After installation of the media script, I experience very slow window dragging, i. e. moving a window is laggy and delayed - the mouse is faster and the window follows only very slowly. Do you experience the same?
"Enable display compositing" in Window Manager Tweaks is disabled as advised. Enabling "Hide the content of the window while moving" in Window Manager Advance settings at least speeds up moving windows a little bit, but not much.
Is this normal behavior or is there anything I can do to improve display performance?
@mar0ni - yes this is normal behaviour i think as there is some inefficient memory copying happening between the gpu and the x server and there is no proper 2d acceleration (used for such window moves) around ... but i guess @JMCC can explain it in more detail ...
best wishes - hexdump
Yes, it is a known issue with glamor, that instead of "accelerating" it slows down certain 2D operations. In the case of Rockchip's modified glamor to work with OpenGL-ES, It is even worse. It is the trade-off for having the possibility of an accelerated canvas for 3D, video playing, browser, etc.
However, in the mainline kernel and current X server, they are tweaking glamor to be much more efficient. Hopefully we can see a stable version soon.
Thanks for clarification :thumbup:. I have read this in your first post's documentation and therefor chose "amsoc" during installation. It seems that armsoc is also not that snappy, but good to know that glamor is even worse. Let's hope mainline with a current X server arrives soon :)
The script is not compatible with Armbian 20.02.0-rc1, as the Kodi uses `nodm`, but Armbian 20.02.0-rc1 uses lightdm.
I have to modify the kodi-gbm-wrapper script to get it work. However, to `service lightdm stop` requiring *authentication*.  so it wont smoothly go to kodi.
Last thing is the version - kodi  18rc4 - it doesn't have PVR addons, and it seems to be a known issue:
https://forum.kodi.tv/showthread.php?tid=336841
Update: Feb 7
After further search, I find the PVR addons for Ubuntu platform requires special installation
https://kodi.wiki/view/Ubuntu_PVR_add-ons
I tried `apt install kodi-pvr-iptvsimple`, but failed with dependency error:
kodi-api-pvr (= 5.2.1)
I am looking for an update for the Kodi installation script :)
Expand
Ditto. Friendly seem to have permanently broken the video acceleration even though Chromium reports it as there. They have also added lots of junk.
Armbian with this script is my preference.
  On 2/7/2020 at 5:10 PM, Secarius said:
Hi did anyone managed to use the eDP port on the Nano PC T4?
Expand
I couldn't get it to work at all. IMO, Friendly generally has sketchy hardware compatibility and only loosely adheres to specs and standards.
Working on Wayland integration and would like a good starting point.
Please post which boards work and specific test results.
I'll keep the list updated.
 Board  Overall
 GPU
 accelerated
 Desktop
 WebGL  VPU encode
 VPU decode
 4K@60
 10-bit
 HEVC
 OpenGL ES 3.2  OpenCL 1.2
 NanoPi TC4  ?        OK
 NanoPi M4  ?        Some freezing
 RockPro 64  OK
 OK
 X11
 OK
Chromium
 ?  OK  OK  OK
 Khadas EDGE  ?        OK
 RockPi 4B   Install failed        ?
 ROCK960C  ?        OK
last updated: 2020-06-01
hello,
After install the media script i can not get gpu hw acceleration.
my current system is
orange pi 4 with rk3399
kernel 4.4.216-rk3399
Description:    Ubuntu 18.04.4 LTS
Release:    18.04
Codename:    bionic
when I play video with mpv the cpu go  more of 150%.
how can I know that the orange pi has the hw acceleration enabled?
note > only one day hw acceleration was working but the next day stop working.
Thx!
Regards
Maybe some update overwrote the config. Have you tried re-running the script?
yes  I run the script again , today let me test in a clean armbian image.
Expand
Expand
I re running the script but the cpu % goes to high, after that  I run script again but  in  a new armbian image, and cpu goes to high to
how can I launch
I use differents options to launch mpv (--hwdec=rkmpp --vo=drm). but always cpu goes to high
what I doing wrong?
Thx
how can I launch
what I doing wrong?
Thx
Expand
Please post the output of the following commands:
$ uname -r
$ ls -l /dev/mali*
$ ls -l /dev/rk*
$ ls -l /dev/vpu*
$ uname -r
$ ls -l /dev/mali*
$ ls -l /dev/rk*
$ ls -l /dev/vpu*
Expand
hello  here is the output
4.4.213-rk3399
crw-rw---- 1 root video 10, 53 Jun 14 04:37 /dev/mali0
crw-rw---- 1 root video 243, 0 Jun 14 04:37 /dev/rkvdec
crw-rw---- 1 root video 244, 0 Jun 14 04:37 /dev/vpu_service
    _    ____  __  __        __   _  _
   / \  |  _ \|  \/  |      / /_ | || |
  / _ \ | |_) | |\/| |_____| '_ \| || |_
 / ___ \|  _ <| |  | |_____| (_) |__   _|
/_/   \_\_| \_\_|  |_|      \___/   |_|
Welcome to Armbian Focal with Linux 5.7.0-rc2-arm-64
No end-user support: built from trunk & unsupported (focal) userspace!
System load:   2.50 0.64 0.22  	Up time:       0 min
Memory usage:  17 % of 3797MB 	IP:            169.254.13.15 192.168.1.167
CPU temp:      69°C
Usage of /:    18% of 29G    	storage/:      1% of 117G
[ General system configuration (beta): armbian-config ]
294 updates can be installed immediately.
101 of these updates are security updates.
To see these additional updates run: apt list --upgradable
Last login: Tue Apr 28 13:19:17 2020 from 192.168.1.214
root@orangepi-arm-64:~# uname -a
Linux orangepi-arm-64 5.7.0-rc2-arm-64 #20.05.3 SMP PREEMPT Sat Apr 25 13:17:40 MSK 2020 aarch64 aarch64 aarch64 GNU/Linux
Hello, i run armbian on orange pi rk3399 , bun I don`t know how take ffmpeg accelerated and other
ls -l /dev/vpu* /dev/rk* /dev/vpu*
ls: cannot access '/dev/vpu*': No such file or directory
ls: cannot access '/dev/rk*': No such file or directory
[    33.917] (--) Log file renamed from "/var/log/Xorg.pid-1938.log" to "/var/log/Xorg.0.log"
[    33.921]
X.Org X Server 1.20.8
X Protocol Version 11, Revision 0
[    33.921] Build Operating System: Linux 4.4.0-177-generic aarch64 Ubuntu
[    33.921] Current Operating System: Linux orangepi-arm-64 5.7.0-rc2-arm-64 #20.05.3 SMP PREEMPT Sat Apr 25 13:17:40 MSK 2020 aarch64
[    33.921] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=uart8250,mmio32,0xff1a0000 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
[    33.921] Build Date: 06 April 2020  09:39:29AM
[    33.921] xorg-server 2:1.20.8-2ubuntu2 (For technical support please see http://www.ubuntu.com/support)
[    33.921] Current version of pixman: 0.38.4
[    33.921] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    33.921] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    33.921] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Aug  7 15:17:24 2020
[    33.929] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    33.929] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    33.940] (==) No Layout section.  Using the first Screen section.
[    33.941] (==) No screen section available. Using defaults.
[    33.941] (**) |-->Screen "Default Screen Section" (0)
[    33.941] (**) |   |-->Monitor "<default monitor>"
[    33.949] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[    33.949] (**) |   |-->Device "Default Device"
[    33.949] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[    33.949] (**) Option "AutoAddGPU" "off"
[    33.949] (**) Option "Debug" "dmabuf_capable"
[    33.949] (==) Automatically adding devices
[    33.949] (==) Automatically enabling devices
[    33.949] (**) Not automatically adding GPU devices
[    33.949] (==) Automatically binding GPU devices
[    33.949] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    33.982] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    33.982] 	Entry deleted from font path.
[    33.982] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    33.982] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    33.987] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    33.987] 	Entry deleted from font path.
[    33.987] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    33.987] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	built-ins
[    33.987] (==) ModulePath set to "/usr/lib/xorg/modules"
[    33.987] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    33.987] (II) Loader magic: 0xaaaab21f4010
[    33.987] (II) Module ABI versions:
[    33.987] 	X.Org ANSI C Emulation: 0.4
[    33.987] 	X.Org Video Driver: 24.1
[    33.987] 	X.Org XInput driver : 24.1
[    33.987] 	X.Org Server Extension : 10.0
[    33.989] (++) using VT number 2
[    33.993] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_32
[    33.995] (II) xfree86: Adding drm device (/dev/dri/card0)
[    33.996] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[    33.997] (II) xfree86: Adding drm device (/dev/dri/card1)
[    33.999] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 13 paused 0
[    34.000] (II) no primary bus or device found
[    34.000] 	falling back to /sys/devices/platform/display-subsystem/drm/card0
[    34.000] (II) LoadModule: "glx"
[    34.006] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    34.164] (II) Module glx: vendor="X.Org Foundation"
[    34.164] 	compiled for 1.20.8, module version = 1.0.0
[    34.164] 	ABI class: X.Org Server Extension, version 10.0
[    34.164] (II) LoadModule: "modesetting"
[    34.171] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    34.183] (II) Module modesetting: vendor="X.Org Foundation"
[    34.183] 	compiled for 1.20.8, module version = 1.20.8
[    34.183] 	Module class: X.Org Video Driver
[    34.184] 	ABI class: X.Org Video Driver, version 24.1
[    34.184] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    34.185] (II) modeset(0): using drv /dev/dri/card0
[    34.186] (II) modeset(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    34.187] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[    34.187] (**) modeset(0): Option "AccelMethod" "none"
[    34.187] (==) modeset(0): RGB weight 888
[    34.187] (==) modeset(0): Default visual is TrueColor
[    34.187] (**) modeset(0): glamor disabled
[    34.187] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[    34.187] (II) modeset(0): Output HDMI-1 has no monitor section
[    34.187] (II) modeset(0): EDID for output HDMI-1
[    34.187] (II) modeset(0): Output HDMI-1 disconnected
[    34.187] (WW) modeset(0): No outputs definitely connected, trying again...
[    34.187] (WW) modeset(0): Unable to find connected outputs - setting 1024x768 initial framebuffer
[    34.187] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    34.187] (==) modeset(0): DPI set to (96, 96)
[    34.187] (II) Loading sub module "fb"
[    34.187] (II) LoadModule: "fb"
[    34.194] (II) Loading /usr/lib/xorg/modules/libfb.so
[    34.201] (II) Module fb: vendor="X.Org Foundation"
[    34.201] 	compiled for 1.20.8, module version = 1.0.0
[    34.201] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    34.223] (==) modeset(0): Backing store enabled
[    34.223] (==) modeset(0): Silken mouse enabled
[    34.231] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    34.232] (==) modeset(0): DPMS enabled
[    34.232] (II) Initializing extension Generic Event Extension
[    34.232] (II) Initializing extension SHAPE
[    34.233] (II) Initializing extension MIT-SHM
[    34.234] (II) Initializing extension XInputExtension
[    34.237] (II) Initializing extension XTEST
[    34.238] (II) Initializing extension BIG-REQUESTS
[    34.239] (II) Initializing extension SYNC
[    34.239] (II) Initializing extension XKEYBOARD
[    34.240] (II) Initializing extension XC-MISC
[    34.240] (II) Initializing extension SECURITY
[    34.241] (II) Initializing extension XFIXES
[    34.242] (II) Initializing extension RENDER
[    34.242] (II) Initializing extension RANDR
[    34.243] (II) Initializing extension COMPOSITE
[    34.244] (II) Initializing extension DAMAGE
[    34.245] (II) Initializing extension MIT-SCREEN-SAVER
[    34.246] (II) Initializing extension DOUBLE-BUFFER
[    34.246] (II) Initializing extension RECORD
[    34.247] (II) Initializing extension DPMS
[    34.247] (II) Initializing extension Present
[    34.248] (II) Initializing extension DRI3
[    34.248] (II) Initializing extension X-Resource
[    34.248] (II) Initializing extension XVideo
[    34.249] (II) Initializing extension XVideo-MotionCompensation
[    34.249] (II) Initializing extension SELinux
[    34.249] (II) SELinux: Disabled on system
[    34.249] (II) Initializing extension GLX
[    34.250] (II) AIGLX: Screen 0 is not DRI2 capable
[    37.380] (II) IGLX: Loaded and initialized swrast
[    37.380] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    37.380] (II) Initializing extension XFree86-VidModeExtension
[    37.381] (II) Initializing extension XFree86-DGA
[    37.381] (II) Initializing extension XFree86-DRI
[    37.390] (II) Initializing extension DRI2
[    37.391] (II) modeset(0): Damage tracking initialized
[    37.638] (II) config/udev: Adding input device adc-keys (/dev/input/event1)
[    37.638] (**) adc-keys: Applying InputClass "libinput keyboard catchall"
[    37.638] (II) LoadModule: "libinput"
[    37.638] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    37.666] (II) Module libinput: vendor="X.Org Foundation"
[    37.666] 	compiled for 1.20.4, module version = 0.29.0
[    37.666] 	Module class: X.Org XInput Driver
[    37.666] 	ABI class: X.Org XInput driver, version 24.1
[    37.666] (II) Using input driver 'libinput' for 'adc-keys'
[    37.671] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 22 paused 0
[    37.671] (**) adc-keys: always reports core events
[    37.671] (**) Option "Device" "/dev/input/event1"
[    37.671] (**) Option "_source" "server/udev"
[    37.695] (II) event1  - adc-keys: is tagged by udev as: Keyboard
[    37.695] (II) event1  - adc-keys: device is a keyboard
[    37.696] (II) event1  - adc-keys: device removed
[    37.696] (**) Option "config_info" "udev:/sys/devices/platform/adc-keys/input/input1/event1"
[    37.696] (II) XINPUT: Adding extended input device "adc-keys" (type: KEYBOARD, id 6)
[    37.696] (**) Option "xkb_model" "pc105"
[    37.696] (**) Option "xkb_layout" "us"
[    37.700] (II) event1  - adc-keys: is tagged by udev as: Keyboard
[    37.700] (II) event1  - adc-keys: device is a keyboard
[    37.703] (II) config/udev: Adding input device gpio-keys (/dev/input/event0)
[    37.703] (**) gpio-keys: Applying InputClass "libinput keyboard catchall"
[    37.703] (II) Using input driver 'libinput' for 'gpio-keys'
[    37.707] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 25 paused 0
[    37.708] (**) gpio-keys: always reports core events
[    37.708] (**) Option "Device" "/dev/input/event0"
[    37.708] (**) Option "_source" "server/udev"
[    37.711] (II) event0  - gpio-keys: is tagged by udev as: Keyboard
[    37.711] (II) event0  - gpio-keys: device is a keyboard
[    37.711] (II) event0  - gpio-keys: device removed
[    37.711] (**) Option "config_info" "udev:/sys/devices/platform/gpio-keys/input/input0/event0"
[    37.711] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 7)
[    37.711] (**) Option "xkb_model" "pc105"
[    37.711] (**) Option "xkb_layout" "us"
[    37.715] (II) event0  - gpio-keys: is tagged by udev as: Keyboard
[    37.715] (II) event0  - gpio-keys: device is a keyboard
  On 1/10/2019 at 1:38 PM, JMCC said:
You need a fresh Armbian Bionic desktop image with legacy kernel installed.
Expand
  On 8/7/2020 at 4:01 PM, whitefox said:
Welcome to Armbian Focal with Linux 5.7.0-rc2-arm-64 No end-user support: built from trunk & unsupported (focal) userspace!
Expand
  On 8/7/2020 at 4:33 PM, NicoD said:
I don't want an legacy kernel.
I fund comment https://github.com/rockchip-linux/ffmpeg/issues/5#issuecomment-526955549
and build first mpp
git clone https://github.com/hizukiayaka/rockchip_mpp.git
cd ../mpp/
cmake -DRKPLATFORM=ON -DHAVE_DRM=ON -DCMAKE_BUILD_TYPE=Release
make -j7
make install
then I build rockchip ffmpeg 4.2 from https://github.com/stweiz/ffmpeg/tree/rockchip-ffmpeg-stevog/release/4.2
apt-get build-dep ffmpeg
git clone https://github.com/stweiz/ffmpeg/tree/rockchip-ffmpeg-stevog/release/4.2
cd ffmpeg/
./configure --prefix=/usr --extra-version=1ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared --enable-rkmpp --enable-version3
make -j7
make install
I want to do it humanly use ppa repo
Expand
  On 8/7/2020 at 9:53 PM, whitefox said:
Expand
OK, you are free to do whatever you want. But this is a thread about using my media script with Armbian legacy kernel. If you want to do something different, please don't discuss it here.
Hi there,
This is my firs msg to this forum.
First off I'd like to congratulate the devs on the superb work they've been doing.
I own a RockPro64 for almost a year and always wanted to use it as both a small server (with a few services installed as for example FTP, NextCloud, etc) and as a media center connected to my TV via HDMI to run Kodi (so no need of a desktop... only Kodi and remote SSH access), but since hardware acceleration was a must, I'd never found a suitable option. So I've been using LibreELEC and installing things I need mostly using Docker (which is not that a good solution since I wanted a 'real' server).
The thing is yesterday I found this topic and noticed the nice work you guys have been doing.
I installed it (eMMC, which seems to be working smoothly so far), but I have a couple of questions I'd like to ask if possible.
Since I don't need a desktop is there a way to boot automatically on Kodi, since it's all 'graphical' I'll need on this machine? I've seen a couple of old Kodi tutorials suggesting the creation of a systemd file, but I'm not sure if it's still valid to use with Armbian. Another option I saw here in this very forum, suggesting either placing kodi-gbm-wrapper in /etc/rc.local or disable the desktop and add "kodi" to my .bashrc (which I believe would be more suitable in my specific case). Which one do you suggest? And what would be the best way I could do that, considering that I just need boot on Kodi and remotely ssh the box?
Another question is the kernel. I've read this whole thread and noticed that you optmized and hacked things deeply. I also noticed that the armbian-config tool has an option to 'freeze' the kernel. In order to keep using your optimizations I must freeze the kernel or it won't be necessary?
And what about other updates? May I safely keep doing 'apt-get udate && apt-get upgrade' and just rebuilding your script?
Another detail I noticed is about Kodi itself. As soon as I run it yesterday I saw a message warning about an update. I imagine I must not update, correct?
The last question is about mainline kernels. I understand that you guys developed a specific solution to a specific scenario (in this case, a legacy kernel). Are there any plans to maybe develop a similar solution to mainline, though?
Thank you very much for any help and keep up the good work. :)
Expand
Expand
Exactly, just disable your desktop by running "sudo systemctl disable lightdm.desktop", and then place kodi-gbm-wrapper in /etc/rc.local
Expand
This script was intended only for testing, so you need to re-run it after every update that may affect some of its components. Besides that, of course you can and should update your system.
We are preparing a fully integrated solution into the Armbian package repos, so you won't need to use the script any more. I'll post about it soon, hopefully. I'll say a few words about Kodi there.
Expand
Yes, there are plans. No timeline for it, though :)
Expand
Hi there,
Thank you for your prompt reply.
May I bother you a little more and ask one or two more questions?
When I was using LibreELEC I was able to use my TV remote control to interact with Kodi via HDMI-CEC. I had to configure nothing, and it worked out of the box. Now with Kodi I can't make it work (I installed Kore on my smartphone, but, welll.... it's far from ideal) . I've googled a little and noticed that not all kernels offer support to this feature. Is that the case here? If so, do you have any suggestion on what I could do in order to enable it?
The other thing is about rebooting via software. I noticed that no matter the command I use ("sudo shutdown -r now", "sudo reboot", "sudo systemctl reboot") it kind of reboot (I can hear the attached disk power off and on again), the white led on the RP64 stops flashing and also power off but then they both (the white and the red leds) power on and nothing happens. It only works if I manually either disconnect the power supply or use the reset button. Is it anything I'm doing wrong, maybe?
Again, thank you so much for your invaluable help.
Expand
You can use the Armbian build script to build your customized kernel. After you select the board and the flavor (it must be Legacy), you can also choose to have a Kernel config menu. Look for the appropriate Kernel feature (I don't know the exact name, probably use the search function and enter 'CEC').
If you get it to work, please post your results here, and maybe you can make a Pull Request and contribute to the Armbian project.
Expand
Sorry, i don't own a RockPro64. You can post this question on a new thread, within this same Rockchip 3399 sub-forum.
ANNOUNCEMENT: The media script is now deprecated, in favor of the official Legacy Multimedia Framework. Please refer to this topic:
  • JMCC unpinned, pinned, featured, unfeatured and unpinned this topic
