Is there a way to fix emmc booting problem from uboot itself, i've updated armbian and now orangepi pc+ doesn't boot, i've connected uart and i see that it reads /boot/boot.scr from mmc 1, but then tries to load stuff from mmc 0, so i guess my boot.scr got overwritten by default one .. or something.
boot shows this
=> boot
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
3565 bytes read in 6 ms (580.1 KiB/s)
U-boot loaded from eMMC or secondary SD
Boot script loaded from mmc
MMC: no card present
** Bad device mmc 0 **
and then BOOTP load
If it's possible to fix from uart console, it would be nice, but i guess i'll have to go search for some sd card or usb key to boot :(
You must have some very old installation. Have you changed anything by hand?
Try this - make and boot from SD card, mount eMMC and copy /boot/boot.* to your eMMC /boot section.
Yep i have very old distribution (Armbian_5.30_Orangepipcplus_Debian_jessie_default_3.4.113), so i've just installed new one on usb and i'm booting from there (needed to print with OctoPrint asap, so i just left it as is),  will play with it later, Thanks for reply.
Same thing happened here.
I have my boot on eMMC and my root is on an external USB HDD.
It loads u-boot from eMMC and then I get a lot of "** Bad device mmc 0 **". The only difference from the gerotmf´s logs is that my external USB is being listed as a valid storage device.
Even listing my external USB, the kernel is not being loaded (it tries to load it from the ethernet and BOOTP).
Finally it shows me the console, but I could not get any command to continue the boot process on the external USB.
My system was up to date, as it is automatically updated. It was a 2017 installation (maybe 5.30, and the last update before 5.60 was 5.36).
Is there anything I can try, to get my server back?
Best regards.
Edited by Guidalpi
Changed SATA to USB
Did you try the same as it was advised to @gerotmf ?
Unfortunately it didn´t solved for me. I could boot from the SD card, but even copying the boot* files to eMMC (/boot) I´m not able to boot from eMMC.
I ´m attaching the image from eMMC boot process.
Exactly this same issue I am facing since morning , I am on legacy desktop version (5.2x ~ 5.30) + OP+2E ... everything was ok till last night ..I just ran update/upgrade  which resulted in a big few MBs of updates.... then carried on my work as usual and later shutdown the board .. but today morning when i fire up the board I start getting the same types of messages as you have posted above ( your screen shot ) .... OS is on emmc ... remedy as suggested by Igor resulted no relief .... seems something got broken  in last/recent updates...
Hello @Igor, @ATK
I´ve managed to fix the boot process.
I had to to copy all /boot content from eMMC to the external HDD /boot directory. It was empty before this procedure, as the /boot mount point was always coming from eMMC. (my first installation was done on a SD and then I performed a nand-sata-install, selecting boot from eMMC and root from external USB).
I really don´t know why, but it is working just fine!
Regards and hope it helps.
I have an opi + 2e, I have armbian (debian) and yesterday with an apt-get update, apt-get upgrade the system and today when I boot up I get the attached image and it does not start, any solution? I'm very noob thnks, internet and dhcp work fine1000169288_2018-09-2509_29_37.thumb.jpg.ccd2aa142670bdc8c66f18046dfaf2a9.jpg
  • Igor pinned this topic
I couldn't recreate. My board boots fine after the upgrade:
U-Boot SPL 2018.05-armbian (Sep 19 2018 - 12:57:55 +0200)
DRAM: 1024 MiB
Trying to boot from MMC2
U-Boot 2018.05-armbian (Sep 19 2018 - 12:57:55 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi PC Plus
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
Loading Environment from EXT4... MMC: no card present
Failed (-5)
In:    serial
Out:   vidconsole
Err:   vidconsole
Net:   phy interface0
eth0: ethernet@1c30000
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
USB4:   USB EHCI 1.00
USB5:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
scanning bus 4 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
Scanning mmc 1:1...
3708 bytes read in 6 ms (603.5 KiB/s)
203 bytes read in 6 ms (32.2 KiB/s)
5228996 bytes read in 258 ms (19.3 MiB/s)
4654496 bytes read in 235 ms (18.9 MiB/s)
Found legacy kernel configuration
36568 bytes read in 5 ms (7 MiB/s)
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Data Size:    5228932 Bytes = 5 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
Starting kernel ...
[sun8i_fixup]: From boot, get meminfo:
        Start:  0x40000000
ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1
ion_reserve_select: ion chipid  [0x2c00081!
ion_reserve_common: ion reserve: [0x50000000, 0x60000000]!
Loading, please wait...
starting version 229
done.
Begin: Will now check root file system ... fsck from util-linux 2.27.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: clean, 108980/472352 files, 484602/1888624 blocks
done.
done.
Welcome to Ubuntu 16.04.5 LTS!
Most likely /boot/boot.scr is corrupted. Also, proper rootdev=UUID=xxxxxxxxxxxxxxxxxxxxxx for eMMC must exists in /boot/armbianEnv.txt
There is really no any extra magic - u-boot , boot script which loads kernel .. and we are only not getting to the kernel loading commands which are in the script.
I used apt-get upgrade yesterday and I have the same problem, I only use the emmc and I can access the emmc files from a system in the SD, could someone solve it? I tried to change the boot.scr by one of the sd that works but Nothing
in what file is the boot disk from UBoot? I think that in this update does not find emmc in the boot since I see what happens to those who have emmc
Please boot from SD card, mount eMMC and provide its content of:
boot/armbienEnv.txt
boot/boot.cmd
boot/boot.scr
and type:
blkid
armbianmonitor -u
boot/armbienEnv.txt
boot/boot.cmd
boot/boot.scr
and type:
blkid
armbianmonitor -u
armbianmonitor -u -> http://ix.io/1nxY
blkid is in attached files, marked uuid is the emmc
file /boot/armbienEnv.txt not found
file /boot/boot.cmd:
gpio set PL10
gpio set PG11
setenv machid 1029
setenv bootm_boot_mode sec
if ext4load mmc 0 0x00000000 /boot/.verbose
then
setenv verbosity 7
else
setenv verbosity 1
fi
# nonstandard monitor settings for A10, A20 and A31 based boards
# screen is initialized before this script -> saving to u-boot environment is mandatory
#setenv video-mode sunxi:1024x768-24@60,monitor=dvi,hpd=0,edid=0,overscan_x=1,overscan_y=2
#saveenv
setenv bootargs "console=ttyS0,115200 console=tty1 root=UUID=3d0c53d0-0261-461b-8145-852fd0c46920 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 panic=10 consoleblank=0 enforcing=0 loglevel=${verbosity}"
# Boot loader script to boot with different boot methods for old and new kernel
if ext4load mmc 0 0x00000000 /boot/.next || fatload mmc 0 0x00000000 .next || ext4load mmc 0 0x00000000 .next
then
# sunxi mainline kernel
ext4load mmc 0 ${fdt_addr_r} /boot/dtb/${fdtfile} || fatload mmc 0 ${fdt_addr_r} /dtb/${fdtfile} || ext4load mmc 0 ${fdt_addr_r} /dtb/${fdtfile}
ext4load mmc 0 ${ramdisk_addr_r} /boot/uInitrd || fatload mmc 0 ${ramdisk_addr_r} uInitrd || ext4load mmc 0 ${ramdisk_addr_r} uInitrd || setenv ramdisk_addr_r "-"
ext4load mmc 0 ${kernel_addr_r} /boot/zImage || fatload mmc 0 ${kernel_addr_r} zImage || ext4load mmc 0 ${kernel_addr_r} zImage
bootz ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r}
else
# sunxi android kernel
ext4load mmc 0 ${fdt_addr_r} /boot/script.bin || fatload mmc 0 ${fdt_addr_r} script.bin || ext4load mmc 0 ${fdt_addr_r} script.bin
fi
# Recompile with:
and file /boot/boot.scr:
gpio set PG11
setenv machid 1029
then
setenv verbosity 7
else
setenv verbosity 1
fi
#saveenv
then
else
fi
# Recompile with:
any idea? thanks
boot/armbienEnv.txt
boot/boot.cmd
boot/boot.scr
and type:
blkid
armbianmonitor -u
Hope it helps finding what´s going on.
#blkid
/dev/mmcblk0p1: UUID="3f1bbc6f-5029-43f9-a7d9-1f5bd5b99bf2" TYPE="ext4" PARTUUID="12672447-01"
/dev/sdb1: UUID="0644804d-3387-40c4-a733-2f168602fb51" TYPE="ext4" PARTUUID="cf59e41c-01"
armbianEnv.txt
armbianmonitor.txt
boot.cmd
boot.scr
The problem is exactly as predicted. You need to update a boot script as described a few posts back:
Since this only happens when booting from eMMC, fixing is super easy. Boot from SD card and copy /boot/boot.* to eMMC's /boot/ directory. You only need to mount eMMC before.
Hello @Igor,
I´ve tried to copy /boot/boot.* to eMMC, but still no sucess on booting. (as @ATK )
As you explained that there is no magic (" u-boot , boot script which loads kernel") and the boot script seems fine to me (there are no differences between the script and scr file on eMMC, SD and HDD) the only part that could be wrong was the u-boot.
So, I decided to downgrade only the u-boot bin. I´ve downloaded the file linux-u-boot-orangepiplus-default_5.39_armhf.deb and extracted its content. Then I ran postinst script setting the device to install u-boot to /dev/mmcblk1 (eMMC, as I had booted from SD card).
Rebooting my OPi I noticed that the version of u-boot was really downgraded and the boot process was succesfully executed.
My guess is that something between 5.39 and 5.60 has broken the support on my hardware.
I´ve made some further investigations and noticed that it seems that in 5.60, the boot script, when running from eMMC, is not being able to read the /boot/armbianEnv.txt as I printed the env variables (env print) and the rootdev was still pointing to the wrong place.
I don´t know if it is possible, but I can try to trace the exactly version that breaks my boot support between 5.39 and 5.60. I just need to know where I can access these versions.
Best Regards.
This is a bit strange but OK.
You can find old u-boot packages in our repository.
http://apt.armbian.com/pool/main/l
default=3.4.y
next=4.14.y
dev=4.18.y ->
Hello !
Same problems on my OrangePiPlus2 .. everything worked fine, untill yesterday.. I ran apt-get update && apt-get upgrade, and when I rebooted, it won't turn on.. (nothing happens.. the screen remains turned off)
I can boot my OP+2 with a SD card without problems, and once it's running, I can mount the emmc
I have an old Armbian running on my OP+2 -> Armbian_5.14_Orangepiplus_Debian_jessie_3.4.112_desktop
What have I done?
1) I made a backup of the /boot directory of my emmc before changing anything
2) I boot with an SD with Armbian_5.59_Orangepiplus_Debian_stretch_next_4.14.65 (the last version published I see)
2.1) I've copied all the /boot/boot.*  files from SD to EMMC
2.2) Doesn't work -> but something changed.. my monitor turns on, in graphical mode, with a kind of garnet-color-background (but nothing happens)
3) I boot with an SD with Armbian_5.14_Orangepiplus_Debian_jessie_3.4.112_desktop (the one I've installed on my OP+2)
3.1) I've copied all the /boot/boot.*  files from SD to EMMC
3.2) Doesn't work
At this moment I'm completely lost :(  All my hopes are on this thread . Thank you so much for your support !
Jordi (Barcelona)
default=3.4.y
next=4.14.y
dev=4.18.y ->
Hello Igor,
Finally I got your point.
I decided to burn my SD again and assured that the right image was being used.
And as you said, copying the boot.* from the SD card to the eMMC solved the problem.
I have just one last doubt: why the boot.cmd and boot.scr files are not being included/upgraded by any deb package?
Best Regards.
On 9/28/2018 at 6:24 PM, Jordi said:
Hello !
What have I done?
3.2) Doesn't work
Jordi (Barcelona)
Try the "Other download options" at the end of the page (https://www.armbian.com/orange-pi-plus-2/). It has the legacy kernel (3.4).
The torrent link is https://dl.armbian.com/orangepiplus/Ubuntu_xenial_default_desktop.7z.torrent
That was the one that finally solved the problem for me.
Good luck!
Good luck!
Thanks a lot Guidalpi !  Unfortunately it did'nt work in my case. I think I've tested every possible combinations of boot files on my system.. and for the moment I've not found the right one.. Fortunately, a friend of mine (a master !) is helping me with this problem. If we (he) find the solution I'll inform here.
Is easily reproducible:
- I have an OrangePiPlus2
- I use the original installation I installed for my system: Armbian_5.14_Orangepiplus_Debian_jessie_3.4.112_desktop   (I have the image)
- And then:
   1) I burn the image it into a µsd card with Etcher
   2) I boot from this µsd on my OPiPlus2
   3) I run nand-sata-install to move the installation to the emmc
   4) Shutdown, and remove the µsd card
   5) Boot from the emmc installation, everything works ok (with kernel 3.4.112 - i see it on /boot)
   6) I run apt-get update && apt-get upgrade   -> I see the /boot folder and I see kernel has updated to 3.4.113
   7) I reboot, and it doesn't work.. the screen remains black and nothing happens
Does anybody know if this problem will be solved on a next upgrade ?  If it's solved, I can repeat this process, and once I get a system running (based on 5.14 and updated) I'll recover my system
Thank you !
On 9/28/2018 at 11:24 PM, Jordi said:
Hello !
What have I done?
3.2) Doesn't work
Jordi (Barcelona)
- Edita el archivo armbianEnv.txt y cambia el UUID de tu SD por el de tu eMMC sino lo modificas es normal que no arranque solo con cambiar la carpeta boot
-Edit the file armbianEnv.txt and change the UUID of your SD to that of your eMMC
Hello @Jordi
@hannibal1986 is right! I didn´t need this step as my root resides in an external HDD (same UUID when booting from SD and eMMC)
Regards.
@hannibal1986, @Guidalpi  Thanks a lot !
Unfortunately, this file does not exist on my installation !  (brand new installation, but from an older distribution !)
My collegue has a plan.. he told me he think he'll be able to solve it, but untill monday we won't meet.. so we'll have to wait ;)   I'll keep you updated
The armbianEnv.txt file exist since several years, so which distribution you are talking about ?
Try unplugging your hdmi cable and booting.  Wait a bit to make sure it's fully booted then plug in the hdmi cable.
Hello! I'm using the  Armbian_5.14_Orangepiplus_Debian_jessie_3.4.112_desktop  distribution   ( we look for the file on the /boot directory,  but it was not there :(  )
I'll wait until monday.. my collegue has a plan, I trust my collegue ;)
Thanks a lot
Wow, have not tried. I'll try next monday. Thanks !!
