HI there .I am facing issues regarding installing the latest image (Ubuntu Bionic ) for Orange Pi One . The normal boot procedure involving u-boot fails as the board attempts to boot from the network . The u-boot console says no fdt found . This is the console log of the boot process .
U-Boot SPL 2018.05-armbian (Jan 09 2019 - 19:39:57 +0100)
DRAM: 512 MiB
Trying to boot from MMC1
U-Boot 2018.05-armbian (Jan 09 2019 - 19:39:57 +0100) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi One
DRAM:  512 MiB
MMC:   SUNXI SD/MMC: 0
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
Failed (-5)
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
230454 bytes read in 23 ms (9.6 MiB/s)
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3798 bytes read in 15 ms (247.1 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
152 bytes read in 12 ms (11.7 KiB/s)
8126319 bytes read in 414 ms (18.7 MiB/s)
6906920 bytes read in 352 ms (18.7 MiB/s)
28858 bytes read in 52 ms (541 KiB/s)
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
4155 bytes read in 54 ms (74.2 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 44000000
Wrong image format for "source" command
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Data Size:    8126255 Bytes = 7.7 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing...
Device 0: device type unknown
... is now current device
** Bad device usb 0 **
ethernet@1c30000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
Abort
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-02-81-58-b5-28-97
_sun8i_emac_eth_init: Timeout
Retrieving file: pxelinux.cfg/00000000
*** ERROR: `serverip' not set
ethernet@1c30000 Waiting for PHY auto negotiation to complete.user interrupt!
ethernet@1c30000 Waiting for PHY auto negotiation to complete..user interrupt!
Retrieving file: pxelinux.cfg/default-arm-sunxi
Do I need to pass the address manually via uboot? I am stumped . Please help .
It looks like a corrupted FDT file on corrupted SDCard ...
Reburn the SDCard with Etcher.
