How to build specific kernel
Officially, how do I convince my build environment that I still want to use 4.14?
When I just
./compile.sh BOARD=nanopiair BRANCH=next
it defaults to 4.17
What I have come up with is:
git checkout sunxi-4.14 && touch .ignore_changes
This results in a lot of patches failing
What is the correct way please?
Link to comment
Share on other sites
18 hours ago, Igor said:
Yep, Read that and tried
LIB_TAG="sunxi-4.14"
but that stilled wanted to use 4.17.
I have since renamed my build directory, and started from scratch cloning your build environment again, and that seems to be working. Obviously, my local directory got corrupted. I'll let you know how the build goes.
Link to comment
If you were editing something outside user area, this is normal. It will not change branches ... and overwrite your changes. Perhaps we need to add another warning.
Link to comment
The only places I am *aware* that I had changed files were:
build/config/kernel/linux-sunxi-next.config (and then reverted)
build/patches/sunxi* (renamed to & from .disabled)
build/userpatches/
cache/sources/linux-mainline/
I'm not saying that these are definitely the only files that I changed, only the ones that I can remember.
colin@ArmbianDev:~/Armbian/build$ git status
didn't flag anything either.
However, all that aside, checking out an entire new build env from your github repo fixed all the errors for my basic build.
./compile.sh BOARD=nanopiair BRANCH=next LIB_TAG=sunxi-4.14 KERNEL_ONLY=yes KERNEL_CONFIGURE=yes
works flawlessly
However, I want a real-time sunxi-next kernel. The latest 4.14 RT patch that I can find at https://mirrors.edge.kernel.org/pub/linux/kernel/projects/rt/4.14/ is patch-4.14.52-rt34.patch. Is there any way that I can convince the compile script to only download 4.14.52, not 4.14.58?
Link to comment
build/patches/sunxi
Those are build system areas. You copy linux-sunxi-next.config to build/userpatches/ and edit there ... the same goes with patches, copy to userpatches/kernel/sunxi-next (in this case) and rename to .patch ... those .disabled are for our internal needs.
Sure it is. https://docs.armbian.com/Developer-Guide_User-Configurations/
Add: KERNELBRANCH='tag:v4.14.52' to build/userpatches/lib.config
Link to comment
OK. That is awesome!!
One problem, I can't find KERNELBRANCH documented :-(
Link to comment
Documentation is always behind/at minimum since we are low on resources. It is stated: "For a comprehensive list of available variables, look through lib/configuration.sh"
https://github.com/armbian/documentation/blob/master/docs/Developer-Guide_User-Configurations.md#user-provided-configuration
Feel free to make a pull request if you want to extend this part of the documentation.
Link to comment
*Blush*
I'll see what I can do to help. Maybe a week before I can.
Link to comment
*Hello, i want to build a armbian image with a custom kernel version. I got some problem.
I read this topic and the following documentation :
- https://docs.armbian.com/Developer-Guide_Build-Options/
I want use this specific version : 5.4.45
So i have put in my "lib.conf" this line
KERNELBRANCH="tag:v5.4.45"
Then i have try to build with these commands :
./compile.sh KERNEL_ONLY=no KERNEL_CONFIGURE=no INSTALL_HEADERS=yes BUILD_DESKTOP=yes BOARD=orangepizeroplus2-h3  RELEASE=buster COMPRESS_OUTPUTIMAGE=sha,gpg,img, BRANCH=current
./compile.sh EXPERT=yes KERNEL_ONLY=no KERNEL_CONFIGURE=no INSTALL_HEADERS=yes BUILD_DESKTOP=yes BOARD=orangepizeroplus2-h3 RELEASE=buster COMPRESS_OUTPUTIMAGE=sha,gpg,img BRANCH=dev
I got error, it seem that the kernel was not found:
[ o.k. ] Checking git sources [ linux-mainline v5.4.45 ]
[ .... ] Fetching updates
fatal: Couldn't find remote ref tags/v5.4.45
[ .... ] Checking out
error: pathspec 'FETCH_HEAD' did not match any file(s) known to git
[ o.k. ] Checking git sources [ sunxi-tools master ]
make: *** No rule to make target 'olddefconfig'.  Stop.
[ error ] ERROR in function compile_kernel [ compilation.sh:414 ]
[ error ] Kernel was not built [ @host ]
[ o.k. ] Process terminated
By reading this topic, i have try this command, but it is seem not to be the good way to do this but the kernel was found:
./compile.sh KERNEL_ONLY=no KERNEL_CONFIGURE=no INSTALL_HEADERS=yes BUILD_DESKTOP=yes BOARD=orangepizeroplus2-h3 RELEASE=buster COMPRESS_OUTPUTIMAGE=sha,gpg,img BRANCH=next
but i still got an error at the end:
  CC      kernel/padata.o
  CC      kernel/crash_dump.o
  CC      kernel/jump_label.o
  CC      kernel/iomem.o
  CC      kernel/rseq.o
  AR      kernel/built-in.a
i have try with different additionnal LIB_TAG argument too : LIB_TAG=sunxi-5.5 or LIB_TAG=sunxi-5.3
"sunxi-5.4" tag seem missing.
It is possible to me to build armbian with a custom kernel version ? what setting i have miss ?
the branch "next" seem legacy, what is the recent way to do this ?  (kernel is not fetch when BRANCH=dev)
Link to comment
That wont work in this special case. Only for kernel sources that are patches by upstream.
On sunxi-legacy however from a specific point Armbian had to print upstream patches by themselves.
Sounds complicated but for you a rather easy fix. Check https://github.com/armbian/build/tree/master/patch/kernel/sunxi-legacy and remove all upstream patches above 5.4.45
Btw as branch you need to use "legacy" instead of "current" since the branches have been cycled a few days ago. current would give you 5.7 kernel.
Link to comment
How i can get the list of all kernel version available for my custom build  by using option provided by armbian?
I have tried to build without specifying the kernel as follows:
./compile.sh KERNEL_ONLY=no KERNEL_CONFIGURE=no INSTALL_HEADERS=yes BUILD_DESKTOP=yes BOARD=orangepizeroplus2-h3 RELEASE=buster COMPRESS_OUTPUTIMAGE=sha,gpg,img BRANCH=legacy
the build work fine and the kernel version is 5.4.51. But if i specify this kernel into "lib.config" and do it again :
KERNELBRANCH="tag:v5.4.51"
the build system can't fetch the kernel version:
fatal: Couldn't find remote ref tags/v5.4.51
If i want a specific version of kernel and maintain it. What i need to look and what i need to set to make it work ?
I didn't understand well what i need to do with different option provided by armbian build system.
Link to comment
Once again in this particular case defining a specific branch won't work since sunxi relying on 3rd party sources. In your particular case here: https://github.com/megous/linux/tree/orange-pi-5.4
You can find these also when you start digging through the configs for your boards and their matching board families.
Back to the sources: Megi does not add tags and also maintains a kernel version only to a certain level and mostly works on the newest available sources. It is up to us as we use these sources to keep them halfway up to date if possible and we do that using our patches. The location you can find in my previous post.
There is no general way to get specific kernel versions for every single board. The wide variety of boards makes that impossible.
Link to comment
