,246 [ 3477.853815] adc_val,258 [ 3479.857837] adc_val,248 [ 3481.861835] adc_val,213 [ 3483.865848] adc_val,200 [ 3485.869850] adc_val,210 [ 3487.873862] adc_val,239 [ 3489.877878] adc_val,258 [ 3491.881872] adc_val,246 [ 3493.885897] adc_val,208 [ 3495.889789] adc_val,202 [ 3497.893898] adc_val,214 [ 3499.897929] adc_val,259 [ 3501.901925] adc_val,254 [ 3503.905940] adc_val,238 [ 3505.909825] adc_val,199 [ 3507.913956] adc_val,206 [ 3509.917904] adc_val,223 [ 3511.921973] adc_val,256 [ 3513.925986] adc_val,249 [ 3515.929990] adc_val,210 [ 3517.934006] adc_val,201 [ 3519.938025] adc_val,216 [ 3521.942029] adc_val,258 [ 3523.946026] adc_val,248 [ 3525.950039] adc_val,205 [ 3527.954045] adc_val,204 [ 3529.957998] adc_val,226 [ 3531.962079] adc_val,257 [ 3533.966075] adc_val,245 [ 3535.970020] adc_val,202 [ 3537.974105] adc_val,205 [ 3539.978102] adc_val,232 [ 3541.982124] adc_val,259 [ 3543.986053] adc_val,245 [ 3545.990065] adc_val,201 [ 3547.994075] adc_val,206 [ 3549.998150] adc_val,238 [ 3552.002176] adc_val,257 [ 3554.006169] adc_val,248 [ 3556.010075] adc_val,200 [ 3558.014201] adc_val,207 [ 3560.018006] adc_val,239 [ 3562.022249] adc_val,253 [ 3564.026262] adc_val,241 [ 3566.030271] adc_val,194 [ 3568.034280] adc_val,206 [ 3570.038054] adc_val,244 [ 3572.042060] adc_val,253 [ 3574.046314] adc_val,237 [ 3576.050316] adc_val,196 [ 3578.054186] adc_val,214 [ 3580.058158] adc_val,255 [ 3582.062206] adc_val,260 [ 3584.066216] adc_val,246 [ 3586.070131] adc_val,202 [ 3588.074236] adc_val,210 [ 3590.078247] adc_val,241 [ 3592.082256] adc_val,262 [ 3594.086267] adc_val,251 [ 3596.090385] adc_val,199 [ 3598.094322] adc_val,199 [ 3600.098440] adc_val,213 [ 3602.102449] adc_val,254 [ 3604.106456] adc_val,249 [ 3606.110236] adc_val,224 [ 3608.114479] adc_val,194 [ 3610.118488] adc_val,207 [ 3612.122497] adc_val,246 [ 3614.126366] adc_val,263 [ 3616.130274] adc_val,246 [ 3618.134341] adc_val,205 [ 3620.138305] adc_val,214 [ 3622.142367] adc_val,263 [ 3624.146407] adc_val,252 [ 3626.150418] adc_val,208 [ 3628.154428] adc_val,211 [ 3630.158409] adc_val,248 [ 3632.162595] adc_val,249 [ 3634.166604] adc_val,222 [ 3636.170611] adc_val,198 [ 3638.174465] adc_val,213 [ 3640.178571] adc_val,253 [ 3642.182640] adc_val,248 [ 3644.186650] adc_val,201 [ 3646.190655] adc_val,201 [ 3647.753342] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 2560x1440p60, type: 11 [ 3648.194670] adc_val,224 [ 3650.198496] adc_val,267 [ 3652.202544] adc_val,253 [ 3654.206553] adc_val,207 [ 3656.210469] adc_val,210 [ 3658.214572] adc_val,222 [ 3660.218544] adc_val,264 [ 3662.222590] adc_val,257 [ 3664.226563] adc_val,240 [ 3666.230568] adc_val,204 [ 3668.234771] adc_val,199 [ 3670.238541] adc_val,212 [ 3672.242824] adc_val,251 [ 3674.246830] adc_val,254 [ 3676.250830] adc_val,243 [ 3678.254850] adc_val,209 [ 3680.258855] adc_val,197 [ 3682.262864] adc_val,205 [ 3684.266877] adc_val,225 [ 3686.270877] adc_val,256 [ 3688.274887] adc_val,251 [ 3690.278905] adc_val,237 [ 3692.282913] adc_val,198 [ 3694.286920] adc_val,202 [ 3696.290923] adc_val,214 [ 3698.294936] adc_val,257 [ 3700.298945] adc_val,251 [ 3702.302957] adc_val,240 [ 3704.306970] adc_val,198 [ 3706.310968] adc_val,200 [ 3708.314987] adc_val,211 [ 3710.318994] adc_val,250 [ 3712.323003] adc_val,254 [ 3714.327029] adc_val,245 [ 3716.331024] adc_val,211 [ 3718.335053] adc_val,199 [ 3720.339063] adc_val,207 [ 3722.343070] adc_val,235 [ 3724.347069] adc_val,257 [ 3726.351086] adc_val,247 [ 3728.355012] adc_val,211 [ 3730.359099] adc_val,199 [ 3732.362836] adc_val,209 [ 3734.367139] adc_val,250 [ 3736.371152] adc_val,253 [ 3738.375074] adc_val,243 [ 3740.379162] adc_val,201 [ 3742.383154] adc_val,201 [ 3744.387174] adc_val,214 [ 3746.391151] adc_val,257 [ 3748.395195] adc_val,249 [ 3750.399186] adc_val,224 [ 3752.403200] adc_val,198 [ 3754.407206] adc_val,211 [ 3756.411212] adc_val,258 [ 3758.415237] adc_val,251 [ 3760.419232] adc_val,205 [ 3762.423241] adc_val,200 [ 3764.427208] adc_val,225 [ 3766.431261] adc_val,253 [ 3768.435278] adc_val,242 [ 3770.439276] adc_val,198 [ 3772.443293] adc_val,210 [ 3774.447299] adc_val,258 [ 3776.451339] adc_val,248 [ 3778.455346] adc_val,204 [ 3780.459344] adc_val,203 [ 3782.463343] adc_val,232 [ 3784.467362] adc_val,255 [ 3786.471362] adc_val,236 [ 3788.475378] adc_val,197 [ 3790.479385] adc_val,214 [ 3792.483404] adc_val,258 [ 3794.487408] adc_val,245 [ 3796.491406] adc_val,197 [ 3798.495420] adc_val,225 [ 3800.499427] adc_val,251 [ 3802.503437] adc_val,246 [ 3804.507460] adc_val,224 [ 3806.511496] adc_val,196 [ 3808.515460] adc_val,208 [ 3810.519493] adc_val,256 [ 3812.523487] adc_val,246 [ 3814.527516] adc_val,198 [ 3816.531512] adc_val,204 [ 3818.535519] adc_val,248 [ 3820.539278] adc_val,252 [ 3822.543536] adc_val,220 [ 3824.547550] adc_val,199 [ 3826.551568] adc_val,213 [ 3828.555484] adc_val,258 [ 3830.559595] adc_val,247 [ 3832.563603] adc_val,200 [ 3834.567598] adc_val,206 [ 3836.571618] adc_val,229 [ 3838.575640] adc_val,256 [ 3840.579642] adc_val,243 [ 3842.583636] adc_val,198 [ 3844.587674] adc_val,213 [ 3846.591693] adc_val,251 [ 3848.595412] adc_val,249 [ 3850.599689] adc_val,238 [ 3852.603683] adc_val,194 [ 3854.607693] adc_val,204 [ 3856.611732] adc_val,237 [ 3858.615705] adc_val,253 [ 3860.619712] adc_val,239 [ 3862.623721] adc_val,198 [ 3864.627732] adc_val,210 [ 3866.631745] adc_val,256 [ 3868.635750] adc_val,246 [ 3870.639756] adc_val,198 [ 3872.643787] adc_val,205 [ 3874.647804] adc_val,252 [ 3876.651889] adc_val,248 [ 3878.655812] adc_val,207 [ 3880.659813] adc_val,204 [ 3882.663814] adc_val,234 [ 3884.667823] adc_val,256 [ 3886.671846] adc_val,239 [ 3888.675849] adc_val,198 [ 3890.679849] adc_val,237 [ 3892.683735] adc_val,251 [ 3894.687894] adc_val,247 [ 3896.691894] adc_val,218 [ 3898.695831] adc_val,196 [ 3900.699915] adc_val,210 [ 3902.703914] adc_val,257 [ 3904.707926] adc_val,247 [ 3906.711952] adc_val,211 [ 3908.715938] adc_val,200 [ 3910.719962] adc_val,213 [ 3912.723973] adc_val,257 [ 3914.727967] adc_val,246 [ 3916.731978] adc_val,200 [ 3918.736010] adc_val,204 [ 3920.739997] adc_val,234 [ 3922.744013] adc_val,256 [ 3924.747969] adc_val,239 [ 3926.752030] adc_val,200 [ 3928.755957] adc_val,211 [ 3930.760004] adc_val,256 [ 3932.764049] adc_val,248 [ 3934.768063] adc_val,206 [ 3936.772078] adc_val,212 [ 3938.776089] adc_val,253 [ 3940.780092] adc_val,248 [ 3942.784107] adc_val,227 [ 3944.788109] adc_val,197 [ 3946.792120] adc_val,213 [ 3948.796045] adc_val,253 [ 3950.800155] adc_val,242 [ 3952.804176] adc_val,197 [ 3954.808148] adc_val,208 [ 3956.812159] adc_val,250 [ 3958.815928] adc_val,251 [ 3960.820198] adc_val,227 [ 3962.824192] adc_val,199 [ 3964.828217] adc_val,212 [ 3966.832222] adc_val,258 [ 3968.836238] adc_val,250 [ 3970.840231] adc_val,213 [ 3972.844240] adc_val,202 [ 3974.848267] adc_val,219 [ 3976.852277] adc_val,256 [ 3978.856271] adc_val,243 [ 3980.860290] adc_val,199 [ 3982.864290] adc_val,232 [ 3984.868298] adc_val,251 [ 3986.872316] adc_val,246 [ 3988.876323] adc_val,196 [ 3990.880334] adc_val,203 [ 3992.884370] adc_val,249 [ 3994.888342] adc_val,249 [ 3996.892348] adc_val,207 [ 3998.896361] adc_val,202 [ 4000.900369] adc_val,231 [ 4002.904376] adc_val,257 [ 4004.908377] adc_val,237 [ 4006.912408] adc_val,199 [ 4008.916448] adc_val,212 [ 4010.920426] adc_val,258 [ 4012.924470] adc_val,246 [ 4014.928458] adc_val,202 [ 4016.932474] adc_val,206 [ 4018.936454] adc_val,240 [ 4020.940464] adc_val,253 [ 4022.944473] adc_val,226 [ 4024.948488] adc_val,201 [ 4026.952518] adc_val,253 [ 4028.956261] adc_val,252 [ 4030.960516] adc_val,237 [ 4032.964522] adc_val,195 [ 4034.968542] adc_val,209 [ 4036.972450] adc_val,256 [ 4038.976542] adc_val,245 [ 4040.980618] adc_val,196 [ 4042.984566] adc_val,207 [ 4044.988571] adc_val,248 [ 4046.992577] adc_val,251 [ 4048.996598] adc_val,223 [ 4051.000601] adc_val,200 [ 4053.004439] adc_val,217 [ 4055.008587] adc_val,262 [ 4057.012485] adc_val,252 [ 4059.016573] adc_val,204 [ 4061.020594] adc_val,211 [ 4063.024697] adc_val,247 [ 4065.028583] adc_val,258 [ 4067.032507] adc_val,231 [ 4069.036607] adc_val,203 [ 4071.040617] adc_val,244 [ 4073.044702] adc_val,256 [ 4075.048631] adc_val,246 [ 4077.052643] adc_val,202 [ 4079.056655] adc_val,206 [ 4081.060655] adc_val,240 [ 4083.064676] adc_val,255 [ 4085.068684] adc_val,232 [ 4087.072766] adc_val,202 [ 4089.076671] adc_val,218 [ 4091.080719] adc_val,258 [ 4093.084757] adc_val,248 [ 4095.088748] adc_val,200 [ 4097.092689] adc_val,213 [ 4099.096708] adc_val,257 [ 4101.100758] adc_val,247 [ 4103.104741] adc_val,207 [ 4105.108763] adc_val,208 [ 4107.112748] adc_val,249 [ 4109.116788] adc_val,253 [ 4111.120778] adc_val,220 [ 4113.124811] adc_val,205 [ 4115.128811] adc_val,225 [ 4117.132832] adc_val,258 [ 4119.136744] adc_val,244 [ 4121.140848] adc_val,201 [ 4123.144809] adc_val,214 [ 4125.148832] adc_val,260 [ 4127.152831] adc_val,253 [ 4129.156850] adc_val,204 [ 4131.160891] adc_val,210 [ 4133.164885] adc_val,245 [ 4135.168827] adc_val,256 [ 4137.172944] adc_val,227 [ 4139.176964] adc_val,200 [ 4141.180859] adc_val,216 [ 4143.184897] adc_val,261 [ 4145.188962] adc_val,247 [ 4147.192986] adc_val,202 [ 4149.196992] adc_val,208 [ 4151.200874] adc_val,245 [ 4153.205022] adc_val,254 [ 4155.209024] adc_val,236 [ 4157.213028] adc_val,200 [ 4159.217046] adc_val,210 [ 4161.221034] adc_val,251 [ 4163.225067] adc_val,254 [ 4165.229048] adc_val,243 [ 4167.233088] adc_val,199 [ 4169.237027] adc_val,209 [ 4171.241058] adc_val,223 [ 4173.245077] adc_val,260 [ 4175.249088] adc_val,256 [ 4177.253090] adc_val,235 [ 4179.257237] adc_val,199 [ 4181.261117] adc_val,209 [ 4183.265129] adc_val,222 [ 4185.269135] adc_val,258 [ 4187.273151] adc_val,252 [ 4189.277169] adc_val,243 [ 4191.281179] adc_val,203 [ 4193.285182] adc_val,203 [ 4195.289191] adc_val,213 [ 4197.293209] adc_val,252 [ 4199.297214] adc_val,258 [ 4201.301244] adc_val,251 [ 4203.305192] adc_val,216 [ 4205.309237] adc_val,199 [ 4207.313247] adc_val,207 [ 4209.317186] adc_val,221 [ 4211.321197] adc_val,253 [ 4213.325304] adc_val,259 [ 4215.329258] adc_val,257 [ 4217.333307] adc_val,250 [ 4219.337303] adc_val,246 [ 4221.341296] adc_val,243 [ 4223.345270] adc_val,233 [ 4225.349263] adc_val,223 [ 4227.353272] adc_val,211 [ 4229.357308] adc_val,206 [ 4231.361350] adc_val,201 [ 4233.365352] adc_val,199 [ 4235.369409] adc_val,200 [ 4237.373370] adc_val,198 [ 4239.377404] adc_val,200 [ 4241.381427] adc_val,201 [ 4243.385409] adc_val,204 [ 4245.389427] adc_val,206 [ 4247.393446] adc_val,212 [ 4249.397467] adc_val,216 [ 4251.401430] adc_val,233 [ 4253.405451] adc_val,252 [ 4255.409480] adc_val,259 [ 4257.413486] adc_val,259 [ 4259.417502] adc_val,256 [ 4259.497638] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 2560x1440p60, type: 11 [ 4261.421486] adc_val,251 [ 4263.425505] adc_val,247 [ 4265.429603] adc_val,244 [ 4267.433552] adc_val,234 [ 4269.437533] adc_val,216 [ 4271.441468] adc_val,205 [ 4273.445536] adc_val,198 [ 4275.449546] adc_val,202 [ 4277.453559] adc_val,202 [ 4279.457566] adc_val,206 [ 4281.461576] adc_val,213 [ 4283.465593] adc_val,218 [ 4285.469597] adc_val,244 [ 4287.473557] adc_val,259 [ 4289.477622] adc_val,258 [ 4291.481627] adc_val,252 [ 4293.485515] adc_val,245 [ 4295.489420] adc_val,237 [ 4297.493600] adc_val,206 [ 4299.497432] adc_val,218 [ 4301.501414] adc_val,222 [ 4303.505698] adc_val,212 [ 4305.509463] adc_val,245 [ 4307.513900] adc_val,270 [ 4309.517608] adc_val,256 [ 4311.521475] adc_val,266 [ 4313.525646] adc_val,254 [ 4315.529928] adc_val,201 [ 4317.533546] adc_val,213 [ 4319.537550] adc_val,216 [ 4321.541552] adc_val,225 [ 4323.545526] adc_val,260 [ 4325.549692] adc_val,261 [ 4327.553826] adc_val,254 [ 4329.557561] adc_val,259 [ 4331.561659] adc_val,218 [ 4333.565718] adc_val,196 [ 4335.569762] adc_val,218 [ 4337.574089] adc_val,229 [ 4339.577604] adc_val,262 [ 4341.581761] adc_val,263 [ 4343.585653] adc_val,257 [ 4345.589640] adc_val,233 [ 4347.593667] adc_val,205 [ 4349.597670] adc_val,212 [ 4351.601674] adc_val,217 [ 4353.608636] adc_val,268 [ 4355.613702] adc_val,249 [ 4357.617759] adc_val,225 [ 4359.621690] adc_val,214 [ 4361.625709] adc_val,214 [ 4363.629837] adc_val,207 [ 4365.633848] adc_val,234 [ 4367.637735] adc_val,269 [ 4369.641734] adc_val,268 [ 4371.645749] adc_val,260 [ 4373.649755] adc_val,227 [ 4375.654977] adc_val,211 [ 4377.661782] adc_val,230 [ 4379.665789] adc_val,261 [ 4381.669795] adc_val,269 [ 4382.643642] usb 3-1: USB disconnect, device number 2 [ 4383.673811] adc_val,263 [ 4385.677924] adc_val,249 [ 4387.682257] adc_val,204 [ 4389.685839] adc_val,207 [ 4391.689843] adc_val,215 [ 4393.693873] adc_val,234 [ 4395.697877] adc_val,263 [ 4397.701884] adc_val,261 [ 4399.705873] adc_val,258 [ 4401.709890] adc_val,218 [ 4403.714175] adc_val,193 [ 4405.717904] adc_val,217 [ 4407.721924] adc_val,228 [ 4409.725948] adc_val,264 [ 4411.729956] adc_val,262 [ 4413.733964] adc_val,257 [ 4415.737967] adc_val,216 [ 4417.741970] adc_val,204 [ 4419.745967] adc_val,219 [ 4421.749996] adc_val,224 [ 4423.754099] adc_val,263 [ 4425.758025] adc_val,258 [ 4427.762022] adc_val,252 [ 4429.766018] adc_val,227 [ 4431.770024] adc_val,209 [ 4433.774149] adc_val,217 [ 4435.778198] adc_val,210 [ 4437.782098] adc_val,270 [ 4439.786076] adc_val,274 [ 4441.790057] adc_val,261 [ 4443.794074] adc_val,229 [ 4445.800148] adc_val,211 [ 4447.806661] adc_val,248 [ 4449.810190] adc_val,266 [ 4451.814117] adc_val,269 [ 4453.818125] adc_val,251 [ 4455.822287] adc_val,208 [ 4457.826234] adc_val,220 [ 4459.830228] adc_val,223 [ 4461.834211] adc_val,263 [ 4463.838213] adc_val,264 [ 4465.842359] adc_val,249 [ 4467.846433] adc_val,209 [ 4469.850214] adc_val,217 [ 4471.854212] adc_val,225 [ 4473.858466] adc_val,229 [ 4475.862317] adc_val,267 [ 4477.866324] adc_val,262 [ 4479.871259] adc_val,217 [ 4481.878295] adc_val,211 [ 4483.882281] adc_val,228 [ 4485.886294] adc_val,270 [ 4487.890304] adc_val,257 [ 4489.894313] adc_val,250 [ 4491.898475] adc_val,207 [ 4493.902317] adc_val,203 [ 4495.906344] adc_val,205 [ 4497.910577] adc_val,217 [ 4499.914516] adc_val,250 [ 4501.918363] adc_val,270 [ 4503.922446] adc_val,261 [ 4505.926358] adc_val,271 [ 4507.930389] adc_val,230 [ 4509.934370] adc_val,211 [ 4511.938366] adc_val,225 [ 4513.942383] adc_val,223 [ 4515.946384] adc_val,261 [ 4517.950390] adc_val,290 [ 4519.954399] adc_val,265 [ 4521.958409] adc_val,268 [ 4523.962415] adc_val,226 [ 4525.966431] adc_val,220 [ 4527.970450] adc_val,232 [ 4529.974489] adc_val,259 [ 4531.978472] adc_val,269 [ 4533.982467] adc_val,263 [ 4535.986476] adc_val,269 [ 4537.990489] adc_val,211 [ 4539.994493] adc_val,227 [ 4541.998502] adc_val,233 [ 4544.002510] adc_val,261 [ 4546.006521] adc_val,283 [ 4548.010531] adc_val,270 [ 4550.014548] adc_val,246 [ 4552.018552] adc_val,204 [ 4554.022561] adc_val,220 [ 4556.026571] adc_val,241 [ 4558.030579] adc_val,286 [ 4560.034589] adc_val,254 [ 4562.038596] adc_val,252 [ 4564.042607] adc_val,195 [ 4566.046617] adc_val,219 [ 4568.050622] adc_val,230 [ 4570.054633] adc_val,264 [ 4572.058642] adc_val,276 [ 4574.062662] adc_val,242 [ 4576.066665] adc_val,222 [ 4578.070668] adc_val,219 [ 4580.074676] adc_val,223 [ 4582.078685] adc_val,242 [ 4584.082696] adc_val,276 [ 4586.086704] adc_val,278 [ 4588.090713] adc_val,245 [ 4590.094724] adc_val,213 [ 4592.098736] adc_val,206 [ 4594.102748] adc_val,231 [ 4596.106751] adc_val,281 [ 4598.110762] adc_val,267 [ 4600.114772] adc_val,257 [ 4602.118781] adc_val,206 [ 4604.122788] adc_val,217 [ 4606.126798] adc_val,210 [ 4608.130803] adc_val,247 [ 4610.134818] adc_val,269 [ 4612.138821] adc_val,266 [ 4614.142835] adc_val,231 [ 4616.146845] adc_val,199 [ 4618.150900] adc_val,223 [ 4620.154907] adc_val,238 [ 4622.158918] adc_val,282 [ 4624.162901] adc_val,263 [ 4626.166893] adc_val,263 [ 4628.170941] adc_val,202 [ 4630.174953] adc_val,201 [ 4632.178956] adc_val,223 [ 4634.182942] adc_val,266 [ 4636.186941] adc_val,279 [ 4638.190992] adc_val,246 [ 4640.194989] adc_val,229 [ 4642.199113] adc_val,197 [ 4644.203016] adc_val,221 [ 4646.206996] adc_val,245 [ 4648.211031] adc_val,265 [ 4650.215017] adc_val,258 [ 4652.219052] adc_val,226 [ 4654.223062] adc_val,214 [ 4656.227073] adc_val,210 [ 4658.231075] adc_val,258 [ 4660.235090] adc_val,280 [ 4662.239103] adc_val,243 [ 4664.243108] adc_val,231 [ 4666.247115] adc_val,201 [ 4668.251126] adc_val,218 [ 4670.255140] adc_val,222 [ 4672.259119] adc_val,258 [ 4674.263152] adc_val,246 [ 4676.267137] adc_val,227 [ 4678.271175] adc_val,196 [ 4680.275187] adc_val,206 [ 4682.279166] adc_val,248 [ 4684.283163] adc_val,259 [ 4686.287242] adc_val,245 [ 4688.291191] adc_val,233 [ 4690.295225] adc_val,195 [ 4692.299211] adc_val,207 [ 4694.303209] adc_val,251 [ 4696.307245] adc_val,254 [ 4698.311263] adc_val,238 [ 4700.315246] adc_val,200 [ 4702.319241] adc_val,199 [ 4704.323280] adc_val,216 [ 4706.327273] adc_val,260 [ 4708.331315] adc_val,248 [ 4710.335322] adc_val,229 [ 4712.339319] adc_val,194 [ 4714.343338] adc_val,229 [ 4716.347315] adc_val,262 [ 4718.351353] adc_val,250 [ 4720.355364] adc_val,231 [ 4722.359345] adc_val,192 [ 4724.363381] adc_val,209 [ 4726.367365] adc_val,254 [ 4728.371359] adc_val,244 [ 4730.375407] adc_val,217 [ 4732.379420] adc_val,222 [ 4734.383433] adc_val,220 [ 4736.387435] adc_val,266 [ 4738.391447] adc_val,240 [ 4740.395428] adc_val,197 [ 4742.399466] adc_val,210 [ 4744.403444] adc_val,262 [ 4746.407484] adc_val,240 [ 4748.411496] adc_val,189 [ 4750.415504] adc_val,210 [ 4752.419510] adc_val,252 [ 4754.423542] adc_val,271 [ 4756.427503] adc_val,218 [ 4758.431495] adc_val,211 [ 4760.435505] adc_val,243 [ 4762.439513] adc_val,253 [ 4764.443523] adc_val,229 [ 4766.447532] adc_val,207 [ 4768.451544] adc_val,213 [ 4770.455545] adc_val,263 [ 4772.459559] adc_val,236 [ 4774.463567] adc_val,200 [ 4776.467579] adc_val,235 [ 4778.471597] adc_val,258 [ 4780.475596] adc_val,243 [ 4782.479601] adc_val,216 [ 4784.483613] adc_val,202 [ 4786.487622] adc_val,239 [ 4788.491632] adc_val,252 [ 4790.495646] adc_val,227 [ 4792.499652] adc_val,201 [ 4794.503657] adc_val,231 [ 4796.507669] adc_val,257 [ 4798.511677] adc_val,243 [ 4800.515685] adc_val,201 [ 4802.519692] adc_val,201 [ 4804.523706] adc_val,225 [ 4806.527809] adc_val,245 [ 4808.531988] adc_val,241 [ 4810.535862] adc_val,187 [ 4812.539816] adc_val,198 [ 4814.543793] adc_val,233 ########################################################################## Linux 4.4.154 (firefly) 19.02.2019 _aarch64_ (6 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 18,18 0,17 0,86 0,18 0,00 80,61 Device tps kB_read/s kB_wrtn/s kB_read kB_wrtn loop0 0,00 0,00 0,00 8 0 mmcblk0 11,23 154,85 145,53 745779 700902 total used free shared buff/cache available Mem: 3,8G 244M 2,4G 43M 1,1G 3,4G Swap: 0B 0B 0B Architecture: aarch64 Byte Order: Little Endian CPU(s): 6 On-line CPU(s) list: 0-5 Thread(s) per core: 1 Core(s) per socket: 3 Socket(s): 2 Vendor ID: ARM Model: 4 Model name: Cortex-A53 Stepping: r0p4 CPU max MHz: 1800,0000 CPU min MHz: 408,0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 Edited February 19, 2019 by Tido added spoiler.. shorted quote - please add a spoiler nexttime yourself, thx
TonyMac32 Posted February 20, 2019 Posted February 20, 2019 On 2/16/2019 at 1:27 AM, gounthar said: I haven't been able to start mine for the time being with the Firefly image. Not one led ever blinked, no output, nothing... the USB-C at the rear with the Ethernet port is the power-in, not hard to do backwards. 1
Redferne Posted February 26, 2019 Posted February 26, 2019 Ok, tried a compiled Armbian firefly-rk3399 image but it refuses to go beyond this: Spoiler channel 0 training pass! channel 1 training pass! change freq to 800MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x2020 ch 1 ddrconfig = 0x101, ddrsize = 0x2020 pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD OUT Boot1: 2018-08-06, version: 1.15 CPUId = 0x0 ChipType = 0x10, 219 mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! emmc reinit mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! emmc reinit mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! SdmmcInit=2 1 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=30528MB FwPartOffset=2000 , 0 StorageInit ok = 55992 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 GPT 0x3190d20 signature is wrong LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0x9a3e8 RunBL31 0x10000 NOTICE: BL31: v1.3(debug):f947c7e NOTICE: BL31: Built : 21:48:22, Feb 10 2019 It simply hangs there in BL31... Comparing the output from image compiled from Firefly repo (which boots correctly): Spoiler channel 0 training pass! channel 1 training pass! change freq to 800MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x2020 ch 1 ddrconfig = 0x101, ddrsize = 0x2020 pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD OUT Boot1: 2018-08-06, version: 1.15 CPUId = 0x0 ChipType = 0x10, 219 mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! emmc reinit mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! emmc reinit mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! SdmmcInit=2 1 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=30528MB FwPartOffset=2000 , 0 StorageInit ok = 56219 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 GPT 0x3190d20 signature is wrong LoadTrust Addr:0x4000 No find bl30.bin Load uboot, ReadLba = 2000 hdr 00000000031906c0 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, Load OK, addr=0x200000, size=0xad060 RunBL31 0x10000 NOTICE: BL31: v1.3(debug):56eea3d NOTICE: BL31: Built : 15:27:37, Aug 8 2018 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1151): pd status 3e INFO: BL31: Initializing runtime services INFO: BL31: Initializing BL32 INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-170-gc4654a6 #16 Wed May 30 08:54:30 UTC 2018 aarch64) INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2 INF [0x0] TEE-CORE:init_teecore:83: teecore inits done INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-g73d3fd4b32 (Feb 02 2019 - 03:32:50 +0100) ... Some expert advice really appreciated
TonyMac32 Posted February 27, 2019 Posted February 27, 2019 Ram configuration, something else. They aren't the same board, and the Rockchip designs, using such complex PMIC's, don't usually just come on with each others' images. (MiQi and Tinker won't boot each other's images, I don't believe Renegade and Rock64 will either). I need to sit down and make a wip/csc for this board. Confirmed, renegade elite has LPDDR4, Firefly has DDR3.
Redferne Posted March 1, 2019 Posted March 1, 2019 I compared the u-boot source between Armbian and the booting Firefly image, there's a lot of changes since they are about 4 months apart. It seems though that there's some tinkering with SDRAM sizes, not sure if those changes are actually executed or if they have made it into v2018.11. Would be good to know if the problem is in BL31 or if it actually reaches u-boot. Not really sure where to start digging at the moment. If in fact the DDR3/DDR4 difference is not already handled in BL31 or if it hangs when BL31 hands over to u-boot. Actually, now when looking closer. It seems to hang already in BL31, Oh crap. So need start digging in there then
Redferne Posted March 3, 2019 Posted March 3, 2019 (edited) Update, I replaced ATF (BL31) with a precompiled version from the Firefly build. File I used for trust_merger is this rk3399_bl31_v1.18.elf I guess this version properly handles LPDDR4. Look into the Rockchip rkbin repo, they are now up to v1.24. Anyhow.. U-Boot is finally executing Now I need to start figure out how to select a working dtb Spoiler LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0x9a3e8 RunBL31 0x10000 NOTICE: BL31: v1.3(debug):56eea3d NOTICE: BL31: Built : 15:27:37, Aug 8 2018 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1151): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2018.11-armbian (Mar 03 2019 - 01:50:38 +0100) Model: Firefly-RK3399 Board DRAM: 3.9 GiB MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from EXT4... Card did not respond to voltage select! In: serial@ff1a0000 Out: serial@ff1a0000 Err: serial@ff1a0000 Model: Firefly-RK3399 Board Net: Error: ethernet@fe300000 address not set. eth-1: ethernet@fe300000 Hit any key to stop autoboot: 0 Card did not respond to voltage select! switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 2958 bytes read in 2 ms (1.4 MiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 137 bytes read in 1 ms (133.8 KiB/s) 4694491 bytes read in 307 ms (14.6 MiB/s) 19980296 bytes read in 1296 ms (14.7 MiB/s) Edited March 3, 2019 by Redferne
