On 6/29/2019 at 5:12 AM, amirul said:
Wlan works on Armbian_5.86_Rk3399-tv_Ubuntu_bionic_default_4.4.154_desktop_20190517. What has changed between the versions?
dtbs are identical
lots of lines in dmesg [WLAN_RFKILL]: wifi turn on power. -1
replaced /lib/frmware/brcm in 5.88 from that in 5.86 -> wireless networks detected but can't connect yet
connected to wlan with gnome-keyring-daemon running :-)
fixed Armbian_5.89_Rk3399-tv_Ubuntu_bionic_default_4.4.154_desktop_20190627 as well
After latest update of armbian-firmware, wlan works out of the box
Magicsee-n6-max Armbian_5.89_Rk3399-tv_Ubuntu_bionic_default_4.4.154_desktop_20190627
Bluetooth paired with my phone, played youtube on the phone -> n6 locked up requiring reboot. Now can't detect phone anymore. Think I'll turn off bluetooth, don't need it.
/var/log/syslog and dmesg has a whole bunch of these messages:
wl_run_escan: LEGACY_SCAN sync ID: nnn, bssidx: 0
where nnn incerments by one
Is this normal when wi-fi is enabled?
I tested latest dev image (5.91 4.4.167) changing to edgev dtb and it seems to work well. Ethernet works but not wifi (as expected). The usb3 port works, but not the usb2 port (up to the usb-c charging port).
Here the output of armbianmonitor -u: http://ix.io/1Ofx
For WIFi on the core 4 you need to install firmware.
What is the problem with USB 2 ?
I tested again and was able to use my keyboard and mouse with this port (the keyboard has an internal hub and the mouse is connected to it), but I have to first connect my keyboard and then connect my mouse otherwise it won't work (no light or blinking light on the mouse). I suppose that there is not enough current via this port for the initialization of all these devices at the same time (keyboard, usb hub and mouse) since I don't observe this behavior on the usb3 port.
I installed the full firmware package, but wifi is not activated. After looking at dmesg, I saw that the firmware files were not present. So I downloaded from a github repo fw_bcm4359c0_ag.bin, nvram_ap6398s.txt and BCM4359C0.hcd and copy them to /lib/firmware/brcm/. I am now able to use wlan0.
Here is the current dmesg output:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.167-rk3399-tv (root@vbox) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02) ) #16 SMP Tue Jul 9 15:41:42 MSK 2019
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB
[    0.000000] On node 0 totalpages: 1007616
[    0.000000]   DMA zone: 15864 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 1007616 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ed5000 s46248 r8192 d31576 u86016
[    0.000000] pcpu-alloc: s46248 r8192 d31576 u86016 alloc=21*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 991752
[    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=uart8250,mmio32,0xff1a0000 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0xef600000-0xf3600000] (64MB) mapped at [ffffffc0ef600000-ffffffc0f35fffff]
[    0.000000] Memory: 3865324K/4030464K available (11070K kernel code, 1574K rwdata, 3984K rodata, 1024K init, 1981K bss, 165140K reserved, 0K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
                   vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
                     .init : 0xffffff8008f40000 - 0xffffff8009040000   (  1024 KB)
                     .text : 0xffffff8008080000 - 0xffffff8008b50000   ( 11072 KB)
                   .rodata : 0xffffff8008b50000 - 0xffffff8008f40000   (  4032 KB)
                     .data : 0xffffff8009040000 - 0xffffff80091c9808   (  1575 KB)
                   vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
                             0xffffffbdc0008000 - 0xffffffbdc3e00000   (    61 MB actual)
                   fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 KB)
                   PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
                   memory  : 0xffffffc000200000 - 0xffffffc0f8000000   (  3966 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]     Build-time adjustment of leaf fanout to 64.
[    0.000000]     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[    0.000000] ITS: allocated 65536 Devices @a200000 (psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x000000000a280000
[    0.000000] ITS: Allocated 1792 chunks for LPIs
[    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] CPU0: using LPI pending table @0x000000000a290000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] rockchip_mmc_get_phase: invalid clk rate
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.002180] Console: colour dummy device 80x25
[    0.002610] console [tty0] enabled
[    0.002945] bootconsole [uart0] disabled
[    0.003347] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.003375] pid_max: default: 32768 minimum: 301
[    0.003540] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.003562] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.004337] Initializing cgroup subsys io
[    0.004364] Initializing cgroup subsys memory
[    0.004404] Initializing cgroup subsys devices
[    0.004424] Initializing cgroup subsys freezer
[    0.004444] Initializing cgroup subsys net_cls
[    0.004463] Initializing cgroup subsys perf_event
[    0.004482] Initializing cgroup subsys net_prio
[    0.004505] Initializing cgroup subsys pids
[    0.004554] ftrace: allocating 40645 entries in 159 pages
[    0.113087] sched-energy: Sched-energy-costs installed from DT
[    0.113115] CPU0: update cpu_capacity 401
[    0.113176] ASID allocator initialised with 32768 entries
[    0.116541] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.117051] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.118421] Detected VIPT I-cache on CPU1
[    0.118455] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.118485] CPU1: using LPI pending table @0x00000000eeca0000
[    0.118532] CPU1: update cpu_capacity 401
[    0.118536] CPU1: Booted secondary processor [410fd034]
[    0.119105] Detected VIPT I-cache on CPU2
[    0.119125] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.119153] CPU2: using LPI pending table @0x00000000eecd0000
[    0.119180] CPU2: update cpu_capacity 401
[    0.119184] CPU2: Booted secondary processor [410fd034]
[    0.119722] Detected VIPT I-cache on CPU3
[    0.119742] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.119769] CPU3: using LPI pending table @0x00000000eed20000
[    0.119796] CPU3: update cpu_capacity 401
[    0.119799] CPU3: Booted secondary processor [410fd034]
[    0.120402] Detected PIPT I-cache on CPU4
[    0.120428] CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.120467] CPU4: using LPI pending table @0x00000000eed60000
[    0.120505] CPU4: update cpu_capacity 1024
[    0.120508] CPU4: Booted secondary processor [410fd082]
[    0.121078] Detected PIPT I-cache on CPU5
[    0.121096] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.121133] CPU5: using LPI pending table @0x00000000eed90000
[    0.121158] CPU5: update cpu_capacity 1024
[    0.121162] CPU5: Booted secondary processor [410fd082]
[    0.121249] Brought up 6 CPUs
[    0.121911] SMP: Total of 6 processors activated.
[    0.121943] CPU features: detected feature: GIC system register CPU interface
[    0.121978] CPU features: detected feature: 32-bit EL0 Support
[    0.122013] CPU: All CPU(s) started at EL2
[    0.122083] alternatives: patching kernel code
[    0.123514] devtmpfs: initialized
[    0.140681] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.140738] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.141262] xor: measuring software checksum speed
[    0.180126]    8regs     :  2855.000 MB/sec
[    0.220187]    8regs_prefetch:  2561.000 MB/sec
[    0.260249]    32regs    :  3191.000 MB/sec
[    0.300309]    32regs_prefetch:  2845.000 MB/sec
[    0.300329] xor: using function: 32regs (3191.000 MB/sec)
[    0.300364] pinctrl core: initialized pinctrl subsystem
[    0.300607] regulator-dummy: no parameters
[    0.301159] NET: Registered protocol family 16
[    0.313412] cpuidle: using governor ladder
[    0.325433] cpuidle: using governor menu
[    0.325630] vdso: 2 pages (1 code @ ffffff8008b56000, 1 data @ ffffff8009044000)
[    0.325684] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.326728] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.340866] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.340944] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.341021] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.341095] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.341171] gpiochip_add_data: registered GPIOs 128 to 159 on device: gpio4
[    0.432650] raid6: int64x1  gen()   473 MB/s
[    0.500696] raid6: int64x1  xor()   424 MB/s
[    0.568768] raid6: int64x2  gen()   655 MB/s
[    0.636862] raid6: int64x2  xor()   609 MB/s
[    0.704995] raid6: int64x4  gen()   918 MB/s
[    0.773049] raid6: int64x4  xor()   669 MB/s
[    0.841159] raid6: int64x8  gen()   751 MB/s
[    0.909281] raid6: int64x8  xor()   635 MB/s
[    0.977372] raid6: neonx1   gen()   994 MB/s
[    1.045496] raid6: neonx1   xor()   681 MB/s
[    1.113611] raid6: neonx2   gen()  1324 MB/s
[    1.181687] raid6: neonx2   xor()   961 MB/s
[    1.249784] raid6: neonx4   gen()  1765 MB/s
[    1.317892] raid6: neonx4   xor()  1162 MB/s
[    1.385992] raid6: neonx8   gen()  1693 MB/s
[    1.454096] raid6: neonx8   xor()  1246 MB/s
[    1.454115] raid6: using algorithm neonx4 gen() 1765 MB/s
[    1.454134] raid6: .... xor() 1162 MB/s, rmw enabled
[    1.454152] raid6: using intx1 recovery algorithm
[    1.455131] of_get_named_gpiod_flags: parsed 'rockchip,power-ctrl' property of node '/rockchip-suspend[0]' - status (0)
[    1.455169] of_get_named_gpiod_flags: parsed 'rockchip,power-ctrl' property of node '/rockchip-suspend[1]' - status (0)
[    1.455434] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vccadc-ref[0]'
[    1.455457] vcc1v8_sys: 1800 mV
[    1.455633] reg-fixed-voltage vccadc-ref: vcc1v8_sys supplying 1800000uV
[    1.455695] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc3v3-sys[0]'
[    1.455711] vcc3v3_sys: 3300 mV
[    1.455869] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[    1.456036] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc5v0-host-regulator[0]' - status (0)
[    1.456081] vcc5v0_host: no parameters
[    1.456226] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[    1.456277] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc5v0-sys[0]'
[    1.456295] vcc5v0_sys: 5000 mV
[    1.456453] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[    1.456577] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-sd[0]' - status (0)
[    1.456618] vcc_sd: 3300 mV
[    1.456774] reg-fixed-voltage vcc-sd: vcc_sd supplying 3300000uV
[    1.456823] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    1.456842] vcc_phy: no parameters
[    1.456995] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV
[    1.457570] iommu: Adding device ff650000.vpu_service to group 0
[    1.457669] iommu: Adding device ff660000.rkvdec to group 1
[    1.457788] iommu: Adding device ff8f0000.vop to group 2
[    1.457890] iommu: Adding device ff900000.vop to group 3
[    1.458372] rk_iommu ff650800.iommu: can't get sclk
[    1.458638] rk_iommu ff660480.iommu: can't get sclk
[    1.458877] rk_iommu ff8f3f00.iommu: can't get sclk
[    1.459050] rk_iommu ff903f00.iommu: can't get sclk
[    1.459421] SCSI subsystem initialized
[    1.459597] libata version 3.00 loaded.
[    1.459771] usbcore: registered new interface driver usbfs
[    1.459828] usbcore: registered new interface driver hub
[    1.459926] usbcore: registered new device driver usb
[    1.460011] media: Linux media interface: v0.10
[    1.460061] Linux video capture interface: v2.00
[    1.460152] pps_core: LinuxPPS API ver. 1 registered
[    1.460172] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.460216] PTP clock support registered
[    1.461334] Advanced Linux Sound Architecture Driver Initialized.
[    1.461853] Bluetooth: Core ver 2.21
[    1.461891] NET: Registered protocol family 31
[    1.461910] Bluetooth: HCI device and connection manager initialized
[    1.461936] Bluetooth: HCI socket layer initialized
[    1.461959] Bluetooth: L2CAP socket layer initialized
[    1.461995] Bluetooth: SCO socket layer initialized
[    1.462202] db.txt is empty, you should update it...
[    1.462262] ------------[ cut here ]------------
[    1.462293] WARNING: at net/wireless/reg.c:523
[    1.462310] Modules linked in:
[    1.462351] CPU: 5 PID: 1 Comm: swapper/0 Not tainted 4.4.167-rk3399-tv #16
[    1.462371] Hardware name: Khadas Edge-V (DT)
[    1.462391] task: ffffffc0eec08000 task.stack: ffffffc0eec10000
[    1.462413] PC is at regulatory_init+0xc8/0x150
[    1.462433] LR is at regulatory_init+0xc8/0x150
[    1.462452] pc : [<ffffff8008f8bd24>] lr : [<ffffff8008f8bd24>] pstate: 60000045
[    1.462482] sp : ffffffc0eec13d10
[    1.462500] x29: ffffffc0eec13d10 x28: ffffff800900aae8
[    1.462524] x27: 0000000000000005 x26: ffffff8008f9e988
[    1.462547] x25: ffffff80091cd000 x24: ffffff8008f4047c
[    1.462571] x23: 0000000000000000 x22: ffffff80093b7e78
[    1.462593] x21: ffffff80093b7ee0 x20: ffffff800918b000
[    1.462616] x19: ffffff80093b7000 x18: 0000000000000005
[    1.462639] x17: 0000000000000000 x16: 0000000000000010
[    1.462662] x15: 0000000000000000 x14: 000000000000000a
[    1.462684] x13: ffffff80891d08d3 x12: 0000000000000030
[    1.462707] x11: 0000000000000006 x10: ffffff80091d08db
[    1.462730] x9 : 0000000005f5e0ff x8 : 2e2e2e7469206574
[    1.462753] x7 : 6164707520646c75 x6 : ffffff80091d090b
[    1.462776] x5 : 0000000000000000 x4 : 0000000000000000
[    1.462799] x3 : 00000040eef32000 x2 : 00000040eef32000
[    1.462822] x1 : 0000000000000005 x0 : 0000000000000028
[    1.462845]
               PC: 0xffffff8008f8bca4:
[    1.462875] bca4  540000e9 2a0003f3 2a1303e0 f94013f5 a94153f3 a8c87bfd d65f03c0 91012295
[    1.462929] bcc4  91002280 aa1503e2 b0fff921 91295021 97c5746e aa1503e2 9100a280 b0fff921
[    1.462981] bce4  9129c421 97c57469 aa1503e0 aa1503e2 b0fff921 912a5421 97c57464 b0002160
[    1.463033] bd04  b94cc000 35000140 90001014 3971d280 350000e0 b0fff920 912ac000 97c76478
[    1.463085] bd24  d4210000 52800020 3931d280 d0000f14 91108280 913a6275 f9402401 c89ffea1
[    1.463137] bd44  5286e721 f9402400 790042a1 91005000 97ec617c 2a0003f3 34000120 3100301f
[    1.463189] bd64  54000081 f94022a0 97d99d53 17ffffcf b0fff920 912b6400 97c76461 91108294
[    1.463241] bd84  f940ca93 aa1303e0 97ec6348 72001c1f 54000081 52800001 aa1303e0 97ec68ff
[    1.463294]
               LR: 0xffffff8008f8bca4:
[    1.463323] bca4  540000e9 2a0003f3 2a1303e0 f94013f5 a94153f3 a8c87bfd d65f03c0 91012295
[    1.463375] bcc4  91002280 aa1503e2 b0fff921 91295021 97c5746e aa1503e2 9100a280 b0fff921
[    1.463427] bce4  9129c421 97c57469 aa1503e0 aa1503e2 b0fff921 912a5421 97c57464 b0002160
[    1.463479] bd04  b94cc000 35000140 90001014 3971d280 350000e0 b0fff920 912ac000 97c76478
[    1.463531] bd24  d4210000 52800020 3931d280 d0000f14 91108280 913a6275 f9402401 c89ffea1
[    1.463583] bd44  5286e721 f9402400 790042a1 91005000 97ec617c 2a0003f3 34000120 3100301f
[    1.463635] bd64  54000081 f94022a0 97d99d53 17ffffcf b0fff920 912b6400 97c76461 91108294
[    1.463687] bd84  f940ca93 aa1303e0 97ec6348 72001c1f 54000081 52800001 aa1303e0 97ec68ff
[    1.463740]
               SP: 0xffffffc0eec13c90:
[    1.463768] 3c90  093b7e78 ffffff80 00000000 00000000 08f4047c ffffff80 091cd000 ffffff80
[    1.463820] 3cb0  08f9e988 ffffff80 00000005 00000000 0900aae8 ffffff80 eec13d10 ffffffc0
[    1.463872] 3cd0  08f8bd24 ffffff80 eec13d10 ffffffc0 08f8bd24 ffffff80 60000045 00000000
[    1.463924] 3cf0  00000000 00000000 16141c01 6f740f03 ffffffff ffffffff 00000008 00000000
[    1.463976] 3d10  eec13d90 ffffffc0 08f8bbe0 ffffff80 00000000 00000000 0916d000 ffffff80
[    1.464028] 3d30  093b7000 ffffff80 ef035620 ffffffc0 ef06aca0 ffffffc0 00000000 00000000
[    1.464080] 3d50  00000000 00000000 08eb0a49 ffffff80 00000000 00000000 00000000 00000000
[    1.464132] 3d70  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.464187]
               X6: 0xffffff80091d088b:
[    1.464215] 0888  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.464267] 08a8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.464318] 08c8  00000000 00000000 00000001 30303020 32303330 31333430 30205d38 20386338
[    1.464370] 08e8  342e3120 38313436 58205d37 30203a36 66666678 38666666 31393030 38383064
[    1.464422] 0908  300a3a62 38663830 34326462 70205d3e 74617473 36203a65 30303030 0a353430
[    1.464474] 0928  6f69673c 7474656d 696c4069 2e78756e 0a3e7469 73757461 29302820 7461740a
[    1.464526] 0948  28207375 740a2930 726f7720 20200a6b 302e3020 30303030 20205d30 76202020
[    1.464578] 0968  6c6c616d 3a20636f 66783020 66666666 30303866 30303038 20303030 7830202d
[    1.464630] 0988  66666666 64626666 66666662 30303030 28202020 32202020 47203634 5b0a2942
[    1.464684]
               X10: 0xffffff80091d085b:
[    1.464712] 0858  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.464764] 0878  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.464816] 0898  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.464867] 08b8  00000000 00000000 00000000 00000000 00000000 00000000 00000001 30303020
[    1.464919] 08d8  342e3120 31393430 30205d39 20386438 342e3120 38363436 58205d34 203a3031
[    1.464971] 08f8  66667830 66666666 39303038 38306431 0a3a6235 38663830 34326462 70205d3e
[    1.465023] 0918  74617473 36203a65 30303030 0a353430 6f69673c 7474656d 696c4069 2e78756e
[    1.465075] 0938  0a3e7469 73757461 29302820 7461740a 28207375 740a2930 726f7720 20200a6b
[    1.465127] 0958  302e3020 30303030 20205d30 76202020 6c6c616d 3a20636f 66783020 66666666
[    1.465181]
               X13: 0xffffff80891d0853:
[    1.465209] 0850  ******** ******** ******** ******** ******** ******** ******** ********
[    1.465267] 0870  ******** ******** ******** ******** ******** ******** ******** ********
[    1.465321] 0890  ******** ******** ******** ******** ******** ******** ******** ********
[    1.465375] 08b0  ******** ******** ******** ******** ******** ******** ******** ********
[    1.465429] 08d0  ******** ******** ******** ******** ******** ******** ******** ********
[    1.465483] 08f0  ******** ******** ******** ******** ******** ******** ******** ********
[    1.465537] 0910  ******** ******** ******** ******** ******** ******** ******** ********
[    1.465591] 0930  ******** ******** ******** ******** ******** ******** ******** ********
[    1.465645] 0950  ******** ******** ******** ******** ******** ******** ******** ********
[    1.465703]
               X19: 0xffffff80093b6f80:
[    1.465731] 6f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.465783] 6fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.465834] 6fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.465886] 6fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.465938] 7000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.465989] 7020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.466041] 7040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.466093] 7060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.466145]
               X20: 0xffffff800918af80:
[    1.466174] af80  0918af78 ffffff80 0814b680 ffffff80 08cc565b ffffff80 08b163c8 ffffff80
[    1.466226] afa0  08b16264 ffffff80 0814b918 ffffff80 08f96038 ffffff80 00000000 00000000
[    1.466278] afc0  0918afc0 ffffff80 0918afc0 ffffff80 0814b680 ffffff80 08cc565b ffffff80
[    1.466330] afe0  08b13c44 ffffff80 08b125e4 ffffff80 0814b918 ffffff80 08f95f74 ffffff80
[    1.466382] b000  00000000 00000000 0918b008 ffffff80 0918b008 ffffff80 0814b680 ffffff80
[    1.466434] b020  08cc565b ffffff80 08b13b90 ffffff80 08b124fc ffffff80 0814b918 ffffff80
[    1.466486] b040  08f9854c ffffff80 00000000 00000000 0918b050 ffffff80 0918b050 ffffff80
[    1.466538] b060  0814b680 ffffff80 08cc565b ffffff80 08b160e0 ffffff80 08b15f18 ffffff80
[    1.466591]
               X21: 0xffffff80093b7e60:
[    1.466619] 7e60  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.466671] 7e80  00000000 00000000 ef0355e8 ffffffc0 00000000 00000000 00000000 00000000
[    1.466723] 7ea0  00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[    1.466775] 7ec0  00000000 dead4ead ffffffff 00000000 ffffffff ffffffff eeaae400 ffffffc0
[    1.466826] 7ee0  00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[    1.466878] 7f00  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.466930] 7f20  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.466982] 7f40  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.467034]
               X22: 0xffffff80093b7df8:
[    1.467063] 7df8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.467115] 7e18  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.467166] 7e38  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.467218] 7e58  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.467269] 7e78  00000000 00000000 00000000 00000000 ef0355e8 ffffffc0 00000000 00000000
[    1.467321] 7e98  00000000 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[    1.467373] 7eb8  00000000 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[    1.467425] 7ed8  eeaae400 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[    1.467478]
               X24: 0xffffff8008f403fc:
[    1.467506] 03fc  d2800801 d2800300 94005302 aa0003f3 aa1503e0 97d51ea4 91000400 d2800002
[    1.467559] 041c  d2800801 940052fb f9000a60 aa1503e1 97d5402d f9411281 f9000433 a9006261
[    1.467610] 043c  f9011293 17ffffe1 a94153f3 52800000 a9425bf5 a94363f7 a8c57bfd d65f03c0
[    1.467662] 045c  a9bf7bfd b0000861 91200021 910003fd 9108c021 97d574f7 a8c17bfd d65f03c0
[    1.467714] 047c  b4000421 a9bd7bfd 910003fd a90153f3 aa0003f4 aa0103f3 f90013f5 97d51e82
[    1.467766] 049c  91000415 8b150295 eb1302bf 54000101 528007a0 381ff2a0 52800000 f94013f5
[    1.467818] 04bc  a94153f3 a8c37bfd d65f03c0 91000800 8b000294 eb14027f 54000141 528007a0
[    1.467870] 04dc  381fe260 aa1303e0 97d51e6f 91000402 aa1303e1 aa1503e0 97d51d43 17ffffef
[    1.467923]
               X25: 0xffffff80091ccf80:
[    1.467951] cf80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.468003] cfa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.468055] cfc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.468107] cfe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.468158] d000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.468209] d020  00000000 00000000 f7f552c0 ffffffc0 f7f55200 ffffffc0 f7f55140 ffffffc0
[    1.468261] d040  00000000 00000000 00000000 00000000 00000001 00000000 00000000 00000000
[    1.468313] d060  00000000 00000000 00000000 00000000 00000000 00000000 e9dc2de6 ffffffc0
[    1.468366]
               X26: 0xffffff8008f9e908:
[    1.468394] e908  00030003 dead4ead ffffffff 00000000 ffffffff ffffffff 08f9e920 ffffff80
[    1.468446] e928  08f9e920 ffffff80 00000001 00000000 00000000 00000000 0900a5d8 ffffff80
[    1.468498] e948  0900a608 ffffff80 0900a740 ffffff80 0900a800 ffffff80 0900a848 ffffff80
[    1.468550] e968  0900ab10 ffffff80 0900ac98 ffffff80 0900bdf8 ffffff80 0900bf48 ffffff80
[    1.468602] e988  08e280ad ffffff80 08dc5ed6 ffffff80 08dbb2b3 ffffff80 08e8ae76 ffffff80
[    1.468654] e9a8  08dbb2bc ffffff80 08dfc7c1 ffffff80 08e38a35 ffffff80 08e28113 ffffff80
[    1.468706] e9c8  746f6f72 42414c00 523d4c45 46544f4f 6f720053 6c66746f 00736761 61746164
[    1.468758] e9e8  6972773d 61626574 72006b63 6f630077 6c6f736e 61750065 32387472 6d2c3035
[    1.468812]
               X28: 0xffffff800900aa68:
[    1.468840] aa68  08f8462c ffffff80 08f8464c ffffff80 08f847f4 ffffff80 08f848a4 ffffff80
[    1.468892] aa88  08f85404 ffffff80 08f86158 ffffff80 08f86524 ffffff80 08f86740 ffffff80
[    1.468944] aaa8  08f87900 ffffff80 08f87940 ffffff80 08f87a94 ffffff80 08f87c84 ffffff80
[    1.468996] aac8  08f890e4 ffffff80 08f892b8 ffffff80 08f8a6a8 ffffff80 08f8bb70 ffffff80
[    1.469048] aae8  08f93504 ffffff80 08f93538 ffffff80 08f987b8 ffffff80 08f6f8c0 ffffff80
[    1.469101] ab08  08f70424 ffffff80 08084054 ffffff80 08f459cc ffffff80 08f4aa24 ffffff80
[    1.469152] ab28  08f4c86c ffffff80 08f4e5e8 ffffff80 08f4ed38 ffffff80 08f4f1e0 ffffff80
[    1.469204] ab48  08f4f2e0 ffffff80 08f4f40c ffffff80 08f572a8 ffffff80 08f57940 ffffff80
[    1.469257]
               X29: 0xffffffc0eec13c90:
[    1.469286] 3c90  093b7e78 ffffff80 00000000 00000000 08f4047c ffffff80 091cd000 ffffff80
[    1.469338] 3cb0  08f9e988 ffffff80 00000005 00000000 0900aae8 ffffff80 eec13d10 ffffffc0
[    1.469390] 3cd0  08f8bd24 ffffff80 eec13d10 ffffffc0 08f8bd24 ffffff80 60000045 00000000
[    1.469441] 3cf0  00000000 00000000 16141c01 6f740f03 ffffffff ffffffff 00000008 00000000
[    1.469493] 3d10  eec13d90 ffffffc0 08f8bbe0 ffffff80 00000000 00000000 0916d000 ffffff80
[    1.469545] 3d30  093b7000 ffffff80 ef035620 ffffffc0 ef06aca0 ffffffc0 00000000 00000000
[    1.469597] 3d50  00000000 00000000 08eb0a49 ffffff80 00000000 00000000 00000000 00000000
[    1.469649] 3d70  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.469726] ---[ end trace f129469bfa4d7288 ]---
[    1.469745] Call trace:
[    1.469765] Exception stack(0xffffffc0eec13b40 to 0xffffffc0eec13c70)
[    1.469788] 3b40: ffffff80093b7000 0000008000000000 ffffffc0eec13d10 ffffff8008f8bd24
[    1.469821] 3b60: 0000000000000028 0000000000000000 ffffffc0eec13c10 ffffff80080ef830
[    1.469853] 3b80: ffffffc0eec13c90 ffffff8008eb0ab0 ffffff80093b7ee0 ffffff80093b7e78
[    1.469885] 3ba0: 0000000000000000 ffffff8008f4047c ffffff80091cd000 ffffff8008f9e988
[    1.469917] 3bc0: 0000000000000005 ffffff800900aae8 ffffffc0eec13c00 ffffff800900c000
[    1.469950] 3be0: 0000000000000028 0000000000000005 00000040eef32000 00000040eef32000
[    1.469981] 3c00: 0000000000000000 0000000000000000 ffffff80091d090b 6164707520646c75
[    1.470013] 3c20: 2e2e2e7469206574 0000000005f5e0ff ffffff80091d08db 0000000000000006
[    1.470046] 3c40: 0000000000000030 ffffff80891d08d3 000000000000000a 0000000000000000
[    1.470076] 3c60: 0000000000000010 0000000000000000
[    1.470098] [<ffffff8008f8bd24>] regulatory_init+0xc8/0x150
[    1.470119] [<ffffff8008f8bbe0>] cfg80211_init+0x70/0xec
[    1.470144] [<ffffff80080831cc>] do_one_initcall+0x18c/0x194
[    1.470167] [<ffffff8008f40e08>] kernel_init_freeable+0x224/0x228
[    1.470190] [<ffffff8008b398c4>] kernel_init+0x18/0x100
[    1.470211] [<ffffff8008082ef0>] ret_from_fork+0x10/0x20
[    1.471108] clocksource: Switched to clocksource arch_sys_counter
[    1.516994] FS-Cache: Loaded
[    1.525586] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    1.525721] NET: Registered protocol family 2
[    1.526169] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.526460] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[    1.527321] TCP: Hash tables configured (established 32768 bind 32768)
[    1.527459] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[    1.527688] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[    1.528118] NET: Registered protocol family 1
[    1.528456] RPC: Registered named UNIX socket transport module.
[    1.528479] RPC: Registered udp transport module.
[    1.528497] RPC: Registered tcp transport module.
[    1.528516] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.528552] PCI: CLS 0 bytes, default 64
[    1.529223] Trying to unpack rootfs image as initramfs...
[    1.833128] Freeing initrd memory: 6464K
[    1.833569] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    1.833683] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    1.837102] Initialise system trusted keyring
[    1.845923] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.846621] FS-Cache: Netfs 'nfs' registered for caching
[    1.847065] NFS: Registering the id_resolver key type
[    1.847127] Key type id_resolver registered
[    1.847147] Key type id_legacy registered
[    1.847180] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.847425] FS-Cache: Netfs 'cifs' registered for caching
[    1.852870] NET: Registered protocol family 38
[    1.852916] Key type asymmetric registered
[    1.852942] Asymmetric key parser 'x509' registered
[    1.853117] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.853289] io scheduler noop registered
[    1.853314] io scheduler deadline registered
[    1.853360] io scheduler cfq registered (default)
[    1.854343] phy phy-ff770000.syscon:usb2-phy@e460.0: Looking up phy-supply from device tree
[    1.854761] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up phy-supply from device tree
[    1.854774] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
[    1.854992] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up vbus-supply from device tree
[    1.855003] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
[    1.855016] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator
[    1.856749] phy phy-ff770000.syscon:phy@f780.2: Looking up phy-supply from device tree
[    1.856761] phy phy-ff770000.syscon:phy@f780.2: Looking up phy-supply property in node /syscon@ff770000/phy@f780 failed
[    1.857620] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc0-supply from device tree
[    1.857633] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc0-supply property in node /power-management@ff310000/power-controller failed
[    1.857848] phy phy-ff800000.phy.3: Looking up phy-supply from device tree
[    1.857859] phy phy-ff800000.phy.3: Looking up phy-supply property in node /phy@ff800000/dp-port failed
[    1.857958] phy phy-ff800000.phy.4: Looking up phy-supply from device tree
[    1.857968] phy phy-ff800000.phy.4: Looking up phy-supply property in node /phy@ff800000/usb3-port failed
[    1.858068] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc1-supply from device tree
[    1.858078] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc1-supply property in node /power-management@ff310000/power-controller failed
[    1.858340] phy phy-pcie-phy.5: Looking up phy-supply from device tree
[    1.858350] phy phy-pcie-phy.5: Looking up phy-supply property in node /pcie-phy failed
[    1.859981] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[    1.859991] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[    1.860018] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[    1.860261] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[    1.860272] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply property in node /pcie@f8000000 failed
[    1.860286] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    1.860313] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree
[    1.860322] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[    1.860334] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    1.860356] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree
[    1.860365] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[    1.860376] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    1.860398] rockchip-pcie f8000000.pcie: missing "memory-region" property
[    1.860427] PCI host bridge /pcie@f8000000 ranges:
[    1.860460]   MEM 0xfa000000..0xfbdfffff -> 0xfa000000
[    1.860483]    IO 0xfbe00000..0xfbefffff -> 0xfbe00000
[    2.407145] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    2.407192] rockchip-pcie f8000000.pcie: deferred probe failed
[    2.407330] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    2.408454] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply from device tree
[    2.408469] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply property in node /vpu_service@ff650000 failed
[    2.408493] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[    2.408889] rk-vcodec ff650000.vpu_service: probe device
[    2.409214] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[    2.409989] rk-vcodec ff650000.vpu_service: could not find power_model node
[    2.410026] rk-vcodec ff650000.vpu_service: init success
[    2.410424] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply from device tree
[    2.410439] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply property in node /rkvdec@ff660000 failed
[    2.410457] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[    2.410965] rk-vcodec ff660000.rkvdec: probe device
[    2.411245] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[    2.411672] rk-vcodec ff660000.rkvdec: could not find power_model node
[    2.411696] rk-vcodec ff660000.rkvdec: init success
[    2.413135] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.413172] dma-pl330 ff6d0000.dma-controller:     DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    2.414640] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.414677] dma-pl330 ff6e0000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.415806] pwm-regulator vdd-log: GPIO lookup for consumer enable
[    2.415815] pwm-regulator vdd-log: using device tree for GPIO lookup
[    2.415826] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log[0]'
[    2.415835] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log[0]'
[    2.415842] pwm-regulator vdd-log: using lookup tables for GPIO lookup
[    2.415851] pwm-regulator vdd-log: lookup for GPIO enable failed
[    2.415898] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.415907] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.415930] vdd_log: 800 <--> 1400 mV at 1118 mV
[    2.416088] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.416098] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.416146] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.416155] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.416551] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    2.417182] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 34, base_baud = 1500000) is a 16550A
[    2.418254] [drm] Initialized drm 1.1.0 20060810
[    2.421951] [drm] Rockchip DRM driver version: v1.0.1
[    2.423914] Unable to detect cache hierarchy for CPU 0
[    2.424776] brd: module loaded
[    2.429989] loop: module loaded
[    2.430325] lkdtm: No crash points registered, enable through debugfs
[    2.432496] of_get_named_gpiod_flags: parsed 'wolirq-gpio' property of node '/ethernet@fe300000[0]' - status (0)
[    2.432527] rk_gmac-dwmac fe300000.ethernet: Looking up phy-supply from device tree
[    2.432611] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    2.432638] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    2.432661] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[    2.432696] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    2.432872] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    2.432893] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    2.437922] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    2.438059] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    2.438078]  Ring mode enabled
[    2.438096]  DMA HW capability register supported
[    2.438104]  Normal descriptors
[    2.438132]  RX Checksum Offload Engine supported (type 2)
[    2.438150]  TX Checksum insertion supported
[    2.438167]  Wake-Up On Lan supported
[    2.438221]  Enable RX Mitigation via HW Watchdog Timer
[    2.438339] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@fe300000[0]' - status (0)
[    2.579552] libphy: stmmac: probed
[    2.579589] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[    2.579623] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01)
[    2.581519] usbcore: registered new interface driver rndis_wlan
[    2.581814] Rockchip WiFi SYS interface (V1.00) ...
[    2.581946] usbcore: registered new interface driver rtl8150
[    2.582024] usbcore: registered new interface driver r8152
[    2.582111] usbcore: registered new interface driver asix
[    2.582187] usbcore: registered new interface driver ax88179_178a
[    2.582264] usbcore: registered new interface driver cdc_ether
[    2.582344] usbcore: registered new interface driver cdc_eem
[    2.582422] usbcore: registered new interface driver rndis_host
[    2.582535] usbcore: registered new interface driver cdc_ncm
[    2.582613] usbcore: registered new interface driver cdc_mbim
[    2.584481] rockchip-dwc3 usb0: failed to get drvdata dwc3
[    2.584642] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_usb3-supply from device tree
[    2.584658] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_usb3-supply property in node /power-management@ff310000/power-controller failed
[    2.589267] rockchip-dwc3 usb1: fail to get drvdata hcd
[    2.590924] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.590974] ehci-pci: EHCI PCI platform driver
[    2.591082] ehci-platform: EHCI generic platform driver
[    2.595160] ehci-platform fe3c0000.usb: EHCI Host Controller
[    2.595449] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[    2.595635] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[    2.607143] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    2.607399] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.607437] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.607490] usb usb1: Product: EHCI Host Controller
[    2.607523] usb usb1: Manufacturer: Linux 4.4.167-rk3399-tv ehci_hcd
[    2.607557] usb usb1: SerialNumber: fe3c0000.usb
[    2.608203] hub 1-0:1.0: USB hub found
[    2.608264] hub 1-0:1.0: 1 port detected
[    2.609061] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.609113] ohci-platform: OHCI generic platform driver
[    2.609816] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    2.610088] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[    2.610253] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[    2.667339] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    2.667377] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.667430] usb usb2: Product: Generic Platform OHCI controller
[    2.667464] usb usb2: Manufacturer: Linux 4.4.167-rk3399-tv ohci_hcd
[    2.667497] usb usb2: SerialNumber: fe3e0000.usb
[    2.668122] hub 2-0:1.0: USB hub found
[    2.668183] hub 2-0:1.0: 1 port detected
[    2.669538] usbcore: registered new interface driver cdc_acm
[    2.669572] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.669673] usbcore: registered new interface driver cdc_wdm
[    2.669757] usbcore: registered new interface driver uas
[    2.669898] usbcore: registered new interface driver usb-storage
[    2.670035] usbcore: registered new interface driver usbserial
[    2.670105] usbcore: registered new interface driver usbserial_generic
[    2.670169] usbserial: USB Serial support registered for generic
[    2.670252] usbcore: registered new interface driver ch341
[    2.670313] usbserial: USB Serial support registered for ch341-uart
[    2.670391] usbcore: registered new interface driver cp210x
[    2.670452] usbserial: USB Serial support registered for cp210x
[    2.670550] usbcore: registered new interface driver ftdi_sio
[    2.670616] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.670809] usbcore: registered new interface driver keyspan
[    2.670870] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    2.670950] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    2.671029] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    2.671143] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    2.671246] usbcore: registered new interface driver option
[    2.671312] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.671537] usbcore: registered new interface driver oti6858
[    2.671598] usbserial: USB Serial support registered for oti6858
[    2.671677] usbcore: registered new interface driver pl2303
[    2.671738] usbserial: USB Serial support registered for pl2303
[    2.671822] usbcore: registered new interface driver qcserial
[    2.671883] usbserial: USB Serial support registered for Qualcomm USB modem
[    2.671978] usbcore: registered new interface driver sierra
[    2.672044] usbserial: USB Serial support registered for Sierra USB modem
[    2.673205] usbcore: registered new interface driver iforce
[    2.673316] usbcore: registered new interface driver xpad
[    2.673900] usbcore: registered new interface driver usbtouchscreen
[    2.674763] i2c /dev entries driver
[    2.676245] fan53555-regulator 4-0040: GPIO lookup for consumer vsel
[    2.676258] fan53555-regulator 4-0040: using device tree for GPIO lookup
[    2.676300] of_get_named_gpiod_flags: parsed 'vsel-gpios' property of node '/i2c@ff3d0000/syr827@40[0]' - status (0)
[    2.676717] fan53555-regulator 4-0040: FAN53555 Option[8] Rev[1] Detected!
[    2.676768] fan53555-regulator 4-0040: Looking up vin-supply from device tree
[    2.676862] fan53555-reg: supplied by vcc5v0_sys
[    2.678329] vdd_cpu_b: 712 <--> 1500 mV at 1000 mV
[    2.678790] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.678806] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.679147] fan53555-regulator 4-0041: GPIO lookup for consumer vsel
[    2.679158] fan53555-regulator 4-0041: using device tree for GPIO lookup
[    2.679170] of_get_named_gpiod_flags: can't parse 'vsel-gpios' property of node '/i2c@ff3d0000/syr828@41[0]'
[    2.679182] of_get_named_gpiod_flags: can't parse 'vsel-gpio' property of node '/i2c@ff3d0000/syr828@41[0]'
[    2.679192] fan53555-regulator 4-0041: using lookup tables for GPIO lookup
[    2.679203] fan53555-regulator 4-0041: lookup for GPIO vsel failed
[    2.679553] fan53555-regulator 4-0041: FAN53555 Option[8] Rev[1] Detected!
[    2.679604] fan53555-regulator 4-0041: Looking up vin-supply from device tree
[    2.679671] fan53555-reg: supplied by vcc5v0_sys
[    2.681405] vdd_gpu: 712 <--> 1500 mV at 1000 mV
[    2.681990] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.682005] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.682760] rk808 4-001b: Pmic Chip id: 0x0
[    2.686648] rk808 4-001b: GPIO lookup for consumer dvs
[    2.686659] rk808 4-001b: using device tree for GPIO lookup
[    2.686672] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3d0000/pmic@1b[0]'
[    2.686684] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3d0000/pmic@1b[0]'
[    2.686694] rk808 4-001b: using lookup tables for GPIO lookup
[    2.686704] rk808 4-001b: lookup for GPIO dvs failed
[    2.686715] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.686751] rk808 4-001b: GPIO lookup for consumer dvs
[    2.686760] rk808 4-001b: using device tree for GPIO lookup
[    2.686772] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3d0000/pmic@1b[1]'
[    2.686783] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3d0000/pmic@1b[1]'
[    2.686792] rk808 4-001b: using lookup tables for GPIO lookup
[    2.686802] rk808 4-001b: lookup for GPIO dvs failed
[    2.686811] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    2.686886] rk808 4-001b: Looking up vcc1-supply from device tree
[    2.686967] DCDC_REG1: supplied by vcc3v3_sys
[    2.687490] vdd_center: 750 <--> 1350 mV at 900 mV
[    2.687802] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.687817] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.687873] rk808 4-001b: Looking up vcc2-supply from device tree
[    2.687934] DCDC_REG2: supplied by vcc3v3_sys
[    2.688280] vdd_cpu_l: 750 <--> 1350 mV at 900 mV
[    2.688574] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.688587] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.688640] rk808 4-001b: Looking up vcc3-supply from device tree
[    2.688691] DCDC_REG3: supplied by vcc3v3_sys
[    2.688760] vcc_ddr: at 3300 mV
[    2.688993] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.689007] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.689065] rk808 4-001b: Looking up vcc4-supply from device tree
[    2.689115] DCDC_REG4: supplied by vcc3v3_sys
[    2.689357] vcc_1v8: 1800 mV
[    2.689622] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.689635] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.689696] rk808 4-001b: Looking up vcc6-supply from device tree
[    2.689746] LDO_REG1: supplied by vcc3v3_sys
[    2.690635] vcc1v8_apio2: 1800 mV
[    2.690929] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.690943] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.691007] rk808 4-001b: Looking up vcc6-supply from device tree
[    2.691057] LDO_REG2: supplied by vcc3v3_sys
[    2.691315] vcc1v8_efuse: Bringing 3000000uV into 1800000-1800000uV
[    2.691470] vcc1v8_efuse: ramp_delay not set
[    2.692007] vcc1v8_efuse: 1800 mV
[    2.692309] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.692323] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.692390] rk808 4-001b: Looking up vcc7-supply from device tree
[    2.692442] LDO_REG3: supplied by vcc3v3_sys
[    2.693177] vcc1v8_pmu: 1800 mV
[    2.693465] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.693479] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.693551] rk808 4-001b: Looking up vcc9-supply from device tree
[    2.693602] LDO_REG4: supplied by vcc3v3_sys
[    2.694339] vccio_sd: 1800 <--> 3000 mV at 3000 mV
[    2.694627] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.694640] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.694711] rk808 4-001b: Looking up vcc9-supply from device tree
[    2.694762] LDO_REG5: supplied by vcc3v3_sys
[    2.695505] vcc_vldo5: 3000 mV
[    2.695764] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.695778] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.695850] rk808 4-001b: Looking up vcc10-supply from device tree
[    2.695900] LDO_REG6: supplied by vcc3v3_sys
[    2.696662] vcc_1v5: 1500 mV
[    2.696924] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.696938] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.697012] rk808 4-001b: Looking up vcc7-supply from device tree
[    2.697062] LDO_REG7: supplied by vcc3v3_sys
[    2.697797] vcca1v8_codec: 1800 mV
[    2.698089] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.698103] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.698181] rk808 4-001b: Looking up vcc11-supply from device tree
[    2.698231] LDO_REG8: supplied by vcc3v3_sys
[    2.698964] vcc_3v0: 3000 mV
[    2.699285] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.699298] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.699374] rk808 4-001b: Looking up vcc8-supply from device tree
[    2.699425] SWITCH_REG1: supplied by vcc3v3_sys
[    2.699493] vcc3v3_s3: at 3300 mV
[    2.699753] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.699766] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.699842] rk808 4-001b: Looking up vcc12-supply from device tree
[    2.699893] SWITCH_REG2: supplied by vcc3v3_sys
[    2.699960] vcc3v3_s0: at 3300 mV
[    2.700223] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    2.700236] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    2.703798] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[    2.704713] fusb302 4-0022: GPIO lookup for consumer int-n
[    2.704724] fusb302 4-0022: using device tree for GPIO lookup
[    2.704772] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0)
[    2.704810] fusb302 4-0022: GPIO lookup for consumer vbus-5v
[    2.704820] fusb302 4-0022: using device tree for GPIO lookup
[    2.704831] of_get_named_gpiod_flags: can't parse 'vbus-5v-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[    2.704842] of_get_named_gpiod_flags: can't parse 'vbus-5v-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[    2.704852] fusb302 4-0022: using lookup tables for GPIO lookup
[    2.704862] fusb302 4-0022: lookup for GPIO vbus-5v failed
[    2.704873] fusb302 4-0022: GPIO lookup for consumer vbus-other
[    2.704882] fusb302 4-0022: using device tree for GPIO lookup
[    2.704893] of_get_named_gpiod_flags: can't parse 'vbus-other-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[    2.704903] of_get_named_gpiod_flags: can't parse 'vbus-other-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[    2.704913] fusb302 4-0022: using lookup tables for GPIO lookup
[    2.704922] fusb302 4-0022: lookup for GPIO vbus-other failed
[    2.704932] fusb302 4-0022: GPIO lookup for consumer discharge
[    2.704942] fusb302 4-0022: using device tree for GPIO lookup
[    2.704952] of_get_named_gpiod_flags: can't parse 'discharge-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[    2.704963] of_get_named_gpiod_flags: can't parse 'discharge-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[    2.704972] fusb302 4-0022: using lookup tables for GPIO lookup
[    2.704982] fusb302 4-0022: lookup for GPIO discharge failed
[    2.705207] fusb302 4-0022: Can't get property of role, set role to default DRP
[    2.705413] fusb302 4-0022: fusb302 send extcon to disable vbus 5v
[    2.708650] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[    2.708751] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80096f4000
[    2.709921] fusb302 8-0022: GPIO lookup for consumer int-n
[    2.709933] fusb302 8-0022: using device tree for GPIO lookup
[    2.709971] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff3e0000/fusb30x@22[0]' - status (0)
[    2.710002] fusb302 8-0022: GPIO lookup for consumer vbus-5v
[    2.710012] fusb302 8-0022: using device tree for GPIO lookup
[    2.710047] of_get_named_gpiod_flags: parsed 'vbus-5v-gpios' property of node '/i2c@ff3e0000/fusb30x@22[0]' - status (0)
[    2.710077] fusb302 8-0022: GPIO lookup for consumer vbus-other
[    2.710087] fusb302 8-0022: using device tree for GPIO lookup
[    2.710098] of_get_named_gpiod_flags: can't parse 'vbus-other-gpios' property of node '/i2c@ff3e0000/fusb30x@22[0]'
[    2.710109] of_get_named_gpiod_flags: can't parse 'vbus-other-gpio' property of node '/i2c@ff3e0000/fusb30x@22[0]'
[    2.710119] fusb302 8-0022: using lookup tables for GPIO lookup
[    2.710129] fusb302 8-0022: lookup for GPIO vbus-other failed
[    2.710139] fusb302 8-0022: GPIO lookup for consumer discharge
[    2.710148] fusb302 8-0022: using device tree for GPIO lookup
[    2.710159] of_get_named_gpiod_flags: can't parse 'discharge-gpios' property of node '/i2c@ff3e0000/fusb30x@22[0]'
[    2.710170] of_get_named_gpiod_flags: can't parse 'discharge-gpio' property of node '/i2c@ff3e0000/fusb30x@22[0]'
[    2.710180] fusb302 8-0022: using lookup tables for GPIO lookup
[    2.710189] fusb302 8-0022: lookup for GPIO discharge failed
[    2.710388] fusb302 8-0022: Can't get property of role, set role to default DRP
[    2.718938] fusb302 8-0022: port 1 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[    2.719194] mcu_probe
[    2.719701] create_mcu_attrs
[    2.719755] mcu_probe,wol enable=0
[    2.720155] rk3x-i2c ff3e0000.i2c: Initialized RK3xxx I2C bus at ffffff80096f6000
[    2.722179] IR NEC protocol handler initialized
[    2.723187] usbcore: registered new interface driver uvcvideo
[    2.723219] USB Video Class driver (1.1.1)
[    2.723940] rockchip-iodomain ff320000.syscon:io-domains: Looking up pmu1830-supply from device tree
[    2.724325] rockchip-iodomain ff770000.syscon:io-domains: Looking up bt656-supply from device tree
[    2.724424] rockchip-iodomain ff770000.syscon:io-domains: Looking up audio-supply from device tree
[    2.724525] rockchip-iodomain ff770000.syscon:io-domains: Looking up sdmmc-supply from device tree
[    2.724648] rockchip-iodomain ff770000.syscon:io-domains: Looking up gpio1830-supply from device tree
[    2.727593] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[    2.727898] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[    2.729470] device-mapper: uevent: version 1.0.3
[    2.729943] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    2.730006] Bluetooth: Virtual HCI driver ver 1.5
[    2.730214] Bluetooth: HCI UART driver ver 2.3
[    2.730248] Bluetooth: HCI UART protocol H4 registered
[    2.730279] Bluetooth: HCI UART protocol LL registered
[    2.730309] Bluetooth: HCI UART protocol ATH3K registered
[    2.730430] usbcore: registered new interface driver bfusb
[    2.730534] usbcore: registered new interface driver btusb
[    2.730573] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    2.731462] cpu cpu0: bin=1
[    2.731582] cpu cpu0: leakage=15
[    2.731643] cpu cpu0: Looking up cpu-supply from device tree
[    2.744845] cpu cpu0: temp=63750, pvtm=147006 (145554 + 1452)
[    2.745159] cpu cpu0: pvtm-volt-sel=1
[    2.745270] cpu cpu0: bin-scale=34
[    2.745677] cpu cpu4: bin=1
[    2.745770] cpu cpu4: leakage=29
[    2.745825] cpu cpu4: Looking up cpu-supply from device tree
[    2.757825] cpu cpu4: temp=63750, pvtm=159165 (158395 + 770)
[    2.757920] cpu cpu4: pvtm-volt-sel=2
[    2.758006] cpu cpu4: bin-scale=17
[    2.758412] cpu cpu0: Looking up cpu-supply from device tree
[    2.758823] cpu cpu0: Looking up cpu-supply from device tree
[    2.759922] cpu cpu0: avs=0, target-scale=34
[    2.759976] cpu cpu0: scale_rate=1416000000
[    2.760260] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    2.762401] cpu cpu0: failed to find power_model node
[    2.762763] cpu cpu4: Looking up cpu-supply from device tree
[    2.763607] cpu cpu4: avs=0, target-scale=17
[    2.763638] cpu cpu4: scale_rate=1800000000
[    2.763806] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    2.765609] cpu cpu4: failed to find power_model node
[    2.766430] sdhci: Secure Digital Host Controller Interface driver
[    2.766449] sdhci: Copyright(c) Pierre Ossman
[    2.766470] Synopsys Designware Multimedia Card Interface Driver
[    2.767638] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    2.767692] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    2.767718] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    2.767778] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    2.767822] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.767858] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[    2.767872] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
[    2.767908] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[    2.767915] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
[    2.767928] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    2.767947] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    2.767987] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[    2.767993] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[    2.768002] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe310000[0]'
[    2.768009] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe310000[0]'
[    2.768014] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[    2.768021] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[    2.768257] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_sdioaudio-supply from device tree
[    2.768267] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_sdioaudio-supply property in node /power-management@ff310000/power-controller failed
[    2.768824] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    2.768871] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    2.768894] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    2.768946] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    2.768987] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.769019] dwmmc_rockchip fe320000.dwmmc: Looking up vmmc-supply from device tree
[    2.769120] dwmmc_rockchip fe320000.dwmmc: Looking up vqmmc-supply from device tree
[    2.769187] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer cd
[    2.769193] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[    2.769200] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/dwmmc@fe320000[0]'
[    2.769207] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/dwmmc@fe320000[0]'
[    2.769213] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[    2.769220] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO cd failed
[    2.769227] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer wp
[    2.769232] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[    2.769239] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe320000[0]'
[    2.769245] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe320000[0]'
[    2.769251] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[    2.769257] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO wp failed
[    2.769394] vccio_sd: unsupportable voltage range: 3300000-3000000uV
[    2.769426] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[    2.769459] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[    2.783168] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.800203] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[    2.801953] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.802861] sdhci-arasan fe330000.sdhci: GPIO lookup for consumer wp
[    2.802875] sdhci-arasan fe330000.sdhci: using device tree for GPIO lookup
[    2.802889] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/sdhci@fe330000[0]'
[    2.802909] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/sdhci@fe330000[0]'
[    2.802919] sdhci-arasan fe330000.sdhci: using lookup tables for GPIO lookup
[    2.802959] sdhci-arasan fe330000.sdhci: lookup for GPIO wp failed
[    2.804128] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply from device tree
[    2.804143] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply property in node /sdhci@fe330000 failed
[    2.804180] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply from device tree
[    2.804193] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe330000 failed
[    2.804254] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[    2.804285] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[    2.829073] mmc_host mmc0: Bus speed (slot 0) = 25000000Hz (slot req 25000000Hz, actual 25000000HZ div = 0)
[    2.829285] mmc0: new SDHC card at address 0001
[    2.830664] mmcblk0: mmc0:0001 SD16G 29.8 GiB
[    2.833020]  mmcblk0: p1 p2
[    2.835300] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    2.836674] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/sys_led[0]' - status (0)
[    2.837195] ledtrig-cpu: registered to indicate activity on CPUs
[    2.837366] hidraw: raw HID events driver (C) Jiri Kosina
[    2.839466] usbcore: registered new interface driver usbhid
[    2.839496] usbhid: USB HID core driver
[    2.840837] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[    2.842224] rockchip-saradc ff100000.saradc: Looking up vref-supply from device tree
[    2.844232] usbcore: registered new interface driver snd-usb-audio
[    2.849583] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.849697] Initializing XFRM netlink socket
[    2.850650] NET: Registered protocol family 10
[    2.852095] NET: Registered protocol family 17
[    2.852165] NET: Registered protocol family 15
[    2.852406] Bluetooth: RFCOMM socket layer initialized
[    2.852451] Bluetooth: RFCOMM ver 1.11
[    2.852543] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.852846] Bluetooth: HIDP socket layer initialized
[    2.853248] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    2.853603] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    2.853686] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
[    2.853715] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    2.853743] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    2.853790] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]'
[    2.853801] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]'
[    2.853811] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]'
[    2.853858] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0)
[    2.853868] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[    2.853916] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    2.853957] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    2.853986] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    2.854077] [BT_RFKILL]: Enter rfkill_rk_init
[    2.854555] of_get_named_gpiod_flags: parsed 'uart_rts_gpios' property of node '/wireless-bluetooth[0]' - status (0)
[    2.854565] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[    2.854615] of_get_named_gpiod_flags: can't parse 'BT,power_gpio' property of node '/wireless-bluetooth[0]'
[    2.854646] of_get_named_gpiod_flags: parsed 'BT,reset_gpio' property of node '/wireless-bluetooth[0]' - status (0)
[    2.854655] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 91.
[    2.854719] of_get_named_gpiod_flags: parsed 'BT,wake_gpio' property of node '/wireless-bluetooth[0]' - status (0)
[    2.854727] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[    2.854791] of_get_named_gpiod_flags: parsed 'BT,wake_host_irq' property of node '/wireless-bluetooth[0]' - status (0)
[    2.854799] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[    2.854844] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[    2.854938] [BT_RFKILL]: Request irq for bt wakeup host
[    2.855024] [BT_RFKILL]: ** disable irq
[    2.855264] [BT_RFKILL]: bt_default device registered.
[    2.855379] Key type dns_resolver registered
[    2.856126] Error: Driver 'ov4689' is already registered, aborting...
[    2.856185] Error: Driver 'ov7750' is already registered, aborting...
[    2.856254] Error: Driver 'ov13850' is already registered, aborting...
[    2.856564] Error: Driver 'sc031gs' is already registered, aborting...
[    2.857493] Registered cp15_barrier emulation handler
[    2.857680] Registered setend emulation handler
[    2.858678] registered taskstats version 1
[    2.858738] fusb302 4-0022: CC connected in CC2 as UFP
[    2.858799] Loading compiled-in X.509 certificates
[    2.867708] zswap: default zpool zbud not available
[    2.867744] zswap: pool creation failed
[    2.870455] Btrfs loaded
[    2.871826] rga: Driver loaded successfully ver:3.02
[    2.871899] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_rga-supply from device tree
[    2.871917] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_rga-supply property in node /power-management@ff310000/power-controller failed
[    2.872207] rga2: Module initialized.
[    2.872885] phy phy-ff770000.syscon:usb2-phy@e450.6: Looking up phy-supply from device tree
[    2.873437] phy phy-ff770000.syscon:usb2-phy@e450.7: Looking up phy-supply from device tree
[    2.873453] phy phy-ff770000.syscon:usb2-phy@e450.7: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[    2.873847] phy phy-ff770000.syscon:usb2-phy@e450.7: Looking up vbus-supply from device tree
[    2.873863] phy phy-ff770000.syscon:usb2-phy@e450.7: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[    2.873893] phy phy-ff770000.syscon:usb2-phy@e450.7: Failed to get VBUS supply regulator
[    2.874905] phy phy-ff7c0000.phy.8: Looking up phy-supply from device tree
[    2.874921] phy phy-ff7c0000.phy.8: Looking up phy-supply property in node /phy@ff7c0000/dp-port failed
[    2.875069] phy phy-ff7c0000.phy.9: Looking up phy-supply from device tree
[    2.875082] phy phy-ff7c0000.phy.9: Looking up phy-supply property in node /phy@ff7c0000/usb3-port failed
[    2.875831] rockchip-drm display-subsystem: defer getting devfreq
[    2.876370] rockchip-vop ff900000.vop: missing rockchip,grf property
[    2.876735] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008bffb88)
[    2.876831] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[    2.877089] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008bffb88)
[    2.877372] mmc1: MAN_BKOPS_EN bit is not set
[    2.877700] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[    2.877809] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.878019] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    2.880555] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008bf4698)
[    2.881447] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[    2.881934] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[    2.882009] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008bf5670)
[    2.882055] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.882082] [drm] No driver support for vblank timestamp query.
[    2.882357] rockchip-drm display-subsystem: failed to parse loader memory
[    2.889676] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[    2.890935] mmcblk1: mmc1:0001 BJTD4R 29.1 GiB
[    2.891866] mmcblk1boot0: mmc1:0001 BJTD4R partition 1 4.00 MiB
[    2.892653] mmcblk1boot1: mmc1:0001 BJTD4R partition 2 4.00 MiB
[    2.893398] mmcblk1rpmb: mmc1:0001 BJTD4R partition 3 4.00 MiB
[    2.922951] fusb302 4-0022: PD connected as UFP, fetching 5V
[    2.962015] fusb302 4-0022: rec unknown init vdm msg
[    3.025578] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    3.160657] Console: switching to colour frame buffer device 240x67
[    3.227038] rockchip-drm display-subsystem: fb0:  frame buffer device
[    3.245299] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[    3.245779] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 3
[    3.246115] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[    3.246373] xhci-hcd xhci-hcd.8.auto: irq 223, io mem 0xfe800000
[    3.246790] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    3.246959] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.247188] usb usb3: Product: xHCI Host Controller
[    3.247311] usb usb3: Manufacturer: Linux 4.4.167-rk3399-tv xhci-hcd
[    3.247465] usb usb3: SerialNumber: xhci-hcd.8.auto
[    3.248310] hub 3-0:1.0: USB hub found
[    3.248434] hub 3-0:1.0: 1 port detected
[    3.248853] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[    3.249281] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 4
[    3.249529] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.249825] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    3.249992] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.250166] usb usb4: Product: xHCI Host Controller
[    3.250288] usb usb4: Manufacturer: Linux 4.4.167-rk3399-tv xhci-hcd
[    3.250441] usb usb4: SerialNumber: xhci-hcd.8.auto
[    3.251129] hub 4-0:1.0: USB hub found
[    3.251266] hub 4-0:1.0: 1 port detected
[    3.253022] xhci-hcd xhci-hcd.8.auto: remove, state 1
[    3.253181] usb usb4: USB disconnect, device number 1
[    3.257632] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    3.258107] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[    3.258451] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[    3.258708] xhci-hcd xhci-hcd.9.auto: irq 224, io mem 0xfe900000
[    3.259178] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    3.259347] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.259521] usb usb5: Product: xHCI Host Controller
[    3.259644] usb usb5: Manufacturer: Linux 4.4.167-rk3399-tv xhci-hcd
[    3.259798] usb usb5: SerialNumber: xhci-hcd.9.auto
[    3.260668] hub 5-0:1.0: USB hub found
[    3.260793] hub 5-0:1.0: 1 port detected
[    3.261207] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    3.261639] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 6
[    3.261903] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.262198] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[    3.262366] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.262539] usb usb6: Product: xHCI Host Controller
[    3.270150] usb usb6: Manufacturer: Linux 4.4.167-rk3399-tv xhci-hcd
[    3.272754] xhci-hcd xhci-hcd.8.auto: Host not halted after 16000 microseconds.
[    3.272759] xhci-hcd xhci-hcd.8.auto: Host controller not halted, aborting reset.
[    3.272801] xhci-hcd xhci-hcd.8.auto: USB bus 4 deregistered
[    3.300387] usb usb6: SerialNumber: xhci-hcd.9.auto
[    3.308637] hub 6-0:1.0: USB hub found
[    3.316062] hub 6-0:1.0: 1 port detected
[    3.324363] xhci-hcd xhci-hcd.8.auto: remove, state 1
[    3.326515] ehci-platform fe380000.usb: EHCI Host Controller
[    3.326814] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 4
[    3.326944] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[    3.335307] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    3.335465] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    3.335470] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.335474] usb usb4: Product: EHCI Host Controller
[    3.335477] usb usb4: Manufacturer: Linux 4.4.167-rk3399-tv ehci_hcd
[    3.335481] usb usb4: SerialNumber: fe380000.usb
[    3.336142] hub 4-0:1.0: USB hub found
[    3.336163] hub 4-0:1.0: 1 port detected
[    3.336956] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    3.337242] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 7
[    3.337347] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[    3.387829] vendor storage:20160801 ret = 0
[    3.399328] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    3.399333] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.399337] usb usb7: Product: Generic Platform OHCI controller
[    3.399341] usb usb7: Manufacturer: Linux 4.4.167-rk3399-tv ohci_hcd
[    3.399344] usb usb7: SerialNumber: fe3a0000.usb
[    3.399946] hub 7-0:1.0: USB hub found
[    3.399985] hub 7-0:1.0: 1 port detected
[    3.400898] input: adc-keys as /devices/platform/adc-keys/input/input0
[    3.402326] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    3.402370] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    3.402386] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    3.402417] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    3.402436] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    3.402445] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[    3.402454] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
[    3.402493] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[    3.402501] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
[    3.402524] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    3.402529] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    3.402546] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[    3.402551] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[    3.402561] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe310000[0]'
[    3.402569] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe310000[0]'
[    3.402574] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[    3.402581] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[    3.402849] platform sdio-pwrseq: GPIO lookup for consumer reset
[    3.402854] platform sdio-pwrseq: using device tree for GPIO lookup
[    3.402884] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0)
[    3.402918] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[    3.419429] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.435445] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[    3.435935] rockchip-dmc dmc: Looking up center-supply from device tree
[    3.436238] rockchip-dmc dmc: Failed to get leakage
[    3.436261] rockchip-dmc dmc: Looking up center-supply from device tree
[    3.436297] vdd_center: could not add device link dmc err -17
[    3.436306] vdd_center: Failed to create debugfs directory
[    3.436314] rockchip-dmc dmc: Failed to get pvtm
[    3.436617] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[    3.436623] rockchip-dmc dmc: failed to get vop pn to msch rl
[    3.436846] rockchip-dmc dmc: could not find power_model node
[    3.437427] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[    3.437436] hdmi-audio-codec hdmi-audio-codec.7.auto: ASoC: Failed to add ELD: -16
[    3.438123] rk-hdmi-dp-sound hdmi-dp-sound: multicodec <-> ff8a0000.i2s mapping ok
[    3.438172] hdmi-audio-codec hdmi-audio-codec.7.auto: ASoC: Failed to create Playback debugfs file
[    3.440309] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp1-supply from device tree
[    3.440323] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp1-supply property in node /power-management@ff310000/power-controller failed
[    3.440393] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp0-supply from device tree
[    3.440401] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp0-supply property in node /power-management@ff310000/power-controller failed
[    3.440470] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_edp-supply from device tree
[    3.440479] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_edp-supply property in node /power-management@ff310000/power-controller failed
[    3.440519] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_gpu-supply from device tree
[    3.440527] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_gpu-supply property in node /power-management@ff310000/power-controller failed
[    3.440582] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_iep-supply from device tree
[    3.440590] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_iep-supply property in node /power-management@ff310000/power-controller failed
[    3.470655] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[    3.472252] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.473846] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.476728] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[    3.480228] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[    3.533332] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[    3.560160] console [netcon0] enabled
[    3.565718] netconsole: network logging started
[    3.571234] usb 5-1: new high-speed USB device number 2 using xhci-hcd
[    3.577534] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/button@0[0]' - status (0)
[    3.577607] gpio-5 (GPIO Key Power): gpiod_set_debounce: missing set() or set_debounce() operations
[    3.577910] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    3.583836] usb usb3: USB disconnect, device number 1
[    3.589522] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:08 UTC (1358499008)
[    3.596412] xhci-hcd xhci-hcd.8.auto: USB bus 3 deregistered
[    3.612094] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopl-supply from device tree
[    3.612122] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopl-supply property in node /power-management@ff310000/power-controller failed
[    3.612234] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vdu-supply from device tree
[    3.612246] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vdu-supply property in node /power-management@ff310000/power-controller failed
[    3.612305] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply from device tree
[    3.612317] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply property in node /power-management@ff310000/power-controller failed
[    3.613352] ALSA device list:
[    3.620198]   #0: rk-hdmi-dp-sound
[    3.627609] Freeing unused kernel memory: 1024K
[    3.716395] usb 5-1: New USB device found, idVendor=05ac, idProduct=1006
[    3.722111] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.727787] usb 5-1: Product: Keyboard Hub
[    3.733407] usb 5-1: Manufacturer: Apple, Inc.
[    3.739022] usb 5-1: SerialNumber: 000000000000
[    3.774733] hub 5-1:1.0: USB hub found
[    3.783217] hub 5-1:1.0: 3 ports detected
[    3.795282] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 218
[    3.806012] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[    3.810271] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[    3.883236] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[    3.947770] random: nonblocking pool is initialized
[    4.067147] usb 5-1.2: new low-speed USB device number 3 using xhci-hcd
[    4.170116] usb 5-1.2: New USB device found, idVendor=05ac, idProduct=0221
[    4.174476] usb 5-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.178806] usb 5-1.2: Product: Apple Keyboard
[    4.183120] usb 5-1.2: Manufacturer: Apple, Inc
[    4.188450] usb 5-1.2: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[    4.193540] usb 5-1.2: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
[    4.226511] input: Apple, Inc Apple Keyboard as /devices/platform/usb1/fe900000.dwc3/xhci-hcd.9.auto/usb5/5-1/5-1.2/5-1.2:1.0/0003:05AC:0221.0001/input/input2
[    4.287848] apple 0003:05AC:0221.0001: input,hidraw0: USB HID v1.11 Keyboard [Apple, Inc Apple Keyboard] on usb-xhci-hcd.9.auto-1.2/input0
[    4.293947] input: Apple, Inc Apple Keyboard as /devices/platform/usb1/fe900000.dwc3/xhci-hcd.9.auto/usb5/5-1/5-1.2/5-1.2:1.1/0003:05AC:0221.0002/input/input3
[    4.351411] apple 0003:05AC:0221.0002: input,hidraw1: USB HID v1.11 Device [Apple, Inc Apple Keyboard] on usb-xhci-hcd.9.auto-1.2/input1
[    4.361013] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopb-supply from device tree
[    4.361027] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopb-supply property in node /power-management@ff310000/power-controller failed
[    4.361153] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vo-supply from device tree
[    4.361160] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vo-supply property in node /power-management@ff310000/power-controller failed
[    5.181185] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    5.343146] usb 5-1.3: new full-speed USB device number 4 using xhci-hcd
[    5.500809] usb 5-1.3: New USB device found, idVendor=1532, idProduct=0039
[    5.506793] usb 5-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.512762] usb 5-1.3: Product: Razer Orochi 2013
[    5.518625] usb 5-1.3: Manufacturer: Razer
[    5.539992] input: Razer  Razer Orochi 2013 as /devices/platform/usb1/fe900000.dwc3/xhci-hcd.9.auto/usb5/5-1/5-1.3/5-1.3:1.0/0003:1532:0039.0003/input/input4
[    5.600399] hid-generic 0003:1532:0039.0003: input,hidraw2: USB HID v1.11 Mouse [Razer  Razer Orochi 2013] on usb-xhci-hcd.9.auto-1.3/input0
[    5.619826] input: Razer  Razer Orochi 2013 as /devices/platform/usb1/fe900000.dwc3/xhci-hcd.9.auto/usb5/5-1/5-1.3/5-1.3:1.1/0003:1532:0039.0004/input/input5
[    5.686864] hid-generic 0003:1532:0039.0004: input,hidraw3: USB HID v1.11 Keyboard [Razer  Razer Orochi 2013] on usb-xhci-hcd.9.auto-1.3/input1
[    5.891434] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[    9.903506] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[   12.760169] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
[   14.157856] systemd[1]: System time before build time, advancing clock.
[   14.185973] cgroup: cgroup2: unknown option "nsdelegate"
[   14.244451] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[   14.295360] systemd[1]: Detected architecture arm64.
[   14.356804] systemd[1]: Set hostname to <edge-v>.
[   15.004325] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[   15.017276] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[   15.424773] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   15.446925] systemd[1]: Reached target System Time Synchronized.
[   15.465240] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[   15.474491] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   15.492172] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   15.509728] systemd[1]: Listening on fsck to fsckd communication Socket.
[   15.537659] systemd[1]: Reached target Swap.
[   15.561332] systemd[1]: Listening on udev Kernel Socket.
[   15.580192] systemd[1]: Listening on Journal Socket.
[   15.606714] systemd[1]: Starting Restore / save the current clock...
[   15.654492] systemd[1]: Starting Set the console keyboard layout...
[   15.673799] systemd[1]: Mounting Kernel Debug File System...
[   15.693962] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   15.719030] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   15.729764] systemd[1]: Listening on Syslog Socket.
[   15.765065] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   15.775400] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[   15.793793] systemd[1]: Reached target Local Encrypted Volumes.
[   15.812956] systemd[1]: Listening on udev Control Socket.
[   15.831598] systemd[1]: Reached target Remote File Systems.
[   15.850438] systemd[1]: Listening on Journal Socket (/dev/log).
[   15.872558] systemd[1]: Starting Journal Service...
[   15.904363] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   15.942882] systemd[1]: Starting udev Coldplug all Devices...
[   15.987729] systemd[1]: Starting Load Kernel Modules...
[   16.015919] systemd[1]: Created slice system-getty.slice.
[   16.030864] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   16.041239] systemd[1]: Starting Remount Root and Kernel File Systems...
[   16.062168] systemd[1]: Starting Nameserver information manager...
[   16.080556] systemd[1]: Created slice User and Session Slice.
[   16.092905] systemd[1]: Reached target Slices.
[   16.095847] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
[   16.106112] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   16.112720] systemd[1]: Mounting POSIX Message Queue File System...
[   16.127494] systemd[1]: Started Restore / save the current clock.
[   16.149642] systemd[1]: Started Set the console keyboard layout.
[   16.158359] systemd[1]: Mounted Kernel Debug File System.
[   16.167971] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   16.179877] systemd[1]: Started Load Kernel Modules.
[   16.196866] systemd[1]: Started Remount Root and Kernel File Systems.
[   16.217655] systemd[1]: Mounted POSIX Message Queue File System.
[   16.230420] systemd[1]: Starting Create System Users...
[   16.241768] systemd[1]: Starting Load/Save Random Seed...
[   16.257058] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   16.263903] systemd[1]: Starting Apply Kernel Variables...
[   16.274114] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   16.282010] systemd[1]: Mounting Kernel Configuration File System...
[   16.293765] systemd[1]: Started Nameserver information manager.
[   16.308975] systemd[1]: Started Journal Service.
[   16.427175] systemd-journald[288]: Received request to flush runtime journal from PID 1
[   17.370743] mali ff9a0000.gpu: Looking up mali-supply from device tree
[   17.375589] mali ff9a0000.gpu: leakage=23
[   17.375739] mali ff9a0000.gpu: Looking up mali-supply from device tree
[   17.375799] vdd_gpu: could not add device link ff9a0000.gpu err -17
[   17.375818] vdd_gpu: Failed to create debugfs directory
[   17.388265] mali ff9a0000.gpu: temp=65000, pvtm=123771 (123483 + 288)
[   17.389190] mali ff9a0000.gpu: pvtm-volt-sel=1
[   17.390011] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[   17.390724] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[   17.390880] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 307; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[   17.392328] mali ff9a0000.gpu: Probed as mali0
[   17.856346] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[   17.856354] ======== dhd_wlan_init_plat_data ========
[   17.856357] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[   17.856365] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=64, oob_irq_flags=0x414
[   17.856367] dhd_wlan_init_gpio: WL_REG_ON=-1
[   17.856369] dhd_wifi_platform_load: Enter
[   17.856389] Power-up adapter 'DHD generic adapter'
[   17.857693] wifi_platform_set_power = 1
[   17.857696] ======== PULL WL_REG_ON(-1) HIGH! ========
[   17.857700] [WLAN_RFKILL]: rockchip_wifi_power: 1
[   17.857704] [WLAN_RFKILL]: wifi turn on power. -1
[   18.041081] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[   18.168472] wifi_platform_bus_enumerate device present 1
[   18.168488] ======== Card detection to detect SDIO card! ========
[   18.168499] mmc2:mmc host rescan start!
[   18.185176] bcmsdh_register: register client driver
[   18.189369] bcmsdh_sdmmc_probe: Enter num=1
[   18.189615] bcmsdh_sdmmc_probe: Enter num=2
[   18.189623] bus num (host idx)=2, slot num (rca)=1
[   18.189629] found adapter info 'DHD generic adapter'
[   18.189680] sdioh_attach: set sd_f2_blocksize 256
[   18.189725] sdioh_attach: sd clock rate = 0
[   18.189942] dhdsdio_probe : no mutex held. set lock
[   18.190050] F1 signature read @0x18000000=0x17294359
[   18.198453] F1 signature OK, socitype:0x1 chip:0x4359 rev:0x9 pkg:0x2
[   18.199041] DHD: dongle ram size is set to 917504(orig 917504) at 0x160000
[   18.199674] dhd_conf_set_chiprev: chip=0x4359, chiprev=9
[   18.199898] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[   18.206034] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[   18.206253] wl_escan_attach: Enter
[   18.206285] wl_escan_init: Enter
[   18.209469] wl_create_event_handler(): thread:wl_escan_handler:1b1 started
[   18.209658] tsk Enter, tsk = 0xffffffc0ed7301b0
[   18.209709] dhd_attach(): thread:dhd_watchdog_thread:1b2 started
[   18.209796] dhd_attach(): thread:dhd_dpc:1b3 started
[   18.209864] dhd_attach(): thread:dhd_rxf:1b4 started
[   18.209878] dhd_deferred_work_init: work queue initialized
[   18.209887] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 2
[   18.209926] dhd_bus_set_default_min_res_mask: Unhandled chip id
[   18.210748] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[   18.215885] Dongle Host Driver, version 1.579.77.41.10 (r)
[   18.216546] wl_ext_iapsta_attach_netdev: ifidx=0, bssidx=0
[   18.216557] Register interface [wlan0]  MAC: 28:ed:e0:e6:ab:9e
[   18.216658] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 -> mode 0
[   18.216672] dhd_wl_ioctl: returning as busstate=0
[   18.216679] dhd_dbg_detach_pkt_monitor, 2204
[   18.216685] dhd_bus_devreset: == Power OFF ==
[   18.216849] bcmsdh_oob_intr_unregister: Enter
[   18.216854] bcmsdh_oob_intr_unregister: irq is not registered
[   18.216865] dhd_txglom_enable: enable 0
[   18.216872] dhd_conf_set_txglom_params: txglom_mode=copy
[   18.216877] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
[   18.216882] dhd_conf_set_txglom_params: txinrx_thres=128, dhd_txminmax=-1
[   18.216887] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=-1
[   18.216892] dhd_bus_devreset:  WLAN OFF DONE
[   18.216921] wifi_platform_set_power = 0
[   18.216927] ======== PULL WL_REG_ON(-1) LOW! ========
[   18.216933] [WLAN_RFKILL]: rockchip_wifi_power: 0
[   18.217101] [WLAN_RFKILL]: wifi shut off power.
[   18.217108] dhdsdio_probe : the lock is released.
[   18.217254] dhd_module_init: Exit err=0
[   18.271225] [BT_RFKILL]: ENABLE UART_RTS
[   18.272912] dhd_ioctl_entry: Interface is down
[   18.375142] [BT_RFKILL]: DISABLE UART_RTS
[   18.375209] [BT_RFKILL]: bt turn on power
[   19.378670] zram: Added device: zram0
[   19.379676] zram: Added device: zram1
[   19.384036] zram: Added device: zram2
[   19.428153] zram1: detected capacity change from 0 to 1073741824
[   19.493650] Adding 1048572k swap on /dev/zram1.  Priority:5 extents:1 across:1048572k SSFS
[   19.666726] zram0: detected capacity change from 0 to 52428800
[   19.855414] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[   23.669615] nr_pdflush_threads exported in /proc is scheduled for removal
[   27.479395] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   27.575160] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   27.575365] dhd_open: Enter ffffffc0eb9c9000
[   27.575372] dhd_open : no mutex held. set lock
[   27.575383]
[   27.575390] wl_ext_iapsta_attach_netdev: ifidx=0, bssidx=0
[   27.575396] wl_android_wifi_on in 1
[   27.575401] wl_android_wifi_on in 2: g_wifi_on=0
[   27.575407] wifi_platform_set_power = 1
[   27.575412] ======== PULL WL_REG_ON(-1) HIGH! ========
[   27.575418] [WLAN_RFKILL]: rockchip_wifi_power: 1
[   27.575425] [WLAN_RFKILL]: wifi turn on power. -1
[   27.879172] sdio_reset_comm():
[   27.895220] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[   27.914627] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[   27.954986] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[   27.958039] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[   27.961075] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[   27.966592] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[   27.973340] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[   28.076547] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[   28.211404] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 219
[   28.211484] sdioh_start: set sd_f2_blocksize 256
[   28.211973]
               dhd_bus_devreset: == WLAN ON ==
[   28.212117] F1 signature read @0x18000000=0x17294359
[   28.216830] F1 signature OK, socitype:0x1 chip:0x4359 rev:0x9 pkg:0x2
[   28.217672] DHD: dongle ram size is set to 917504(orig 917504) at 0x160000
[   28.217758] dhd_bus_set_default_min_res_mask: Unhandled chip id
[   28.280451] dhd_os_open_image: /lib/firmware/brcm/config.txt (70 bytes) open success
[   28.296854] dhd_conf_read_pm_params: PM = 0
[   28.296872] dhd_conf_read_nv_by_chip: nv_by_chip_count=1
[   28.296878] dhd_conf_read_nv_by_chip: chip=0xa962, chiprev=1, name=nvram_ap6210.txt
[   28.296883] CONFIG-ERROR) dhd_conf_read_config: not a right parameter 43430 0 nvram_ap6212.txt
[   28.296905] Final fw_path=/lib/firmware/brcm/fw_bcm4359c0_ag.bin
[   28.296909] Final nv_path=/lib/firmware/brcm/nvram_ap6398s.txt
[   28.296913] Final clm_path=/lib/firmware/brcm/clm.blob
[   28.296916] Final conf_path=/lib/firmware/brcm/config.txt
[   28.297546] dhd_os_open_image: /lib/firmware/brcm/fw_bcm4359c0_ag.bin (604169 bytes) open success
[   28.430420] dhd_os_open_image: /lib/firmware/brcm/nvram_ap6398s.txt (5861 bytes) open success
[   28.436918] NVRAM version: AP6398S_NVRAM_V1.1_20170926
[   28.437622] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[   28.612970] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[   28.613019] si_get_pmu_reg_addr: addrRET: 18000670
[   28.613112] bcmsdh_oob_intr_register: HW_OOB irq=64 flags=0x4
[   28.613876] dhd_get_memdump_info: File [/data/misc/wifi/.memdump.info] doesn't exist
[   28.613883] dhd_get_memdump_info: MEMDUMP ENABLED = 2
[   28.614121] Disable tdls_auto_op failed. -1
[   28.614128] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 1
[   28.614490] dhd_apply_default_clm: Ignore clm file /lib/firmware/brcm/clm.blob
[   28.617299] Firmware up: op_mode=0x0405, MAC=28:ed:e0:e6:ab:9e
[   28.625688]   Driver: 1.579.77.41.10 (r)
                 Firmware: wl0: Aug  6 2018 16:57:33 version 9.87.51.11.18 (4ce23ed@shgit) (r) FWID 01-c6593a53
                 CLM: 9.7.5
[   28.625891] dhd_txglom_enable: enable 1
[   28.625897] dhd_conf_set_txglom_params: txglom_mode=copy
[   28.625901] dhd_conf_set_txglom_params: txglomsize=36, deferred_tx_len=0
[   28.625906] dhd_conf_set_txglom_params: txinrx_thres=128, dhd_txminmax=-1
[   28.625910] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=-1
[   28.625923] dhd_conf_get_disable_proptx: fw_proptx=0, disable_proptx=1
[   28.626919] dhd_pno_init: Support Android Location Service
[   28.653132] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23
[   28.653147] dhd_rtt_init : FTM is not supported
[   28.653153] dhd_preinit_ioctls: SensorHub diabled 0
[   28.653399] dhd_preinit_ioctls failed to set ShubHub disable
[   28.654415] failed to set WNM capabilities
[   28.654598] dhd_conf_set_country: set country CN, revision 38
[   28.657125] Country code: CN (CN/38)
[   28.658612] CONFIG-ERROR) dhd_conf_set_intiovar: txbf setting failed -23
[   28.658798] wl_android_wifi_on: Success
[   28.673385] dhd_open : the lock is released.
[   28.673394] dhd_open: Exit ret=0
[   29.558500] P2P interface registered
[   29.558522] wl_cfgp2p_add_p2p_disc_if: wdev: ffffffc0e8492400, wdev->net:           (null)
[   29.581009] WLC_E_IF: NO_IF set, event Ignored
[   29.582374] P2P interface started
[   29.617512] wl_run_escan: LEGACY_SCAN sync ID: 0, bssidx: 0
[   33.082546] wl_run_escan: LEGACY_SCAN sync ID: 1, bssidx: 0
[   36.263363] ttyS0 - failed to request DMA, use interrupt mode
[   36.279416] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   36.279437] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   36.279446] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   36.279454] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   36.279462] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   36.279470] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   40.543604] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   41.932554] fuse init (API version 7.23)
[   47.280281] [BT_RFKILL]: ENABLE UART_RTS
[   47.383220] [BT_RFKILL]: DISABLE UART_RTS
[   47.383288] [BT_RFKILL]: bt turn on power
[   51.154445] wl_run_escan: LEGACY_SCAN sync ID: 2, bssidx: 0
[   60.846724] wl_run_escan: LEGACY_SCAN sync ID: 3, bssidx: 0
[   62.105297] Connecting with d4:a0:2a:cd:30:0f ssid "Wifi-ECN", len (8) channel=40
[   62.105321] dhd_dbg_start_pkt_monitor, 1724
[   62.191863] wl_iw_event: Link UP with d4:a0:2a:cd:30:0f
[   62.191943] wl_bss_connect_done succeeded with d4:a0:2a:cd:30:0f
[   62.192205] CFG80211-ERROR) wl_cfg80211_scan_abort : scan abort  failed
[   62.263334] wl_bss_connect_done succeeded with d4:a0:2a:cd:30:0f vndr_oui: 00-40-96
[   68.543620] rk_gmac-dwmac fe300000.ethernet eth0: Link is Down
[   83.256883] Error getting the SSID
[   83.256928] Error getting the SSID
[   86.928863] Error getting the SSID
[  115.595517] [BT_RFKILL]: ENABLE UART_RTS
[  115.699211] [BT_RFKILL]: DISABLE UART_RTS
[  115.699332] [BT_RFKILL]: bt turn on power
[  130.986395] [BT_RFKILL]: bt shut off power
17 hours ago, jeanrhum said:
I installed the full firmware package, but wifi is not activated. After looking at dmesg, I saw that the firmware files were not present. So I downloaded from a github repo fw_bcm4359c0_ag.bin, nvram_ap6398s.txt and BCM4359C0.hcd and copy them to /lib/firmware/brcm/. I am now able to use wlan0.
EDGE uses its own version of firmware (it is not in the official Linux packages).
1.7 & 2.2 is the upper limit perhaps
...but it crashed after a while :-(
Edited by amirul
update
Wifi device not ready fix by copying from previous version fw_bcm4356a2_ag.bin & nvram_ap6356.txt into /lib/firmware/brcm
The new version of the images for RK3399 5.96_20190920.
Added support for NanoPC T4.
Added items for priority use of big cores.
Magicsee N6 Max stable with
MIN_SPEED=600000
MAX_SPEED=2208000
GOVERNOR=interactive
for /etc/default/cpufrequtils
2 hours ago, balbes150 said:
New image 5.98 for rk3399
"default" and "dev"
I'll stick with the default, coz dev does not have magicsee dtb in them
Default is core 4, and dev is core 5.
Add image NEXT 5.98 kernel 5.4.0-rc2
By the way, when switching to the screen resolution in the settings on 1920x1080, I have sound working through HDMI. :)
I checked the latest DEV and NEXT images on N6. The system starts and works with dtb rock-pi-4.  :)
Only need to wait 4-5 minutes until the system starts (a picture will appear on the screen).
By the way, I just checked, on N6 starts LE with 5 core, but you need to wait more than 5 minutes until the setup wizard starts. :)
New version 20191011 of Armbian and Libreelec with support to run from USB media on RK3399. :)
It makes it easy to test different systems without using SD card, using normal USB flash drives. Tested on EDGE. How to use USB start-up. There are two ways to use. Test, for the overall evaluation of the launch with USB on new models of TV boxes or SBC. You need to write a new image to the SD card (if necessary, configure the correct dtb), check the system startup on the device from the SD card. If everything works from an SD card, you need to write a test image of another system to a USB drive. i.e. if on an Armbian SD card, you need to write LE to a  USB system (if necessary, configure the correct dtb) or Vice versa. This is due to the peculiarities of testing, in real use there will be no such restriction. Connect both the SD card and USB flash drive to the device and turn on the power. After a few minutes, the system should start with a USB flash drive. If the system starts from the SD card, you need to check the USB flash drive connection to all available USB ports on the device in turn and check the start. On EDGE, only the USB 2.0 ports are working for now. For those who have the option, it would be interesting to check the operation of the USB launcher on other devices with RK3399.
I checked the system startup from USB to N6, everything starts and works. :)
To start you need to use the USB port which is to the right of the microSD card.
On EDGE, I checked the installation of new Armbian and LE versions in eMMC (with USB startup support). Everything works. :) Now I have a stable version of LE in eMMC and I can quickly and easily check new versions of Armbian and LE using regular cheap USB flash drives. I no longer need to look for many different SD cards (and having a card reader on a PC to write to) to quickly test different systems. :)
Armbian_5.98_Rk3399-tv_Ubuntu_bionic_next_5.4.0-rc2-next-20191009_desktop runs from sdcard on the N6 - no wifi though
@balbes150
I've tried with next bionic desktop and default bionic desktop. Both on an sd-card, but used a usb3 sd-card reader for one.  Changed the background to see the difference.
On the RockPi4. Both images work(hdmi works, no wifi in default). When having default in the RockPi4 it always boots the default, no matter where I put the sd-card reader with next.
With next in the rockpi4 and the sd-card reader in the bottom left usb3 port nothing seems to boot. The sd-reader turns on and flashes(doesn't do that in other ports). It doesn't seem to boot, display doesn't turn on. Flashing of sd-card reader stops after a few seconds, led stays on.
With the NanoPi M4V2 there's no .dtb file for the NanoPi M4(also not in Buster) in default. I've copied the one from NEXT. It seems to boot, but without hdmi(as that other person said in the M4V2 thread).
So I had the same behaviour as with the RockPi4. Only with next it seemed to boot from the sd-card reader. It even kept flashing as if it was booted. But since hdmi doesn't work on the default image I'm now not sure if it booted or just was stuck like the RockPi4.
I also tried with LE on the M4V2. That didn't boot into KODI. It did it reseize, rebooted. But stayed at the screen of just enough os for kodi without going further.
That also didn't seem to boot from USB. And also with LE in the M4V2 it didn't boot Armbian from USB.
I hope you're something with this information. It only made me more confused the longer I tried.
Great job. Very cool to be able to run from USB. And also great to be able to use the same image on different boards. You make the compatibillity so much better with this. Cheers.
