TonyMac32 Posted May 26, 2017 Posted May 26, 2017 Ah, something I've mentioned but didn't make a big deal of: the RK808 gets hot enough to burn you under heavy loads. Put a heatsink on it.
Tido Posted May 26, 2017 Posted May 26, 2017 Isn't the RK808 designed to feed the RK3288 - so in this regard it should be able to cope with the load, I guess (as long as you do not overclock) ? If it does also feed the USB-Hub I can imagine it gets to much without heatsink and you mentioned your heatsink before but without measured degrees - for a human it feels like hot, around 60°C just in average. How hot got your RK808? Is there no thermal sensor in it - does anyone know?
chrisf Posted May 26, 2017 Posted May 26, 2017 Just now, Tido said: Isn't the RK808 designed to feed the RK3288 - so in this regard it should be able to cope with the load, I guess (as long as you do not overclock) ? If it does also feed the USB-Hub I can imagine it gets to much without heatsink and you mentioned your heatsink before but without measured degrees - for a human it feels like hot, around 60°C just in average. How hot got your RK808? Is there no thermal sensor in it - does anyone know? RK808 doesn't have an accessible thermal sensor. It's got two thermal shutdown thresholds and you can set one of 4 high temp thresholds. You can't get the current temperature, just if it's over the thresholds or not.
Tido Posted May 26, 2017 Posted May 26, 2017 (edited) 1 hour ago, chrisf said: It's got two thermal shutdown thresholds and you can set one of 4 high temp thresholds. So I read 6 thresholds. 2 x for shutdown, why 2 ? 4 x high temp, of which I can set one. What happens if high temp is reached, throttling of the SoC ? Edited May 26, 2017 by Tido changed clocking with throttling :)
chrisf Posted May 26, 2017 Posted May 26, 2017 30 minutes ago, Tido said: So I read 6 thresholds. 2 x for shutdown, why 2 ? 4 x high temp, of which I can set one. What happens if high temp is reached, down clocking of the SoC ? It's in the RK808 datasheet You can set shutdown to 140c or 170C You can set hot die to 85, 95, 105 or 115C The RK808 driver can then read the shutdown status or the hot die status http://rockchip.fr/RK808 datasheet V0.8.pdf 1
Myy Posted May 26, 2017 Posted May 26, 2017 On 2017/5/24 at 3:23 PM, patrick-81 said: Hello, As I try to use X11vnc on the tinkerboard I am stuck with a default display resolution which is less than what I need. Is there any way to change the default resolution ? Thanks IIRC, X11Vnc uses its own X11 configuration file. You might find some useful tips in there : http://www.karlrunge.com/x11vnc/faq.html#faq-display-manager
chrisf Posted May 26, 2017 Posted May 26, 2017 Are kernel is everyone using? I've been using rockchip-default I'm having trouble using an SPI device... there is no /dev/spidev* devices, yet I can see there are 3 in the devicetree -r--r--r-- 1 root root 14 May 26 22:15 /sys/firmware/devicetree/base/aliases/spi0 -r--r--r-- 1 root root 14 May 26 22:15 /sys/firmware/devicetree/base/aliases/spi1 -r--r--r-- 1 root root 14 May 26 22:15 /sys/firmware/devicetree/base/aliases/spi2 From what I can gather, there is no spidev config in the device tree I see there is a spi2 in the dev and next dts's, are those kernels stable for everyday use or can I apply the patch t the default dts?
TonyMac32 Posted May 26, 2017 Posted May 26, 2017 It could be attempted, however I'd guess spidev.c won't take the patch, since those definitions get added to periodically. (It had to be adjusted from 4.11 to 4.12, for instance). You can try it, worst case you need to go into spidev.c and manually add the compatibility entry you see in the patch to whatever list of devices is there.
TonyMac32 Posted May 27, 2017 Posted May 27, 2017 @chrisf try to build now and let me know. I'll be out town for a few days for the holiday here in the US, but I'll keep tabs on the forums. Also, forgot to mention, running for several days on GPIO power, and no HDMI dropouts.
HackXIt Posted May 27, 2017 Posted May 27, 2017 Hello! First of all, it's amazing to have armbian for the tinkerboard and it already functioning better than the tinkerOS (at least from my point of view), so great job to everyone involved! I was wondering if the GPIO pins are fully supported yet, or at least the UART pins, on the current version? used legacy kernel from the website -> Armbian 5.27 Ubuntu Xenial Default 4.4.66 (Hopefully I'm posting in the right thread, kinda just jumped into here... please lemme know if I should open a topic for this or if it's ok to post here) The reason I'm asking is because I've been trying to program an ESP8266 module over the UART pins of the TinkerBoard (using Arduino IDE and the ESP8266 extension) and as of yet haven't gotten it to work, or do anything. Maybe the mistake lies in me being unable to use the ESP8266 properly yet, or it lies within the fact that Arduino IDE can't send data over UART pins, or the PINs don't work at all yet... But as a matter of fact I can select ttyS0, ttyS1, ttyS2 and ttyS3 in the IDE, making me believe that it actually is recognized. I would really appreciate a little help or push in the right direction since I've kinda hit a dead end at the moment. (currently I've been using 8 and 10 which is UART1 on the pinmap) For those that know the ESP8266 module, here's what I've connected: CH_PD and VCC -> 3.3V GND -> GND REST -> 3.3V or GND (to reset I switch it to GND if I understood that correctly) GPIO0 -> 3.3V TXD -> TinkerBoard GPIO10 RXD -> TinkerBoard GPIO8 3.3V and GND is supplied from the Tinkerboard as well, but I can change that to an external power supply if necessary, but I figured my power supply (official raspberry pi, 5V 2.5A) is sufficient enough, and the ESP8266 lights up as well. Hopefully someone here can support me a little bit in this
martinayotte Posted May 27, 2017 Posted May 27, 2017 Like many other boards, even if you have many /dev/ttyS*, it doesn't mean the actual UARTs are enabled in the DeviceTree. You should probably look in the DTS (or decompile DTB into DTS) to figured out. When a UART is detected at boot time, you will see it in "dmesg" which will show on which /dev/tttyS* it will be attached. BTW, if not enabled, UARTs can also be enabled using overlays ... 1
HackXIt Posted May 28, 2017 Posted May 28, 2017 (edited) That's honestly quite an information load to chew on. So from what I've gathered in my short time investment: DTS is the Device Tree given by DTB (from the bootloader), which contains all the devices that "should turn on", practically speaking. How I can enable UART's via overlay I would understand with the raspberry pi, as it holds a well documented config.txt where I simply change something already there... So the twist is that I'm using a tinkerboard and obviously things work a little differently, when not completely. So, not really a genius on this topic yet nor probably will ever be... Finding out now via dmesg if my UART's are enabled and on which /dev/ttyS is the thing I'm currently wrapping my head around. Espescially since I'm not the best linux guy yet, barely a beginner, getting it to show me what I need to see is gonna take a little bit. But thanks, at least pushed me into a reasonable direction of where the problem might be. Edit: Noticed that there's PL2302 Driver support activated from the 'dmesg' output. I have such a usb to serial cable lying around so I checked if that works and smiled pretty brightly when it suddenly showed up as USB0 in Arduino IDE. Now I've got to figure out another problem, but more of an esp8266 matter... This works temporarily as a quick fix, I'll check back into how I can get the GPIO UART running once I have more time on my hands, since this project got a deadline. I want the GPIO to work at some point as it would be much nicer for future projects... So yea... Thanks for the nudge Edited May 28, 2017 by HackXIt
martinayotte Posted May 28, 2017 Posted May 28, 2017 Quote DTS is the Device Tree given by DTB (from the bootloader), which contains all the devices that "should turn on", practically speaking. It could be defined, but not enabled by default ... Another to verify DT is using "cat status", for example here checking uart1 and uart2 on some AllWinner boards : cat /proc/device-tree/soc/serial@01c28000/status okay cat /proc/device-tree/soc/serial@01c28400/status disabled How to enable uart2 uising overlays ? simply edit /boot/armbianEnv.txt and add "overlays=uart2" In the meantime, yes, using USB-TTL Serial is a good workaround ...
zador.blood.stained Posted May 29, 2017 Posted May 29, 2017 8 hours ago, martinayotte said: How to enable uart2 uising overlays ? simply edit /boot/armbianEnv.txt and add "overlays=uart2" which is implemented only to Allwinner boards. For Rockchip boards DT should be edited and recompiled manually.
martinayotte Posted May 29, 2017 Posted May 29, 2017 Apologize ! I didn't knew that since all my boards are AllWinner.
zador.blood.stained Posted May 29, 2017 Posted May 29, 2017 3 minutes ago, martinayotte said: Apologize ! I didn't knew that since all my boards are AllWinner. I mean it shouldn't be too hard to add configfs support patches to these kernels, but you will still need to write overlays for each platform from scratch since base DT configuration will be different. 1
chrisf Posted May 30, 2017 Posted May 30, 2017 12 hours ago, zador.blood.stained said: I mean it shouldn't be too hard to add configfs support patches to these kernels, but you will still need to write overlays for each platform from scratch since base DT configuration will be different. How do we going about doing this?
Minty Posted May 30, 2017 Posted May 30, 2017 When I try to start UFW I get an error message. Do you know what the problem is? Might be the wrong thread but I'm not sure if the problem is Armbian, Rockchip, UFW or the Linux beginner using the keyboard ERROR: problem running ufw-init modprobe: FATAL: Module nf_conntrack_netbios_ns not found in directory /lib/modules/4.4.66-rockchip iptables-restore: line 77 failed iptables-restore: line 30 failed ip6tables-restore: line 138 failed Problem running '/etc/ufw/before.rules' Problem running '/etc/ufw/user.rules' Problem running '/etc/ufw/before6.rules'
chrisf Posted May 31, 2017 Posted May 31, 2017 On 5/30/2017 at 7:25 PM, Minty said: modprobe: FATAL: Module nf_conntrack_netbios_ns not found in directory /lib/modules/4.4.66-rockchip NF_CONNTRACK_NETBIOS_NS is not configured in the kernel build https://github.com/armbian/build/blob/master/config/kernel/linux-rockchip-default.config#L780
Minty Posted June 1, 2017 Posted June 1, 2017 Thanks, this means I can't do anything right now(on a beginner level)?
Tido Posted June 2, 2017 Posted June 2, 2017 (edited) There are updated images available If you don't have the torrent client 'transmission', get it from here https://transmissionbt.com/ Big advantage of torrent, it does automatically check with SHA-key if the file downloaded is okay. Kernel 4.4.70 no desktop https://dl.armbian.com/tinkerboard/Ubuntu_xenial_default.7z.torrent desktop https://dl.armbian.com/tinkerboard/Ubuntu_xenial_default_desktop.7z.torrent Edit: reboot works /var/log/armhwinfo.log has been uploaded to http://sprunge.us/NVBD MAC-Address still changes: eth0 Link encap:Ethernet HWaddr 2c:4d:54:42:c5:6f eth0 Link encap:Ethernet HWaddr da:42:ea:69:d7:ca Edited June 2, 2017 by Tido
TonyMac32 Posted June 2, 2017 Posted June 2, 2017 I haven't configured that module in the kernel config, so for this particular issue the newer kernel won't help. The spidev patch has been committed, has anyone tried using it?
Myy Posted June 2, 2017 Posted June 2, 2017 Hey everyone ! Due to some demands, I started to try integrating the Tinkerboard Wifi module, which is nicely implemented in their own kernel. Really, first time I see actual Wifi configuration tools directly integrated into the kernel source tree. Work of art ! I don't know if the most important part is the DTS part that seems to hint that the Wireless system is detected through the RFKill subsystem. Or if that part is kind of a red herring and the most important parts are the ones common to many different RK3288 DTS integrating Wifi, which is a combination of a sdio_pwrseq definition, some pinctrl definitions and an SDIO section definition. Example on an official RK3288 DTS, rk3288-veyron.dts : sdio_pwrseq: sdio-pwrseq { compatible = "mmc-pwrseq-simple"; clocks = <&rk808 RK808_CLKOUT1>; clock-names = "ext_clock"; pinctrl-names = "default"; pinctrl-0 = <&bt_enable_l>, <&wifi_enable_h>; /* * On the module itself this is one of these (depending * on the actual card populated): * - SDIO_RESET_L_WL_REG_ON * - PDN (power down when low) */ reset-gpios = <&gpio4 RK_PD4 GPIO_ACTIVE_LOW>; } &sdio0 { status = "okay"; bus-width = <4>; cap-sd-highspeed; cap-sdio-irq; keep-power-in-suspend; mmc-pwrseq = <&sdio_pwrseq>; non-removable; num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&sdio0_clk &sdio0_cmd &sdio0_bus4>; sd-uhs-sdr12; sd-uhs-sdr25; sd-uhs-sdr50; sd-uhs-sdr104; vmmc-supply = <&vcc33_sys>; vqmmc-supply = <&vcc18_wl>; }; Similar sections can be found in the Tinkerboard's kernel rk3288-miniarm.dts file. These sections are not present in the official rk3288-tinker.dts, so I created a patch to add it like this : https://github.com/Miouyouyou/MyyQi/blob/master/patches/kernel/v4.12/0014-Second-tinkerboard-Wifi-driver-addition-tentative.patch However, I don't own the hardware so if anyone can give it a try, while enabling the staging rtl8723bs driver (´・ω・` ) Also, here's a mainlined Sunxi SoC DTS declaring the driver in a totally different way.
TonyMac32 Posted June 3, 2017 Posted June 3, 2017 I will take a look, I haven't had much any luck getting it going personally, although I haven't had the time of late (extra work projects/etc) [edit] oh my, I actually missed the declaration in the Sunxi file entirely... that is different. x_x [edit 2] First round no success, compiles but no device, noticed the "wireless-wlan" node was missing, added. No effect. :-/ Something I saw in the rockchip kernel (common to the Tinkerboard and the MiQi 4.4) was all that intricate management and https://github.com/TinkerBoard/debian_kernel/blob/linux4.4-rk3288/drivers/net/wireless/rockchip_wlan/wifi_sys/rkwifi_sys_iface.c
Myy Posted June 3, 2017 Posted June 3, 2017 Ah, too bad. Yeah, I've seen that a part of the wireless detection is linked to the RFKill subsystem (Why though...). Is the SDIO part enabled though ? The driver itself seems to rely on SDIO detection ID. I wonder if there's a way to probe any hardware using the SDIO subsystem, a bit like lspci or lsusb , in order to get the hardware ID of hardware available through this protocol. https://github.com/TinkerBoard/debian_kernel/blob/linux4.4-rk3288/drivers/net/wireless/rockchip_wlan/rtl8723bs/os_dep/linux/sdio_intf.c https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/staging/rtl8723bs/os_dep/sdio_intf.c Anyway, I'll try to compile the Tinkerboard version of the driver on the newest kernel, see if it can be done and see if it adds anything.
TonyMac32 Posted June 3, 2017 Posted June 3, 2017 config WIFI_LOAD_DRIVER_WHEN_KERNEL_BOOTUP bool "Wifi load driver when kernel bootup" default y ---help--- Wifi driver will be load (use late_initcall) when kernel bootup Is from the kconfig. I remembered seeing that in the conifgs when I got wifi running on the 4.4 kernel (most of the rockchip stuff is in there, so it was simple) As for what's currently happening: http://sprunge.us/ZieI That will give you the pertinent bits from my boot in case you're curious, but excerpts: [ 1.573208] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 1.573258] mmc1: error -84 whilst initialising SDIO card [ 1.573395] dwmmc_rockchip ff0d0000.dwmmc: card claims to support voltages below defined range [ 1.581858] mmc1: error -110 whilst initialising MMC card [ 1.635230] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 1.635285] mmc1: error -110 whilst initialising SDIO card [ 1.635427] dwmmc_rockchip ff0d0000.dwmmc: card claims to support voltages below defined range [ 1.643855] mmc1: error -110 whilst initialising MMC card [ 1.658874] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0) [ 1.704513] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 1.704567] mmc1: error -84 whilst initialising SDIO card [ 1.704734] dwmmc_rockchip ff0d0000.dwmmc: card claims to support voltages below defined range [ 1.712853] mmc1: error -110 whilst initialising MMC card Also noticed the io domain entry for the wifi-supply was missing, trying it out. http://elixir.free-electrons.com/linux/latest/source/Documentation/devicetree/bindings/power/rockchip-io-domain.txt
TonyMac32 Posted June 3, 2017 Posted June 3, 2017 Progress! Meaning the driver module is being loaded but is babbling out errors like crazy! [ 59.019326] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin [ 59.019392] rtl8723bs mmc1:0001:1: Direct firmware load for rtlwifi/rtl8723bs_nic.bin failed with error -2 [ 59.019403] Request firmware failed with error 0xfffffffe So, to figure out why the firmware either doesn't exist or isnt being loaded. *update* I manually dumped the firmware file from https://github.com/hadess/rtl8723bs into the appropriate directory, disabled/enabled wifi and success! Now, I don't know what to do about the firmware itself, some how-to would be handy, there is firmware for the BT as well I believe. I should be able to roll this through both the Next and Dev kernels. In the meantime I'll get the patches out for the device trees and hopefully I can get help with the firmware.
tkaiser Posted June 3, 2017 Posted June 3, 2017 35 minutes ago, TonyMac32 said: I don't know what to do about the firmware itself, some how-to would be handy, there is firmware for the BT as well I believe. There's https://github.com/armbian/build/tree/master/bin/firmware-overlay/rtlbt (Pine64 and in the meantime also Orange Pi Prime use the same module)
TonyMac32 Posted June 3, 2017 Posted June 3, 2017 1 hour ago, tkaiser said: There's https://github.com/armbian/build/tree/master/bin/firmware-overlay/rtlbt (Pine64 and in the meantime also Orange Pi Prime use the same module) Thanks tkaiser, I obviously didn't look around hard enough. :-/ *update* wifi firmware added, kernel config updated, and device tree patched. Anyone using 4.12 should be able to happily use wifi. 4.11 may not be worth the effort due to it not having any driver support for the rtl8723bs. You would have to patch in the driver/etc. 2
othbert Posted June 3, 2017 Posted June 3, 2017 Following this thread with interest! Has there been any movement on the reboot bug for the latest kernels? Running 4.11 here. And thanks for all the hard work!
