How to force resize of SD partition?
Go to solution Solved by F4VSJ,
Hello, please help
I moved ARMBIAN 5.60 stable Debian GNU/Linux 8 (jessie) 3.4.113-sun8i from 2Gb SD to 16Gb and cant do resize i tried everthing from others topics but it does not work anymore!
(i need 3.4.113 for acpid)
I put this scipt into /etc/init.d but it does not work
sudo sh ./resize2fs start
[....] Starting resize2fs (via systemctl): resize2fs.serviceJob for resize2fs.service failed. See 'systemctl status resize2fs.service' and 'journalctl -xn' for details.
 failed!
normally (when moving manually from a small to a bigger sdcard) İ do the following:
fdisk /dev/myospartition
d for delete the partition
n for new primary partition
set size to 95% of the max sector/cluster
set partition type to 83 linux
(leave ext4 marker intact = dont delete)
set boot flag for partition
w for write and exit
(os will use the old partition data until reboot)
reboot
After reboot at commandline:
resize2fs /dev/myospartition
Thank you but its to complicated(for me), but i just resized it in Gparted(on pc with Ubuntu) and it works!
I wish to have some script for that in Armbian (like in Lubuntu)
Welcome to ARMBIAN 5.60 stable Debian GNU/Linux 8 (jessie) 3.4.113-sun8i
System load:   1.00 0.28 0.09      Up time:       0 min
Memory usage:  7 % of 1000MB     IP:            192.168.1.229
CPU temp:      30°C
Usage of /:    9% of 14G
[ General system configuration (beta): armbian-config ]
Last login: Mon Nov 12 20:16:45 2018 from 192.168.1.214
root@orangepipcplus:~# resize2fs /dev/mmcblk0p1
resize2fs 1.42.12 (29-Aug-2014)
The filesystem is already 3711232 (4k) blocks long.  Nothing to do!
I have the same problem
I cannot resize the fs to the larger SD card
neither the command
update-rc.d firstrun defaults
works, it returns
update-rc.d: error: unable to read /etc/init.d/firstrun
nor the above mentioned resite2fs, it retirnes the above mentioned "Nothing to do!"
Thanks for any help
Rainer
  • Solution
It's easy and works for all the Orange Pi and pc
run the following script
enter the exact text below in a terminal (as root)
#  /etc/init.d/resize2fs start
wait 1 minute
reboot
login
and again as root:
and check with:
#  fdisk -l
Than you will see the partition has the size of the whole sd card
I did it already with a bunch of systems, not hundreds but 40-50...
hans f4vsj
3 hours ago, Whoo said:
I wish there could be tool in armbian-config to resize partion(s) on SD card and other disk like raspberry pi config tool has.
Armbian is more advanced then Rpi OS. It resizes SD card automatic on 1st boot.
sudo wget https://raw.githubusercontent.com/canonical/cloud-utils/main/bin/growpart -P /usr/local/bin/
sudo chmod +x /usr/local/bin/growpart
# assuming we are resizing an ext4 partition "/dev/mmcblk1p1":
sudo growpart /dev/mmcblk1 1
sudo resize2fs /dev/mmcblk1p1
