GeorgeL Posted November 20, 2018 Posted November 20, 2018 Hi, I setup armbian version 5.6 (Ubuntu 16.04.5 Xenial) on OrangePI PC. Working long time without problem. But after power failure I found that directories in /var/run have bad permissions and some daemons won't start. After investigation I found failure start of systemd-tmpfiles: systemd-tmpfiles[210]: Failed to fstat() file /dev/btrfs-control: Bad file descriptor systemd-tmpfiles[210]: Failed to fstat() file /dev/net: Bad file descriptor systemd-tmpfiles[210]: Failed to fstat() file /dev/net/tun: Bad file descriptor I setup debug loglevel and got this: systemd-tmpfiles[210]: Failed to fstat() file /dev/btrfs-control: Bad file descriptor systemd-tmpfiles[210]: Running create action for entry d /dev/net systemd-tmpfiles[210]: Created directory "/dev/net". systemd-tmpfiles[210]: Failed to fstat() file /dev/net: Bad file descriptor systemd-tmpfiles[210]: Running create action for entry c /dev/net/tun systemd-tmpfiles[210]: Created char device node "/dev/net/tun" 1:128. systemd-tmpfiles[210]: Failed to fstat() file /dev/net/tun: Bad file descriptor Corrupted filesystem? I created /forcefsck and reboot. But /dev directory is not on root filesystem and is dynamicaly created. I apologize for my English, Thanks.
drapas Posted November 21, 2018 Posted November 21, 2018 I have the same trouble with build to NanoPi Duo (Armbian 5.67), have any solution?
Igor Posted November 21, 2018 Posted November 21, 2018 39 minutes ago, drapas said: the same trouble How is the same? I am producing images every day (not exactly for Nanopi duo but still) and haven't seen any troubles.
Sann-X! Posted November 21, 2018 Posted November 21, 2018 Hi, I have two orange pi zero devices. But I can't log in via putty to both devices. There is connection refused error. Syslog contains this line: Nov 21 09:15:43 localhost sshd[996]: Missing privilege separation directory: /var/run/sshd But if I create this dir manually, ssh starts fine.. until next boot. I suppose it happens because 'systemd-tmpfiles-setup' service start failed at system boot: [FAILED] Failed to start Create Volatile Files and Directories. See 'systemctl status systemd-tmpfiles-setup.service' for details. Also before this message the boot log contains these lines: .. [FAILED] Failed to start Load Kernel Modules. See 'systemctl status systemd-modules-load.service' for details. .. [FAILED] Failed to start Create Static Device Nodes in /dev. See 'systemctl status systemd-tmpfiles-setup-dev.service' for details. .. The first device has ARMBIAN 5.60 stable Ubuntu 16.04.5 LTS 3.4.113-sun8i, the second - ARMBIAN 5.35 user-built Ubuntu 16.04.3 LTS 3.4.113-sun8i How to fix it?
Igor Posted November 21, 2018 Posted November 21, 2018 Moved to SD card troubles section. Very little chances that this problem has anything to do with Armbian.
Sann-X! Posted November 21, 2018 Posted November 21, 2018 1. h2tesw test finished without errors. 2. I wrote Armbian 5.35 image. Change root pswd, reboot. SSH is ok. 3. Then unattended upgrades are run. After upgrading the OS has 5.60 ver. Reboot. And now SSH service start failed at system boot. I can't log in via putty. Why so?
AlexTochka Posted November 21, 2018 Posted November 21, 2018 (edited) Similarly, on Orange Pi One and CubieTruck. The sshd cannot find the /var/run/sshd folder, it simply does not exist. After creating the folder and starting the service, everything works until the reboot. And after a reboot, the same thing again: sshd cannot find the /var/run/sshd folder... Orange Pi One works on uSD card, but CubieTruck works on SATA SSD. Edited November 21, 2018 by AlexTochka
AlexTochka Posted November 21, 2018 Posted November 21, 2018 2 hours ago, Igor said: Very little chances that this problem has anything to do with Armbian. I doubt very much that he has not.
Igor Posted November 21, 2018 Posted November 21, 2018 We use stock Debian/Ubuntu SSH settings and only keys are being recreated at 1st boot. Without armbianmonitor -u there is little I can tell.
Sann-X! Posted November 21, 2018 Posted November 21, 2018 I'll check this answer tomorrow at my work.
Igor Posted November 21, 2018 Posted November 21, 2018 3 hours ago, AlexTochka said: http://ix.io/1u5F armbianmonitor -u Good news is that everything looks O.K. and bad news is that I have no idea why this is so. It must have been some upstream change. Let's wait for others input.
AlexTochka Posted November 22, 2018 Posted November 22, 2018 http://ix.io/1u8S armbianmonitor -u from another device - CubieTruck.
Igor Posted November 22, 2018 Posted November 22, 2018 It is most likely upstream Ubuntu problem since we haven't change anything in Xenial for a very long time.
Igor Posted November 22, 2018 Posted November 22, 2018 4 hours ago, AlexTochka said: from another device - CubieTruck. And again Ubuntu Xenial which could and is most likely broken upstream. We can't do anything about that.
Sann-X! Posted November 22, 2018 Posted November 22, 2018 I found issue trigger. After this upgrade: Packages that will be upgraded: libnss-myhostname libpam-systemd libpython2.7-minimal libpython2.7-stdlib libpython3.5 libpython3.5-minimal libpython3.5-stdlib libsystemd0 libudev1 linux-libc-dev python2.7 python2.7-minimal python3.5 python3.5-minimal systemd systemd-sysv udev the 'systemd-tmpfiles-setup' service start failed at system boot.
Sann-X! Posted November 22, 2018 Posted November 22, 2018 It's a new common linux issue: Nov 12 Redhat https://access.redhat.com/solutions/1519263 Nov 21 Ubuntu https://askubuntu.com/questions/1094776/systemd-tmpfiles-wont-start
AlexTochka Posted November 22, 2018 Posted November 22, 2018 26 minutes ago, Igor said: And again Ubuntu Xenial which could and is most likely broken upstream. We can't do anything about that. There is no such problem on x86. Probably some kind of build problem for ARM.
Igor Posted November 22, 2018 Posted November 22, 2018 3 minutes ago, AlexTochka said: There is no such problem on x86. Probably some kind of build problem for ARM. Well, we have to wait that problems are solved upstream.
Igor Posted November 22, 2018 Posted November 22, 2018 I noticed that both Ubuntu's are breaking building. Perhaps that is related.
drapas Posted November 22, 2018 Posted November 22, 2018 I builded image with legacy kernel and Xenial desktop using armbian build tools (5.67). I get following boot log: Spoiler Quote U-Boot SPL 2018.05-armbian (Nov 21 2018 - 11:13:04 +0500) DRAM: 256 MiB Trying to boot from MMC1 U-Boot 2018.05-armbian (Nov 21 2018 - 11:13:04 +0500) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: FriendlyARM NanoPi DUO Air DRAM: 256 MiB MMC: SUNXI SD/MMC: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** Failed (-5) In: serial Out: serial Err: serial Net: No ethernet found. 230454 bytes read in 31 ms (7.1 MiB/s) Unknown command 'bmp' - try 'help' starting USB... No controllers found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3684 bytes read in 10 ms (359.4 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 142 bytes read in 8 ms (16.6 KiB/s) ** File not found /boot/uInitrd ** 4654472 bytes read in 371 ms (12 MiB/s) Found legacy kernel configuration 35384 bytes read in 24 ms (1.4 MiB/s) Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid SCRIPT FAILED: continuing... starting USB... No controllers found USB is stopped. Please issue 'usb start' first. starting USB... No controllers found No ethernet found. missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-sunxi No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default No ethernet found. Config file not found starting USB... No controllers found No ethernet found. Environments and mmc/boot folder consist of: Spoiler Quote => ls mmc 0:1 /boot <DIR> 4096 . <DIR> 4096 .. <SYM> 17 script.bin <SYM> 21 zImage <DIR> 4096 bin <DIR> 4096 overlay-user 1536 armbian_first_run.txt.template 2043391 System.map-3.4.113-sun8i 142 armbianEnv.txt 97193 config-3.4.113-sun8i 4882 boot-desktop.png 230454 boot.bmp 3612 boot.cmd 3684 boot.scr 5220352 initrd.img-3.4.113-sun8i 4654472 vmlinuz-3.4.113-sun8i 5220288 initrd.img-3.4.113-sun8i.dpkg-bak => printenv arch=arm baudrate=115200 board=sunxi board_name=sunxi boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr} boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf boot_net_usb_start=usb start boot_prefixes=/ /boot/ boot_script_dhcp=boot.scr.uimg boot_scripts=boot.scr.uimg boot.scr boot_targets=fel mmc0 usb0 pxe dhcp bootargs=root=UUID=ed18df55-26a6-4886-97bb-4732a8387081 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=afcd1551-01 ubootsource=mmc usb-storage.quirks= sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 bootcmd=run distro_bootcmd bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi; bootcmd_fel=if test -n ${fel_booted} && test -n ${fel_scriptaddr}; then echo '(FEL boot)'; source ${fel_scriptaddr}; fi bootcmd_mmc0=setenv devnum 0; run mmc_boot bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi bootcmd_sunxi_compat=setenv root /dev/mmcblk0p3 rootwait; if ext2load mmc 0 0x44000000 uEnv.txt; then echo Loaded environment from uEnv.txt; env import -t 0x44000000 ${filesize}; fi; setenv bootargs console=${console} root=${root} ${extraargs}; ext2load mmc 0 0x43000000 script.bin && ext2load mmc 0 0x48000000 uImage && bootm 0x48000000 bootcmd_usb0=setenv devnum 0; run usb_boot bootdelay=1 bootfstype=ext4 bootm_size=0xa000000 console=both consoleargs=console=ttyS0,115200 console=tty1 cpu=armv7 devnum=0 devplist=1 devtype=mmc dfu_alt_info_ram=kernel ram 0x42000000 0x1000000;fdt ram 0x43000000 0x100000;ramdisk ram 0x43300000 0x4000000 disp_mem_reserves=off disp_mode=1920x1080p60 distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done docker_optimizations=on ethaddr=02:42:5a:ab:f9:d4 fdt_addr_r=0x43000000 fdtcontroladdr=4bf4f0a0 fdtfile=sun8i-h2-plus-nanopi-duo.dtb fileaddr=43000000 filesize=8a38 initrd_high=0xFFFFFFFF kernel_addr_r=0x42000000 load_addr=0x44000000 loadsplash= for prefix in ${boot_prefixes}; do if test -e mmc 0 ${prefix}boot.bmp; then load mmc 0 ${splashimage} ${prefix}boot.bmp; bmp d ${splashimage}; fi; done mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi mmc_bootdev=0 overlay_error=false overlay_prefix=sun8i-h3 overlays=usbhost2 usbhost3 partitions=name=loader1,start=8k,size=32k,uuid=${uuid_gpt_loader1};name=loader2,size=984k,uuid=${uuid_gpt_loader2};name=esp,size=128M,bootable,uuid=${uuid_gpt_esp};name=system,size=-,uuid=${uuid_gpt_system}; partuuid=afcd1551-01 preboot=run loadsplash; usb start pxefile_addr_r=0x43200000 ramdisk_addr_r=0x43300000 rootdev=UUID=ed18df55-26a6-4886-97bb-4732a8387081 rootfstype=ext4 scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done; scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done scriptaddr=0x43100000 serial#=02c000425aabf9d4 soc=sunxi splashimage=66000000 splashpos=m,m stderr=serial stdin=serial,usbkbd stdout=serial usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi uuid_gpt_esp=c12a7328-f81f-11d2-ba4b-00a0c93ec93b uuid_gpt_system=69dad710-2ce4-4e3c-b16c-21a1d49abed3 verbosity=1 Environment size: 4266/131068 bytes When i build image for Orange Pi Zero and NanoPi M1+ all fine.
Igor Posted November 22, 2018 Posted November 22, 2018 4 minutes ago, drapas said: I builded image with legacy kernel and Xenial desktop using armbian build tools Upstream problems. Not possible to build Ubuntu ATM.
drapas Posted November 22, 2018 Posted November 22, 2018 27 minutes ago, Igor said: Upstream problems. Not possible to build Ubuntu ATM. I didn't understand exactly how it influence to boot?
Igor Posted November 22, 2018 Posted November 22, 2018 13 minutes ago, drapas said: I didn't understand exactly how it influence to boot? Me neither but its pretty irrelevant. I noticed that building of Ubuntu(s) is/are failing with lots of errors and systemd has this issue. It is highly possible that this is related. I can give you detail report in a few weeks, but then it will be irrelevant again.
Igor Posted November 22, 2018 Posted November 22, 2018 5 hours ago, Igor said: failing with lots of errors In case you were installing INSTALL_HEADERS="yes" you could run out of space. Affected Ubuntu builds and was fixed. But this systemd problem remains.
RenatoLorenzi Posted November 22, 2018 Posted November 22, 2018 I have several orangepi with this problem. Looking better I saw that the systemd was updated and after that the problem started. From version 229-4ubuntu21.2 to 229-4ubuntu21.9. I also found this to follow: https://bugs.launchpad.net/ubuntu/+source/systemd/+bug/1804603 I'm using ARMBIAN 5.38 stable Ubuntu 16.04.4 LTS 3.4.113-sun8i.
guidol Posted November 22, 2018 Posted November 22, 2018 14 hours ago, Igor said: It is most likely upstream Ubuntu problem since we haven't change anything in Xenial for a very long time. it is "beastly" when I say "I know why I prefer the debian stretch version of armbian"?
fvgenn Posted November 22, 2018 Posted November 22, 2018 does anyone tried to downgrade systemd-related packages
fvgenn Posted November 22, 2018 Posted November 22, 2018 did it! # apt list | grep systemd |grep "[" libpam-systemd/xenial-security,xenial-updates,xenial-security,xenial-updates,now 229-4ubuntu21.9 armhf [установлен] libsystemd0/xenial-security,xenial-updates,xenial-security,xenial-updates,now 229-4ubuntu21.9 armhf [установлен] systemd/xenial-security,xenial-updates,xenial-security,xenial-updates,now 229-4ubuntu21.9 armhf [установлен] systemd-sysv/xenial-security,xenial-updates,xenial-security,xenial-updates,now 229-4ubuntu21.9 armhf [установлен] # apt list -a systemd systemd/xenial-security,xenial-updates,xenial-security,xenial-updates,now 229-4ubuntu21.9 armhf [установлен] systemd/xenial,xenial 229-4ubuntu4 armhf # apt-get install libpam-systemd=229-4ubuntu4 libsystemd0=229-4ubuntu4 systemd=229-4ubuntu4 systemd-sysv=229-4ubuntu4
