Baudrate supported by RK3399
Rahul
I am using rockpro64 "https://www.pine64.org/?product=rockpro64-4gb-single-board-computer" that uses Rockchip RK3399 Hexa-Core (dual ARM Cortex A72 and quad ARM Cortex A53) 64-Bit Processor.
My simple application is to have a UART communication.
When i run serial write with 1500000 Baudrate, then it works fine. But if i lower the baudrate such as 115200, then it throws garbage value.
So can i get some suggestions here?
Thanks.
Link to comment
Share on other sites
2 hours ago, NicoD said:
It's as simple as that.
no.. :P
It could probably set to 115200 in DT. but then it had to be changed in u-boot as well.. and to keep stuff in a proper order.. for all RK3399 boards.. Is it worth to write a whole patchseries just for such a change.. I thought about it but I'm not sure..
Link to comment
my UART script which does some funny monitoring in case the SBC doesn't respond anymore wouldn't need a $BAUDRATE variable anymore.... :lol:
The only gain IMO is that all other armbian supported SBCs run (to my knowledge) at 115200... But as said.. Don't think it's really worth it.. :P
Link to comment
