root@rockpi:~# dmesg|grep serial
[    1.965909] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[    1.969249] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A
[    1.972774] ff370000.serial: ttyS1 at MMIO 0xff370000 (irq = 41, base_baud = 1500000) is a 16550A
what pin is "ttyS0" ?
when "okay"
serial@ff1b0000 {
        pinctrl-0 = < 0x42 >;
        status = "disabled";
        phandle = < 0xd9 >;
network fall
1 hour ago, atula said:
serial@ff1b0000 {
This UART is UART3, and according to DT, it is pins GPIO3_B6 and GPIO3_B7 ...
But be aware that those pins are used on most of the boards for the Ethernet GMAC !
Since we still don't have access to RockPi4B schematic, it is a bit hard to confirm ...
If you are looking for serial@ff180000, it is UART0, than the pins are GPIO2_C0 and GPIO2_C1, which on some board is a UART connected to BlueTooth.
If you are looking at the UART available on Header at usual pin 8/10, it is GPIO4_C3 and GPIO4_C4, which is the UART2 located in node serial@ff1a0000.
what pin is w1 default pin ?
The rockchip-w1-gpios.dtbo overlay has it hard coded to GPIO1_A4, which is available on both RockPro64 and NanoPCT4, but unfortunately not availaible on RockPi4B ...
For RockPi4B, you will have to either do yourself a custom build with a patch that change this pin, or decompile/edit/recompile de overlay itself.
In longer terms, I will try to make the "param_w1_pin" available and working in /boot/armbianEnv.txt, but it can take while ...
Finally, the "param_w1_pin" management task didn't took too long ... ;)
Commits needed :
https://github.com/armbian/build/commit/aba46df74255c7684112a921014dab75bafd3414
https://github.com/armbian/build/commit/e4e34c7f15b33a3a186033a0c40555c208f035ee
I've tested it by providing "param_w1_pin=GPIO4_C5"  as an alternate pin on RockPro64, and it is now working ... :rolleyes:
EDIT : additional commits for other RK3399 boards have been added ...
w1 works "param_w1_pin=GPIO4_D5"  ok
how to find i2c
root@rockpi:~# dmesg|grep i2c
[    1.543735] i2c /dev entries driver
and
root@rockpi:~# ls /dev/*i2c*
/dev/i2c-0  /dev/i2c-1	/dev/i2c-3  /dev/i2c-4
i2cdetect find nothing
Which I2C are you using, the one on the RockPi Header ? It is I2C7, which need the new overlay just committed ...
Which device did you connect to that bus ?
GPIO2_A7, GPIO2_B0,  like raspberry
or GPIO2_A0, GPIO2_A1
or ?
BMP280, ds2482, ds2483 and ADS115...
i have two, rockpi4a and rockpi4b, how i repare MAC adress
or ?
Right ! I2C7 is on GPIO2_A7/GPIO2_B0 ... (but what do you mean by "like raspberry" ?)
What do you mean ?
two same addresses do not work on the same network, the other must be different (dhcp IP)
"/dev/i2c-0 /dev/i2c-1 /dev/i2c-3 /dev/i2c-4" none is working
I understand, but are those two RockPi has the same MAC ?
As I said, the I2C on the RockPi header are not one of those, it is I2C7 ! You need to enable it either in Main DT or using a overlay for the node i2c@ff160000
yes, in all RockPi image use the same MAC. in radxa rock it modify in "parameter" txt, raspberry also
WD Black 500GB, PCIe, 3400/2500 MB/s - SSD- M.2 works  only Armbian_5.67_Rockpi4b_Debian_stretch_default_4.4.154_desktop_20181210-gpt.img.gz
i'll test later other (Kingston 240GB A1000, PCIe NVMe, 1500/1000 MB/s -SSD) SSD disks, other armbian images not working this M.2 SSD disk
Armbian_5.73.190128_Rockpi-4b_Debian_stretch_dev_4.20.0.img PCIe NVMe not work
can i download Armbian_5.67_Rockpi4b_Debian_stretch_default_4.4.154_desktop_20181210-gpt.img.gz without a desktop this img?
That is normal that RockPi-4B doesn't work with PCIe, it is not part of current DT !
Maybe in the future ...
i have rockpi 4 A model without bluetooth, its possible  use serial@ff180000 UART0  gpio like  GPIO4_D5,  (RX)
What do you mean ?
I don't have Model A schematic ... Is the GPIO2_C0/GPIO2_C1 are available on some header pins ? ... It is not the case for Model B ...
On 3/1/2019 at 4:32 PM, martinayotte said:
You need to install DT compiler from : http://ftp.debian.org/debian/pool/main/d/device-tree-compiler/device-tree-compiler_1.4.7-3_arm64.deb
Backup /boot/dtb/rockchip/rk3399-rockpi4b.dtb into /boot/dtb/rockchip/rk3399-rockpi4b.dtb-ORIG
Decompile the DTB into DTS :
dtc -@ -I dtb -O dts -o rk3399-rockpi4b.dts-4.20.0 /boot/dtb/rockchip/rk3399-rockpi4b.dtb
Edit the file rk3399-rockpi4b.dts-4.20.0 by changing all the serial node from "disabled" to "okay", then recompile DTB :
dtc -@ -I dts -O dtb -o /boot/dtb/rockchip/rk3399-rockpi4b.dtb rk3399-rockpi4b.dts-4.20.0
2
Thank you very much, this helped a lot!
some details who may help others: (note: I'm not an expert)
install DT compiler version from the above link, not from online mirrors.
to do so cd into temp directory, curl or wget the above url and chown +x the file as executable
Then install with apt
cd /tmp
wget http://ftp.debian.org/debian/pool/main/d/device-tree-compiler/device-tree-compiler_1.4.7-3_arm64.deb
sudo chmod +x device-tree-compiler_1.4.7-3_arm64.deb
sudo apt install device-tree-compiler_1.4.7-3_arm64.deb
decompile DTB to DTS as mentioned above.
open the decompiled file and lookup for the interface in the aliases section (e.g. i2c7)
You will find the address (e.g. i2c@ff160000)
scroll down now to this address and verify that status is set to okay
status = "okay";
if not change and re-compile to DTB
As I'm not an expert I wonder if it's possible to change or increase the i2c baudrate to 400 kHz ?
I found descriptions to add
dtparam=i2c_arm=on,i2c_baudrate=400000
to /boot/config.txt
As Armbian hasn't this config file I tried to add the same line to /boot/armbianEnv.txt but it doesn't seem to have any effect.
cd /tmp
sudo chown +x device-tree-compiler_1.4.7-3_arm64
The normal way to install is to do "dpkg -i device-tree-compiler_1.4.7-3_arm64.deb" ...
It should be done within the DT using "clock-frequency = <400000>;" in the i2c node, nearby the "status"
perfect solution. works fine. thank you!
For thus who try to C&P the above clock-frequency string: Attention it contains non-standard space chars after the number. So compiling to dtb fil fail with an error. Better use
Armbian_5.88_Rockpi-4b_Debian_stretch_default_4.4.180
i not find /boot/dtb/rockchip/overlay
i try armbianEnv.txt
overlays=w1-gpio
param_w1_pin=GPIO4_D2
and
root@rockpi:/# lsmod
Module                  Size  Used by
w1_therm               16384  0
w1_gpio                16384  0
wire                   32768  2 w1_gpio,w1_therm
but nothing /sys/bus/w1/devices/
Somebody needs to develop this feature, but since relation between developers and users wishes are extremely extreme, you can't use this feature unless you do it.
Here https://github.com/armbian/sunxi-DT-overlays you can observe overlays project made for Allwinner chips. As an example.
Debian Buster with Armbian Linux 4.4.184-rockchip64
dev/ttyS2 , dev/ttyS4 not works, only read
dev /ttyUSB0 woks fine
root@rockpi:~# digitemp_DS9097U -i -s /dev/ttyS4 -c digitemp.conf
DigiTemp v3.7.2 Copyright 1996-2018 by Brian C. Lane
GNU General Public License v2.0 - http://www.digitemp.com
Error 5: DS2480B Adapter Not Detected
Error 10: Read COM Failed
root@rockpi:~# digitemp_DS9097U -i -s /dev/ttyUSB0 -c digitemp.conf
Turning off all DS2409 Couplers
Searching the 1-Wire LAN
28208071030000A0 : DS18B20 Temperature Sensor
ROM #0 : 28208071030000A0
owfs works i2c adapter but not serial DS2480B, digitemp also.......maybe old systems
passive readers works both ...ttyS2 and ....ttyS4
and onewire works also now
serialport /dev/ttyS4 problem is boot. when reconnect tx cable or ds2480 pover after boot it works.
problem is only armbian
maybe on board SPI1 W25Q64F***.....?
Kingston 240GB A1000 SSD,
Samsung 250GB 970 EVO Plus SSD-levy, M.2 2280, PCIe 3.0 x4, NVMe, 3500/2300 MB/s,
XPG GAMMIX S5 PCIe Gen3x4 M.2 2280 512 works
not support Intel 512GB 660P 1500/1000 MB/s -SSD- M.2, not find it
linaro-alip 4.4.154 works and boot Intel 512GB 660P 1500/1000 MB/s -SSD- M.2 from spi
XPG GAMMIX S5 PCIe Gen3x4 M.2 2280 512 boot also spi but not stabile
Samsung 250GB 970 EVO Plus SSD-, M.2 2280, PCIe 3.0 x4, NVMe, 3500/2300 MB/s,
not boot spi
