nasbdh9 Posted October 11, 2018 Posted October 11, 2018 I purchased a V7 version of ebin But after updating uboot, the reboot is still in stock uboot. Marvell>> bubt flash-image-1g-1cs-1000_800.bin spi usb Burning U-BOOT image "flash-image-1g-1cs-1000_800.bin" from "usb" to "spi" USB0: Register 2000104 NbrPorts 2 Starting the controller USB XHCI 1.00 USB1: USB EHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 1 for devices... 2 USB Device(s) found reading flash-image-1g-1cs-1000_800.bin Image checksum...OK! SF: Detected mx25u3235f with page size 256 Bytes, erase size 64 KiB, total 4 MiB 262144 bytes written, 593344 bytes skipped in 2.65s, speed 424017 B/s Done! Marvell>> TIM-1.0 TIM-1.0 TIM-1.0 WTMI-armada-17.10.5-bb8f823 WTMI: system early-init SVC REV: 4, CPU VDD voltage: 1.120V Fill memory before self refresh...done Now in Self-refresh Mode Exited self-refresh ... Self refresh Pass. DDR self test mode test done!! Vref read training =================== Final vdac_value 0x00000020 Vref write training =================== Final vref_value 0x0000001F DLL TUNING ============== DLL 0xc0001050[21:16]: [8,35,1e] DLL 0xc0001050[29:24]: [8,2b,19] DLL 0xc0001054[21:16]: [b,31,1e] DLL 0xc0001054[29:24]: [e,30,1f] DLL 0xc0001074[21:16]: [0,3f,1f] DLL 0xc0001074NOTICE: Booting Trusted Firmware NOTICE: BL1: v1.3(release):armada-17.10.3:39a62a1 NOTICE: BL1: Built : 15:40:57, Jun 1 2NOTICE: BL2: v1.3(release):armada-17.10.3:39a62a1 NOTICE: BL2: Built : 15:40:59, Jun 1 201NOTICE: BL31: v1.3(release):armada-17.10.3:39a62a1 NOTICE: BL31: U-Boot 2017.03-armada-17.10.2-g14aeedc (Jun 01 2018 - 15:39:10 +0800) Model: Marvell Armada 3720 Community Board ESPRESSOBin CPU @ 1000 [MHz] L2 @ 800 [MHz] TClock @ 200 [MHz] DDR @ 800 [MHz] DRAM: 1 GiB U-Boot DT blob at : 000000003f7161b8 Comphy-0: USB3 5 Gbps Comphy-1: PEX0 2.5 Gbps
Igor Posted October 11, 2018 Posted October 11, 2018 2 hours ago, nasbdh9 said: Marvell>> bubt flash-image-1g-1cs-1000_800.bin spi usb Where did you get that u-boot? It doesn't look ours. You need to start here: https://www.armbian.com/espressobin/
nasbdh9 Posted October 11, 2018 Author Posted October 11, 2018 32 minutes ago, Igor said: Where did you get that u-boot? It doesn't look ours. You need to start here: https://www.armbian.com/espressobin/ I downloaded it from dl.armbian.com/espressobin/u-boot/
ebin-dev Posted October 11, 2018 Posted October 11, 2018 3 hours ago, nasbdh9 said: U-Boot 2017.03-armada-17.10.2-g14aeedc (Jun 01 2018 - 15:39:10 +0800) Your u-boot was not provided by Armbian - you can convince yourself by comparing it to the ones in the Archive (yours was compiled on June 1st, in timezone GMT +8 ...). Your EspressoBin is equipped with a Macronix SPI - if you need to rescue it start from here or here. 1
Igor Posted October 11, 2018 Posted October 11, 2018 1 hour ago, ebin-dev said: Your EspressoBin is equipped with a Macronix SPI Last u-boot builds should have support for Macronix OOTB, right?
skandalfo Posted October 11, 2018 Posted October 11, 2018 22 minutes ago, Igor said: Last u-boot builds should have support for Macronix OOTB, right? That's what I tested, but to be completely sure I'll check the test logs I published in the other thread to make sure the printed build date got updated. If the flashed file turns out to be Armbian's, my only theory is that the factory bootloader recognises the Macronix chip but somehow fails to update its contents (so that the factory bootloader remains unchanged). That could be fixed by reflashing from an UART-downloaded image.
ebin-dev Posted October 11, 2018 Posted October 11, 2018 1 hour ago, Igor said: Last u-boot builds should have support for Macronix OOTB, right? Yes - it was confirmed at least by FoodGenius in the parallel thread (see here - below the EDIT).
skandalfo Posted October 11, 2018 Posted October 11, 2018 Yeah, I also got versions/dates like the ones here after I successfully flashed via UART download + bubt: TIM-1.0 WTMI-devel-18.07.0-6050fd5 WTMI: system early-init SVC REV: 5, CPU VDD voltage: 1.155V NOTICE: Booting Trusted Firmware NOTICE: BL1: v1.5(release):711ecd3 (Marvell-armada-18.09.4) NOTICE: BL1: Built : 15:13:47, Sep 7 2018 NOTICE: BL1: Booting BL2 NOTICE: BL2: v1.5(release):711ecd3 (Marvell-armada-18.09.4) NOTICE: BL2: Built : 15:13:50, Sep 7 2018 NOTICE: BL1: Booting BL31 NOTICE: BL31: v1.5(release):711ecd3 (Marvell-armada-18.09.4) NOTICE: BL31: Built : 15:1 U-Boot 2017.03-armada-18.09.1-ga92bd86-armbian (Sep 05 2018 - 21:49:34 +0200) Model: Marvell Armada 3720 Community Board ESPRESSOBin CPU 1000 [MHz] L2 1000 [MHz] NB AXI 250 [MHz] SB AXI 250 [MHz] DDR 800 [MHz] DRAM: 2 GiB U-Boot DT blob at : 000000007f7142d8 Comphy chip #0: Comphy-0: USB3 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 6 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link up MMC: sdhci@d0000: 0 SF: Detected mx25u3235f with page size 256 Bytes, erase size 64 KiB, total 4 MiB Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0 Marvell>>
ebin-dev Posted October 14, 2018 Posted October 14, 2018 @nasbdh9 It would appear that your 1g-1cs EspressoBin (V7_0-2) is equipped with DDR4 RAM. Could you post an image of the RAM chip ?
nasbdh9 Posted October 14, 2018 Author Posted October 14, 2018 32 minutes ago, ebin-dev said: @nasbdh9 It would appear that your 1g-1cs EspressoBin (V7_0-2) is equipped with DDR4 RAM. Could you post an image of the RAM chip ? Samsung K4A8G165WB-BCRC
ebin-dev Posted October 14, 2018 Posted October 14, 2018 Bingo! It is an 8gb DDR4 chip with 2400 Mbps (see here). All current Armbian flash-images-18.09 are for EspressoBins with DDR3 DRAM only.
kostap Posted October 20, 2018 Posted October 20, 2018 There are some nice upgrades in this v7 board design, like the new SATA connector. However the FW image is based on old Marvell 17.10 LSP. Since the new DDR4 layout is only included in Globalscale in-house FW images, the official Marvell LSP has no support for the new DDDR4 layouts yet. Marvell asked Globalscale team to upgrade their base to 18.09. If it happens, it will be much easier to add these new layouts to the official LSP and to the mainline sources. FYI - the A3700 support pull request is under review @ TF-A right now. Once it gets merged, you will be able to try the new TF-A v2.0. Unfortunately this PR code supports only DDR3-based EspressoBin for now.
JDL Posted December 13, 2018 Posted December 13, 2018 I also have a ESPRESSObin v7 board, but I can't find any OS image to use for even basic testing. Does anyone know where I can get this? GlobalScale is not responding to emails.
ebin-dev Posted December 13, 2018 Posted December 13, 2018 GlobalScale has published some stuff for the V7 EspressoBin here and here (based on the version 17.x bootloader). May be that is useful for you. Armbian uses the 18.x branch of the bootloader and the environment settings are adapted to it. Updated sources of the 18.x bootloader with support for the V7 EspressoBin are expected to be published by Marvell some time soon and updated versions of Armbian and the corresponding bootloader images for V7 EspressoBins will follow.
JDL Posted December 13, 2018 Posted December 13, 2018 Yes, I noticed that. I have the board up with their rootfs on 4.4.52 so I can at least test some things.
ebin-dev Posted December 26, 2018 Posted December 26, 2018 @nasbdh9 @JDL : the new boot loader 18.12 is available now. See the parallel thread.
