using the usb-otg only as usb port
arjepsen
Hey.
I'm trying to install octoprint on my Opi Zero +2, using the latest armbian image I found here on the site.
Installation works fine, and I get the web interface up and running no problem.
But I have connected power to the board on the gpio pins, and want to use the mini-usb to connect to the 3d printer.
I have enabled usbhost0-3 in the hardware in armbian-config, but still it seems the printer cannot be reached.
I read some older posts regarding other boards, where the solution seemed to be recompiling. Is this a necessity, and if so, could someone please point me to a walkthrough?
Regards
Anders
Link to post
Share on other sites
Donate and support the project!
lsusb gives:
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
and dmesg:
[    0.000000] Kernel command line: root=UUID=289bd460-9951-431f-bf37-6007ea923b14 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 panic=10 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=memory swapaccount=1
[    1.283924] usbcore: registered new interface driver usbfs
[    1.283961] usbcore: registered new interface driver hub
[    1.284015] usbcore: registered new device driver usb
[    2.408662] ehci-platform 1c1a000.usb: EHCI Host Controller
[    2.408685] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    2.409219] ehci-platform 1c1a000.usb: irq 11, io mem 0x01c1a000
[    2.421479] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    2.421715] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    2.421722] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.421728] usb usb1: Product: EHCI Host Controller
[    2.421734] usb usb1: Manufacturer: Linux 4.19.17-sunxi64 ehci_hcd
[    2.421739] usb usb1: SerialNumber: 1c1a000.usb
[    2.422737] ehci-platform 1c1b000.usb: EHCI Host Controller
[    2.422755] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
[    2.423243] ehci-platform 1c1b000.usb: irq 13, io mem 0x01c1b000
[    2.437485] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    2.437675] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    2.437682] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.437688] usb usb2: Product: EHCI Host Controller
[    2.437693] usb usb2: Manufacturer: Linux 4.19.17-sunxi64 ehci_hcd
[    2.437698] usb usb2: SerialNumber: 1c1b000.usb
[    2.438615] ehci-platform 1c1c000.usb: EHCI Host Controller
[    2.438633] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
[    2.439082] ehci-platform 1c1c000.usb: irq 15, io mem 0x01c1c000
[    2.453484] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    2.453665] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    2.453672] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.453677] usb usb3: Product: EHCI Host Controller
[    2.453683] usb usb3: Manufacturer: Linux 4.19.17-sunxi64 ehci_hcd
[    2.453688] usb usb3: SerialNumber: 1c1c000.usb
[    2.454566] ehci-platform 1c1d000.usb: EHCI Host Controller
[    2.454583] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 4
[    2.455038] ehci-platform 1c1d000.usb: irq 17, io mem 0x01c1d000
[    2.469474] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[    2.469655] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    2.469662] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.469667] usb usb4: Product: EHCI Host Controller
[    2.469672] usb usb4: Manufacturer: Linux 4.19.17-sunxi64 ehci_hcd
[    2.469677] usb usb4: SerialNumber: 1c1d000.usb
[    2.470775] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    2.470798] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 5
[    2.471052] ohci-platform 1c1a400.usb: irq 12, io mem 0x01c1a400
[    2.533722] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    2.533729] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.533735] usb usb5: Product: Generic Platform OHCI controller
[    2.533741] usb usb5: Manufacturer: Linux 4.19.17-sunxi64 ohci_hcd
[    2.533746] usb usb5: SerialNumber: 1c1a400.usb
[    2.534673] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    2.534696] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
[    2.534972] ohci-platform 1c1b400.usb: irq 14, io mem 0x01c1b400
[    2.597725] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    2.597732] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.597738] usb usb6: Product: Generic Platform OHCI controller
[    2.597743] usb usb6: Manufacturer: Linux 4.19.17-sunxi64 ohci_hcd
[    2.597748] usb usb6: SerialNumber: 1c1b400.usb
[    2.598651] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    2.598669] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
[    2.598948] ohci-platform 1c1c400.usb: irq 16, io mem 0x01c1c400
[    2.661728] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    2.661736] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.661741] usb usb7: Product: Generic Platform OHCI controller
[    2.661747] usb usb7: Manufacturer: Linux 4.19.17-sunxi64 ohci_hcd
[    2.661752] usb usb7: SerialNumber: 1c1c400.usb
[    2.662633] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[    2.662650] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
[    2.662914] ohci-platform 1c1d400.usb: irq 18, io mem 0x01c1d400
[    2.725722] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    2.725729] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.725735] usb usb8: Product: Generic Platform OHCI controller
[    2.725740] usb usb8: Manufacturer: Linux 4.19.17-sunxi64 ohci_hcd
[    2.725745] usb usb8: SerialNumber: 1c1d400.usb
[    2.727096] usbcore: registered new interface driver usb-storage
[    2.731595] usbcore: registered new interface driver usbhid
[    2.731597] usbhid: USB HID core driver
Link to post
I've soldered two wires to pin-hole 2 and 4 on the expansion port. 5v is supplied from an ATX pc psu.
Heres the dmesg command after unplugging/plugging:
[    1.283959] usbcore: registered new interface driver usbfs
[    1.283996] usbcore: registered new interface driver hub
[    1.284051] usbcore: registered new device driver usb
[    2.408156] ehci-platform 1c1a000.usb: EHCI Host Controller
[    2.408178] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    2.408713] ehci-platform 1c1a000.usb: irq 11, io mem 0x01c1a000
[    2.421513] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    2.421741] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    2.421748] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.421754] usb usb1: Product: EHCI Host Controller
[    2.421760] usb usb1: Manufacturer: Linux 4.19.17-sunxi64 ehci_hcd
[    2.421765] usb usb1: SerialNumber: 1c1a000.usb
[    2.422793] ehci-platform 1c1b000.usb: EHCI Host Controller
[    2.422816] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
[    2.423299] ehci-platform 1c1b000.usb: irq 13, io mem 0x01c1b000
[    2.437518] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    2.437719] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    2.437726] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.437732] usb usb2: Product: EHCI Host Controller
[    2.437737] usb usb2: Manufacturer: Linux 4.19.17-sunxi64 ehci_hcd
[    2.437742] usb usb2: SerialNumber: 1c1b000.usb
[    2.438659] ehci-platform 1c1c000.usb: EHCI Host Controller
[    2.438677] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
[    2.439143] ehci-platform 1c1c000.usb: irq 15, io mem 0x01c1c000
[    2.453507] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    2.453690] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    2.453697] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.453703] usb usb3: Product: EHCI Host Controller
[    2.453708] usb usb3: Manufacturer: Linux 4.19.17-sunxi64 ehci_hcd
[    2.453713] usb usb3: SerialNumber: 1c1c000.usb
[    2.454591] ehci-platform 1c1d000.usb: EHCI Host Controller
[    2.454608] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 4
[    2.455053] ehci-platform 1c1d000.usb: irq 17, io mem 0x01c1d000
[    2.469518] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[    2.469691] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    2.469698] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.469704] usb usb4: Product: EHCI Host Controller
[    2.469709] usb usb4: Manufacturer: Linux 4.19.17-sunxi64 ehci_hcd
[    2.469714] usb usb4: SerialNumber: 1c1d000.usb
[    2.470809] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    2.470827] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 5
[    2.471093] ohci-platform 1c1a400.usb: irq 12, io mem 0x01c1a400
[    2.533695] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    2.533702] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.533707] usb usb5: Product: Generic Platform OHCI controller
[    2.533713] usb usb5: Manufacturer: Linux 4.19.17-sunxi64 ohci_hcd
[    2.533718] usb usb5: SerialNumber: 1c1a400.usb
[    2.534651] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    2.534668] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
[    2.534966] ohci-platform 1c1b400.usb: irq 14, io mem 0x01c1b400
[    2.597847] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    2.597854] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.597859] usb usb6: Product: Generic Platform OHCI controller
[    2.597865] usb usb6: Manufacturer: Linux 4.19.17-sunxi64 ohci_hcd
[    2.597870] usb usb6: SerialNumber: 1c1b400.usb
[    2.598776] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    2.598794] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
[    2.599072] ohci-platform 1c1c400.usb: irq 16, io mem 0x01c1c400
[    2.661858] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    2.661865] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.661871] usb usb7: Product: Generic Platform OHCI controller
[    2.661876] usb usb7: Manufacturer: Linux 4.19.17-sunxi64 ohci_hcd
[    2.661882] usb usb7: SerialNumber: 1c1c400.usb
[    2.662776] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[    2.662793] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
[    2.663069] ohci-platform 1c1d400.usb: irq 18, io mem 0x01c1d400
[    2.725845] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    2.725852] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.725858] usb usb8: Product: Generic Platform OHCI controller
[    2.725863] usb usb8: Manufacturer: Linux 4.19.17-sunxi64 ohci_hcd
[    2.725869] usb usb8: SerialNumber: 1c1d400.usb
[    2.727225] usbcore: registered new interface driver usb-storage
[    2.731090] usbcore: registered new interface driver usbhid
[    2.731092] usbhid: USB HID core driver
Link to post
no - only pin 2 and 4. Should pin 3 also be connected? If so - why? As far as I can tell, it's function is listed as: TWI0_SDA / PA12 / GPIO12
Pin 2 is connected to 5v, and pin 4 to ground - both on the atx supply. According to the link I posted, pin 4 (among others) are ground on the Opi.
Since I've been able to boot, and install armbian, having it powered like this, I assume the power is connected correctly?
Link to post
I'm sorry - I've probably been too vague in describing what I'm aiming for.
You're refering to the 1x13 header. I've connected power to the 2x13 header.
But my problem is:
I want to use the small micro-usb port that for the printer. The port that I would otherwise normally use for powering the board.
That's the reason I've connected power to the pins of the 2x13 header.
But I can't seem to get that port to work as a regular usb host.
Link to post
... but there is no USB port on this one ...
In this case , you absolutely needs to have USB node in DT with : dr_mode = "host";
Using 1x13 header could be use easily with adaptors like :
https://www.ebay.ca/itm/10PCS-USB-Female-Port-Connector-Breakout-Board-Power-2-54mm-Header-for-Arduino/132482993278
Link to post
44 minutes ago, arjepsen said:
Ok. Could you give some details on how to get this done?
First, install DeviceTree compiler :
wget http://ftp.debian.org/debian/pool/main/d/device-tree-compiler/device-tree-compiler_1.4.7-3_arm64.deb
dpkg -i device-tree-compiler_1.4.7-3_arm64.deb
Second, de-compile the main DT of OPiZeroPlus2-H5 :
dtc -@ -I dtb -O dts -o sun50i-h5-orangepi-zero-plus2.dts-NEW /boot/dtb/allwinner/sun50i-h5-orangepi-zero-plus2.dtb
Edit the sun50i-h5-orangepi-zero-plus2.dts-NEW file, locate the node "usb@1c19000", and add the property ' dr_mode = "host"; ' into it, and change "status" to "okay". Then, recompile it after having done a backup :
mv /boot/dtb/allwinner/sun50i-h5-orangepi-zero-plus2.dtb /boot/dtb/allwinner/sun50i-h5-orangepi-zero-plus2.dtb-ORIG
dtc -@ -I dts -O dtb -o /boot/dtb/allwinner/sun50i-h5-orangepi-zero-plus2.dtb sun50i-h5-orangepi-zero-plus2.dts-NEW
Then, do a "sync" followed by "reboot" ...
I wasn't able to test complete recipe, since my USB-OTG cable is taking the 5V from the board, but it is not present when PSU is attached to header pins 4/6 .
Link to post
This is also my procedure that I have to go through every time there is a kernel upgrade. Really wish that either
  • armbian-config would point out the fact that setting "host mode" here may or may not be effective, and the dtc trickery is necessary for OTG ports
or (better)
  • armbian-config would offer to do the patching of the dtb when the OTG port is changed to "host mode"
or (best)
  • there was a way for custom dtb settings to automatically "survive" a kernel upgrade
Link to post
