C3MX Posted September 20, 2018 Posted September 20, 2018 Hi Guys, I also want to run my TV box with linux (Armbian). To install IObroker. It worked on the SD card. About Armbian I flashed the EMCC again so I do not need an SD card anymore. After a reboot, nothing worked anymore Armbian on the EMCC also not on the SD card. Connecting via USB to the PC does not work either. Can I flash it all over RX and TX? Does one have an idea? Thank you
guidol Posted September 20, 2018 Posted September 20, 2018 Maybe you could find a eMMC image and use RKBatch Tool to reflash the eMMC with the right partitions.... something like the last one in this thread: http://freaktab.com/forum/tv-player-support/rockchip-based-tv-players/rk3328-devices/673798-searching-help-for-my-a5x-max-rk3328
balbes150 Posted September 21, 2018 Posted September 21, 2018 11 hours ago, C3MX said: About Armbian I flashed the EMCC again so I do not need an SD card anymore What image was used and what installation steps were performed in eMMC ?
C3MX Posted September 22, 2018 Author Posted September 22, 2018 I used the Armbian_5.59_Rock64_Ubuntu_bionic_default_4.4.152 image. I'm not coming to the eMMC. In the case of the Orangepi, it worked that way via the Ambrian config thanks
C3MX Posted September 22, 2018 Author Posted September 22, 2018 On 9/20/2018 at 10:30 PM, guidol said: Maybe you could find a eMMC image and use RKBatch Tool to reflash the eMMC with tge right partitions.... something like the last one in this thread: http://freaktab.com/forum/tv-player-support/rockchip-based-tv-players/rk3328-devices/673798-searching-help-for-my-a5x-max-rk3328 I've already read and done that. But the Tv box still does not boot. Thanks
jeanrhum Posted September 22, 2018 Posted September 22, 2018 Surely a stupid question, but is your psu working well ? and do you use the right usb port when use connect to pc?
xiles89 Posted December 31, 2018 Posted December 31, 2018 Hi everyone, I am new to Armbian and trying to get the A5X Max box working. So far pretty unsuccessful. So far it doesn't boot anything with a as card inserted. Neither Android (which is good I guess) nor Armbian. Can one of the people running the box give me a hint?
balbes150 Posted January 8, 2019 Posted January 8, 2019 On 12/31/2018 at 12:08 PM, xiles89 said: So far it doesn't boot anything with a as card inserted. Neither Android (which is good I guess) nor Armbian. Can one of the people running the box give me a hint? What image was used ?
