FoodGenius Posted September 5, 2018 Author Posted September 5, 2018 33 minutes ago, ebin-dev said: The 1g-2cs images are confirmed to be working. all these confirmation-tests (you mentioned in https://pastebin.com/mfrDk4AQ, ) shows boards with SPI w25q32dw - thats the old winbond SPI. we have only those problems with the new one... macronix SPI mx25u3235f it seems, your build only supports these macronix SPI mx25u1635e and mx25u6435f http://www.macronix.com/Lists/Datasheet/Attachments/7412/MX25U1635E, 1.8V, 16Mb, v2.1.pdfhttp://www.macronix.com/Lists/Datasheet/Attachments/7411/MX25U6435F, 1.8V, 64Mb, v1.5.pdf but mx25u3235f is neededhttp://www.macronix.com/Lists/Datasheet/Attachments/7438/MX25U3235F, 1.8V, 32Mb, v1.6.pdf since the new espresso board use a Macronix MXIC MX 25V3 2311 -> SF: Detected mx25u3235f with page size 256 Bytes, erase size 64 KiB, total 4 MiB (shown by vendor/manufacturer shipped bootloader) U-Boot 2017.03-armada-17.10.2-g14aeedc (Jun 01 2018 - 15:39:10 +0800) aarch64-linux-gnu-gcc (Linaro GCC 5.2-2015.11-2) 5.2.1 20151005 GNU ld (GNU Binutils) 2.25.0 Linaro 2015_10
ebin-dev Posted September 5, 2018 Posted September 5, 2018 The issue with your Macronix chip needs to be dealt with by the manufacturer - unannounced board changes leading to unsupported systems are not very pleasant.
FoodGenius Posted September 5, 2018 Author Posted September 5, 2018 1 minute ago, ebin-dev said: The issue with your Macronix chip needs to be dealt with by the manufacturer - unannounced board changes leading to unsupported systems are not very pleasant. that is right. i known this. thank you for you work. but it means, that any new user who's buying an actual espresso bin board and using armbian with the current provided armbian bootloader... will "brick" the board, can't use bubt oder or save env, and so.. can't use armbian. armbian espressobin release only works with old espresso bin boards (those with winbond SPI). This hint should be clearly visible at https://www.armbian.com/espressobin/ since support ist now "broken", until we have a bootloader that supports mx25u3235f. I have no response from espressobin yet. I referenced this thread.
ebin-dev Posted September 5, 2018 Posted September 5, 2018 1 hour ago, FoodGenius said: I have no response from espressobin yet. I referenced this thread. Thank you for making public the issue with the unsupported Macronix chip. There is a corresponding warning on the EspressoBin download page. I have a reason to assume that this issue is already being dealt with. We have reverted back the flash-images to 17.10 as compiled on Aug. 26th since there still seem to exist some issues with the new 18.09 images that need to be resolved.
andreacao Posted September 5, 2018 Posted September 5, 2018 somewhere can downlaod image for flash and uart image? which correct
kostap Posted September 5, 2018 Posted September 5, 2018 3 hours ago, ebin-dev said: We have reverted back the flash-images to 17.10 as compiled on Aug. 26th since there still seem to exist some issues with the new 18.09 images that need to be resolved. U-boot-2017 18.09 is still good. I tried it and it seems to boot normally: IM-1.0 WTMI-devel-18.07.0-6050fd5 WTMI: system early-init CPU VDD voltage default value: 1.108V NOTICE: Booting Trusted Firmware NOTICE: BL1: v1.5(release):v1.5-221-g9e22043 (Marvell-devel-18.09.0) NOTICE: BL1: Built : 16:51:14, Sep 5 2018 NOTICE: BL1: Booting BL2 NOTICE: BL2: v1.5(release):v1.5-221-g9e22043 (Marvell-devel-18.09.0) NOTICE: BL2: Built : 16:51:15, Sep 5 2018 WARNING: Failed to obtain reference to image id=4 (-2) WARNING: Failed to load BL32 (-2) NOTICE: BL1: Booting BL31 NOTICE: BL31: v1.5(release):v1.5-221-g9e22043 (Marvell-devel-18.09.0) NOTICE: BL31: Built : 16:51:18 U-Boot 2017.03-devel-18.09.0-00814-g09e03ea-dirty (Sep 05 2018 - 16:45:31 +0300) Model: Marvell Armada 3720 Community Board ESPRESSOBin CPU 800 [MHz] L2 800 [MHz] NB AXI 200 [MHz] SB AXI 250 [MHz] DDR 800 [MHz] DRAM: 1 GiB U-Boot DT blob at : 000000003f7142d8 Comphy chip #0: Comphy-0: USB3 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 6 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link down MMC: sdhci@d0000: 0 SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0 Marvell>> Marvell>> version U-Boot 2017.03-devel-18.09.0-00814-g09e03ea-dirty (Sep 05 2018 - 16:45:31 +0300) aarch64-linux-gnu-gcc (Linaro GCC 7.3-2018.05) 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] GNU ld (Linaro_Binutils-2018.05) 2.28.2.20170706 0001-drivers-spi-Add-support-for-Macronix-mx25u3235f-devi.patch
ebin-dev Posted September 5, 2018 Posted September 5, 2018 On 9/5/2018 at 11:44 AM, FoodGenius said: we have only those problems with the new one... macronix SPI mx25u3235f So here there is finally a set of new flash-images-18.09 (with u-boot 2017.03-18.09 and with macronix support - not tested) (patch provided by @kostap - thanks!). The official Armbian flash images are still version 17.10 as compiled on Aug. 26th (without macronix support). Edit: 18.09 images compiled with u-boot 2017.03-18.09, macronix support Edit: 18.09 images are confirmed to work on the 1g-2cs EspressoBin, but changes to the Armbian bootscript are necessary in order to boot Armbian images with the environment settings shown on the EspressoBin download page.
kostap Posted September 5, 2018 Posted September 5, 2018 19 minutes ago, ebin-dev said: Edit: U-boot 2018.03-18.09 does not correctly display available DDR RAM - but it is supposed to be available Just remember that Marvell release 18.09 contains both u-boot 2017.03 and 2018.03. It turns out that A3700 support in the new 2018 u-boot is not yet mature. So I would recommend to take all the component of 18.09 release (ATF, DDR code, A3700 utilities) and build the image with u-boot 2017.03-18.09 (the last one after applying Macronix patch on top). So you will benefit from all extensions and fixes in the boot loader code up to current date.
ebin-dev Posted September 5, 2018 Posted September 5, 2018 @kostap I have made available firmware images compiled with u-boot 2017.03-18.09 in my previous post. @FoodGenius now you have something worth trying.
FoodGenius Posted September 6, 2018 Author Posted September 6, 2018 I'm currently using this Image kostap-flash-image-espressobin-1g-2cs-1000_800_v2017.bin a predecessor of flash-images-18.09/flash-image-1g-2cs-1000_800_boot_sd_and_usb.bin out of https://www.dropbox.com/s/sn8bafe250s8r2c/flash-images-18.09.tar.gz?dl=1 which was also provided by kostap. Marvell>> version U-Boot 2017.03-devel-18.09.0-00814-g09e03ea-dirty (Sep 05 2018 - 16:45:31 +0300) aarch64-linux-gnu-gcc (Linaro GCC 7.3-2018.05) 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] GNU ld (Linaro_Binutils-2018.05) 2.28.2.20170706 and modified env to boot armbian from mmc. still not sure about the address ranges, but until now it runs stable. will do some further testing. setenv default -a setenv verbosity "2" setenv boot_interface mmc setenv image_name boot/Image setenv initrd_image "boot/uInitrd" setenv fdt_name boot/dtb/marvell/armada-3720-community.dtb setenv fdt_high "0xffffffffffffffff" setenv rootdev "/dev/mmcblk0p1" setenv rootfstype "ext4" setenv initrd_addr "0x1100000" setenv usbstoragequirks "0x2537:0x1066:u,0x2537:0x1068:u" setenv fdt_addr "0x6000000" setenv kernel_addr "0x7000000" setenv loadaddr "0x8000000" setenv initrd_size "0x2000000" setenv bootcmd 'mmc dev 0; ext4load mmc 0:1 $kernel_addr $image_name;ext4load mmc 0:1 $initrd_addr $initrd_image; ext4load mmc 0:1 $fdt_addr $fdt_name; setenv bootargs $console root=$rootdev rw rootwait; booti $kernel_addr $initrd_addr $fdt_addr' setenv ethaddr F0:AD:4E:..... setenv eth1addr F0:AD:4E:..... setenv eth2addr F0:AD:4E:..... setenv eth3addr F0:AD:4E:..... env save and this works an boots into armbian on actual espresso bin board with macronix chip. I will also test the current releases from kostap. Edit: OK. fine. flash-images-18.09/flash-image-1g-2cs-800_800_boot_sd_and_usb.bin Marvell>> version U-Boot 2017.03-armada-18.09.1-ga92bd86-armbian (Sep 05 2018 - 21:49:34 +0200) aarch64-linux-gnu-gcc (Linaro GCC 7.3-2018.05) 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] GNU ld (Linaro_Binutils-2018.05) 2.28.2.20170706 Marvell>> sspi SF: Detected mx25u3235f with page size 256 Bytes, erase size 64 KiB, total 4 MiB works for me and booting into armbian with my posted environment. Many Thanks @kostap , @skandalfo and @ebin-dev Thank you. still have to do some stability test and recover the stack of all "burned" testboards.
ebin-dev Posted September 6, 2018 Posted September 6, 2018 The current 18.09 bootloader images (compiled Sept. 5th, 21:49) do work fine with the adapted address ranges. (u-boot 2017.03-18.09 used, macronix support confirmed by @FoodGenius, 1g-2cs images tested) Booting from SD into the current Armbian Stretch 4.18.y image works fine with these environment settings: setenv default -a setenv verbosity "2" setenv boot_interface mmc setenv image_name boot/Image setenv initrd_image "boot/uInitrd" setenv fdt_name boot/dtb/marvell/armada-3720-espressobin.dtb setenv fdt_high "0xffffffffffffffff" setenv rootdev "/dev/mmcblk1p1" setenv rootfstype "ext4" setenv initrd_addr "0x1100000" setenv usbstoragequirks "0x2537:0x1066:u,0x2537:0x1068:u" setenv fdt_addr "0x6000000" setenv kernel_addr "0x7000000" setenv loadaddr "0x8000000" setenv initrd_size "0x2000000" setenv bootcmd 'mmc dev 0; ext4load mmc 0:1 $kernel_addr $image_name;ext4load mmc 0:1 $initrd_addr $initrd_image; ext4load mmc 0:1 $fdt_addr $fdt_name; setenv bootargs $console root=$rootdev rw rootwait; booti $kernel_addr $initrd_addr $fdt_addr' setenv ethaddr F0:AD:4E:..... setenv eth1addr F0:AD:4E:..... setenv eth2addr F0:AD:4E:..... setenv eth3addr F0:AD:4E:..... env save ... and the environment to boot from SCSI into a current Armbian Stretch 4.18.y image: setenv default -a setenv verbosity "2" setenv boot_interface scsi setenv image_name boot/Image setenv initrd_image "boot/uInitrd" setenv fdt_name boot/dtb/marvell/armada-3720-espressobin.dtb setenv fdt_high "0xffffffffffffffff" setenv rootdev "/dev/sda1" setenv rootfstype "ext4" setenv initrd_addr "0x1100000" setenv usbstoragequirks "0x2537:0x1066:u,0x2537:0x1068:u" setenv fdt_addr "0x6000000" setenv kernel_addr "0x7000000" setenv loadaddr "0x8000000" setenv initrd_size "0x2000000" setenv bootcmd 'scsi scan; scsi dev 0; ext4load scsi 0:1 $kernel_addr $image_name;ext4load scsi 0:1 $initrd_addr $initrd_image; ext4load scsi 0:1 $fdt_addr $fdt_name; setenv bootargs $console root=$rootdev rw rootwait; booti $kernel_addr $initrd_addr $fdt_addr' setenv ethaddr F0:AD:4E:..... setenv eth1addr F0:AD:4E:..... setenv eth2addr F0:AD:4E:..... setenv eth3addr F0:AD:4E:..... env save Edit: SCSI environment added Edit: Linked to https://dl.armbian.com/espressobin/u-boot/
jrtaylor Posted September 6, 2018 Posted September 6, 2018 Unable to boot with new u-boot image 1g-2cs-1000_800 using Armbian_5.59_Espressobin_Debian_stretch_next_4.18.5.img. https://dl.armbian.com/espressobin/u-boot/archive/flash-image-1g-2cs-1000_800_boot_sd_and_usb.bin TIM-1.0 WTMI-armada-17.10.5-177ba47 WTMI: system early-init SVC REV: 4, CPU VDD voltage: 1.143V Fill memory before self refresh...done Fill memory before self refresh...done Now in Self-refresh Mode Restore termination values to original values Exited self-refresh ... Self refresh Pass. DDR self test mode test done!! Self refresh Pass. DDR self test mode test done!! QS GATING ============= Calibration done: cycle = 0x00 tap =0x62 CH0_PHY_RL_Control_CS0_B0[0xC0001180]: 0x00000062 CH0_PHY_RL_Control_CS0_B1[0xC0001184]: 0x00000062 QS GATING ============= Calibration done: cycle = 0x00 tap =0x61 CH0_PHY_RL_Control_CS1_B0[0xC00011A4]: 0x00000061 CH0_PHY_RL_Control_CS1_B1[0xC00011A8]: 0x00000061 DLL TUNING ============== DLL 0xc0001050[21:16]: [0,20,10] DLL 0xc0001050[29:24]: [6,30,1b] DLL 0xc0001054[21:16]: [0,23,11] DLL 0xc0001054[29:24]: [6,33,1c] DLL 0xc0001074[21:16]: [0,3f,1f] DLL 0xc0001074NOTICE: Booting Trusted Firmware NOTICE: BL1: v1.3(release):armada-17.10.8:34247e0 NOTICE: BL1: Built : 19:00:29, Aug 26 2NOTICE: BL2: v1.3(release):armada-17.10.8:34247e0 NOTICE: BL2: Built : 19:00:29, Aug 26 2018 NNOTICE: BL31: v1.3(release):armada-17.10.8:34247e0 NOTICE: BL31: U-Boot 2017.03-armada-17.10.3-g06ad760 (Aug 26 2018 - 19:00:03 +0200) Model: Marvell Armada 3720 Community Board ESPRESSOBin CPU @ 1000 [MHz] L2 @ 800 [MHz] TClock @ 200 [MHz] DDR @ 800 [MHz] DRAM: 1 GiB U-Boot DT blob at : 000000003f7182d8 Comphy-0: USB3 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 6 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link up MMC: sdhci@d0000: 0 SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device ext4load - load binary file from a Ext4 filesystem Usage: ext4load <interface> [<dev[:part]> [addr [filename [bytes [pos]]]]] - load binary file 'filename' from 'dev' on 'interface' to address 'addr' from ext4 filesystem 4589284 bytes read in 212 ms (20.6 MiB/s) 8607 bytes read in 18 ms (466.8 KiB/s) Bad Linux ARM64 Image magic! printenv baudrate=115200 boot_interface=mmc bootargs=console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 root=UUID=d556ab78-e4f7-4914-bfd1-7e3fb44f7a54 rw rootwait bootcmd=mmc dev 0; ext4load mmc 0:1 $kernel_addr $image_name;ext4load mmc 0:1 $initrd_addr $initrd_image; ext4load mmc 0:1 $fdt_addr $fdt_name; setenv bootargs $console root=$rootdev rw rootwait; booti $kernel_addr $initrd_addr $fdt_addr bootdelay=2 bootmmc=mmc dev 0; ext4load mmc 0:1 $kernel_addr $image_name;ext4load mmc 0:1 $fdt_addr $fdt_name;setenv bootargs $console root=/dev/mmcblk0p1 initrd=initrd.img rw rootwait; booti $kernel_addr - $fdt_addr console=console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 default=-a emmc_fix=off eth1addr=00:50:43:... eth2addr=00:50:43:... eth3addr=00:50:43:... ethact=neta@30000 ethaddr=F0:AD:4E:... ethaddr=F0:AD:4E:... ethprime=eth0 fdt_addr=0x6000000 fdt_addr=0x6000000 fdt_high=0xffffffffffffffff fdt_name=boot/dtb/marvell/armada-3720-espressobin.dtb fdt_name_a=boot/dtb/marvell/armada-3720-community.dtb fdt_name_b=boot/dtb/marvell/armada-3720-espressobin.dtb fdtcontroladdr=3f7182d8 fileaddr=6000000 filesize=219f gatewayip=10.4.50.254 get_images=tftpboot $kernel_addr $image_name; tftpboot $fdt_addr $fdt_name; run get_ramfs get_ramfs=if test "${ramfs_name}" != "-"; then setenv ramfs_addr 0x8000000; tftpboot $ramfs_addr $ramfs_name; else setenv ramfs_addr -;fi hostname=marvell image_name=boot/Image initrd_addr=0x1100000 initrd_image=boot/uInitrd initrd_size=0x2000000 ipaddr=0.0.0.0 kernel_addr=0x7000000 load_script=if test -e mmc 0:1 boot/boot.scr; then echo "... booting from SD";setenv boot_interface mmc;else echo "... booting from USB/SATA";usb start;setenv boot_interface usb;fi;if test -e $boot_interface 0:1 boot/boot.scr;then ext4load $boot_interface 0:1 0x00800000 boot/boot.scr; source; fi loadaddr=0x8000000 netdev=eth0 netmask=255.255.255.0 ramfs_addr=- ramfs_name=- root=root=/dev/nfs rw rootdev=UUID=d556ab78-e4f7-4914-bfd1-7e3fb44f7a54 rootfstype=ext4 rootpath=/srv/nfs/ serverip=0.0.0.0 set_bootargs=setenv bootargs $console $root ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:none nfsroot=$serverip:$rootpath $extra_params stderr=serial@12000 stdin=serial@12000 stdout=serial@12000 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u verbosity=1 Environment size: 2440/65532 bytes
ebin-dev Posted September 6, 2018 Posted September 6, 2018 @jrtaylor You are using the official 17.10 image: U-Boot 2017.03-armada-17.10.3-g06ad760 (Aug 26 2018 - 19:00:03 +0200). You need to set the environment settings as specified on the EspressoBin download page (bootloader script). (Before you apply the settings you can reset your environment to default values with Marvell>> env default -a ) The new 18.09 images as linked in my previous posting (not yet official) currently do not work with that script since load addresses were moved - therefore you need to use the environment settings shown above - only for those 18.09 images.
skandalfo Posted September 6, 2018 Posted September 6, 2018 Yay! I can confirm at least the new 18.09 flash-image-2g-2cs-1000_800_boot_sd_and_usb.bin works in my board.
jrtaylor Posted September 6, 2018 Posted September 6, 2018 Loaded correct u-boot image but same problem. TIM-1.0 WTMI-devel-18.07.0-6050fd5 WTMI: system early-init SVC REV: 4, CPU VDD voltage: 1.143V NOTICE: Booting Trusted Firmware NOTICE: BL1: v1.5(release):711ecd3 (Marvell-armada-18.09.4) NOTICE: BL1: Built : 21:52:23, Sep 5 2018 NOTICE: BL1: Booting BL2 NOTICE: BL2: v1.5(release):711ecd3 (Marvell-armada-18.09.4) NOTICE: BL2: Built : 21:52:26, Sep 5 2018 NOTICE: BL1: Booting BL31 NOTICE: BL31: v1.5(release):711ecd3 (Marvell-armada-18.09.4) NOTICE: BL31: Built : 21:5 U-Boot 2017.03-armada-18.09.1-ga92bd86-armbian (Sep 05 2018 - 21:49:34 +0200) Model: Marvell Armada 3720 Community Board ESPRESSOBin CPU 1000 [MHz] L2 1000 [MHz] NB AXI 250 [MHz] SB AXI 250 [MHz] DDR 800 [MHz] DRAM: 1 GiB U-Boot DT blob at : 000000003f7142d8 Comphy chip #0: Comphy-0: USB3 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 6 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link up MMC: sdhci@d0000: 0 SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device ext4load - load binary file from a Ext4 filesystem Usage: ext4load <interface> [<dev[:part]> [addr [filename [bytes [pos]]]]] - load binary file 'filename' from 'dev' on 'interface' to address 'addr' from ext4 filesystem 4589284 bytes read in 212 ms (20.6 MiB/s) ext4load - load binary file from a Ext4 filesystem Usage: ext4load <interface> [<dev[:part]> [addr [filename [bytes [pos]]]]] - load binary file 'filename' from 'dev' on 'interface' to address 'addr' from ext4 filesystem Bad Linux ARM64 Image magic! Marvell>> printenv arch=arm baudrate=115200 board=mvebu_armada-37xx board_name=mvebu_armada-37xx boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr} boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootaa64.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf boot_interface=mmc boot_net_pci_enum=pci enum boot_net_usb_start=usb start boot_prefixes=/ /boot/ boot_script_dhcp=boot.scr.uimg boot_scripts=boot.scr.uimg boot.scr boot_targets=mmc1 mmc0 usb0 scsi0 pxe dhcp bootargs=console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 root=/dev/mmcblk1p1 rw rootwait bootcmd=mmc dev 0; ext4load mmc 0:1 $kernel_addr $image_name;ext4load mmc 0:1 $initrd_addr $initrd_image; ext4load mmc 0:1 $fdt_addr $fdt_name; setenv bootargs $console root=$rootdev rw rootwait; booti $kernel_addr $initrd_addr $fdt_addr bootcmd_dhcp=run boot_net_usb_start; run boot_net_pci_enum; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00011:UNDI:003000;setenv bootp_arch 0xb;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci; bootcmd_mmc0=setenv devnum 0; run mmc_boot bootcmd_mmc1=setenv devnum 1; run mmc_boot bootcmd_nfs=run get_images; run set_bootargs; booti $kernel_addr_r $ramdisk_addr_r $fdt_addr_r bootcmd_pxe=run boot_net_usb_start; run boot_net_pci_enum; dhcp; if pxe get; then pxe boot; fi bootcmd_scsi0=setenv devnum 0; run scsi_boot bootcmd_usb0=setenv devnum 0; run usb_boot bootdelay=2 console=console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 cpu=armv8 distro_bootcmd=setenv scsi_need_init; for target in ${boot_targets}; do run bootcmd_${target}; done efi_dtb_prefixes=/ /dtb/ /dtb/current/ eth1addr=F0:AD:4E:... eth2addr=F0:AD:4E:... eth3addr=F0:AD:4E:... ethact=neta@30000 ethaddr=F0:AD:4E:... ethprime=eth0 extra_params=pci=pcie_bus_safe fdt_addr=0x6000000 fdt_addr_r=0x6f00000 fdt_high=0xffffffffffffffff fdt_name=boot/dtb/marvell/armada-3720-espressobin.dtb fdtcontroladdr=3f7142d8 fileaddr=1100000 filesize=4606e4 gatewayip=10.4.50.254 get_images=tftpboot $kernel_addr_r $image_name; tftpboot $fdt_addr_r $fdt_name; run get_ramdisk get_ramdisk=if test "${ramdisk_name}" != "-"; then tftpboot $ramdisk_addr_r $ramdisk_name; else setenv ramdisk_addr_r -;fi hostname=marvell image_name=boot/Image initrd_addr=0x1100000 initrd_image=boot/uInitrd initrd_size=0x2000000 ipaddr=0.0.0.0 kernel_addr=0x7000000 kernel_addr_r=0x7000000 load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile} loadaddr=0x8000000 mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi netdev=eth0 netmask=255.255.255.0 pxefile_addr_r=0x6e00000 ramdisk_addr_r=0xa000000 ramdisk_name=- root=root=/dev/nfs rw rootdev=/dev/mmcblk1p1 rootfstype=ext4 rootpath=/srv/nfs scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi; scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootaa64.efi; then echo Found EFI removable media binary efi/boot/bootaa64.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done scriptaddr=0x6d00000 scsi_boot=run scsi_init; if scsi dev ${devnum}; then setenv devtype scsi; run scan_dev_for_boot_part; fi scsi_init=if ${scsi_need_init}; then setenv scsi_need_init false; scsi scan; fi serverip=0.0.0.0 set_bootargs=setenv bootargs $console $root ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:none nfsroot=$serverip:$rootpath $extra_params $cpuidle soc=mvebu stderr=serial@12000 stdin=serial@12000 stdout=serial@12000 usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u vendor=Marvell verbosity=2 Environment size: 5575/65532 bytes
ebin-dev Posted September 7, 2018 Posted September 7, 2018 8 hours ago, jrtaylor said: mmc0 is current device Did you reset your environment settings ? Please use the new ones: setenv default -a setenv verbosity "2" setenv boot_interface mmc setenv image_name boot/Image setenv initrd_image "boot/uInitrd" setenv fdt_name boot/dtb/marvell/armada-3720-espressobin.dtb setenv fdt_high "0xffffffffffffffff" setenv rootdev "/dev/mmcblk1p1" setenv rootfstype "ext4" setenv initrd_addr "0x1100000" setenv usbstoragequirks "0x2537:0x1066:u,0x2537:0x1068:u" setenv fdt_addr "0x6000000" setenv kernel_addr "0x7000000" setenv loadaddr "0x8000000" setenv initrd_size "0x2000000" setenv bootcmd 'mmc dev 0; ext4load mmc 0:1 $kernel_addr $image_name;ext4load mmc 0:1 $initrd_addr $initrd_image; ext4load mmc 0:1 $fdt_addr $fdt_name; setenv bootargs $console root=$rootdev rw rootwait; booti $kernel_addr $initrd_addr $fdt_addr' setenv ethaddr F0:AD:4E:..... setenv eth1addr F0:AD:4E:..... setenv eth2addr F0:AD:4E:..... setenv eth3addr F0:AD:4E:..... env save
ebin-dev Posted September 7, 2018 Posted September 7, 2018 9 hours ago, skandalfo said: Yay! I can confirm at least the new 18.09 flash-image-2g-2cs-1000_800_boot_sd_and_usb.bin works in my board. Thanks.
ebin-dev Posted September 7, 2018 Posted September 7, 2018 The new 18.09 bootloader flash images are now available through the EspressoBin downoad page. Please remember that it is mandatory to reset the environment settings once the 18.09 image is loaded the first time (Marvell>> env default -a). Then the updated environment settings as shown on the EspressoBin download page should be used.
Igor Posted September 7, 2018 Posted September 7, 2018 1 hour ago, ebin-dev said: The new 18.09 bootloader flash images are now available through the EspressoBin downoad page. Please remember that it is mandatory to reset the environment settings once the 18.09 image is loaded the first time (Marvell>> env default -a). Then the updated environment settings as shown on the EspressoBin download page should be used. Images have also been rebuilt, kernel 4.18.6
jrtaylor Posted September 7, 2018 Posted September 7, 2018 8 hours ago, ebin-dev said: Did you reset your environment settings ? Please use the new ones: setenv default -a setenv verbosity "2" setenv boot_interface mmc setenv image_name boot/Image setenv initrd_image "boot/uInitrd" setenv fdt_name boot/dtb/marvell/armada-3720-espressobin.dtb setenv fdt_high "0xffffffffffffffff" setenv rootdev "/dev/mmcblk1p1" setenv rootfstype "ext4" setenv initrd_addr "0x1100000" setenv usbstoragequirks "0x2537:0x1066:u,0x2537:0x1068:u" setenv fdt_addr "0x6000000" setenv kernel_addr "0x7000000" setenv loadaddr "0x8000000" setenv initrd_size "0x2000000" setenv bootcmd 'mmc dev 0; ext4load mmc 0:1 $kernel_addr $image_name;ext4load mmc 0:1 $initrd_addr $initrd_image; ext4load mmc 0:1 $fdt_addr $fdt_name; setenv bootargs $console root=$rootdev rw rootwait; booti $kernel_addr $initrd_addr $fdt_addr' setenv ethaddr F0:AD:4E:..... setenv eth1addr F0:AD:4E:..... setenv eth2addr F0:AD:4E:..... setenv eth3addr F0:AD:4E:..... env save I did a reset and I used those values. Will try again.
ebin-dev Posted September 7, 2018 Posted September 7, 2018 5 minutes ago, jrtaylor said: I did a reset and I used those values. Will try again. May be you did a reset while the 17.10 image was still loaded. Anyway - you can now also use the adapted environment settings on the EspressoBin download page (just changed by Igor). Boot priority with the load_script is: 1. USB, 2. SATA, 3. SD card, 4. eMMC
jrtaylor Posted September 7, 2018 Posted September 7, 2018 5 minutes ago, jrtaylor said: I did a reset and I used those values. Will try again. The new values you posted worked and it booted on Armbian_5.59_Espressobin_Debian_stretch_next_4.18.5.img.
jrtaylor Posted September 7, 2018 Posted September 7, 2018 1 minute ago, ebin-dev said: May be you did a reset while the 17.10 image was still loaded. Anyway - you can now also use the adapted environment settings on the EspressoBin download page (just changed by Igor). Boot priority with the load_script is: 1. USB, 2. SATA, 3. SD card, 4. eMMC Nope I loaded the new image. Then did a reset and then env default -a.
skandalfo Posted September 7, 2018 Posted September 7, 2018 Uhm... it looks like the Linux kernel doesn't support c2, 25, 36 for mx25u3235f either: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/mtd/spi-nor/spi-nor.c#n1088 and because of that /proc/mtd shows empty after boot...
martinayotte Posted September 8, 2018 Posted September 8, 2018 2 hours ago, skandalfo said: because of that /proc/mtd shows empty after boot Beware that even if a specific flash chip is supported, DT requires to have partition table in flash node definition ...
skandalfo Posted September 11, 2018 Posted September 11, 2018 On 9/8/2018 at 3:38 AM, martinayotte said: Beware that even if a specific flash chip is supported, DT requires to have partition table in flash node definition ... Realized that. I managed to build a patched kernel/DT combination including: Patched spi-nor.c to recognize the new Macronix chip. Patched DT to set the SPI flash partitions to the locations I found 18.09 uboot is using (environment is in the final 64kB of the 4MB chip), and set state to okay. Added support for GPIO LEDs to the kernel config. Added a GPIO LED entry to DT so that the onboard red LED is accessible through sysfs. Now the LED, /proc/mtd and fw_printenv are working as expected. I only get a complaint at boot time when the SPI flash is probed that a Macronix chip has been found rather than a Winbond one. Maybe adding more "compatible" entries there will be enough to fix that. If anyone's interested in these changes, let me know.
skandalfo Posted September 12, 2018 Posted September 12, 2018 Here are my patches (which also depend on CONFIG_LEDS_GPIO=y being set in the kernel config). I finally set the compatible string for the SPI flash to a generic type to allow the chip type to be probed. espressobin_gpio_led_and_spi_flash_fixes.patch
FoodGenius Posted September 20, 2018 Author Posted September 20, 2018 this is for everyone, who "bricked" a board by flashing old or testing bootloader, that can't reflash from uboot, because macronix SPI is not detected or uboot won't answer at all. I revived the board this way: * use the old UART recovery images from globalscale (even if they don't detect macronix SPI NOR Flash) so download them from http://espressobin.net/wp-content/uploads/2018/07/ebin-17.10-uart.zip unfortunately globalscale still won't provide newer image. following these instructions http://wiki.espressobin.net/tiki-index.php?page=Bootloader+recovery+via+UART in short... * jumper your board to "UART-Bootmode" * use a terminal and connect to espressobin by usb * you now see the recovery prompt ">" instead of "Marvell>>" so type the command wtp followed by enter. board is now in a mode to receive the temporary bootloader.. so close the terminal. * use the marvell tool to flash the UART recovery images to RAM ./WtpDownload_linux -P UART -C 0 -R 115200 -B TIM_ATF.bin -I wtmi_h.bin -I boot-image_h.bin -E * do not reset the board now. just start the terminal again to connect to espressobin by usb * you should see the prompt "Marvell>>" now and can use the command "version" to show uboot version. * now we are able to boot a linux kernel I build a small kernel, with patches from skandalfo. so this kernel can access macronix SPI and you can reflash the SPI from userspace, instead from uboot. this is my kernel build process mkdir espresso_rescue_kernel_build cd espresso_rescue_kernel_build # get kernelsource wget https://cdn.kernel.org/pub/linux/kernel/v4.x/linux-4.18.7.tar.xz tar xvf linux-4.18.7.tar.xz # patch kernel wget https://download.foodgenius.de/data/patches/espressobin/201809/armada-3720-espressobin.dts.patch wget https://download.foodgenius.de/data/patches/espressobin/201809/spi-nor.c.patch patch linux-4.18.7/arch/arm64/boot/dts/marvell/armada-3720-espressobin.dts < armada-3720-espressobin.dts.patch patch linux-4.18.7/drivers/mtd/spi-nor/spi-nor.c b/drivers/mtd/spi-nor/spi-nor.c < spi-nor.c.patch # you can you espressobin kernel default config wget https://raw.githubusercontent.com/MarvellEmbeddedProcessors/linux-marvell/linux-4.14.22-armada-18.09/arch/arm64/configs/mvebu_v8_lsp_defconfig cp mvebu_v8_lsp_defconfig linux-4.18.7/arch/arm64/configs/ # .... but we need a rootfs, and i build it as initramfs in the kernel # download my modified config with initramfs (path ../initramfs in config and user_id mapping = 1000 to 0. change this!) wget https://download.foodgenius.de/data/patches/espressobin/201809/kernel_config # since user_id mapping for initramfs is 1000 to 0, you have to change this to your current userid (user for build process) in the kernel_config file. so do this... sed -i "s/CONFIG_INITRAMFS_ROOT_UID=1000/CONFIG_INITRAMFS_ROOT_UID=`id -u`/g" kernel_config sed -i "s/CONFIG_INITRAMFS_ROOT_UID=1000/CONFIG_INITRAMFS_ROOT_GID=`id -g`/g" kernel_config # use the kernel_config for your kernel def config cp kernel_config linux-4.18.7/arch/arm64/configs/mvebu_v8_lsp_defconfig # you can download my initramfs, but also can build your own (with buildroot) wget https://download.foodgenius.de/data/patches/espressobin/201809/initramfs.tar.gz tar xvfz initramfs.tar.gz # build_kernel now cd linux-4.18.7/ export ARCH=arm64 export CROSS_COMPILE=aarch64-linux-gnu- make mvebu_v8_lsp_defconfig make -j4 # you have to run a tftp-hpa on your machine for tftp boot # you will find more information in https://help.ubuntu.com/community/TFTP # so i am assuming you have tftpd-hpa up and running. base path /srv/tftp/ mkdir /srv/tftp/espresso_recovery # copy new kernel and dts to tftp path on my machine cp arch/arm64/boot/dts/marvell/armada-3720-espressobin.dtb /srv/tftp/espresso_recovery/ cp arch/arm64/boot/Image /srv/tftp/espresso_recovery/ (+++ additionally ++++ # if you want to download and extract buildroot source wget https://buildroot.org/downloads/buildroot-2018.08.tar.gz tar xvfz buildroot-2018.08.tar.gz # buildroot default config https://raw.githubusercontent.com/MarvellEmbeddedProcessors/buildroot-marvell/buildroot-2015.11-16.08/configs/mvebu_armv8_le_defconfig cp mvebu_armv8_le_defconfig buildroot-2018.08/configs/ # build buildroot cd buildroot-2018.08 make mvebu_armv8_le_defconfig make menuconfig #you have to rebuild your kernel then) but i didn't use full buildroot. just uses busybox and a handmade minimal init script in the initramfs of the kernel #!/bin/busybox sh /bin/busybox --install /bin/ mount -t proc none /proc mount -t sysfs none /sys mknod /dev/sda b 8 0 mknod /dev/sda1 b 8 1 mknod /dev/mtd0 c 90 0 /bin/busybox/sh then i boot my new kernel via tftp and this environment. my tftpd machine had 192.168.5.5 ... you have to change this in your setting setenv default -a setenv baudrate '115200' setenv bootdelay 2 setenv ethact 'neta@30000' setenv ethaddr '00:51:82:11:22:00' setenv ethprime 'eth0' setenv fdt_addr '0x4f00000' setenv fdt_high '0xffffffffffffffff' setenv get_images 'tftpboot $kernel_addr $image_name; tftpboot $fdt_addr $fdt_name; run get_ramfs' setenv get_ramfs 'if test "${ramfs_name}" != "-"; then setenv ramfs_addr 0x8000000; tftpboot $ramfs_addr $ramfs_name; else setenv ramfs_addr -;fi' setenv set_bootargs 'setenv bootargs $console $root ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:none' setenv bootcmd 'run get_images; run set_bootargs; booti $kernel_addr $ramfs_addr $fdt_addr' setenv hostname 'marvell' setenv initrd_addr '0xa00000' setenv initrd_size '0x2000000' setenv kernel_addr '0x8000000' setenv fdt_addr '0x7000000' setenv loadaddr '0x8000000' setenv ramfs_addr '0x9000000' setenv ramfs_name - setenv netdev 'eth0' setenv netmask '255.255.255.0' setenv stderr 'serial@12000' setenv stdin 'serial@12000' setenv stdout 'serial@12000' setenv serverip '192.168.5.5' setenv gatewayip '192.168.5.250' setenv ipaddr '192.168.5.10' setenv image_name 'espresso_recovery/Image' setenv fdt_name 'espresso_recovery/armada-3720-espressobin.dtb' setenv root '' setenv console 'console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000' dhcp boot so now you should boot into the kernel download https://download.foodgenius.de/data/patches/espressobin/201809/mtd0.img.gz this file is a compressed dump of the uboot, supporting macronix spi. unpack it and copy the uncompressed(!) img to a usb stick (assuming partitioned usb stick, partition 1) connect the usb-stick with to your espresso board. run the following commands in the rescue kernel linux, to flash SPI from userspace # connect usb stick mkdir -p /mnt/a mount /dev/sda1 /mnt/a cd /mnt/a # dd image from usb stick to nor flash dd if=mtd0.img of=/dev/mtd0 cd / umount /mnt/a now you can reset the board. the current uboot should support macronix spi. test in "Marvell>> " prompt with version sspi so you can use https://www.armbian.com/espressobin/ bubt flash-image-MEM-RAM_CHIPS-CPU_DDR_boot_sd_and_usb.bin spi usb or any other image and environment
ebin-dev Posted September 20, 2018 Posted September 20, 2018 On 9/20/2018 at 11:13 AM, FoodGenius said: use the old UART recovery images from globalscale New UART images are created with every build (uart-images.tgz). Edit: uart-images-18.09 and sata-images-18.09 with Macronix support are available. EspressoBin should be recovered after './WtpDownload_linux -P UART -C 0 -R 115200 -B TIM_ATF.bin -I wtmi_h.bin -I boot-image_h.bin -E' as described above followed by a reset. Edit: Links adapted to subfolder rescue
FoodGenius Posted September 24, 2018 Author Posted September 24, 2018 fine. thanks. would be nice to publish these images in https://dl.armbian.com/espressobin/u-boot/ in a subfolder "rescue".
